云台舵机力矩4KG/cm如何理解?
做无人机三轴稳像云台,用到一款电机GBM62508-150T,其说明参数中力矩的单位是KG/cm,这个单位如何理解?正常电机力矩应该是力x力臂,这个单位是力÷力臂,谢谢各位!The GBM62 series motor by iPower Motors are the ultimate brushless gimbal motor for DSLR / CANON 5D MARKII,MARKIII Cameras.This motor is designed for large scale multi-rotor platforms looking to lift Red Epic & DSLR sized gear – 4KG/cm Torque.The principle of the camera stabilization using brushless direct drive motors In fact,gimbal based on BLDC motors is very similar to regular gimbal based on hobby servo.
Kg 换装N。。Cm 换成m。。
问销售 parkorliu 发表于 2018-10-22 13:46
Kg 换装N。。Cm 换成m。。
注意:4Kg/cm和4Kg.cm的区别
303不锈钢制造专家 无名小卒 发表于 2018-10-22 13:56
注意:4Kg/cm和4Kg.cm的区别
我也没提醒你,知道你就说,没必要挑别人毛病!
