查看: 2537|回复: 3
那位大侠帮我翻译成英语?非常感谢!
发表于 2013-1-10 08:36:02 | 显示全部楼层 |阅读模式
1、打槽工装调整不到位
, \9 F3 u3 x5 `' q0 `1.1、各底座安装不同轴, B/ r3 N8 V& \3 i: x
1.2、零件安装的松紧程度不适合
/ p& |& \1 O& D: B! t( K: z) o1.3、压杆安装的松紧程度不适合8 T( u* H" |+ W1 k" Y4 A* u+ Q3 I
1.4、打槽机空间小调整困难
$ Q6 {, a' m2 s2、加工前没有检查冲针的磨损程度
  M4 A+ P! B# K% x6 [0 Y: _3、打槽机工装不适合M15/M16产品加工  `' z2 [) P8 {& u
3.1、底座不能安装高度为2.9mm的产品
8 D6 N  o  u/ H3.2、压杆不能固定OD75的产品
. Z5 k! M, R4 Y. u2 |2 H  o3.3、压块不能压紧产品" Y0 I! x3 R2 J8 c. }
4、冲针切削阻力大,尺寸变化大; _; ?2 |  j. d. w9 u
4.1冲针形状不适合0 C) ?5 x) K/ e) T9 N; m! \, ?/ C! ~
5、气缸不稳定
7 M: p$ P+ D- L; t/ J" T1 `- Z# Z1 a5.1、气压不稳定
6 J+ l. H; E! a4 n) |2 Y5.2、冲针松动" Z7 g  `1 E7 s. Y& @  G
5.3、气缸松动! P3 r6 I  w0 u  E) _
6、产品外径小,剖面小装夹困难7 I) T$ a. X, v* Z0 j! s9 Y
7、产品易塑性变形,加工困难. q3 u4 @; a# z  F
8、槽尺寸测量困难% \9 K" c! u- S- G8 f
) ^6 u% \) [+ W/ Y, f  y8 Q
. c, c4 \' z5 S& h' o兄弟的英语实在是太难了。上面这些需要给老板看,那位好心的帮帮忙啊!. i6 _0 q1 J; }+ _5 m
发表于 2013-1-10 09:01:34 | 显示全部楼层
In 1, playing the slot tooling adjustment does not reach the designated positionIn, ~, c" J. g! Y1 F
1.1, the base mounting shaft
4 S. p8 x- e5 R. L3 f% x1 d1 r4 d1.2, the degree of tightness for mounting parts3 q: Z; d7 I/ R2 K- u
1.3, the degree of tightness of the pressure rod is arranged forIn * Q, T+ b4 U  C" T  `; ^
1.4, playing the slot machine in the whole space is difficultIn 3 s# d+ D& r  L; _. u
2, prior to processing did not check the degree of wear of the punch needleIn 4 l% h1 B( @; `: W, B9 `0 m
3, playing the slot machine tooling is not suitable for M15\/M16 products processingIn $ U* B# j2 ]% \% |- x% Z; V
3.1, the base can not be installed height of 2.9mm products
" a5 f( s  j6 h& v* A. X" P3.2, push rod can not be fixed OD < 75 productsIn
( U# D# }' b& {9 y3.3, the pressing block can not be pressed productsIn
* m4 C# M5 ~" y7 e! L4, the punching needle big cutting resistance, dimensional change
2 e8 D/ q- M' f2 ~  ^4.1 punch needle shape is not suitable forIn  ^0 v& Z  p! {$ H2 V7 \, I
5, the cylinder is not stableIn
* t6 d: i& {" W* ^5.1, the pressure of not stableIn ; J( G  S8 d& b) u1 p7 j' @/ h
5.2, the punching needle looseningIn
% O; |" f4 a% Z  t2 n5.3, the cylinder is looseIn
, V, f  X- {7 c9 q$ E6, the product of small external diameter, small difficult clamping sectionIn 7 [* h5 p2 L+ p, Z# G
7, the product easy to plastic deformation, difficult processing6 X: t" Q$ Z, I! w" q4 n2 m# V
8, groove size measurement difficulties
以后自己在百度上面可以翻译,中英文翻译就行。
这翻译够给力,跟世奢会酒瓶子上的有一拼...俺还是学了专业英语再发言吧,现在新概念3ing  发表于 2013-1-10 10:30
呵呵,自己多学学英语。  发表于 2013-1-10 09:35
不要误人子弟啊!开始还以为自己翻的,后来仔细看了一下,这样的东西要交给老板,不得被开了!  发表于 2013-1-10 09:11
发表于 2013-1-10 10:32:44 | 显示全部楼层
谷歌翻译  感觉不错    翻译之后再翻回去可以验证有没有不准确的地方
 楼主| 发表于 2013-1-10 10:37:18 | 显示全部楼层
非常感谢各位
GMT+8, 2025-9-18 18:42 , Processed in 0.067876 second(s), 18 queries , Gzip On.
