jnzc 发表于 2006-10-29 20:34:48
机械英语
<P>中间齿轮<BR>intermediate gear(counter gear)<BR>副轴齿轮<BR>counter shaft gear<BR>副轴<BR>counter shaft<BR>变速器输入轴<BR>transmission imput shaft<BR>变速器输出轴<BR>transmission output shaft<BR>变速器主动齿轮轴<BR>transmission drive gear shaft<BR>变速器主轴<BR>transmission main shaft<BR>变速器中间轴<BR>transmission countershaft<BR>变速器轴的刚度<BR>rigidity of shaft<BR>变速齿轮比(变速比)<BR>transmission gear ratio<BR>传动比<BR>gear ratio<BR>主压力<BR>line pressure<BR>调制压力<BR>modulated pressure<BR>真空调制压力<BR>vacuum modulator pressure<BR>速控压力<BR>governor pressure<BR>缓冲压力<BR>compensator or trimmer pressure<BR>限档压力<BR>hold presure<BR>前油泵<BR>front pump (input pump )<BR>液力传动装置充油压力<BR>hydrodynamic unit change pressure<BR>后油泵<BR>gear pump (output pump )<BR>回油泵<BR>scavenge oil pump<BR>调压阀<BR>pressure -regulator vavle<BR></P>
<P><SPAN class=tpc_content>变速轨(拨叉道轨)<BR>shift rail<BR>直接变速<BR>direct change(direct control)<BR>方向盘式变速<BR>column shift (handle change)<BR>按钮控制<BR>finger-tip control<BR>槽导变速<BR>gate change<BR>空档位置<BR>neutral position<BR>直接驱动<BR>direct drive<BR>高速档<BR>top gear(high gear)<BR>低速档<BR>bottom gear(low speed gear)<BR>第一档<BR>first gear<BR>第二档<BR>second gear<BR>超速档<BR>overdirve gear<BR>经济档<BR>economic gear<BR>倒档<BR>reverse gear<BR>爬行档<BR>creeper gear<BR>驱动特性<BR>drive performance<BR>反拖特性<BR>coast performance<BR>定输入扭矩特性<BR>constant input torque performance<BR>全油门特性<BR>full throttle performance<BR>寄生损失特性<BR>no load (parasitic losses)performance<BR>原始特性<BR>primary characteristic<BR>响应特性<BR>response characteristic</SPAN><BR></P>
<P><SPAN class=tpc_content>吸收特性<BR>absorption characteristic<BR>全特性<BR>total external characteristic<BR>输入特性<BR>characteristic of enhance<BR>输出特性<BR>characteristic of exit<BR>力矩特性<BR>torque factor(coefficient of moment)<BR>过载系数<BR>overloading ratio<BR>变矩系数<BR>torque ratio<BR>能容系数<BR>capacity factorr<BR>几何相似<BR>geometry similarity<BR>运动相似<BR>kinematic similarity<BR>动力相似<BR>dynamic similarity<BR>透穿性<BR>transparency<BR>万向节和传动轴<BR>universal joint and drive shaft<BR>万向节<BR>universal joint<BR>非等速万向节<BR>nonconstant velocity universal joint<BR>等速万向节<BR>constant velocity universal joint<BR>准等速万向节<BR>near constant velocity universal joint<BR>自承式万向节<BR>self-supporting universal joint<BR>非自承式万各节<BR>non self suporting universal joint<BR>回转直径<BR>swing diameter<BR>等速平面<BR>constant velocity plane<BR>万向节夹角<BR>true joint angle</SPAN><BR></P>
<P>&nbsp;</P>
wl6823245 发表于 2006-10-31 13:06:07
Re: 机械英语
谢谢楼主,一直在找!
查看完整版本: 机械英语
