United States Army Aviation Warfighting Center$ ^. S' g& j: Z+ E+ |4 h
Fort Rucker, Alabama% ]. D# h) t9 ?' W3 p# P3 M
February 2008
, e8 U1 ]3 ?* b0 MUH-60A, y6 U! x8 o, z X
Terminal Learning Objective:
' y* t0 y3 p3 u# |' ^Action: Describe the operational procedures that pertain to the UH-60 Powertrain and Rotor systems.
P( d h6 A% r; z4 {) L$ S6 zCondition: Without reference, given the aircraft systems examination and an answer sheet.9 j5 ^- G6 M% M; ^: x+ J
Standard: Be able to describe the operational characteristics that pertain to the UH-60 Powertrain/ Rotor4 P3 Z7 }7 s+ @
system. This includes the operational characteristics of the Main Transmission System, Transmission7 h* @7 P7 B) x" k
Lubrication System, Transmission Chip Detector System, the Gust Lock, and Main and Tail Rotor
. y8 T6 u6 S" N* s0 ?Components.* F( y% N2 ~- M9 ^/ H& |. V
Safety Requirements: Use care when operating training aids and/or devices.
& t& @5 E$ ^2 u# Y ]4 @Risk Assessment Level: Low.+ X9 f* K+ M3 D$ m$ u' b) }! _; \
Environmental Considerations: It is the responsibility of all soldiers and DA civilians to protect the
: Z' p; p& q5 B. I5 e: ^" aenvironment from damage.
M/ G" f/ V/ H% w& t LEvaluation: You must answer (4) out of (6) questions correctly on in this scorable unit on the systems
, c; ?, y- g8 K1 ~$ c* t+ |examination to receive a "GO". You will have one hour to complete the system examination.
& {) A# q1 U6 sLearning Step/Activity 1. Describe the operational characteristics of the Main Transmission System.1 Q2 q8 K& ?2 ?, y; o
' n8 `2 h K' {6 |4 Y" [( l' P
$ y1 T) _1 C( C' ` |
