查看: 2748|回复: 7
有誰會公差計算?
发表于 2012-11-23 15:10:07 | 显示全部楼层 |阅读模式
有誰會公差計算?' S5 N, X4 l! M: e" y
公差計算用軟體也可以.Thx ^^$ @  h5 F! y1 X# k4 F
发表于 2012-11-23 16:26:43 | 显示全部楼层
呵呵,楼主把公差与配合去好好研读一下......
6 U! f! K, W. e光靠软体只是提高效率问题,不知道为什么软体不会帮你找出错误的
 楼主| 发表于 2012-11-23 16:28:54 | 显示全部楼层
charles006 发表于 2012-11-23 16:26
5 A0 a/ B& Z  `- R呵呵,楼主把公差与配合去好好研读一下......
& n, ^; `1 j; ~2 v1 A光靠软体只是提高效率问题,不知道为什么软体不会帮你找出错 ...
$ l0 q8 M9 C6 U3 Z" E+ ?
Thanks for your suggestion, I will study it and find out what I could learn from it, thx a lot,{:soso_e113:}
0 \% p  H. A( c0 E9 j/ Y
发表于 2012-11-23 16:31:19 | 显示全部楼层
还是查表来的直接!
 楼主| 发表于 2012-11-23 16:33:55 | 显示全部楼层
路上的黑马 发表于 2012-11-23 16:31
) r( C% x. f8 r* Z6 H' K还是查表来的直接!
1 k2 r& P5 L! O) @9 r% ^& _( T+ {
+ S- y" `3 g# l$ W- I4 a
) y- F, w; V# @3 O
Thanks a lot, I'll learn it all, and if any question please advise,{:soso_e163:}
1 B5 S6 B4 f6 D2 |# s
 楼主| 发表于 2012-11-23 16:38:50 | 显示全部楼层
Because I am a ME designer, basically I don't need to analizy the dims that I design ,but sometimes my client asks me to prove the critical  dim, therefor I've better to learn from now on, hopefully all you guys could doing it as well, good luck,{:soso_e162:}
发表于 2012-11-23 16:41:20 | 显示全部楼层
呵呵,是不是中文有问题啊?这样交流就困难了哦!
他是在练习英语啊,很不错!  发表于 2012-11-23 16:48
发表于 2013-12-17 10:54:49 | 显示全部楼层
我建议楼主还是看一看《公差配合与技术测量》这本书,理论学好了再去寻找公差配合的查询软件;
GMT+8, 2025-2-21 19:44 , Processed in 0.068521 second(s), 19 queries , Gzip On.
