基于电子积木arduino(AVR)的G代码解释器原代码
基于电子积木arduino的G代码解释器原代码,来源于http://arduino.cc/forum/搜CNC我去年收集了许多程序,经过测试挑选出可以用,后来没时间继续研究学习,现在发
上来给有用的朋友参考
下面是其中的小段源码
//init our variables
long max_delta;
long x_counter;
long y_counter;
long z_counter;
bool x_can_step;
bool y_can_step;
bool z_can_step;
int milli_delay;
void init_steppers()
//turn them off to start.
disable_steppers();
//init our points.
current_units.x = 0.0;
current_units.y = 0.0;
current_units.z = 0.0;
target_units.x = 0.0;
target_units.y = 0.0;
target_units.z = 0.0;
pinMode(X_STEP_PIN, OUTPUT);
pinMode(X_DIR_PIN, OUTPUT);
pinMode(X_ENABLE_PIN, OUTPUT);
pinMode(X_MIN_PIN, INPUT);
pinMode(X_MAX_PIN, INPUT);
pinMode(Y_STEP_PIN, OUTPUT);
pinMode(Y_DIR_PIN, OUTPUT);
pinMode(Y_ENABLE_PIN, OUTPUT);
pinMode(Y_MIN_PIN, INPUT);
pinMode(Y_MAX_PIN, INPUT);
pinMode(Z_STEP_PIN, OUTPUT);
pinMode(Z_DIR_PIN, OUTPUT);
pinMode(Z_ENABLE_PIN, OUTPUT);
pinMode(Z_MIN_PIN, INPUT);
pinMode(Z_MAX_PIN, INPUT);
//figure our stuff.
calculate_deltas();
void dda_move(long micro_delay)
//enable our steppers
digitalWrite(X_ENABLE_PIN, HIGH);
digitalWrite(Y_ENABLE_PIN, HIGH);
digitalWrite(Z_ENABLE_PIN, HIGH);
//figure out our deltas
max_delta = max(delta_steps.x, delta_steps.y);
max_delta = max(delta_steps.z, max_delta);
//init stuff.
long x_counter = -max_delta/2;
long y_counter = -max_delta/2;
long z_counter = -max_delta/2;
//our step flags
bool x_can_step = 0;
bool y_can_step = 0;
bool z_can_step = 0;
if (micro_delay >= 16383)
milli_delay = micro_delay / 1000;
else
milli_delay = 0;
有2轴圆弧查补和3轴直线查补功能 谢谢分享。 谢谢分享。 谢谢分享 谢谢分享! 感谢分享 电子积木是什么意思?是CNC的G码吗? 这个还没怎么接触过,楼主能详细解释解释吗
谢谢分享
