stickzhang 发表于 2007-1-19 21:14:17
不锈钢与P91钢焊接适用技术---[求助]
<P>我公司是电力管道加工企业,在我厂现在遇到一个难题,在焊接P91钢与不锈钢1Gr18Ni9Ti<FONT style="BACKGROUND-COLOR: #ff0000">角焊缝</FONT>焊接过程中,焊接形式见附件,在焊接时候原来采用A302焊条,焊前预热90<SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">℃,在焊接完后电厂运行一段时间以后发现在熔合线附近有贯穿性裂纹,后来改进工艺后,采用镍基焊条施焊过渡层,预热温度150-170<SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">℃,然后采用A307焊条施焊,焊后层间和表面做PT检验,发现均有碎裂纹,请问各位高手前辈这是什么原因?有没有合适的施焊工艺?</SPAN></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 36.15pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center; mso-char-indent-count: 3.0" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%"><FONT face="Times New Roman">附:P91</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">钢的化学成分(</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%"><FONT face="Times New Roman">%</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-SIZE: 12pt; LINE-HEIGHT: 150%"><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></B></P>
<DIV align=center>
<TABLE class=MsoNormalTable style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN: auto auto auto -8.35pt; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-table-layout-alt: fixed; mso-border-top-alt: solid windowtext 1.5pt; mso-border-bottom-alt: solid windowtext 1.5pt; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-insideh: .75pt solid windowtext" cellSpacing=0 cellPadding=0 border=1>
<TBODY>
<TR style="HEIGHT: 20.85pt; page-break-inside: avoid">
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1.5pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 20.85pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt; mso-border-bottom-alt: solid windowtext .75pt" width=56>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN style="FONT-FAMILY: 宋体">元素<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">C<o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1.5pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 47.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 20.85pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt; mso-border-bottom-alt: solid windowtext .75pt" width=63>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">S<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">P<o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1.5pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 36.75pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 20.85pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt; mso-border-bottom-alt: solid windowtext .75pt" width=49>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">Mn<o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1.5pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 31.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 20.85pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt; mso-border-bottom-alt: solid windowtext .75pt" width=42>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">Si<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">Ni<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">Cr<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">Mo<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">V<o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1.5pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 40.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 20.85pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt; mso-border-bottom-alt: solid windowtext .75pt" width=54>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">Nb<o:p></o:p></SPAN></P></TD></TR>
<TR style="HEIGHT: 23.25pt; page-break-inside: avoid; mso-yfti-lastrow: yes">
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 42pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1.5pt solid; HEIGHT: 23.25pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext .75pt" width=56>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN style="FONT-FAMILY: 宋体">含量<SPAN lang=EN-US>%<o:p></o:p></SPAN></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0.078<o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 47.25pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1.5pt solid; HEIGHT: 23.25pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext .75pt" width=63>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0.0031<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0.016<o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 36.75pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1.5pt solid; HEIGHT: 23.25pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext .75pt" width=49>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0. 27<o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 31.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1.5pt solid; HEIGHT: 23.25pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext .75pt" width=42>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0.3<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0.043<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">8.56<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0.96<o:p></o:p></SPAN></P></TD>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0.22<o:p></o:p></SPAN></P></TD>
<TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 40.15pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1.5pt solid; HEIGHT: 23.25pt; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext .75pt" width=54>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 150%; TEXT-ALIGN: center" align=center><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0.081<o:p></o:p></SPAN></P></TD></TR></TBODY></TABLE></DIV>
<DIV align=center>&nbsp;</DIV>
<DIV align=center><BR>&nbsp;</DIV>
黄河湃 发表于 2007-1-24 23:20:39
Re: 不锈钢与P91钢焊接适用技术---[求助]
楼主好!
转载一篇专业文章,可能对你有所启发:
焊接裂纹产生原因
  形成焊接裂纹的原因是多方面的,但可以归纳为力学因素和冶金因素两方面。
3.1 力学因素
  导致裂纹产生的力学因素主要为拘束应力。压力钢管焊接时采用多层多道焊,焊接第一层焊缝时,由于焊缝截面远小于构件的截面,因此拘束应力和拘束变形将集中在截面比母材
  小很多并且变形相对容易的焊接区内,造成第一道焊缝的焊接区是最容易出现裂纹的区域。拘束度越大,焊接区域承受的拘束应力和应变越大,造成焊接裂纹的危险性也越大。焊缝在压缝完成后,特别工地环缝不可避免地会产生拘束度偏大,从而致使点焊区域承受的拘束应力和应变偏大。焊接时,由于焊接区域的温度升高,点焊区域拘束应力得以释放,易造成裂纹的产生。有时钢管丁字接头部位容易产生裂纹就是因应力过分集中造成。
3.2 冶金因素
3.2.1 冶炼杂质对高温脆性区的影响
  钢中的杂质元素如C、S、P、B会明显地扩大高温脆性区的温度范围。60kgf/mm2钢种是一种含C、S、P量很低的Cr-Mo-V系合金钢。Mn含量较高,约为1.20%~1.60%,可以减小高温脆性区,因而60kgf/mm2钢是一种可以减小高温脆性区的钢种。
3.2.2 钢的淬硬致脆倾向
  60kgf/mm2钢种碳当量Ceq=0.35%,裂纹敏感系数Pcm=0.185%,钢的淬硬致脆倾向不明显,是一种焊接性及抗裂性良好的钢种。
3.2.3 钢中氢的致脆
  氢是焊接冶金过程残留在钢中的气体杂质。由于钢中残留的氢使钢的塑性恶化而形成氢脆。
3.2.4 焊接粗晶区晶界的弱化
  由于合金结晶过程的选择作用和相临晶粒间的相位不同,使得晶界总是含有比晶粒内部多得多的杂质和缺陷:而且由于晶界很薄,因而晶界的变形能力总是远低于晶粒本身的变形能力。在正常受力下,晶粒本身承担厂主要的塑性变形,保证了合金的塑性和强度。但NK HITEN610U2钢种因含有Cr、Mo、V等成分,Cr、Mo、V元素属于强碳化物及强氮化物形成元素,它们将会使晶界弱化或相对弱化。经计算,经验公式Psr=Cr+Cu+2Mo+5Ti+7Nb+10V-2,Psr<0,因而该材料不易发生晶界断裂。
4 焊接裂纹的防止措施
  根据形成裂纹的因素,为了防止裂纹的产生,需从结构设计、材料选择以及施工工艺三方面进行控制。
4.1 结构设计
  因压力钢管的设计是比较成熟的设计模式,它的设计有国家规范为依据,焊缝的布置是合理的。
4.2 材料选择
4.2.1钢管母材的选择
  钢管母材选用日本生产的610U2及610F调质高强钢板,这是一种含C、S量很低的Cr Mo V系合金钢,有着优良的综合力学性能,抗拉强度≥610MPa,低温韧性vE 40≥330J(2mmv形缺口冲击试验),脆性断面转变温度vTs=-36℃。而碳当量Ceq=0.35%,裂纹敏感性指数Pcm=0.185%,当焊接热输入量为17kJ/cm时,热影响区的最高硬度HVmax≤300,这是一种具有很好的焊接性和抗裂性的钢种。该钢的化学成分见表1,力学性能见表2。
表1 610U2及610F钢化学成分(%)
4.2.2 焊材的选择
  因工期较紧,在施工初期进行工艺评定选择焊材时,仅进行了手工电弧焊的焊接工艺评定。评定合格后,选定了两种高强钢焊条:宜昌猴王焊条厂生产的MK.J607RH焊条及四川自贡大西洋焊条厂生产的CHE62CHJt焊条。这两种焊条熔敷金属化学成分及力学性能如表3、表4。
表3 焊条熔敷金属化学成分(%)
表4 焊条熔敷金属力学性能
这两种焊条均为超低氢性焊条,扩散氢含量很低,MK.J607RH焊条扩散氢含量Hmax=1.28ml/100g,CHE62CFLH焊条扩散氢含量Hmax=2.29ml/100g,远低于国标规定的4ml/100g的标准。由这两种焊条进行的高强钢的焊接工艺经评定是合格的。焊缝的化学成分基本与母材相一致,焊缝的机械性能不低于母材,热影响区的维氏硬度不大于300,证明此焊材与母材是相匹配的。
4.3 施工工艺
  要防止焊接裂纹的产生,必须严格施工工艺,加强钢管制安过程的控制,使钢管从制作开始到安装验收完成都处于受控状态。
4.3.1 加强钢管制安过程控制
  (1)严格按引水压力钢管制作规范制作管节,必须保证出厂管节的管口平面度及椭圆度符合规范要求,防止偏心管节的出厂。偏心管节的检查通过测量管节四轴线弦长差可得。
  (2)工地环缝压缝时,保持环缝组对间隙基本一致,避免局部区域压缝内应力偏大。
  (3)控制环缝焊接顺序。环缝焊接时,必须采用8名或10名焊工对称分段退步焊,要求对称部位的焊工焊接参数基本一致。
4.3.2 加强钢管焊接过程控制
  (1)严格高强钢焊条烘烤及领用制度,严格清除环缝坡口及两侧30mm范围内铁锈、油污等杂质。
  (2)因工地湿度大、温度高,当焊接环境水蒸气分压高于25mmHg柱时,应选择高于规定预热温度20℃~30℃进行预热。
  (3)高强钢的焊接,不论是δ=34mm,还是δ=60mm,尽量保证焊前预热50℃,必须保证层温不低于预热温度,且不超过230℃。尤其对于δ=60mm高强钢焊缝,必须保证预热温度为50℃~100℃。
  (4)δ=34mm、60mm强钢焊缝焊后必须进行焊后消氢处理,加热温度150℃~200℃,保温1h。其中δ=60mm高强钢焊缝必须进行消应处理,使消应后的焊缝内应力小于钢材屈服强度的一半。
  以上几方面均能降低接头冷却速度防止其产生淬硬组织,从而避免产生延迟裂纹,保证焊缝内部质量。
5 结论
  通过介绍焊接裂纹分类及分析焊接裂纹产生机理,根据三峡工程的实际情况,得出以下结论:要保证焊缝质量,避免高强钢焊缝产生焊接裂纹,必须严格施工工艺,加强钢管制安过程的控制,使钢管从制作开始到安装验收完全处于质量受控状态。
楼主可以参考ASME标准中的P91和TP347的焊接工艺评定来处理,我没有做过你说的这种焊接.
不过,可以肯定的是预热温度不够,而且焊后是否进行的适当的焊后处理呢!
焊条我建议你选择ESAB的OK 76.96来焊接!
需要进行焊后热处理
不过 可不要将 不锈钢侧 处理呀
只将91侧和焊缝进行高温回火
对了 那一侧 再空气中 不要 保温
另外,P91 必须在管道内充氩,否则根部氧化,后果很严重呀
看样子是温度测点的套管,现在怎么样了,大家说了不少,楼主应该冒个泡吧。
漂流瓶 发表于 2008-5-5 23:33:45
一直关注这个问题,可总是没有消息咯,瓶子在锅炉厂的朋友那里问到了一些工艺,如果没有解决,请与瓶子联系。
lgkokode 发表于 2008-5-7 18:09:05
焊前预热温度低取16o—180℃
道间温度控制在280-320℃之间
建议TIG打底焊,管内充氩保护
查看完整版本: 不锈钢与P91钢焊接适用技术---[求助]
