adams常用快捷键
Display OperationsViewing Operations
Table 3. Display Operation Shortcuts
To display: Select:
Command window F3
Coordinate window F4
Menu Builder F5
Dialog Box Builder F6
Working grid g
Plotting window F8
Help window F1
Table 4. Viewing Operation Shortcuts
To: Select:
Rotate view in the XY directions r
Rotate view in the Z direction s (lowercase)
Translate view t
Change perspective depth d
Dynamically zoom view z
Use dynamic increment Shift
4
Edit Operations
Table 1. File Operation Shortcuts
To: Select:
Create a new modeling database Ctrl + n
Open an existing modeling database Ctrl + o
Save the current modeling database Ctrl + s
Print Ctrl + p
Read command file F2
Exit Ctrl + q
Table 2. Edit Operation Shortcuts
To: Select:
Undo the last operation Ctrl + z
Redo the last undone operation Ctrl- Shift + z
Copy objects Ctrl + c
Paste text in text boxes in dialog boxes and as comments Ctrl + v
Cut text from text boxes in dialog boxes Ctrl + x
Delete selected object Del
Modify object Ctrl + e
Escape operation Esc
