谢鹏 发表于 2011-6-7 11:54:27
输送机械相关英语
Shaft
Solid shafts.
As a machine component a shaft is commonly a cylindrical bar that supports and rotates with devices for receiving and delivering rotary motion and torque .The crankshaft of a reciprocating engine receive its rotary motion from each of the cranks, via the pistons and connecting roads (the slider-crank mechanisms), and delivers it by means of couplings, gears, chains or belts to the transmission, camshaft, pumps, and other devices. The camshafts, driven by a gear or chain from the
crankshaft, has only one receiver or input, but each cam on the shaft delivers rotary motion to the valve-actuating mechanisms.
gcjxdashijie 发表于 2011-6-7 13:39:10
这个比较专业,下载一份备用
查看完整版本: 输送机械相关英语
