查看: 2582|回复: 0
汽车机械专业用语
发表于 2007-12-26 15:26:24 | 显示全部楼层 |阅读模式
气门油封 valve oil seal & J' s/ r' y5 F" v$ b) m' D8 h: \
气门口 valve port $ @( t% @1 e) c$ u7 j- d" Q& ]" d
气门座 valve seat 2 |4 I, Y9 D- ?; `
气门座镶圈(嵌镶式气门座圈) valve seat insert (valve seat ring)
! S9 S7 K* N& M2 J: j3 U! I4 L; @/ q  u" m- M4 W$ u
气门座锥角 valve seat angle
' ^* _  w$ o2 n  c气门座宽度 valve seat width 4 ?. m, d% W( u/ }  L
气门挺杆 valve tappet (valve lifter)   ?7 z9 K8 S! B$ E; i! B/ F7 O
液力挺杆 hydraulic tappet (lifter)
. n: n6 A+ F% j! W* T/ n无间隙挺杆 zero-rush tappet (non-clearance tappet)
, ?- G& S) s- I/ B3 a0 `筒形挺杆 barrel type tappet
+ r: h# x9 r* s. q. T9 ]) j- `3 v油压挺杆 ooil tappet 6 D( V7 Q" g1 i5 Q; b9 h
滚轮挺杆 roller tappet (lifter) / Y) k' y+ S% E
挺杆转位 tappet rotation # f( e  w% j+ k. q0 c$ r
排气门挺杆 exhaust valve lifter
% y, \9 g# I+ i5 |气门导管 valve guide 5 ?% e, Q6 n8 w
气门杆导管 stem guide / n: r9 i2 ?& }$ u- ~6 m7 B  |
气门重叠度 stem overlap - }4 y% c* v7 X7 e
气门开启持续时间 valve duration ' K* j# f) d4 K- U, M# k) A$ K! y
气门正时标记 valve timing sign 9 Z1 ]+ q* ?! y9 ]8 Q6 E# D
气门弹簧 valve spring . O# c! n/ M+ a# I0 ?
气门内弹簧 inner valve spring
4 q2 |; b6 _% ]3 ]2 r. y" F气门外弹簧 outer valve spring
" l9 q; r6 t  N/ `刚性缓冲弹簧 stiff buffer spring ! I* m' `1 l4 W4 J
上紧弹簧 energizing spring
9 ]& S0 \- D) O2 B9 @) V& f防振气门弹簧 non-surging spring
) w# U5 u$ c: b* ^5 s5 }弹簧座圈 spring retainer
* [; M9 x" F8 `' f蝶形弹簧 belleville spring - Y& [2 A' [* k+ T
滚柱 roller
+ a  K# x5 x: Y8 @气门室盖 valve chamber cover + p4 O6 u! t3 u  b, {
摇臂 rocker arm
+ b/ g7 D, |9 w+ Y高升程摇臂 high lift rocker arm ( B/ t& p% p% [
摇臂轴 rocker arm shaft 5 }8 J" Q+ p( j: x9 q3 w
推杆 push-rod
) n- i. W: t. g! d# |7 J2 L摇臂支架 rocker arm bracket ' t1 z* m( C3 N/ b
气门摇臂室罩 valve rocker chamber cover
8 ^+ E6 h0 U* S# L& @& O! D导向轮 guide wheel
6 p9 l8 r; U; _8 G: p. T5 g导杆 slide bar % R/ i& m; T& y" N& t4 ~0 F% {
导轨 slide rail
5 o, K! z) s( V/ J6 ^: }8 W+ g张紧轮 tensioning wheel . ~  {# O6 c; G+ J0 y$ b
链条张紧调节装置 assembly chain tension adjuster 4 w4 A2 _$ M' E+ ~2 Z6 H; e
张紧带轮 tensioning pulley
3 ?6 X! r; t# F4 _% Y. N$ X0 e传动带张紧装置 belt tensioner 0 x4 r0 E; C5 h" f8 y' v
同步驱动皮带 synchronous belt
GMT+8, 2025-4-25 13:05 , Processed in 0.058194 second(s), 14 queries , Gzip On.
