查看: 3485|回复: 2
皮带轮或链轮的规格说明,求助
发表于 2007-10-25 10:58:37 | 显示全部楼层 |阅读模式
Pulley  with taper bushes SPB 300-5 Bore 50 - 100pieces  ) F3 O  [; l7 ^# d
3 H! n, Y) u; {
Pulley  with taper bushes SPB 265-5 Bore 50 - 100pieces
8 V6 d' Z( l% N; H9 b4 P. Z  F, L8 {
Pulley  with locking assemblies SPB 250-4 Bore 50 - 800 pieces
7 k0 u/ C) l" W4 [- w0 i/ ?7 `+ ~. f! f+ ]+ R& I# P9 H3 }
Pulley  with locking assemblies SPB 170-3 Bore 50 - 800 pieces# H. A8 X) l8 O5 L" \
" |2 r# w. s6 ^1 Y
6 A7 h6 q. P/ V, f$ T' A; _6 L/ F& t0 Z. S. M
Sprocket, 24B-2, 70 teeth with taper lock for 80mm shaft - 6 pcs
/ g+ a* h" f  Y& Z8 s+ n) x+ w# y) ]  B* `, D& o- i
Sprocket, 24B-2, 19 teeth with taper lock for 100mm shaft - 6 pcs$ v$ h- A/ ?/ w. ^  s
. z/ v# [9 f9 l3 DSprocket, 24B-1, 70 teeth with taper lock for 80mm shaft - 2 pcs
! w) z7 c5 a$ P1 a$ z
( E' X& [4 m& L3 Z5 c4 jSprocket, 24B-1, 23 teeth with taper lock for 100mm shaft - 2 pccs. O$ \9 W; @& `
( z$ D$ h' F- K% M" F0 k
! X: j5 z7 ^2 J' J
2 D3 ]# v5 q6 s( z5 c- W谁知道这都是什么样的型号?望指点
发表于 2007-11-4 20:02:49 | 显示全部楼层
下边的是链轮  24B-2  70齿内经80mm   6个
发表于 2007-11-4 22:48:04 | 显示全部楼层
Pulley  with taper bushes SPB 300-5 Bore 50 - 100pieces ,5槽皮带轮,中径300,锥形胀套连接,内径50。其他同。4 x: x' Z; }( ]$ ?
Sprocket, 24B-2, 70 teeth with taper lock for 80mm shaft - 6 pcs,不太理解,国外是按照链条节距分的,比如25B,指的是链条节距1/4“,24B就没见过。后面的-2,指的是双排链,70是齿数,锥形胀套连接,内径80。其他同。
GMT+8, 2025-2-21 19:41 , Processed in 0.050834 second(s), 14 queries , Gzip On.
