neo8625 发表于 2007-9-2 14:11:47
waterjet cutting machine spare part name
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Tie rod </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">螺纹拉杆</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 1">&nbsp; </SPAN><SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>O-ring O</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">型环</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 2">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Spacer</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">垫片</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp; </SPAN><SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Oil seal </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油封</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Snap ring<SPAN style="mso-tab-count: 1"> </SPAN></FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">卡环</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Back up ring </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">背托环</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Low pressure cylinder</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">低压缸</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Piston assembly</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">活塞总成</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>End bell</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">低压端盖</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 2">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>High pressure cylinder </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">高压缸</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Seal ring </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">密封圈</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp; </SPAN>High pressure seal </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">高压密封</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">Seal hoop</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">密封环</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Seal back up sleeve </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">衬套</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 2">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Retaining screw </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">固定螺纹</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Inlet check valve support assembly </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">止回阀总成</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 2">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Check valve body </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">止回阀主体</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Inlet poppet </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">堵水阀芯</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 2">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Insert</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">阀体</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 2">&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>End cap</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">高压端盖</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Outlet body </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">止回阀出口体</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 1">&nbsp;&nbsp; </SPAN>Outlet poppet</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">出口体阀芯</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"><SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp;&nbsp; </SPAN>Compression spring </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">压缩弹簧</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Shift sensor </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">换位传感器</SPAN><SPAN lang=EN-US><FONT face="Times New Roman"> <SPAN style="mso-tab-count: 1">&nbsp;&nbsp;&nbsp; </SPAN>plunger assembly</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">活塞总成(换位传感部件)</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">intensifier </FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">增压器</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><SPAN lang=EN-US><FONT face="Times New Roman">Ceramic plunger assembly</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">陶瓷活塞总成</SPAN><FONT face="Times New Roman"> </FONT></FONT></P>
雷雨 发表于 2007-9-3 08:45:05
Re: waterjet cutting machine spare part name
学习
查看完整版本: waterjet cutting machine spare part name
