伊凡 发表于 2011-5-10 17:26:12
Jig和Clamp的区别,请教
请问夹具的英语表达,JIG和Clamp的区别是?
工装的英语表达?
伊凡 发表于 2011-5-10 17:27:15
是不是Fixture指工装,Jig是指夹具?
datafield 发表于 2011-5-10 17:29:13
Jig是检具吗?
伊凡 发表于 2011-5-10 17:39:33
14.1 What is a jig ?
14.2 What is a fixture ?
14.3 What are the applications of jigs and fixtures ?
14.4 How is the work piece represented in a jig or fixture drawing ?
14.5 List the various jig components and their uses.
14.6 List different types of jigs and sketch the following :
(a) turn over jig, and
(b) leaf jig.
14.7 With the help of sketches, describe the different types of bushes.
14.8 What is bush clearance and what is its importance ?
14.9 List various fixture components and their uses.
14.10 Name the different types of fixtures.
伊凡 发表于 2011-5-10 17:40:25
有点晕啊,高人指点一下吧,谢谢。
伊凡 发表于 2011-5-10 17:40:28
有点晕啊,高人指点一下吧,谢谢。
天空的樱花 发表于 2011-5-10 18:10:50
你别晕啊,我都被你搞晕了:dizzy:我英文零分
伊凡 发表于 2011-5-11 15:21:19
A jig is a device, which holds and supports the work and also guides the path of the
cutting tool, as the operation is performed. Jigs are used extensively for operations such as
drilling, reaming, tapping and counter-boring. The jig need not be secured to the machine.
A fixture is a device which locates and holds the work securely in a definite position. It
is usually secured to the table of the machine and it does not guide the cutting tool. The cutting
tool is either moved into position for the operation or the table is moved under the cutting tool.
Fixtures are used while performing milling, turning, honing, broaching, grinding and welding
operations.
yichuxi 发表于 2011-5-11 18:20:08
期待高人解答
英语基本上全部还给老师了:lol
伊凡 发表于 2011-5-12 11:47:59
回复 yichuxi 的帖子
那就上传一个电子书,名字就叫做 Machine Drawing, 好像是印度出版的,不清楚。
页: [1] 2 3
查看完整版本: Jig和Clamp的区别,请教
