wingman1985 发表于 2010-1-26 13:53:03
齿轮表面处理里面是否有“闪镀铜”一说?
http://www.jxcad.com.cn/read.php?tid-1060152.html
上面是原帖子地址,下面是各位朋友的解答。请求大家帮忙。
顶楼:What's the meaning of "copper flash finish"?
          Please kindly help me translate the surface treatment of the gears, "copper flash finish".
Thank you in advance.
二楼:根据字面的理解应该是表面镀铜;I think
再提供一点讯息:Our products are supplied in various finishedlikeBluing,Blackening, Zinc, Copper, Nickel, Chromes & CadmiumPlating,as perthe requirements of our customers.
Forprotectionagainstcorrosion, zinc plated finish is available as astandardextra.Passivation is a surface treatment which further improvesthecorrosionresistance of the plated film but because of itsyellowirridescentfinish may not be suitable for some decorativeapplications.For decorative effect a copper flash finish may be applied
是铜的溅射喷镀(表面)处理
三楼: 闪镀 flash(flash plate) 电时间极短产生薄层的电镀。
按上述,可否理解为闪镀铜
查看完整版本: 齿轮表面处理里面是否有“闪镀铜”一说?
