查看: 2465|回复: 0
齿轮表面处理里面是否有“闪镀铜”一说?
发表于 2010-1-26 13:53:03 | 显示全部楼层 |阅读模式
http://www.jxcad.com.cn/read.php?tid-1060152.html5 Q0 t* G$ R9 Y- a9 y" V- Y
! H" ^; K# f! ^( E- l# _" x8 ~) Q" u8 @$ q" i
上面是原帖子地址,下面是各位朋友的解答。请求大家帮忙。
: }1 G1 d3 O  E! R" \) C; s/ X! @) `7 Q) o0 {& M/ @! H
顶楼:What's the meaning of "copper flash finish"?
4 g! {, B. o" c; X          Please kindly help me translate the surface treatment of the gears, "copper flash finish".9 A% t" J2 Q8 L5 C- H
Thank you in advance.
4 q) @- N" M0 J) {  ]4 ~3 n, ]) h4 g- U$ |
  S: B% B4 d- y1 ^5 p0 C3 O
二楼:根据字面的理解应该是表面镀铜;I think& k* }) O# v, x& o. v. e
$ {/ s* t1 m- n0 r. s4 Z. x* I
再提供一点讯息:Our products are supplied in various finishedlikeBluing,Blackening, Zinc, Copper, Nickel, Chromes & CadmiumPlating,as perthe requirements of our customers.: w& H& Y) Q: P5 V
& D9 m4 W5 [/ ~5 u; K  R* {6 z9 _$ c
Forprotectionagainstcorrosion, zinc plated finish is available as astandardextra.Passivation is a surface treatment which further improvesthecorrosionresistance of the plated film but because of itsyellowirridescentfinish may not be suitable for some decorativeapplications.For decorative effect a copper flash finish may be applied2 x. c# k! |4 V1 i# P) N5 e
8 f* x# G8 Z4 i5 q. [1 U
是铜的溅射喷镀(表面)处理$ G) N/ m( L/ Z5 w8 h/ x9 z8 p4 i( q
# `& P* H; E% L4 v  e# N三楼 闪镀 flash(flash plate) 电时间极短产生薄层的电镀。7 B- ?# h9 Y, n% m8 z% l* Y3 u1 ^
按上述,可否理解为闪镀铜" h! y+ w( a6 S& U
GMT+8, 2025-7-12 14:54 , Processed in 0.070652 second(s), 14 queries , Gzip On.
