中间齿轮 intermediate gear(counter gear) 副轴齿轮 counter shaft gear 副轴 counter shaft 变速器输入轴 transmission imput shaft 变速器输出轴 transmission output shaft 变速器主动齿轮轴 transmission drive gear shaft 变速器主轴 transmission main shaft 变速器中间轴 transmission countershaft 变速器轴的刚度 rigidity of shaft 变速齿轮比(变速比) transmission gear ratio 传动比 gear ratio 主压力 line pressure 调制压力 modulated pressure 真空调制压力 vacuum modulator pressure 速控压力 governor pressure 缓冲压力 compensator or trimmer pressure 限档压力 hold presure 前油泵 front pump (input pump ) 液力传动装置充油压力 hydrodynamic unit change pressure 后油泵 gear pump (output pump ) 回油泵 scavenge oil pump 调压阀 pressure -regulator vavle
1 Z, q+ T8 h) y: _
变速轨(拨叉道轨) shift rail 直接变速 direct change(direct control) 方向盘式变速 column shift (handle change) 按钮控制 finger-tip control 槽导变速 gate change 空档位置 neutral position 直接驱动 direct drive 高速档 top gear(high gear) 低速档 bottom gear(low speed gear) 第一档 first gear 第二档 second gear 超速档 overdirve gear 经济档 economic gear 倒档 reverse gear 爬行档 creeper gear 驱动特性 drive performance 反拖特性 coast performance 定输入扭矩特性 constant input torque performance 全油门特性 full throttle performance 寄生损失特性 no load (parasitic losses)performance 原始特性 primary characteristic 响应特性 response characteristic
. i0 |+ p/ I8 ]% x0 h+ \2 g# B吸收特性 absorption characteristic 全特性 total external characteristic 输入特性 characteristic of enhance 输出特性 characteristic of exit 力矩特性 torque factor(coefficient of moment) 过载系数 overloading ratio 变矩系数 torque ratio 能容系数 capacity factorr 几何相似 geometry similarity 运动相似 kinematic similarity 动力相似 dynamic similarity 透穿性 transparency 万向节和传动轴 universal joint and drive shaft 万向节 universal joint 非等速万向节 nonconstant velocity universal joint 等速万向节 constant velocity universal joint 准等速万向节 near constant velocity universal joint 自承式万向节 self-supporting universal joint 非自承式万各节 non self suporting universal joint 回转直径 swing diameter 等速平面 constant velocity plane 万向节夹角 true joint angle
7 t" h/ b" u2 J# ]3 K6 N0 a
