发表于 2012-4-7 15:00:12
显示全部楼层
好像是分度器吧' J" @! s& e, W% g6 j) i
The Cyclo-Index Basic Drive features a compact, 2-piece sealed housing with precision ground shafts, antifriction bearings, and oil bath lubrication. Housings are supplied with oil level and base drain plugs, and with oil fill and vent plugs at the top. Standard housings are provided with mounting holes in side no. 3, but can be supplied in any of the other 5 sides. The housing design allows universal mounting; the units can be operated with the shafts in a horizontal, vertical or inclined position. Oil level, fill, drain, and vent plug locations must be planned to suit.
) J5 b! r0 B* U& U; m; t! Y
. D8 h7 a4 ]; p& m/ o) YCyclo-Index drive units can be operated in either direction of rotation and function with a precision +/-.001" backlash at a 1-in. radius at dwell position. Direction of rotation of the input shaft is opposite that of the output shaft for basic, alternating and tandem units. For compound and geared Index Drive Units, the direction of rotation is the same for both shafts.9 w' e* n* J9 s9 J# w; U# h, @
2 }3 d4 c+ P* n& p0 {) R |
