那位大侠帮我翻译成英语?非常感谢!
1、打槽工装调整不到位1.1、各底座安装不同轴
1.2、零件安装的松紧程度不适合
1.3、压杆安装的松紧程度不适合
1.4、打槽机空间小调整困难
2、加工前没有检查冲针的磨损程度
3、打槽机工装不适合M15/M16产品加工
3.1、底座不能安装高度为2.9mm的产品
3.2、压杆不能固定OD<75的产品
3.3、压块不能压紧产品
4、冲针切削阻力大,尺寸变化大
4.1冲针形状不适合
5、气缸不稳定
5.1、气压不稳定
5.2、冲针松动
5.3、气缸松动
6、产品外径小,剖面小装夹困难
7、产品易塑性变形,加工困难
8、槽尺寸测量困难
兄弟的英语实在是太难了。上面这些需要给老板看,那位好心的帮帮忙啊!
In 1, playing the slot tooling adjustment does not reach the designated positionIn
1.1, the base mounting shaft
1.2, the degree of tightness for mounting parts
1.3, the degree of tightness of the pressure rod is arranged forIn
1.4, playing the slot machine in the whole space is difficultIn
2, prior to processing did not check the degree of wear of the punch needleIn
3, playing the slot machine tooling is not suitable for M15\/M16 products processingIn
3.1, the base can not be installed height of 2.9mm products
3.2, push rod can not be fixed OD < 75 productsIn
3.3, the pressing block can not be pressed productsIn
4, the punching needle big cutting resistance, dimensional change
4.1 punch needle shape is not suitable forIn
5, the cylinder is not stableIn
5.1, the pressure of not stableIn
5.2, the punching needle looseningIn
5.3, the cylinder is looseIn
6, the product of small external diameter, small difficult clamping sectionIn
7, the product easy to plastic deformation, difficult processing
8, groove size measurement difficulties以后自己在百度上面可以翻译,中英文翻译就行。 谷歌翻译感觉不错 翻译之后再翻回去可以验证有没有不准确的地方 非常感谢各位
