无线风筝 发表于 2006-7-28 23:52:00
7月话题二:缸套的损坏与重新搪磨
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 24pt; LINE-HEIGHT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 12.0pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 12pt">对于发动机缸套的作用不言而喻,不管是湿式还是干式都是组成燃烧室的必要部分,那么对于它的修理怎么样呢?我们下面就看一下有关缸套的损坏和修理.:</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 24pt; LINE-HEIGHT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 12.0pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 12pt">2</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、缸套的损坏与重新搪磨</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 24pt; LINE-HEIGHT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 12.0pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"></SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt">1</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)缸套材料:球墨铸铁、高磷合金铸铁、磷矾铸铁及含硼铸铁。</SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 24pt; LINE-HEIGHT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 12.0pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"></SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt">2</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)表面处理:镀铬、表面淬火。</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt"><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 24pt; LINE-HEIGHT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 12.0pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 12pt">3</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)缸套内表面磨损的一般规律</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt"><o:p></o:p></SPAN></P>
<DIV align=center>
<TABLE style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; BORDER-LEFT: medium none; WIDTH: 469.7pt; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-alt: solid windowtext .5pt" cellSpacing=0 cellPadding=0 width=626 border=1>
<TBODY>
<TR style="HEIGHT: 25.65pt">
<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 0.5pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 96.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.65pt; BACKGROUND-COLOR: transparent" vAlign=top width=129>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 20pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">在轴向上磨损成上大下小的近似锥形</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt"><o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 0.5pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 372.75pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.65pt; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=497>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 20pt; mso-line-height-rule: exactly"><SPAN lang=EN-US style="FONT-SIZE: 12pt">1</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、部位主要在活塞环移动的区域内;</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt">2</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、结果是上大下小,且在活塞位于上止点时第一环的位置磨损最大;</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt">3</SPAN><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、磨损的上大下小是不均匀的,呈近似的锥形</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt"><o:p></o:p></SPAN></P></TD></TR>
<TR style="HEIGHT: 24.5pt">
<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 96.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 24.5pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=129>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 20pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">在径向上磨损成椭圆形</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt"><o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 372.75pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 24.5pt; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=497>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 20pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">在上死点的第一环位置磨损量最大,椭圆度也最大;在向下的几十毫米处时磨损量已经很小,其椭圆度也变得很小,即基本上成正圆磨损</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt"><o:p></o:p></SPAN></P></TD></TR>
<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 96.95pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.65pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=129>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 20pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">多缸机各缸磨损不均</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt"><o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 372.75pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 0.5pt solid; HEIGHT: 25.65pt; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=497>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 20pt; mso-line-height-rule: exactly"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">影响因素很多,一般冷却比较强的缸套磨损量较大</SPAN><SPAN lang=EN-US style="FONT-SIZE: 12pt"><o:p></o:p></SPAN></P></TD></TR></TBODY></TABLE></DIV><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-font-kerning: 1.0pt; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">&nbsp;&nbsp;&nbsp; 缸套磨损后,缸壁与活塞间隙将增大,活塞环开口间隙也相应增大,工作时产生窜气、窜油,压缩不良、马力下降、起动困难、机油很快变质且耗量增加等。各缸磨损不均会使发动机工作不稳定而产生振动等。</SPAN>
一剑飘红 发表于 2006-11-21 14:59:59
Re: 7月话题二:缸套的损坏与重新搪磨
请问:“搪磨”是怎样的一种加工方法?谢谢。
搪磨实际上是“镗孔”加工与“珩磨”加工点简称。发动机工作一段时间后,会有磨损,使得
缸套(缸筒)磨偏失圆,必须经过重新镗孔找圆,加大尺寸,镗加工后,由于粗糙度达不到要求,所以再加一道工序,叫作珩磨,就是在一个支架上安装一组油石条,固定在类似钻床的珩磨机上,边旋转,边上下来回移动,主要是用来提高粗糙度。
一般是针对湿式缸套才采用的,现在好象基本是直接换了,很少看到搪缸的了,呵呵
所说的窜油是不是说油可能会从排气口排出啊~~~~????
希望楼主把工艺再清楚地给讲一下。
<P>原帖由 菜鸟→张 发表
所说的窜油是不是说油可能会从排气口排出啊~~~~???? </P>
<P>&nbsp;</P>
<P>不是从排气门排出,人家说的是窜到活塞下面去了。</P>
摩托车缸套镗大后,转速高了,开了快。
缸套内表面激光表面处理(淬火),选用花纹状而不是整体,对活塞有利。
查看完整版本: 7月话题二:缸套的损坏与重新搪磨
