求推荐一款台式车-铣床
用于简单零件的加工,使用频率不高,精度要求适中,求各位大侠推荐~非常感谢 台式车-铣床? 是不是车铣一体机? 补充:外观尽量美观大方 这个算不算?http://www.americanmachinetools.com/images/smithy_midas1220LTD.jpg
这个用的人还比较少呢。。 本帖最后由 ValleyViews 于 2015-5-21 01:24 编辑
其实我个人比较喜欢这种:
http://mfgnewsweb.com/archives/metalcutting/oct02/Pics/IntPrazi.jpg
PraziPowerturn Powermill SD400-BF400 Combo这个是德国生产的,可车,铣,包括钻在内的机加工。
The Prazi Powerturn Powermill Deluxe Lathe Mill Combo is manufactured in Germany. This combo serves as a complete "Machining Center" enabling the operator to perform turning, facing, milling and drilling applications.
The solid lathe bed design has hand scrapped and precise ground V-way bed, with precision spindle accuracy of .0002". The powerturn lathe has nine spindle speeds from 170 to 3360 RPM driven by a 2/3 HP motor with 110V electrics. The powermill head swivels 180¡ and has a MT2 spindle with heavy-duty column and quill. All dials are in inch graduations.
The Prazi Powerturn Powermill SD400-BF400 Combo is ergonomically designed, weighs 350 lbs. and offers super rigidity and close tolerance repeatability for the demanding professional.
