那位高手大侠帮我再验算一遍。
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">已求得油缸最大垂直线速度为:</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">0.92rad/s</FONT></SPAN><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: Gulim">×</SPAN><FONT face="Times New Roman"><?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" /><st1:chmetcnv w:st="on" UnitName="m" SourceValue="1.05" HasSpace="False" Negative="False" NumberType="1" TCSC="0"><SPAN lang=EN-US style="FONT-SIZE: 14pt">1.05m</SPAN></st1:chmetcnv><SPAN lang=EN-US style="FONT-SIZE: 14pt">=<st1:chmetcnv w:st="on" UnitName="m" SourceValue=".9657" HasSpace="False" Negative="False" NumberType="1" TCSC="0">0.9657m</st1:chmetcnv>/s=9.657dm/s<o:p></o:p></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">油缸缸径为</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">?125mm,</FONT></SPAN><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">无杆腔有效面积为</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">1.227dm</FONT></SPAN><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: Gulim">2</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">.<o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">故,按油缸瞬时最大速度计算,则单缸所需流量为:</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">1.227 dm</FONT></SPAN><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: Gulim">2×</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt; FONT-FAMILY: Gulim; mso-fareast-font-family: 宋体">9.657</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman"> dm/s=<st1:chmetcnv w:st="on" UnitName="l" SourceValue="11.849" HasSpace="False" Negative="False" NumberType="1" TCSC="0">11.849L</st1:chmetcnv>/s=<st1:chmetcnv w:st="on" UnitName="l" SourceValue="710" HasSpace="False" Negative="False" NumberType="1" TCSC="0">710L</st1:chmetcnv>/min.<o:p></o:p></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 49pt; mso-char-indent-count: 3.5"><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">则泵的流量选</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">1000L/min</FONT></SPAN><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">。</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">此结果似乎不对?</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><o:p></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US style="FONT-SIZE: 14pt"><FONT face="Times New Roman">?<st1:chmetcnv w:st="on" UnitName="mm" SourceValue="125" HasSpace="False" Negative="False" NumberType="1" TCSC="0">125mm</st1:chmetcnv></FONT></SPAN><SPAN style="FONT-SIZE: 14pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">的油缸需这么大的泵,有此流量的柱塞泵么?</SPAN><SPAN lang=EN-US style="FONT-SIZE: 14pt"><o:p></o:p></SPAN></P>
Re: 那位高手大侠帮我再验算一遍。
你的油缸的速度是怎么算出来的,每秒钟一米这样的速度可够快的,你再核实一下,你的速度怎么是圆周线速度呢?Re: 那位高手大侠帮我再验算一遍。
你的计算结果无误Re: 那位高手大侠帮我再验算一遍。
不知道你说的是否是摆动或者叫旋转的液压缸,我觉得1:开始参数是否选择过高0.92rad/s、1.05m,2:若是旋转的话,那其运动呈扇形,所需油量不能按最大线速度乘有效面积算,我没有手册,不知我理解的有效面积是否是你所说的有效面积,3:是否选用螺杆泵供油。Re: 那位高手大侠帮我再验算一遍。
楼住提到应该是油缸推动摇臂转动,要达到0.92rad/s的角速度吧。既然计算出来的最大值是710L/min,那么流量就取800L/min好了,1000L/min流量浪费太大了。。能不能考虑加大容量蓄能器呢?用多个泵组如何?另外,工作压力是多高呢,能不能适当提高压力,以减小油缸直径呢?Re: 那位高手大侠帮我再验算一遍。
没有算你的数据,但是你选的直径不大,而速度怎么那么高,你在核实一下,完了我们再帮你算,你说的1000L/MIN的流量的泵是有,但是比较大,你用了太浪费了.Re: 那位高手大侠帮我再验算一遍。
先不看你计算是否正确,遇到此类问题,先要考虑要求是否合理,如果确实需要如此大的瞬间流量,不一定选择大排量液压泵,因为油缸速度要求快,所需的油液的体积其实并没有多少,所以你可以考虑采用蓄能器来提供瞬间大流量,确保满足油缸所需流量值! 7#正解。
