查看: 2771|回复: 0
LED 环型光源LED Light Source
发表于 2010-7-21 11:34:31 | 显示全部楼层 |阅读模式
LED 环型光源LED Light Source功能Feature无闪烁   No Flash节能省电   Save Power超长20,000小时使用寿命   Super Long Life 20,000hrs光源亮度可调   0~100%Adjustable Light Intensity0~100%色温不变    Constant color temperature低发热量   Low Heat
5 u/ M0 s- M$ X6 D4 }规格   Specification输入电压   Input Voltage AC100~240V输入电压频率   Input Power Frequency 50/60Hz输入功率   Input Power 4W输出电流   Output Current 180mA输出电流控制方式   Output Type 直流定电流控制方式  DC Lighting Type光源亮度可调范围    Light Intensity Adjustable  0~100%LED光色     LED Color  白色及其它光色可选  White or Other Light ColorLED寿命  LED Life 20,000小时   20,000hrs工作距离   Working Distance 55~160mm工作环境温湿度   Temperature and Humidity 0~45℃/16~85%RH工作内径   Ring Diameter Inside    MaxФ61mm外形尺寸(mm)   Dimension(mm)  外径Ф95x高x29x长125.5  重量(g)   Weight 100g备注: 尺寸及重量不包括外露部分(如电源), LED寿命会因使用环境不同而改变., O9 R9 e2 O% R  ^" X. {
Remarks: Dimension or weight not included the expose parts(such as: power adaptor), LED’s life can be influenced by the environmental temperature.多种光色及亮度选配Various light color and light intensity may choose白光LED/高亮度白光LED/白光(偏蓝)LED/白光(偏黄)LED/紫外光LED/红外光LED/蓝光LED/绿光LED/黄光LED
6 N/ j- u# x4 M0 \: N8 aWhite LED/High Luminosity White LED/ White LED (Share Blue)LED/ White LED (Share yellow)LED/Ultra violet-LED/Infrared Rays LED/ Blue LED/Green LED/ yellow LED Light Source
GMT+8, 2025-2-23 07:05 , Processed in 0.055637 second(s), 16 queries , Gzip On.
