查看: 3329|回复: 3
foundry defects analysis准确翻译---求助
发表于 2007-12-24 08:16:56 | 显示全部楼层 |阅读模式
foundry defects analysis 请问准确翻译它是指铸造缺陷分布,还是铸造车间缺陷分布阿?后者我感觉不通顺,但客户给的是后者,意思可与前一个不一样了。
发表于 2007-12-24 10:31:43 | 显示全部楼层
Foundry defects 铸疵
7 X6 V$ h" H" t3 [% {5 M3 F: ^6 w9 r6 E4 R( s! o& m  b
Analysis of Foundry Defect铸造缺陷分析(分布? 分布图吗?)% ?) F8 G* @7 [8 x7 @
8 q. U9 z9 p) I, c" k% T
参考翻译文献:
' H. L/ T  W, y+ ^% n! b4 Mhttp://dict.cnki.net/dict_result.aspx?r=1&t=%e9%93%b8%e9%80%a0%e7%bc%ba%e9%99%b7%e5%88%86%e6%9e%90&searchword=analysis+of+defects
( l8 w5 A% l2 l7 ]) ]8 V$ t) x5 k2 T7 u! j
我认为: Analysis = Diagnosis) E5 Q! R7 r- X( W( z  T
" |* `7 j# @6 w  P
Some essay on metallurgy for your reference!
7 Z1 M7 W/ h9 e1 l1 h" {  W& t. Z" V1 [' h5 v' t  F( r1 o  u( J
Seems Analysis needs to find out causes of casting defects, which means to identify design, process or material parameters which could be responsible for the occurrence of defective castings in a manufacturing campaign., whatever during preproduction, production and afterproduction., F$ f, n, d+ h
+ Q0 D) r- H  z2 w0 w( a& }/ V& C5 r7 `
Sometimes a diagram will help pave the way for sucessful defects Analysis.
  x  C: {3 Q( h1 ~, k7 {$ U- Y* S
$ @5 ^1 }- F& Y; J+ E( M+ o" q1 sWhat do you think?
, r& j7 c9 K. v. S* i" u8 @% Y* g8 A" y3 O
[ 本帖最后由 ivantse 于 2007-12-24 11:14 编辑 ]
 楼主| 发表于 2007-12-24 15:29:26 | 显示全部楼层
谢谢楼上,我想表达铸造缺陷分析,结果不小心打成了分布,谢谢你详细的解释。
发表于 2008-4-30 21:31:33 | 显示全部楼层
2 R* S/ R+ E5 j$ m. Q铸造缺陷分析,客户是想了解在铸造车间这些铸造缺陷主要发生在哪个车间,哪道工序,主要是做一个对铸造缺陷发生情况的分析,便于解决缺陷!
GMT+8, 2025-4-25 13:08 , Processed in 0.062886 second(s), 16 queries , Gzip On.
