UH-60A Powertrain/ Rotor System
United States Army Aviation Warfighting CenterFort Rucker, Alabama
February 2008
UH-60A
Terminal Learning Objective:
Action: Describe the operational procedures that pertain to the UH-60 Powertrain and Rotor systems.
Condition: Without reference, given the aircraft systems examination and an answer sheet.
Standard: Be able to describe the operational characteristics that pertain to the UH-60 Powertrain/ Rotor
system. This includes the operational characteristics of the Main Transmission System, Transmission
Lubrication System, Transmission Chip Detector System, the Gust Lock, and Main and Tail Rotor
Components.
Safety Requirements: Use care when operating training aids and/or devices.
Risk Assessment Level: Low.
Environmental Considerations: It is the responsibility of all soldiers and DA civilians to protect the
environment from damage.
Evaluation: You must answer (4) out of (6) questions correctly on in this scorable unit on the systems
examination to receive a "GO". You will have one hour to complete the system examination.
Learning Step/Activity 1. Describe the operational characteristics of the Main Transmission System.
woyaojifen太爱你了,好贴 中国有几架UH-60A都坏了,这资料有用。谢谢!
