重命名零件和工程图(图纸升版本)
在论坛看到大佬 怕瓦落地2011 的帖子http://www.cmiw.cn/thread-1061682-1-1.html代码:Dim swApp As Object
Dim Part As Object
Dim Error As Long
Dim Warning As Long
Dim mip As String
Dim Status As Boolean
Dim Newpath As String
Dim mipname As String
Dim vDepend() As String
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set swSelMgr = Part.SelectionManager
Set swComp = swSelMgr.GetSelectedObjectsComponent4(1, 0)
swComp.SetSuppression2 (3)
Set swSelModel = swComp.GetModelDoc2
Set swSelModelext = swSelModel.Extension
oldpathname = swComp.GetPathName
Path = Left(oldpathname, InStrRev(oldpathname, "\")) '路径
Debug.Print Path
ntype = Mid(oldpathname, InStrRev(oldpathname, ".")) '后缀
Debug.Print ntype
oldfi = Mid(oldpathname, InStrRev(oldpathname, "\") + 1) '旧文件名
Debug.Print oldfi
oldname = Left(oldfi, InStrRev(oldfi, ".") - 1)
mipname = InputBox("changename", "name", oldname) '新文件名
mip = Path & mipname & ntype '新文件名带路径
Debug.Print mip
If mip <> "" Then
Status = swSelModelext.SaveAs3(mip, 0, 512, Nothing, Nothing, Error, Warning) '更改零件文件名(替换装配体中的原文件)
Debug.Print Status
'更改工程图文件名
Debug.Print Path
tmpfi = Dir(Path & "*.SLDDRW") '遍历原文件夹中的工程图文件
Debug.Print tmpfi
Do Until tmpfi = Null
tmpfiname = Mid(tmpfi, InStrRev(tmpfi, "\") + 1)
Debug.Print tmpfiname
tmpoldname = Mid(oldfi, 1, InStr(1, oldfi, ".") - 1) & ".SLDDRW"
Debug.Print tmpoldname
If tmpfiname = tmpoldname Then '查找同名工程图
newdrwname = Path & mipname & ".SLDDRW"
Debug.Print newdrwname
olddrwname = Path & tmpfi
FileCopy olddrwname, newdrwname '复制工程图到新文件夹
vDepend = swApp.GetDocumentDependencies2(Path & tmpfi, False, False, False) '查找工程图依赖
Debug.Print vDepend(1)
bl = swApp.ReplaceReferencedDocument(newdrwname, vDepend(1), mip) '替换工程图依赖
Debug.Print bl
Exit Do
End If
tmpfi = Dir
Debug.Print tmpfi
Loop
End If
End Sub
试了下这个宏(本人用的SW2018)报错:
对象不支持这个属性或方法(错误 438)
Status = swSelModelext.SaveAs3(mip, 0, 512, Nothing, Nothing, Error, Warning)'更改零件文件名(替换装配体中的原文件)
有哪位大佬能帮解答一下吗?是不是SaceAs3语句的问题?
以下方法说明,请自行测试:
'Usage
IModelDocExtension.SaveAs3(Name, Version, Options, ExportData, AdvancedSaveAsOptions, Errors, Warnings)
'Func Declaration
Function SaveAs3( _
ByVal Name As System.String, _
ByVal Version As System.Integer, _
ByVal Options As System.Integer, _
ByVal ExportData As System.Object, _
ByVal AdvancedSaveAsOptions As System.Object, _
ByRef Errors As System.Integer, _
ByRef Warnings As System.Integer _
) As System.Boolean
Parameters
Name
Full pathname of the document to save; the file extension indicates any conversion that should be performed (for example, Part1.igs to save in IGES format) (see Remarks)
Version
Format in which to save this document as defined in swSaveAsVersion_e (see Remarks)
Options
Option indicating how to save the document as defined in swSaveAsOptions_e (see Remarks)
ExportData
IExportPdfData object for exporting drawing sheets to PDF (see Remarks)
IAdvancedSaveAsOptions (see Remarks)
Errors
Errors that caused the save to fail as defined in swFileSaveError_e (see Remarks)
Warnings
Warnings or extra information generated during the save operation as defined in swFileSaveWarning_e (see Remarks)
Return Value
True if the save is successful, false if not
内容摘自apihelp.chm(通常存于 xxx\SOLIDWORKS Corp\SOLIDWORKS\api\ )
拿去
Status = swSelModelext.SaveAs2(mip, 0, 512, Nothing, "", False, Error, Warning) '更改零件文件名(替换装配体中的原文件)
拿去,不用谢
