benkkj 发表于 2012-11-23 15:10:07
有誰會公差計算?
有誰會公差計算?
公差計算用軟體也可以.Thx ^^
charles006 发表于 2012-11-23 16:26:43
呵呵,楼主把公差与配合去好好研读一下......
光靠软体只是提高效率问题,不知道为什么软体不会帮你找出错误的
benkkj 发表于 2012-11-23 16:28:54
charles006 发表于 2012-11-23 16:26 static/image/common/back.gif
光靠软体只是提高效率问题,不知道为什么软体不会帮你找出错 ...
Thanks for your suggestion, I will study it and find out what I could learn from it, thx a lot,{:soso_e113:}
路上的黑马 发表于 2012-11-23 16:31:19
还是查表来的直接!
benkkj 发表于 2012-11-23 16:33:55
路上的黑马 发表于 2012-11-23 16:31 static/image/common/back.gif
还是查表来的直接!
Thanks a lot, I'll learn it all, and if any question please advise,{:soso_e163:}
benkkj 发表于 2012-11-23 16:38:50
Because I am a ME designer, basically I don't need to analizy the dims that I design ,but sometimes my client asks me to prove the criticaldim, therefor I've better to learn from now on, hopefully all you guys could doing it as well, good luck,{:soso_e162:}
honyo2011 发表于 2012-11-23 16:41:20
呵呵,是不是中文有问题啊?这样交流就困难了哦!
SDBYDSL 发表于 2013-12-17 10:54:49
我建议楼主还是看一看《公差配合与技术测量》这本书,理论学好了再去寻找公差配合的查询软件;
查看完整版本: 有誰會公差計算?
