我在对一个模型进行网格划分时,出现了如下警告,请各位大侠给解释一下,谢谢!
@. x4 O, L+ }# Ksolid 95单元,210e9模量,0.3泊松比
) O ]6 q( L2 f) _2 X3 B2 a7 F# x6 b8 q5 p( r! U% t; H
<<<<<< FOR NEW OR MODIFIED ELEMENTS >>>>>>0 q" V( O6 N2 @* ]: j# j
( e1 a2 }3 p, E3 j2 ` --------------------------------------# K( [6 w5 N: L1 h1 ]8 P, O
| Element count 9201 SOLID95 |
; e) h4 V1 n1 _; m9 |6 D --------------------------------------, a' ?) K" N+ z2 M' I8 K' p
6 i" h$ a P9 _! j$ X! y- x: GTest Number tested Warning count Error count Warn+Err %& W& A( |* k: X. m6 `9 U0 C
% h- r, }! s' ]* EAspect Ratio 9201 0 0 0.00 %" ~4 |5 C& D; _1 a0 `% f! [& t5 R
Maximum Angle 9201 1 0 0.01 %; ?( ~' N- K; M/ D- u1 w% a3 ?
Jacobian Ratio 9201 0 0 0.00 %* k% I- }# J6 E9 N" a1 @6 N6 d
" p3 \2 @) A: n, k+ B- T- V) S2 f
Any 9201 1 0 0.01 %* _. W3 {& m5 E# u" m% w
------------------------------------------------------------------------------( l6 s/ x, M# j- o+ b
3 |, s+ M9 K: v6 O7 ?) ^*** WARNING *** CP = 5.219 TIME= 22:00:12
+ r4 Y! T5 {! lShape testing revealed that 1 of the 9201 new or modified elements/ K: A9 S- F1 y9 o* V8 A
violate shape warning limits. To review test results, please see the' n6 L3 V: s* t* p/ l( G' {
output file or issue the CHECK command.' c- ?# M( w! B3 f
PRODUCE ELEMENT PLOT IN DSYS = 09 D0 I7 z' `* z4 e
USER SCALING FOR WINDOW 13 v6 _( Z% w3 {" c$ M
DISTANCE = 684.0( c( W; i" G! Q+ J5 u7 S
FOCUS POINT = 175.0 0.000 110.0- }/ s+ q: x8 g/ F: J$ Q
view point for window 1 0.79719 -0.29100 0.52896# q f y- i* [5 q
ROTATION ANGLE FOR WINDOW 1 IS -26.26 ABOUT AXIS ZS. a, o) ?* D" C/ Y
, n9 K$ g2 t) u9 eDISTANCE MULTIPLIER FOR WINDOW 1 1.082, ~* h6 x4 z# o* \, H' j
DISTANCE FOR WINDOW 1 740.3
! h' a; S! J+ kPRODUCE ELEMENT PLOT IN DSYS = 0
% r, G8 |) i. I: H$ zDISTANCE MULTIPLIER FOR WINDOW 1 1.082
/ N% p: h* P& r5 }1 f' K$ d9 uDISTANCE FOR WINDOW 1 801.10 f* A( H8 H; ~6 V8 b
8 v6 R+ W* N& t$ c EDISTANCE MULTIPLIER FOR WINDOW 1 1.0822 K6 r% } e# ~' O3 P
DISTANCE FOR WINDOW 1 867.09 P1 U! d! H" w! V
[/ y7 p$ i- d/ O: yDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
# i' u0 l7 a! g5 fDISTANCE FOR WINDOW 1 801.1
+ _; E8 S& U/ a3 q: BPRODUCE ELEMENT PLOT IN DSYS = 0
7 Q' j) G q4 e- f; cDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
0 B5 L( B" ^: z4 X: ?DISTANCE FOR WINDOW 1 740.3
3 _3 o5 l! f v9 m( V" u) l2 OPRODUCE ELEMENT PLOT IN DSYS = 0; F& P) A+ O- {+ M' c" Z
, [# r& U; i1 p) b& o+ iDISTANCE FOR WINDOW 1 684.0
0 S/ k% @0 i) A' ^' jPRODUCE ELEMENT PLOT IN DSYS = 03 S% @! S6 e# k# s' X$ M
0 S9 L1 `" j5 ]* uDISTANCE FOR WINDOW 1 632.0
7 z: f* l/ ]9 q/ c' u# w) N: B) HPRODUCE ELEMENT PLOT IN DSYS = 0
, i9 p6 Y$ L O6 q# z7 WDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
9 B* m& w% P5 iDISTANCE FOR WINDOW 1 584.03 l. u& M4 \. e4 M
PRODUCE ELEMENT PLOT IN DSYS = 0( o7 ~& I3 e3 g9 ~' J
DISTANCE MULTIPLIER FOR WINDOW 1 0.9240- i. g* P1 b5 f7 Z" f7 N
DISTANCE FOR WINDOW 1 539.7
8 C+ H4 q: T$ N4 m) z( Y( A* \PRODUCE ELEMENT PLOT IN DSYS = 0+ G5 w: y* W2 U$ v& ^; q* G4 ^5 w
DISTANCE MULTIPLIER FOR WINDOW 1 0.92404 H$ n2 {% Z; e Q4 G. P
DISTANCE FOR WINDOW 1 498.6; f0 e7 w0 `$ y& I" l
PRODUCE ELEMENT PLOT IN DSYS = 0! \- C8 V. O c2 p
view point for window 1 0.60345 -0.19726 0.77262* Y' [9 a( i# s2 e: B& E
ROTATION ANGLE FOR WINDOW 1 IS -21.81 ABOUT AXIS ZS
2 |$ ^: y: B/ I+ G# NPRODUCE ELEMENT PLOT IN DSYS = 0
' ^+ D( `$ K) N; cview point for window 1 0.44704 -0.33138E-01 0.89390 {* i9 K/ k2 I
ROTATION ANGLE FOR WINDOW 1 IS -20.38 ABOUT AXIS ZS, t" {2 F8 }. N: ?+ Q
# b+ B- H2 a }3 i- nview point for window 1 0.11290 0.28683 0.95131
9 z: A4 [, ?8 L& u0 V6 oROTATION ANGLE FOR WINDOW 1 IS -22.28 ABOUT AXIS ZS
6 ~/ ^" b. ]1 bPRODUCE ELEMENT PLOT IN DSYS = 0
, F. T- ?( `) h. E8 gDISTANCE MULTIPLIER FOR WINDOW 1 1.082* P# G5 _+ H: ], [3 u1 W
DISTANCE FOR WINDOW 1 539.71 h6 |, p- P9 P" @+ d( j
PRODUCE ELEMENT PLOT IN DSYS = 03 H# x+ R7 m, ?$ I- b% i
: n, D! v$ \& Z- u' w! E, M( z' dDISTANCE FOR WINDOW 1 584.0, Y9 i/ k4 L6 b7 ?6 H8 i. e
) |0 z/ j7 ]- f" RDISTANCE MULTIPLIER FOR WINDOW 1 1.082; a. l$ W1 M7 W r% _. f
1 M$ ~0 t, F. s( `+ Z2 RPRODUCE ELEMENT PLOT IN DSYS = 0
d6 R+ ^9 i, P' d4 {! }3 F- xDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
0 ~/ x# j4 s2 K! MDISTANCE FOR WINDOW 1 584.0" r) P3 s" e( k- H4 O0 o0 `
# k" ^* U8 c7 F7 }* b3 p) c. IDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
* a/ A9 Q4 {1 m2 c' i5 _DISTANCE FOR WINDOW 1 539.7
n) R- Y I; JPRODUCE ELEMENT PLOT IN DSYS = 0' e" k2 N9 i( y) G2 D# k
3 c: O9 M) {0 ^0 v! X$ r/ ZDISTANCE FOR WINDOW 1 498.6" Z+ @8 R9 f2 n3 s
% U6 e! k6 q: m9 UDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
2 x4 S/ S7 a6 r3 ^DISTANCE FOR WINDOW 1 460.8
- S4 C4 \1 o6 NPRODUCE ELEMENT PLOT IN DSYS = 05 ?8 Q4 [# {& Q; i3 O1 U
% p& E1 A2 e) N0 C- t+ h8 }1 F* S! iDISTANCE FOR WINDOW 1 425.8
S% x0 L9 m# m+ ~( uPRODUCE ELEMENT PLOT IN DSYS = 0
# ^- h. ]7 m- r' HDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
) v; F4 C- \, F; S/ e. p2 M. E- ]DISTANCE FOR WINDOW 1 393.4
7 v c; W4 `5 r( ?2 xPRODUCE ELEMENT PLOT IN DSYS = 0( }' f& q' T7 ]
) f! Y4 z8 g) s/ U: iDISTANCE FOR WINDOW 1 363.5
! w: a$ _% [6 ?3 ?3 G, N3 C, ]PRODUCE ELEMENT PLOT IN DSYS = 0
" U/ d2 L7 u! YDISTANCE MULTIPLIER FOR WINDOW 1 0.9240! ~5 x) R7 \( w- p
DISTANCE FOR WINDOW 1 335.98 V1 t- X f: Y8 _
PRODUCE ELEMENT PLOT IN DSYS = 0, s' U; E' _3 [, J
3 Q6 o# N9 C; kDISTANCE FOR WINDOW 1 310.4
3 {0 t! w; X& E uPRODUCE ELEMENT PLOT IN DSYS = 0
6 H5 F ?! @5 a3 t1 ^8 U& sDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
+ R9 n1 ]6 r: |! ~DISTANCE FOR WINDOW 1 286.8
. L' |# O* w E/ y9 D6 ]PRODUCE ELEMENT PLOT IN DSYS = 0
' L, a: ~' a/ b* r& j4 iDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
; E8 b' F1 l' q' ]3 zDISTANCE FOR WINDOW 1 265.0
H! s- k1 I2 T6 G5 qPRODUCE ELEMENT PLOT IN DSYS = 0
9 E* J2 u! `$ q+ I: |5 _DISTANCE MULTIPLIER FOR WINDOW 1 0.9240$ C) o0 P9 A+ ~* m7 H
DISTANCE FOR WINDOW 1 244.9 |3 c4 E |9 i8 R, h' z" W! [
* O% c8 T+ d& B0 b" e7 \$ T+ V' NDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
" \- k1 [6 t# hDISTANCE FOR WINDOW 1 226.39 P$ {. x/ R: r/ `7 {% |
8 y0 n& \% F& X& \* m0 g* bDISTANCE MULTIPLIER FOR WINDOW 1 0.9240* J; S6 U8 T/ R: o9 L
DISTANCE FOR WINDOW 1 209.11 a( y! b K7 ?' H
0 o7 q j) `( d5 L7 cDISTANCE MULTIPLIER FOR WINDOW 1 0.9240, t0 k" s4 D, m& e; Z! _
DISTANCE FOR WINDOW 1 193.2+ \9 l$ O% ~, r2 G7 w; [8 T
PRODUCE ELEMENT PLOT IN DSYS = 00 ~* E7 q" B# }2 ~# b! B! f5 D
DISTANCE MULTIPLIER FOR WINDOW 1 0.92407 D' P3 [2 T; }* Y" A
DISTANCE FOR WINDOW 1 178.5
; w+ y0 O% \! c; q# vPRODUCE ELEMENT PLOT IN DSYS = 0
1 r. N! J7 p4 s0 k# N/ O5 D6 zDISTANCE MULTIPLIER FOR WINDOW 1 0.92406 N7 B% K! C* _
DISTANCE FOR WINDOW 1 164.9
$ q2 z, M5 h* T1 S9 T# FPRODUCE ELEMENT PLOT IN DSYS = 05 f7 J4 V) n& ?5 F9 t3 b B
& C, t" [, O+ o9 CDISTANCE FOR WINDOW 1 152.4
( D! n T: r, qPRODUCE ELEMENT PLOT IN DSYS = 0
6 x; c, \3 ~6 m8 F: C9 MDISTANCE MULTIPLIER FOR WINDOW 1 0.9240
6 J3 O2 w. x, B% A: h5 n: Y( vDISTANCE FOR WINDOW 1 140.8
7 a/ p# w/ a7 Y5 qPRODUCE ELEMENT PLOT IN DSYS = 00 G$ U" d* Q5 Q$ v5 {
C2 A3 V0 j d' y2 e; T! yDISTANCE FOR WINDOW 1 130.1
6 y N6 {6 Q% [1 R1 ~! uPRODUCE ELEMENT PLOT IN DSYS = 0
. K5 l0 z9 M; N, v$ j3 j6 SDISTANCE MULTIPLIER FOR WINDOW 1 0.9240/ I( i! D- n4 p
DISTANCE FOR WINDOW 1 120.2, e( d; W: j6 E, Y5 Y& X7 I1 b8 _: t
PRODUCE ELEMENT PLOT IN DSYS = 0, b6 v# C6 t/ \5 h' R0 }
view point for window 1 -0.65020E-01 0.12625 0.98987
5 U& L5 j! j+ E6 O8 x. hROTATION ANGLE FOR WINDOW 1 IS -24.75 ABOUT AXIS ZS
* b& E4 ?% b- j. d. iPRODUCE ELEMENT PLOT IN DSYS = 0 |
