是个LISP文件 二次开发的 (defun c:set() 1 S$ }7 K9 b8 e! Y, g( R
(setvar "cmdecho" 0)4 E6 \6 T" \; J; J0 {, j. ? [2 {
(setvar "mirrtext" 0)
* ]3 @: @- X- a (setq tz (getstring"\nDrawing parrten(A0/A1\/A2\/A3/A4/B4)<A3>:"))
/ ^# q6 I+ P. X (if(= tz "") (setq tz "A3"))
6 {' U* h9 t2 p; o) D% H (setq bl (getreal"Scale<1>:"))# h) t# r0 E3 Z+ `8 d9 d0 S
(if(= bl nil) (setq bl 1.0))
$ K, T% N8 ~$ q. t (setq p (list 0 0))' {$ A' f. m0 S" F
(setq zt (* 5 bl))
/ @4 O7 e+ H. y2 t* o8 I! w2 g$ M (setq zg (* 3 bl))
9 o( S9 H" K1 v6 u8 H (setq tzg (* 0.7 zg))
! v& }0 Z2 t+ ]6 l; D- ~% | (setq lt (* 10 bl))
, U9 w! p$ I6 c( E( o ~ }8 s (command "insert" tz p bl "" "")2 c3 {% S5 R4 G) E* x3 `7 o8 S" q, z
(command "zoom" "e")
7 ?! z. h! r& U (setvar "dimscale" bl)
+ z1 C- Y1 G- e) J1 Q( G) w5 p (setvar "dimgap" 1)* z; t1 p1 s5 Y6 K( W. b
(setvar "dimtxt" 3) 1 z8 a& h7 s, H4 ^# J) G
(setvar "dimasz" 2.5)
6 B3 S5 M g9 u' i4 z, \& U7 | (setvar "dimexe" 1)
" p' r7 I' R# ~, |1 X0 L '(setvar "dimdli" 7)
0 L. z# H3 Y* W. e% M& e ;(setvar "dimzin" 12)
8 g* |) g: a* Y* Z6 A/ B6 i (setvar "ltscale" lt)6 y, S0 h& ~$ y& V& n
(command "style" "st" "romans" zt "0.7" "0" "" "" "")3 B: z: Z$ }: A+ h# e9 g- m$ ]
(command "style" "romans" "romans" zg "0.7" "0" "" "" "")
- f3 u5 D- K% t$ q); J" U1 r4 c" x" Y
7 `' E5 l; }$ j1 w; G: ^4 P$ @
(VMON)
2 P) H9 Y' X' ~& I0 M(DEFUN c:A8 () (COMMAND "APERTURE" "8")), L" e4 ?# f) }1 r3 W! a |) q
(DEFUN d:A4 () (COMMAND "APERTURE" "4"))# ^. l" A$ f% R7 j$ j
(DEFUN c:A () (COMMAND "ARRAY"))6 [0 b6 l e/ v, c4 r" z
(DEFUN c:B () (COMMAND "BLOCK"))
- J3 z6 V% T; m6 N7 a5 T(DEFUN c:BH () (COMMAND "BHATCH"))1 t) y* N: \9 ^3 t
(DEFUN c:BI () (COMMAND (LOAD "BI")))# w Q( ?9 q! w3 c2 U
(DEFUN c:BK () (COMMAND "BREAK"))
1 z0 e5 O! y- ^1 z# U/ ]' V(DEFUN c:CA () (COMMAND "CHAMFER"))2 r# `5 X. v. V
(DEFUN c:CC () (COMMAND "CIRCLE"))
; z" v4 T* I. {3 s* u: q" M(DEFUN c:C () (COMMAND "COPY"))
$ {- }. T0 F' Q& a4 H(DEFUN c:CF () (COMMAND "CHAMFER"))
0 z2 t7 X; k, u: h$ }" M(DEFUN c:CG () (COMMAND "CHANGE"))
( m% m, }% e' q( w(DEFUN c:CH () (COMMAND "CHAMFER"))
7 j( C5 I( P! p# ~! U Q0 ^(DEFUN c:CW () (COMMAND "COPY" "W"))4 D& V) F v. I0 Z- X$ @; X
(DEFUN c () (COMMAND "DIST")) + h6 o' H2 q0 [9 W: s/ p0 p
(DEFUN c Z () (COMMAND (LOAD "DDHZ")))0 }0 }4 {! B2 z% j: c$ a
(DEFUN c:E () (COMMAND "ERASE"))
, h; U- [6 C* D |1 D(DEFUN c:EC () (COMMAND "ERASE" "C"))/ F. x: D1 ] b( B
(DEFUN c:EC () (COMMAND "ERASE" "CROSSING"))
0 T4 r; ^# c, s- m(DEFUN c:EX () (COMMAND "EXPLODE")): X* M+ X$ z9 W* b- D* d3 w" B2 G
(DEFUN c:EL () (COMMAND "ERASE" "L" ""))
- ]* y0 C2 U" | }3 U. k(DEFUN c:EP () (COMMAND "EXPLODE"))
4 v! M2 f. m' A- F2 }4 g) I(DEFUN c:ET () (COMMAND "EXTEND"))
; {* s, v) r7 H* O o(DEFUN c:EW () (COMMAND "ERASE" "W"))
9 u+ M/ Q5 j$ R, a; Z1 B6 q(DEFUN c:FL () (COMMAND "FILLET")); g* {9 A8 j. R8 n, w
(DEFUN c:G () (COMMAND "GRID"))
1 j8 }# z; H z5 x. V+ O% a(DEFUN c:HT () (COMMAND "HATCH"))* a* w$ a2 c& M& [3 G! [
(DEFUN c:I () (COMMAND "INSERT"))
9 b. @, g% S5 [+ a. p; `. H% }/ T(DEFUN c S () (COMMAND "LAYER" "S"))
$ V+ q$ k- w0 p% X4 Q(DEFUN c 0 () (COMMAND "LAYER" "S" "0" ""))4 ]6 x9 d" a# b0 r$ }/ _
(DEFUN c 1 () (COMMAND "LAYER" "S" "1" ""))
7 A" f$ a% \9 {! n(DEFUN c:L2 () (COMMAND "LAYER" "S" "2" ""))
$ K2 R/ s. n1 w. L! G(DEFUN c:L3 () (COMMAND "LAYER" "S" "3" ""))
) m$ z% ?) g9 g/ j* }" i8 c(DEFUN c:L4 () (COMMAND "LAYER" "S" "4" ""))# G( {; m1 I/ k* ^
(DEFUN c:L5 () (COMMAND "LAYER" "S" "5" ""))
2 n& V& r3 s* Q5 m(DEFUN c:L6 () (COMMAND "LAYER" "S" "6" ""))1 l5 [& ]9 r# t& p# p* w% s
(DEFUN c:L7 () (COMMAND "LAYER" "S" "7" ""))0 J& P2 c4 h$ y# S6 [+ ~7 l6 ^- f& [
(DEFUN c:L8 () (COMMAND "LAYER" "S" "8" ""))' z! n0 q" R0 o
(DEFUN c:L () (COMMAND "LINE"))1 ?; [9 G) o! B
(DEFUN c:LR () (COMMAND "LINE" "@"))+ ^ w/ C/ A+ D, o1 b* R0 W
(DEFUN c:LD () (COMMAND "LAYER" "S" "D" ""))
3 I7 j) n, b2 j. Q' I& G(DEFUN c:LH () (COMMAND "LAYER" "S" "H" ""))
8 F+ ]6 o5 U! T p* U(DEFUN c:MR () (COMMAND "MIRROR"))
5 r! L, ^2 b s% D(DEFUN c:M () (COMMAND "MOVE"))
; G( i0 V3 W8 `. Q' k$ K(DEFUN c:MC () (COMMAND "MOVE" "C"))4 ~9 S% T* ~% L# L: X
(DEFUN c:ML () (COMMAND "MOVE" "L" ""))3 h/ `5 D# f: R. B" w6 i
(DEFUN c:MN () (COMMAND "MVSETUP" "N"))* v J- s; q; \# |( d
(DEFUN c:MV () (COMMAND "SCRIPT" "MV"))
4 p9 t, L$ i& m H! j(DEFUN c:MW () (COMMAND "MOVE" "W"))8 g7 w, @& _# {" g
(DEFUN c:MXB () (COMMAND (LOAD "MXB"))) ; X' c6 y, M" `+ Y j9 O
(DEFUN c:NT () (COMMAND (LOAD"NDIM.LSP")))8 Y: F& Z! [6 ^; v
(DEFUN c:O () (COMMAND "OOPS"))4 r& u5 g0 D' ~1 Z
(DEFUN c:OF () (COMMAND "OFFSET"))
0 {: z/ L+ M) r! y' z7 m# B) V7 U4 q(DEFUN c () (COMMAND " AN")): \9 i( {4 D+ Y; L$ |
(DEFUN c HZ () (COMMAND (LOAD " PHZ")))# C u: E& l6 b5 u
(DEFUN c L () (COMMAND " LINE"))8 Z R% H6 S6 f) }: k. p9 w
(DEFUN c:PT () (COMMAND (LOAD "PTEXT" )))
# u+ I8 X% f' c( F7 S' c/ r(DEFUN c:PU () (COMMAND "PURGE"))
& _* V' t& d4 l1 g, \(DEFUN c:RW () (COMMAND "REDRAW"))' X( Y$ I5 j2 C( m
(DEFUN c:R () (COMMAND "ROTATE"))
6 @* M9 j* G% E8 k9 A* s(DEFUN c:RE () (COMMAND "RECTANG"))
" J4 ^, b- ^1 C(DEFUN c:RT () (COMMAND "RECTANG")) f# ?2 v& ^9 e
(DEFUN c:S1 () (COMMAND "SCRIPT" "SET1"))
/ h6 h5 l$ |3 @1 Z(DEFUN c:S2 () (COMMAND "SCRIPT" "SET2"))
! }: ?3 F& y+ `, G1 h( r(DEFUN c:S3 () (COMMAND "SCRIPT" "SET3")) ]5 u2 C7 r) s+ v, y
(DEFUN c:S4 () (COMMAND "SCRIPT" "SET4"))
a3 A. Y. v" W% x# u! h; l' U(DEFUN c:S5 () (COMMAND "SCRIPT" "SET5"))
9 S$ R& O% g" f9 u0 w(DEFUN c:S6 () (COMMAND "SCRIPT" "SET6"))
( W z% x- ^. O I(DEFUN c:ST () (COMMAND "SCRIPT" "SET10"))8 F6 b7 Z9 k# i+ c
(DEFUN c:S () (COMMAND "SAVE" "")), K, ~2 P7 Q5 c! _. V2 K
(DEFUN c:SL () (COMMAND "SCALE"))1 \/ u) ~$ B) n3 z
(DEFUN c:SC () (COMMAND "SCRIPT"))9 S. K9 x; r0 Z& |9 o1 y2 ~+ U# u
(DEFUN c:SD () (COMMAND "STYLE" "S" "" "" "" "" "" "" ""))
0 Q4 J) q1 J, B0 `% D. G(DEFUN c:SF () (COMMAND "SCRIPT" "FAM0"))3 E, \! P% X& @ K
(DEFUN c:SN () (COMMAND "SNAP"))* Y, j! v6 l, A5 p. H L) U8 G; ]
(DEFUN c:SO () (COMMAND "SOLID"))4 @, ^. D0 r7 O5 q' Q, ~
(DEFUN c:ST () (COMMAND "STYLE" "ST" "" "" "" "" "" "" ""))! X9 c' i0 h" a+ Y7 w6 @
(DEFUN c:STR () (COMMAND "STRETCH" "CROSSING"))& f" @) V0 s8 D( d0 _, `2 g
(DEFUN c:STY () (COMMAND "STYLE"))
: R1 o! d. U! C; N& D8 {(DEFUN c:T () (COMMAND "TEXT")) _! I6 k/ ^/ x ?
(DEFUN c:TA () (COMMAND "TEXT" "A"))1 m% k5 o1 E& |1 [- r! D% D# G6 G
(DEFUN c:TM () (COMMAND "TEXT" "M")): \. E( g0 u/ u8 P4 O2 @! A" B
(DEFUN c:TF () (COMMAND "TEXT" "F")), V1 i' R/ R2 S$ {( N
(DEFUN c:TP () (COMMAND (LOAD "PTEXT")))# I* v2 e5 U# p4 C
(DEFUN c:TR () (COMMAND "TRIM"))
" @- @6 B' c$ S& e9 N4 y/ M+ ](DEFUN c:UO () (COMMAND "UCS" "O"))
3 D& r" V! I) V(DEFUN c:UE () (COMMAND "UCS" "E"))
' |- ]& L& ^- z f(DEFUN c:UP () (COMMAND "UCS" "P"))- ^, @8 I' C5 Y5 k& y' ~
(DEFUN c:VD () (COMMAND "VIEW" "D"))) h& C( X1 X5 w G7 D! T% A
(DEFUN c:VR () (COMMAND "VIEW" "R")) Y- T) y! ?" o# ?0 H2 K: t
(DEFUN c:V1 () (COMMAND "VIEW" "R" "1"))
- v' Q- q4 a9 N5 s9 j( h, e1 Z& b(DEFUN c:V2 () (COMMAND "VIEW" "R" "2"))
& X, w$ @7 j# D* d0 a; L(DEFUN c:V3 () (COMMAND "VIEW" "R" "3"))
% C" g3 G+ v# D+ o/ K& B+ Y" J6 O(DEFUN c:V4 () (COMMAND "VIEW" "R" "4")), ?- O! R. T7 j+ M. \
(DEFUN c:V5 () (COMMAND "VIEW" "R" "5"))* }0 W* j% I6 P
(DEFUN c:V6 () (COMMAND "VIEW" "R" "6"))# Q& I/ t9 h0 e1 p/ q
(DEFUN c:V7 () (COMMAND "VIEW" "R" "7"))& ]6 N" l& I. [ m/ z$ a0 `
(DEFUN c:V8 () (COMMAND "VIEW" "R" "8"))8 I- s x% b. v. v, C9 {
(DEFUN c:V9 () (COMMAND "VIEW" "R" "9"))2 M% f) | H/ P# x# d- ~
(DEFUN c:V10 () (COMMAND "VIEW" "R" "10"))
1 B) K6 X' r* A) S* |4 ~(DEFUN c:VS () (COMMAND "VIEW" "S"))/ @& n/ f4 _+ ]4 s& _/ k
(DEFUN c:VW () (COMMAND "VIEW" "W"))
; }$ X6 W$ S: e- A4 r(DEFUN c:VP () (COMMAND "VIEWPORTS"))( _ s* c& y# G) N
(DEFUN c:VJ () (COMMAND "VIEWPORTS" "J")) F0 O" A; Y+ w; t9 Y( _) y% h# G
(DEFUN c:W () (COMMAND "WBLOCK"))
- ]% B' k$ n+ P9 |% }% d(DEFUN c:WB () (COMMAND (LOAD "WB")))
2 C! {* t' ]6 A7 l) ^3 a" |8 h. Z(DEFUN c:XH () (COMMAND (LOAD "XH.LSP")))* h* Q- m" X3 ]) p
(DEFUN c:Z () (COMMAND "ZOOM"))+ Q- l+ U! v" v/ T+ Q: a
(DEFUN c:ZA () (COMMAND "ZOOM" "A"))) J2 G6 \* R2 t7 S' k% b
(DEFUN c:ZD () (COMMAND "ZOOM" "D"))$ @; ]$ O7 x( f3 t
(DEFUN c:ZE () (COMMAND "ZOOM" "E"))
( x& v, N' v% H: @& @: ` g* X(DEFUN c:ZL () (COMMAND "ZOOM" "L"))
% d U3 [+ b- |3 g v8 O(DEFUN c:ZP () (COMMAND "ZOOM" "P"))
. t8 L* Y; Z: T9 ^' k, G, z(DEFUN c:ZW () (COMMAND "ZOOM" "W"))
$ y3 [3 Y9 [% o(DEFUN c:VI () (COMMAND "VIEWRES"))" }' f$ X$ W1 M( b! x; |, j4 y
(DEFUN c:LT () (COMMAND "LTSCALE"))
6 F4 b/ r+ o& ^9 a& V! U2 b% H5 x$ V8 Z
