ValleyViews 发表于 2015-8-10 16:49:35
如何做个支撑架?
做个焊接件支撑架,并做个简单的有限元分析试验。
第一步:建新文件,使用公制长度单位。
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7385/large.jpg?1330691917
第二步:创建一个矩形。
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7386/large.jpg?1330691918
第三步:先垂直约束至中心。
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7387/large.jpg?1330691919
第四步:再水平约束至中心。然后结束草图。
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7388/large.jpg?1330691920
ValleyViews 发表于 2015-8-10 16:55:33
第五步:矩形板厚度设定为10mm 。
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7389/large.jpg?1330691921
第六步:选择上平面做草图。
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7390/large.jpg?1330691922
ValleyViews 发表于 2015-8-10 17:01:12
第七步:草图上定位四个点。可使用垂直水平约束。
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7391/large.jpg?1330691923
第八步:加尺寸,完成草图。
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7392/large.jpg?1330691924
ValleyViews 发表于 2015-8-10 17:03:38
第九步:We use the hole command and a new window appears. Our points should be autoselected for hole centers. If not select them manually. In the window we choose 14mm for our holes diameter and through all for termination. Then we click OK.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7393/large.jpg?1330691925
第十步:Finally we will add properties to our part. In the model browser right click Part one and in the menu choose iProperties.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7394/large.jpg?1330691927
ValleyViews 发表于 2015-8-10 17:12:54
第十一:Go to Physical tab and in the Material drop down menu choose Steel Mild. We will need those properties for our FEA test. Once you are finished save your part.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7395/large.jpg?1330691928
第十二:Create a new part with the dimension shown in the image using the exact same steps as above. The holes should be in the center of the part. Add properties and save.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7396/large.jpg?1330691929
ValleyViews 发表于 2015-8-10 18:23:06
Step 13: Create a new part with the dimension shown in the image using the exact same steps as above. Add properties and save.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7397/large.jpg?1330691930
Step 14: Choose new and choose Weldment (ISO).iam
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7398/large.jpg?1330691931
ValleyViews 发表于 2015-8-11 01:56:51
Step 15: In the Assemble tab choose place component. In the new window browse to the location we saved our first part, select it and place it. By deafault the first part that is placed in an assembly or weldment file is grounded. You can change that later but for this tutorial we will keep this configuration.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7399/large.jpg?1330691932
Step 16: Do the same for the second part.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7400/large.jpg?1330691933
ValleyViews 发表于 2015-8-11 01:59:48
Step 17: Using the constraint command and selecting Mate we choose the faces of our parts shown in the red arrows. then select Apply.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7401/large.jpg?1330691934
Step 18: This is what we should be looking at if everything was done correct.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7402/large.jpg?1330691935
ValleyViews 发表于 2015-8-11 02:07:55
Step 19: Then choose flush instead of mate (red circle) and select the two faces shown. In the Offset value (red circle) put 40mm offset. Click Apply.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7403/large.jpg?1330691936
Step 20: Expand Part1 and Part 2 in the model browser. With the flush command still active choose the YZ plane of part 1 and YZ plane of part 2. Click OK.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7404/large.jpg?1330691937
ValleyViews 发表于 2015-8-11 02:10:52
Step 21: This is what we should be looking at. Now Part 2 is fully constraint.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7405/large.jpg?1330691938
Step 22: Next we place our third part 2 times. Use the exact same steps for placing part 2.
https://d2t1xqejof9utc.cloudfront.net/pictures/files/7406/large.jpg?1330691939
页: [1] 2 3
查看完整版本: 如何做个支撑架?
