jiajiang951 发表于 2019-8-15 10:05:40
这段代码谁翻译一下
是个LISP文件 二次开发的(defun c:set()
(setvar "cmdecho" 0)
(setvar "mirrtext" 0)
(setq tz (getstring"\nDrawing parrten(A0/A1\/A2\/A3/A4/B4)<A3>:"))
(if(= tz "") (setq tz "A3"))
(setq bl (getreal"Scale<1>:"))
(if(= bl nil) (setq bl 1.0))
(setq p (list 0 0))
(setq zt (* 5 bl))
(setq zg (* 3 bl))
(setq tzg (* 0.7 zg))
(setq lt (* 10 bl))
(command "insert" tz p bl "" "")
(command "zoom" "e")
(setvar "dimscale" bl)
(setvar "dimgap" 1)
(setvar "dimtxt" 3)
(setvar "dimasz" 2.5)
(setvar "dimexe" 1)
'(setvar "dimdli" 7)
;(setvar "dimzin" 12)
(setvar "ltscale" lt)
(command "style" "st" "romans" zt "0.7" "0" "" "" "")
(command "style" "romans" "romans" zg "0.7" "0" "" "" "")
(VMON)
(DEFUN c:A8() (COMMAND "APERTURE" "8"))
(DEFUN d:A4() (COMMAND "APERTURE" "4"))
(DEFUN c:A   () (COMMAND "ARRAY"))
(DEFUN c:B   () (COMMAND "BLOCK"))
(DEFUN c:BH() (COMMAND "BHATCH"))
(DEFUN c:BI() (COMMAND (LOAD "BI")))
(DEFUN c:BK() (COMMAND "BREAK"))
(DEFUN c:CA() (COMMAND "CHAMFER"))
(DEFUN c:CC() (COMMAND "CIRCLE"))
(DEFUN c:C   () (COMMAND "COPY"))
(DEFUN c:CF() (COMMAND "CHAMFER"))
(DEFUN c:CG() (COMMAND "CHANGE"))
(DEFUN c:CH () (COMMAND "CHAMFER"))
(DEFUN c:CW() (COMMAND "COPY" "W"))
(DEFUN c:D   () (COMMAND "DIST"))
(DEFUN c:DZ () (COMMAND (LOAD "DDHZ")))
(DEFUN c:E   () (COMMAND "ERASE"))
(DEFUN c:EC() (COMMAND "ERASE" "C"))
(DEFUN c:EC() (COMMAND "ERASE" "CROSSING"))
(DEFUN c:EX() (COMMAND "EXPLODE"))
(DEFUN c:EL() (COMMAND "ERASE" "L" ""))
(DEFUN c:EP() (COMMAND "EXPLODE"))
(DEFUN c:ET() (COMMAND "EXTEND"))
(DEFUN c:EW() (COMMAND "ERASE" "W"))
(DEFUN c:FL() (COMMAND "FILLET"))
(DEFUN c:G   () (COMMAND "GRID"))
(DEFUN c:HT() (COMMAND "HATCH"))
(DEFUN c:I   () (COMMAND "INSERT"))
(DEFUN c:LS() (COMMAND "LAYER" "S"))
(DEFUN c:L0() (COMMAND "LAYER" "S" "0" ""))
(DEFUN c:L1() (COMMAND "LAYER" "S" "1" ""))
(DEFUN c:L2() (COMMAND "LAYER" "S" "2" ""))
(DEFUN c:L3() (COMMAND "LAYER" "S" "3" ""))
(DEFUN c:L4() (COMMAND "LAYER" "S" "4" ""))
(DEFUN c:L5() (COMMAND "LAYER" "S" "5" ""))
(DEFUN c:L6() (COMMAND "LAYER" "S" "6" ""))
(DEFUN c:L7() (COMMAND "LAYER" "S" "7" ""))
(DEFUN c:L8() (COMMAND "LAYER" "S" "8" ""))
(DEFUN c:L   () (COMMAND "LINE"))
(DEFUN c:LR() (COMMAND "LINE" "@"))
(DEFUN c:LD() (COMMAND "LAYER" "S" "D" ""))
(DEFUN c:LH() (COMMAND "LAYER" "S" "H" ""))
(DEFUN c:MR() (COMMAND "MIRROR"))
(DEFUN c:M   () (COMMAND "MOVE"))
(DEFUN c:MC() (COMMAND "MOVE" "C"))
(DEFUN c:ML() (COMMAND "MOVE" "L" ""))
(DEFUN c:MN() (COMMAND "MVSETUP" "N"))
(DEFUN c:MV() (COMMAND "SCRIPT" "MV"))
(DEFUN c:MW() (COMMAND "MOVE" "W"))
(DEFUN c:MXB () (COMMAND (LOAD "MXB")))
(DEFUN c:NT() (COMMAND (LOAD"NDIM.LSP")))
(DEFUN c:O   () (COMMAND "OOPS"))
(DEFUN c:OF() (COMMAND "OFFSET"))
(DEFUN c:P   () (COMMAND "PAN"))
(DEFUN c:PHZ () (COMMAND (LOAD "PPHZ")))
(DEFUN c:PL() (COMMAND "PLINE"))
(DEFUN c:PT() (COMMAND (LOAD "PTEXT" )))
(DEFUN c:PU() (COMMAND "PURGE"))
(DEFUN c:RW() (COMMAND "REDRAW"))
(DEFUN c:R   () (COMMAND "ROTATE"))
(DEFUN c:RE() (COMMAND "RECTANG"))
(DEFUN c:RT() (COMMAND "RECTANG"))
(DEFUN c:S1() (COMMAND "SCRIPT" "SET1"))
(DEFUN c:S2() (COMMAND "SCRIPT" "SET2"))
(DEFUN c:S3() (COMMAND "SCRIPT" "SET3"))
(DEFUN c:S4() (COMMAND "SCRIPT" "SET4"))
(DEFUN c:S5() (COMMAND "SCRIPT" "SET5"))
(DEFUN c:S6() (COMMAND "SCRIPT" "SET6"))
(DEFUN c:ST() (COMMAND "SCRIPT" "SET10"))
(DEFUN c:S   () (COMMAND "SAVE" ""))
(DEFUN c:SL() (COMMAND "SCALE"))
(DEFUN c:SC() (COMMAND "SCRIPT"))
(DEFUN c:SD() (COMMAND "STYLE" "S" "" "" "" "" "" "" ""))
(DEFUN c:SF() (COMMAND "SCRIPT" "FAM0"))
(DEFUN c:SN() (COMMAND "SNAP"))
(DEFUN c:SO() (COMMAND "SOLID"))
(DEFUN c:ST() (COMMAND "STYLE" "ST" "" "" "" "" "" "" ""))
(DEFUN c:STR () (COMMAND "STRETCH" "CROSSING"))
(DEFUN c:STY () (COMMAND "STYLE"))
(DEFUN c:T   () (COMMAND "TEXT"))
(DEFUN c:TA() (COMMAND "TEXT" "A"))
(DEFUN c:TM() (COMMAND "TEXT" "M"))
(DEFUN c:TF() (COMMAND "TEXT" "F"))
(DEFUN c:TP() (COMMAND (LOAD "PTEXT")))
(DEFUN c:TR() (COMMAND "TRIM"))
(DEFUN c:UO() (COMMAND "UCS" "O"))
(DEFUN c:UE() (COMMAND "UCS" "E"))
(DEFUN c:UP() (COMMAND "UCS" "P"))
(DEFUN c:VD() (COMMAND "VIEW" "D"))
(DEFUN c:VR() (COMMAND "VIEW" "R"))
(DEFUN c:V1() (COMMAND "VIEW" "R" "1"))
(DEFUN c:V2() (COMMAND "VIEW" "R" "2"))
(DEFUN c:V3() (COMMAND "VIEW" "R" "3"))
(DEFUN c:V4() (COMMAND "VIEW" "R" "4"))
(DEFUN c:V5() (COMMAND "VIEW" "R" "5"))
(DEFUN c:V6() (COMMAND "VIEW" "R" "6"))
(DEFUN c:V7() (COMMAND "VIEW" "R" "7"))
(DEFUN c:V8() (COMMAND "VIEW" "R" "8"))
(DEFUN c:V9() (COMMAND "VIEW" "R" "9"))
(DEFUN c:V10 () (COMMAND "VIEW" "R" "10"))
(DEFUN c:VS() (COMMAND "VIEW" "S"))
(DEFUN c:VW() (COMMAND "VIEW" "W"))
(DEFUN c:VP() (COMMAND "VIEWPORTS"))
(DEFUN c:VJ() (COMMAND "VIEWPORTS" "J"))
(DEFUN c:W   () (COMMAND "WBLOCK"))
(DEFUN c:WB() (COMMAND (LOAD "WB")))
(DEFUN c:XH() (COMMAND (LOAD "XH.LSP")))
(DEFUN c:Z   () (COMMAND "ZOOM"))
(DEFUN c:ZA() (COMMAND "ZOOM" "A"))
(DEFUN c:ZD() (COMMAND "ZOOM" "D"))
(DEFUN c:ZE() (COMMAND "ZOOM" "E"))
(DEFUN c:ZL() (COMMAND "ZOOM" "L"))
(DEFUN c:ZP() (COMMAND "ZOOM" "P"))
(DEFUN c:ZW() (COMMAND "ZOOM" "W"))
(DEFUN c:VI() (COMMAND "VIEWRES"))
(DEFUN c:LT() (COMMAND "LTSCALE"))
魍者归来 发表于 2019-8-15 13:51:14
说正经的,Lisp国内玩的人可不多,圈子很窄的,这个圈子里再接触机械的就更少之又少了。
远祥 发表于 2019-8-16 17:52:27
C语言里面还能有表情吗,涨知识了。。。
C语言里面还能有表情吗,涨知识了。。。
当然没有啊是论坛里的表情代码 自动识别显示出来啦
jiajiang951 发表于 2020-1-12 11:17:27
有没有会的呀?
CDKEY* 发表于 2023-3-26 20:22:23
(defun c:set()
;;; 定义一个名为 c:set 的函数
;;; 关闭命令回显功能
;;; 关闭镜像文字功能
(setq tz (getstring "\nDrawing parrten(A0/A1\/A2\/A3/A4/B4)<A3>:"))
;;; 获取用户输入的绘图规格,如果用户未输入则默认为 A3
(if (= tz "") (setq tz "A3"))
(setq bl (getreal "Scale<1>:"))
;;; 获取用户输入的比例,如果用户未输入则默认为 1.0
(if (= bl nil) (setq bl 1.0))
(setq p (list 0 0))
;;; 设置插入图框的坐标
(setq zt (* 5 bl))
;;; 设置图框线宽
(setq zg (* 3 bl))
;;; 设置图框内的边框线宽
;;; 设置图框内的文本高度
(setq lt (* 10 bl))
;;; 设置维度线的长度
;;; 在坐标为 p 的位置插入指定比例和规格的图框
;;; 自动缩放视图
;;; 设置维度线的比例
(setvar "dimgap" 1)
;;; 设置维度线和对象之间的距离
(setvar "dimtxt" 3)
;;; 设置维度线上的文本高度
;;; 设置维度线的箭头大小
(setvar "dimexe" 1)
(setvar "dimdli" 7)
;;; 设置维度线与文字的距离
;;; (setvar "dimzin" 12)
;;; 设置维度线与对象之间的间距
;;; 设置当前图层的线宽比例
;;; 设置样式 "st" 为 RomanS,线宽为 zt,文字高度为 0.7,文字样式为0
(command "style" "romans" "romans" zg "0.7" "0" "" "" ""))
;;; 设置样式 "romans" 为 RomanS,线宽为 zg,文字高度为 0.7,文字样式为0
;;; 该函数的主要作用是设置AutoCAD绘图软件的一些参数和样式
查看完整版本: 这段代码谁翻译一下
