muzi357078083 发表于 2007-12-24 08:16:56
foundry defects analysis准确翻译---求助
foundry defects analysis 请问准确翻译它是指铸造缺陷分布,还是铸造车间缺陷分布阿?后者我感觉不通顺,但客户给的是后者,意思可与前一个不一样了。
伊凡 发表于 2007-12-24 10:31:43
Foundry defects 铸疵
Analysis of Foundry Defect铸造缺陷分析(分布? 分布图吗?)
参考翻译文献:
http://dict.cnki.net/dict_result.aspx?r=1&t=%e9%93%b8%e9%80%a0%e7%bc%ba%e9%99%b7%e5%88%86%e6%9e%90&searchword=analysis+of+defects
我认为: Analysis = Diagnosis
Some essay on metallurgy for your reference!
Seems Analysis needs to find out causes of casting defects, which means to identify design, process or material parameters which could be responsible for the occurrence of defective castings in a manufacturing campaign., whatever during preproduction, production and afterproduction.
Sometimes a diagram will help pave the way for sucessful defects Analysis.
What do you think?
[ 本帖最后由 ivantse 于 2007-12-24 11:14 编辑 ]
muzi357078083 发表于 2007-12-24 15:29:26
谢谢楼上,我想表达铸造缺陷分析,结果不小心打成了分布,谢谢你详细的解释。
铸造缺陷分析,客户是想了解在铸造车间这些铸造缺陷主要发生在哪个车间,哪道工序,主要是做一个对铸造缺陷发生情况的分析,便于解决缺陷!
查看完整版本: foundry defects analysis准确翻译---求助
