ansys网格划分时遇到的问题【急】
我在对一个模型进行网格划分时,出现了如下警告,请各位大侠给解释一下,谢谢!solid 95单元,210e9模量,0.3泊松比
<<<<<< FOR NEW OR MODIFIED ELEMENTS >>>>>>
|Element count 9201 SOLID95 |
Test Number testedWarning countError count Warn+Err %
Aspect Ratio 9201 0 0 0.00 %
Maximum Angle 9201 1 0 0.01 %
Jacobian Ratio 9201 0 0 0.00 %
Any 9201 1 0 0.01 %
*** WARNING *** CP = 5.219 TIME= 22:00:12
Shape testing revealed that 1 of the 9201 new or modified elements
violate shape warning limits.To review test results, please see the
output file or issue the CHECK command.
PRODUCE ELEMENT PLOT IN DSYS = 0
USER SCALING FOR WINDOW1
DISTANCE = 684.0
FOCUS POINT = 175.0 0.000 110.0
view point for window1 0.79719 -0.29100 0.52896
ROTATION ANGLE FOR WINDOW 1 IS -26.26 ABOUT AXIS ZS
DISTANCE MULTIPLIER FOR WINDOW 1 1.082
DISTANCE FOR WINDOW 1 740.3
DISTANCE FOR WINDOW 1 801.1
DISTANCE FOR WINDOW 1 867.0
DISTANCE MULTIPLIER FOR WINDOW 10.9240
DISTANCE FOR WINDOW 1 684.0
DISTANCE FOR WINDOW 1 632.0
DISTANCE FOR WINDOW 1 584.0
DISTANCE FOR WINDOW 1 539.7
DISTANCE FOR WINDOW 1 498.6
view point for window1 0.60345 -0.19726 0.77262
ROTATION ANGLE FOR WINDOW 1 IS -21.81 ABOUT AXIS ZS
view point for window1 0.44704 -0.33138E-01 0.89390
ROTATION ANGLE FOR WINDOW 1 IS -20.38 ABOUT AXIS ZS
view point for window1 0.11290 0.28683 0.95131
ROTATION ANGLE FOR WINDOW 1 IS -22.28 ABOUT AXIS ZS
DISTANCE FOR WINDOW 1 460.8
DISTANCE FOR WINDOW 1 425.8
DISTANCE FOR WINDOW 1 393.4
DISTANCE FOR WINDOW 1 363.5
DISTANCE FOR WINDOW 1 335.9
DISTANCE FOR WINDOW 1 310.4
DISTANCE FOR WINDOW 1 286.8
DISTANCE FOR WINDOW 1 265.0
DISTANCE FOR WINDOW 1 244.9
DISTANCE FOR WINDOW 1 226.3
DISTANCE FOR WINDOW 1 209.1
DISTANCE FOR WINDOW 1 193.2
DISTANCE FOR WINDOW 1 178.5
DISTANCE FOR WINDOW 1 164.9
DISTANCE FOR WINDOW 1 152.4
DISTANCE FOR WINDOW 1 140.8
DISTANCE FOR WINDOW 1 130.1
DISTANCE FOR WINDOW 1 120.2
view point for window1-0.65020E-01 0.12625 0.98987
ROTATION ANGLE FOR WINDOW 1 IS -24.75 ABOUT AXIS ZS
PRODUCE ELEMENT PLOT IN DSYS = 0 不了解 , 学习中 物理冲突了吧
