打开IGS文件时打不开了,出现以下信息---[请教]
<DIV style="FLOAT: right" align=right><A title="评分 0" href="http://www.3dportal.cn/discuz/misc.php?action=viewratings&tid=326000&pid=1459553"></A><BR><SCRIPT type=text/javascript><!--
google_ad_client = "pub-3257084675551833";
google_ad_width = 200;
google_ad_height = 200;
google_ad_format = "200x200_as";
google_ad_type = "text_image";
//2007-07-23: http://www.3dportal.cn/discuz/
google_ad_channel = "9883031642";
google_ui_features = "rc:0";
google_ad_channel = "7742284859";
google_color_border = "F2F2F2";
google_color_bg = "F2F2F2";
google_color_link = "0000FF";
google_color_text = "003366";
google_color_url = "008000";
</SCRIPT>
<SCRIPT src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type=text/javascript>
</SCRIPT>
</DIV><SPAN class=bold>打开文件遇到的问题,请教!</SPAN>
<DIV class=t_msgfont id=message1459553>打开IGS文件时打不开了,出现以下信息:<BR><BR>无法打开E:\zl\sl01。下列文件不能被载入<BR>导致以下打开失败:<BR>E:zl\sl01.igs-导入失败。没有生成部件文件。详情请参见日志文件<BR>日志文件如下:<BR>IGES to UG<BR>! INFO- NX V3.0 / IGES Specification 5.3<BR>! INFO- <BR>! INFO- Start of Translation: 28-JUL-2007 8:10:31 AM<BR>! INFO- <BR>! STATUS- Converting Part: E:\zl\sl40-04-01-00.igs<BR>! INFO- Comment <BR>! WARNING- IM1106 DE section at line 20 does not contain D in 10th/20th<BR>! WARNING- field. Further warnings of this type are suppressed.<BR>! WARNING- <BR>! WARNING- IM1110 Could not parse Data Entry field number 20 at DE# 3214.<BR>! WARNING- <BR>! WARNING- IM1110 Could not parse Data Entry field number 15 at DE# 3214.<BR>! WARNING- <BR>! WARNING- IM1110 Could not parse Data Entry field number 20 at DE# 3216.<BR>! WARNING- <BR>! ERROR- IM1105 Directory entry record is formatted incorrectly <BR>! ERROR- at line 1608<BR>! ERROR- <BR>! INFO- <BR>! INFO- End of Translation: 28-JUL-2007 8:10:31 AM<BR>! INFO- <BR>请问如何解决!!!谢谢!!!</DIV> 提示数据无法解析。
原因不详。
你可以重新安装translator来解决。 重新装,并且要有里面的.LC 文件覆盖才行 一般来说只重新装认证程序即可。
translator一定也要装。
如果是5。0的可以不装(程序自带有)
