syw开门造车 发表于 2006-8-27 08:50:41
画斜钻孔零件三维图--斜孔怎画?
<P>各位网友好!</P>
<P>我现在已经能够比较熟练的用SolidWorks画比较规则的零件图和装配图了。</P>
<P>有能力用三维图的直观方式回答“<SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><STRONG><FONT color=#000000><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><STRONG>半缘”网友的见解</STRONG></SPAN></SPAN></FONT></STRONG></SPAN></SPAN></P>
<P><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><STRONG><FONT color=#000000><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><STRONG>和“<SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=4170')"><STRONG>中国制造”网友发起的讨论。</STRONG></SPAN></SPAN></STRONG></SPAN></SPAN></FONT></STRONG></SPAN></SPAN></P>
<P><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=4170')"><FONT color=#000000>今早,我用了很长时间也没将“钻斜孔零件--A011.SLDPRT”图中的斜孔画出来。</FONT></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></P>
<P><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=4170')"><FONT color=#000000>请熟习的网友给我指点。</FONT></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></P>
<P><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=4170')"><FONT color=#000000>syw--060827---08.50</FONT></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></P>
<P><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=4170')"><FONT color=#000000>//*****************************</FONT></SPAN></SPAN></SPAN></SPAN></SPAN></SPAN></P>
<P><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><STRONG><FONT color=#000000><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><STRONG><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=4170')"></SPAN></SPAN></STRONG></SPAN></SPAN></FONT></STRONG></SPAN></SPAN>&nbsp;</P>
<P><SPAN class=txt2><SPAN class=inlineLink onclick="window.open('/user/Profile.aspx?UserID=26543')"><STRONG>-------</STRONG></SPAN> <STRONG>液压集成块上的斜孔---[我的见解]</STRONG></SPAN></P>
<TABLE cellSpacing=0 cellPadding=2 width="100%" border=0>
<TBODY>
<TR>
<TD vAlign=top noWrap align=left>
<P><SPAN class=txt2>&nbsp;--------<STRONG>讨论:斜孔的加工工艺.......</STRONG></SPAN></P>
<P><SPAN class=txt2><STRONG></STRONG></SPAN>&nbsp;</P>
<P><SPAN class=txt2><STRONG></STRONG><BR>&nbsp;</P></SPAN></TD></TR>
<TR>
<TD align=right height=25></TD></TR></TBODY></TABLE></SPAN></P>
syw开门造车 发表于 2006-8-27 08:55:05
Re: ?:画斜钻孔零件三维图--斜孔怎画?
刚才文件占用,没传上,再传一次。
syw   060827---08.54
版主及管理员网友好!
我不知什么原因,我在回帖中要传的三维图文件,两次都没传上,
请指点。
再传一次。
syw   060827---09.01
钻斜孔零件--A011.SLDPRT      84K
我是画成直的再旋转
明天试试。
syw开门造车 发表于 2006-8-27 18:50:17
Re: 画斜钻孔零件三维图--斜孔怎画?
金枫液压 网友好! 在上此帖之前我曾试图这样做过。 看完你在4楼的帖后,又反复试了好多次,还是没有成功。 我首先认为,我哪个步骤没有做对。 请“金枫液压”及知道的网友,将详细步骤用下面的方式告诉我。具体如下面所示: 谢谢! syw 060827---18.50 //******************************************** 1***-----2***-----3***-----4***-----5***-----6***-----……
金枫液压 及各位网友好! 还有,我能做到对改变孔的直径的大小,孔的深浅,和孔在上表面的位置。 而我要的是,上表面的位置不变,孔的底部向任意一条边进行45度的角度旋转。 具体见附件。 syw 060827---18.58
金枫液压 及各位网友好! 我用压缩的办法传一下这个文件,(“钻斜孔零件--A011.SLDPRT”) 请会做的网友画好后,再将文件压缩后传上来。 谢谢。 我相信,这回我的毅力会祝我传递成功! syw 060827---09.09
在你要钻孔位置增加一个45度的辅助面,然后在辅助面上钻孔即可
srq 网友好!
直觉告诉我,你的方法可行。马上去试。
谢谢!
syw   060828---03.36
页: [1] 2 3
查看完整版本: 画斜钻孔零件三维图--斜孔怎画?
