查看: 4104|回复: 0
[adams] adams常用快捷键
发表于 2011-12-19 08:27:16 | 显示全部楼层 |阅读模式
Display Operations
- X! B0 @' z$ a- B% y; R) n* m8 OViewing Operations
! X/ \; N' R$ |2 k, C: i1 |6 T3 v. B: Q! STable 3. Display Operation Shortcuts# m' F+ t4 B) Q% t( @4 ~
To display: Select:, u3 w) g$ `2 C9 b( n  o
Command window F3
2 E* K# K% ?6 Y" kCoordinate window F4
1 {1 c  ?. c  r& M9 r# `7 EMenu Builder F5
( N- ?+ V7 n2 \0 I; F- RDialog Box Builder F6% j6 |5 w1 M+ B& W
Working grid g" ^' M1 R7 P8 w( `# v. A
Plotting window F89 {2 O" Q4 |! M  H4 U6 G
Help window F1
# p9 z. T, ^' U4 S6 D- s$ JTable 4. Viewing Operation Shortcuts
6 o( z- p) L" qTo: Select:
% y- l0 O' S/ R& F5 }Rotate view in the XY directions r8 h2 ?0 J/ \. ?/ q' W1 Q4 y
Rotate view in the Z direction s (lowercase)
! ?) p( y  F6 U9 h$ E1 ATranslate view t
! U, D) K# z8 ^: i% P9 e0 iChange perspective depth d9 e8 w( ]) v) ?: y
Dynamically zoom view z9 q1 C, T* V9 R9 d+ d5 L3 T0 l0 E
Use dynamic increment Shift
6 k2 @# @8 g* a2 `0 Z' Z4
* _+ r$ }/ e& R; @/ uEdit Operations
9 I/ w. L" s& STable 1. File Operation Shortcuts
8 X# Y- B6 m& x2 W. t# T/ yTo: Select:5 I+ k1 d( f2 w$ j
Create a new modeling database Ctrl + n
/ b4 h/ O9 S  K2 U$ qOpen an existing modeling database Ctrl + o- \* i4 X0 F  f8 M3 D' o, O
Save the current modeling database Ctrl + s/ D9 N( v  p& {, }
Print Ctrl + p
+ I/ S3 @, g; O; S  x5 }Read command file F29 h8 Q' G# x) T" l8 q
Exit Ctrl + q7 q* ]3 f/ ?6 G0 l& H
Table 2. Edit Operation Shortcuts
$ Z2 J9 f2 k9 g0 C& Q: i% {: wTo: Select:
1 I, Q2 g* i' p. j1 hUndo the last operation Ctrl + z
$ W! u! ~' p3 |$ q; QRedo the last undone operation Ctrl- Shift + z; f) v6 Z$ Y; [6 `
Copy objects Ctrl + c& d- ^- L0 e( C1 `7 s
Paste text in text boxes in dialog boxes and as comments Ctrl + v3 m8 \# @$ ^( h6 i- F6 X) b
Cut text from text boxes in dialog boxes Ctrl + x8 S: Q& [9 x3 }7 z6 ?
Delete selected object Del1 M8 x4 Z# r2 k' \. [' m
Modify object Ctrl + e& L7 G) s* i! t
Escape operation Esc
  j; M; W. a6 A7 `1 S
GMT+8, 2025-2-19 07:10 , Processed in 0.054767 second(s), 14 queries , Gzip On.
