查看: 2868|回复: 1
waterjet cutting machine spare part name
发表于 2007-9-2 14:11:47 | 显示全部楼层 |阅读模式
Tie rod 螺纹拉杆         O-ring O型环        Spacer垫片           Oil seal 油封
+ r$ o4 K9 L2 F5 {* I: R
Snap ring 卡环     Back up ring 背托环     Low pressure cylinder低压缸
9 F7 G+ d" B. \9 H* h8 X( m
Piston assembly活塞总成     End bell低压端盖         High pressure cylinder 高压缸
' F1 [+ Q/ M/ R! j
Seal ring 密封圈    High pressure seal 高压密封Seal hoop密封环
$ d. {2 c) D G" x* v
Seal back up sleeve 衬套             Retaining screw 固定螺纹
; C% |" k/ l' h8 \9 Y0 h
Inlet check valve support assembly 止回阀总成        Check valve body 止回阀主体
7 Z" @ D8 ~; [+ X8 N
Inlet poppet 堵水阀芯          Insert阀体            End cap高压端盖
: E5 O# t9 _* A" s8 k
Outlet body 止回阀出口体   Outlet poppet出口体阀芯     Compression spring 压缩弹簧
% F1 w% e+ S: p+ ~
Shift sensor 换位传感器     plunger assembly活塞总成(换位传感部件)intensifier 增压器
. ]) }5 u0 K8 _( s( \
Ceramic plunger assembly陶瓷活塞总成
发表于 2007-9-3 08:45:05 | 显示全部楼层
Re: waterjet cutting machine spare part name
学习
GMT+8, 2025-1-10 02:42 , Processed in 0.051225 second(s), 15 queries , Gzip On.
