皮带轮或链轮的规格说明,求助
Pulleywith taper bushes SPB 300-5 Bore 50 - 100piecesPulleywith taper bushes SPB 265-5 Bore 50 - 100pieces
Pulleywith locking assemblies SPB 250-4 Bore 50 - 800 pieces
Pulleywith locking assemblies SPB 170-3 Bore 50 - 800 pieces
Sprocket, 24B-2, 70 teeth with taper lock for 80mm shaft - 6 pcs
Sprocket, 24B-2, 19 teeth with taper lock for 100mm shaft - 6 pcs
Sprocket, 24B-1, 70 teeth with taper lock for 80mm shaft - 2 pcs
Sprocket, 24B-1, 23 teeth with taper lock for 100mm shaft - 2 pccs
谁知道这都是什么样的型号?望指点 下边的是链轮24B-270齿内经80mm 6个 Pulleywith taper bushes SPB 300-5 Bore 50 - 100pieces ,5槽皮带轮,中径300,锥形胀套连接,内径50。其他同。
Sprocket, 24B-2, 70 teeth with taper lock for 80mm shaft - 6 pcs,不太理解,国外是按照链条节距分的,比如25B,指的是链条节距1/4“,24B就没见过。后面的-2,指的是双排链,70是齿数,锥形胀套连接,内径80。其他同。
