小鼠大胆 发表于 2012-4-7 12:41:03
美国设计的特种分度器,谁设计过类似产品
拍了几张米国设计的特种减速器图。有哪位大虾设计制造过类似产品?
http://bbs.cmiw.cn/data/attachment/album/201204/07/122435jzob8o828tcayzsa.jpghttp://bbs.cmiw.cn/data/attachment/album/201204/07/1220407sdhs74y5ssdcfe2.jpghttp://bbs.cmiw.cn/data/attachment/album/201204/07/122614asacxfa4zxxbxqtc.jpghttp://bbs.cmiw.cn/data/attachment/album/201204/07/1222425d23w25m3ua35i5a.jpghttp://bbs.cmiw.cn/data/attachment/album/201204/07/1229532n5g2z4fcclvey5q.jpghttp://bbs.cmiw.cn/data/attachment/album/201204/07/122435jzob8o828tcayzsa.jpg
我拆的这个减速器算是特殊的产品吧?十几年前的产品了,对本人来说机械结构依然先进。
这个减速器的作用是输入轴转动一圈输出轴转动八分之一圈自动锁死定位,算不算凸轮式传动?输出轴精度很高,换角度后基本手感上没有可转动的间隙。这种输出输入可定制,各种比例应该能做。本人之前上传的视频《组装机....》里有这种大功率的传动机构。
http://bbs.cmiw.cn/data/attachment/album/201204/07/121142tnp7fghz11ym2ckx.jpghttp://bbs.cmiw.cn/data/attachment/album/201204/07/121337wrkk0ir4p4f4fgmi.jpghttp://bbs.cmiw.cn/data/attachment/album/201204/07/121523b91pdiig889pgccc.jpg
nulisp 发表于 2012-4-7 12:56:15
这种结构从来没见过呢.建议楼主用SW建个模型出来
杨若萱 发表于 2012-4-7 13:09:56
没看太清楚!不过学习了
小鼠大胆 发表于 2012-4-7 14:41:46
LIAOYAO大虾看来还是懂的,我过些天还得山寨个大号的。自己用,做自动化步进需要这玩意。
nulisp 发表于 2012-4-7 14:51:17
小鼠大胆 发表于 2012-4-7 14:41 static/image/common/back.gif
这种结构挺神秘的,盼望楼主把它拿下后跟我们讲解下.画个原理图什么的
robotics30 发表于 2012-4-7 15:00:12
好像是分度器吧
The Cyclo-Index Basic Drive features a compact, 2-piece sealed housing with precision ground shafts, antifriction bearings, and oil bath lubrication. Housings are supplied with oil level and base drain plugs, and with oil fill and vent plugs at the top. Standard housings are provided with mounting holes in side no. 3, but can be supplied in any of the other 5 sides. The housing design allows universal mounting; the units can be operated with the shafts in a horizontal, vertical or inclined position. Oil level, fill, drain, and vent plug locations must be planned to suit.
Cyclo-Index drive units can be operated in either direction of rotation and function with a precision +/-.001" backlash at a 1-in. radius at dwell position. Direction of rotation of the input shaft is opposite that of the output shaft for basic, alternating and tandem units. For compound and geared Index Drive Units, the direction of rotation is the same for both shafts.
自己的一点意见.对不对的不要用板砖砸我
robotics30 发表于 2012-4-7 15:10:47
这种分度器,在伺服电机没有大规模使用的年代,具有不可替代性,但现在伺服电机的成本越来越低,已经很少有人使用了,逐渐退出历史舞台了。
刘景亚 发表于 2012-4-7 17:12:39
应用摆线外传动实现的分度装置,铭牌上都写出来了,cyclo index。
刘景亚 发表于 2012-4-7 17:20:40
上传一张原理图。
页: [1] 2 3 4
查看完整版本: 美国设计的特种分度器,谁设计过类似产品
