查看: 4340|回复: 6
云台舵机力矩4KG/cm如何理解?
发表于 2018-10-22 13:36:11 | 显示全部楼层 |阅读模式
做无人机三轴稳像云台,用到一款电机GBM62508-150T,其说明参数中力矩的单位是KG/cm,这个单位如何理解?正常电机力矩应该是力x力臂,这个单位是力÷力臂,谢谢各位!& I- |& v  e8 J2 L( Q! R; ^
# w1 P' z5 h7 TThe GBM62 series motor by iPower Motors are the ultimate brushless gimbal motor for DSLR / CANON 5D MARKII,MARKIII Cameras.This motor is designed for large scale multi-rotor platforms looking to lift Red Epic & DSLR sized gear – 4KG/cm Torque.The principle of the camera stabilization using brushless direct drive motors In fact,gimbal based on BLDC motors is very similar to regular gimbal based on hobby servo.
  j4 ]+ s6 ~  j8 R. n/ ~) R
发表于 2018-10-22 13:46:21 | 显示全部楼层
Kg 换装N。。Cm 换成m。。. I3 p3 H( M0 }' c5 K1 Z' C
发表于 2018-10-22 13:54:24 | 显示全部楼层
问销售
 楼主| 发表于 2018-10-22 13:56:44 | 显示全部楼层
parkorliu 发表于 2018-10-22 13:46# D# B* {$ J9 e& y) h8 l2 J
Kg 换装N。。Cm 换成m。。
0 \$ D+ ^& T5 [. a3 v# S
注意:4Kg/cm和4Kg.cm的区别% g- q! d$ J' @8 {/ U
你提醒谁注意,你的口吻好像你已经知道答案,却装傻  发表于 2018-10-22 14:59
发表于 2018-10-22 16:33:11 | 显示全部楼层
303不锈钢制造专家
 楼主| 发表于 2018-10-22 19:55:22 | 显示全部楼层
无名小卒 发表于 2018-10-22 13:56
2 K4 }9 K4 n! I注意:4Kg/cm和4Kg.cm的区别
" D* n9 T0 I! E" s9 B( K
我也没提醒你,知道你就说,没必要挑别人毛病!
GMT+8, 2025-4-28 08:45 , Processed in 0.055780 second(s), 17 queries , Gzip On.
