LED 环型光源LED Light Source
LED 环型光源LED Light Source功能Feature无闪烁 No Flash节能省电 Save Power超长20,000小时使用寿命 Super Long Life 20,000hrs光源亮度可调 0~100%Adjustable Light Intensity0~100%色温不变 Constant color temperature低发热量 Low Heat规格 Specification输入电压 Input Voltage AC100~240V输入电压频率 Input Power Frequency 50/60Hz输入功率 Input Power 4W输出电流 Output Current 180mA输出电流控制方式 Output Type 直流定电流控制方式DC Lighting Type光源亮度可调范围 Light Intensity Adjustable0~100%LED光色 LED Color白色及其它光色可选White or Other Light ColorLED寿命LED Life 20,000小时 20,000hrs工作距离 Working Distance 55~160mm工作环境温湿度 Temperature and Humidity 0~45℃/16~85%RH工作内径 Ring Diameter Inside MaxФ61mm外形尺寸(mm) Dimension(mm)外径Ф95x高x29x长125.5重量(g) Weight 100g备注: 尺寸及重量不包括外露部分(如电源), LED寿命会因使用环境不同而改变.
Remarks: Dimension or weight not included the expose parts(such as: power adaptor), LED’s life can be influenced by the environmental temperature.多种光色及亮度选配Various light color and light intensity may choose白光LED/高亮度白光LED/白光(偏蓝)LED/白光(偏黄)LED/紫外光LED/红外光LED/蓝光LED/绿光LED/黄光LED
White LED/High Luminosity White LED/ White LED (Share Blue)LED/ White LED (Share yellow)LED/Ultra violet-LED/Infrared Rays LED/ Blue LED/Green LED/ yellow LED Light Source
