路大叔 发表于 2007-12-26 15:26:24
汽车机械专业用语
气门油封 valve oil seal
气门口 valve port
气门座 valve seat
气门座镶圈(嵌镶式气门座圈) valve seat insert (valve seat ring)
气门座锥角 valve seat angle
气门座宽度 valve seat width
气门挺杆 valve tappet (valve lifter)
液力挺杆 hydraulic tappet (lifter)
无间隙挺杆 zero-rush tappet (non-clearance tappet)
筒形挺杆 barrel type tappet
油压挺杆 ooil tappet
滚轮挺杆 roller tappet (lifter)
挺杆转位 tappet rotation
排气门挺杆 exhaust valve lifter
气门导管 valve guide
气门杆导管 stem guide
气门重叠度 stem overlap
气门开启持续时间 valve duration
气门正时标记 valve timing sign
气门弹簧 valve spring
气门内弹簧 inner valve spring
气门外弹簧 outer valve spring
刚性缓冲弹簧 stiff buffer spring
上紧弹簧 energizing spring
防振气门弹簧 non-surging spring
弹簧座圈 spring retainer
蝶形弹簧 belleville spring
滚柱 roller
气门室盖 valve chamber cover
摇臂 rocker arm
高升程摇臂 high lift rocker arm
摇臂轴 rocker arm shaft
推杆 push-rod
摇臂支架 rocker arm bracket
气门摇臂室罩 valve rocker chamber cover
导向轮 guide wheel
导杆 slide bar
导轨 slide rail
张紧轮 tensioning wheel
链条张紧调节装置 assembly chain tension adjuster
张紧带轮 tensioning pulley
传动带张紧装置 belt tensioner
同步驱动皮带 synchronous belt
查看完整版本: 汽车机械专业用语
