查看: 2181|回复: 5
求推荐一款台式车-铣床
发表于 2015-5-20 13:38:32 | 显示全部楼层 |阅读模式
用于简单零件的加工,使用频率不高,精度要求适中,求各位大侠推荐~非常感谢
发表于 2015-5-20 14:46:33 | 显示全部楼层
台式车-铣床? 是不是车铣一体机?
是的,一体的,因为使用频率不高,设备多了也占地方  发表于 2015-5-20 15:44
 楼主| 发表于 2015-5-20 15:45:41 | 显示全部楼层
补充:外观尽量美观大方
发表于 2015-5-20 16:23:01 | 显示全部楼层
这个算不算?& O' v2 }( [& Q9 i9 G( X
; X1 f$ |: T# Q3 H! |3 [
谢谢大侠,我去查一下  发表于 2015-5-21 08:38
我个人倾向 PraziPowerturn Powermill SD400-BF400 Combo. (见6楼文字)。  发表于 2015-5-21 01:34
这个是Smithy的产品。型号为:SMITHY MIDAS-1220LTD 。  发表于 2015-5-21 01:28
听说过安徽贝可 大侠要求精度高吗?  发表于 2015-5-20 20:27
就是这种,大侠知道那个牌子和型号好一些吗?  发表于 2015-5-20 19:01
发表于 2015-5-20 21:06:04 | 显示全部楼层
4 H8 V2 E7 u3 T4 N, l
这个用的人还比较少呢。。
发表于 2015-5-21 01:08:33 | 显示全部楼层
' s4 a+ ]0 V7 \2 q& R' ~% e7 V0 P) h4 e" o  [4 e/ g( R7 X& V3 M. k0 z" r
其实我个人比较喜欢这种:
! H. x, ^3 B3 ]( W" h6 d
" ~& t/ |) Z$ E4 e8 A$ G, V6 W
6 N) W7 A# [& A7 w
这个是德国生产的,可车,铣,包括钻在内的机加工。
& p/ r, M5 L# E3 m) D# P. Y! wThe Prazi Powerturn Powermill Deluxe Lathe Mill Combo is manufactured in Germany. This combo serves as a complete "Machining Center" enabling the operator to perform turning, facing, milling and drilling applications.
" w9 y- z/ A4 J2 \# z: X+ m: M  DThe solid lathe bed design has hand scrapped and precise ground V-way bed, with precision spindle accuracy of .0002". The powerturn lathe has nine spindle speeds from 170 to 3360 RPM driven by a 2/3 HP motor with 110V electrics. The powermill head swivels 180¡ and has a MT2 spindle with heavy-duty column and quill. All dials are in inch graduations./ [4 _- n% l9 M( S, E. a( l  h( T
The Prazi Powerturn Powermill SD400-BF400 Combo is ergonomically designed, weighs 350 lbs. and offers super rigidity and close tolerance repeatability for the demanding professional.
这个挺像proxxon的产品的  发表于 2015-5-21 08:38
GMT+8, 2025-10-20 13:55 , Processed in 0.076834 second(s), 20 queries , Gzip On.
