查看: 2470|回复: 1
输送机械相关英语
发表于 2011-6-7 11:54:27 | 显示全部楼层 |阅读模式
Shaft
3 H% P) P8 V- \; T, I
Solid shafts.& j- a  @5 _5 E0 Q5 ^# j: T
As a machine component a shaft is commonly a cylindrical bar that supports and rotates with devices for receiving and delivering rotary motion and torque .The crankshaft of a reciprocating engine receive its rotary motion from each of the cranks, via the pistons and connecting roads (the slider-crank mechanisms), and delivers it by means of couplings, gears, chains or belts to the transmission, camshaft, pumps, and other devices. The camshafts, driven by a gear or chain from the
/ G' @4 b% C) h. ?1 ~# N* Ocrankshaft, has only one receiver or input, but each cam on the shaft delivers rotary motion to the valve-actuating mechanisms.
发表于 2011-6-7 13:39:10 | 显示全部楼层
这个比较专业,下载一份备用
GMT+8, 2025-4-26 09:33 , Processed in 0.062984 second(s), 16 queries , Gzip On.
