查看: 1187|回复: 1
重命名零件和工程图(图纸升版本)
发表于 2024-4-9 20:55:08 | 显示全部楼层 |阅读模式
在论坛看到大佬 怕瓦落地2011 的帖子http://www.cmiw.cn/thread-1061682-1-1.html
. @" N- _7 c( P  F6 e代码:
  1. Dim swApp As Object
    $ Y$ a" f; y' k. B) b' l$ G
  2.   Dim Part As Object
    $ K" w, `: s4 W: ~1 Q
  3.   Dim Error As Long, `, q3 P1 {4 U7 x4 @, g1 P
  4. Dim Warning As Long
    ) H* K4 ?6 u$ H' ^
  5. Dim mip As String$ ^3 R8 m$ z; |; R' y8 U
  6. Dim Status As Boolean  p* O& j0 y, \
  7. Dim Newpath As String
    % O) Z" j/ y; R8 p: w, z: f8 r( G
  8. Dim mipname As String
    - T1 R6 s, X& ?& g7 U' }
  9. Dim vDepend() As String
    % ~* x( V) G9 `% w- U" b" Z
  10.     Sub main()2 Z, g+ ?% v- @2 f" Z0 H' U1 X
  11.     Set swApp = Application.SldWorks
    ' |: z8 f7 F, A; y8 \& _. q. Y
  12.     Set Part = swApp.ActiveDoc  l+ t) g4 [4 }/ M
  13.     Set swSelMgr = Part.SelectionManager4 T: b$ u4 h" ~9 S! }; y2 ]" z0 ]
  14.     Set swComp = swSelMgr.GetSelectedObjectsComponent4(1, 0)
    3 j0 E+ @( z4 T" ]
  15.         swComp.SetSuppression2 (3)
    ) q+ X! Y3 X& ]5 B) ?/ k/ R* \" A
  16.     Set swSelModel = swComp.GetModelDoc2
    & b% Y! ^7 I% S6 N8 t1 X8 C+ H: m
  17.     Set swSelModelext = swSelModel.Extension
    ( T- M. R; z5 F7 z4 `( j; \
  18. ' Q5 G! s7 [0 F8 m/ g2 Z" r4 D
  19.     oldpathname = swComp.GetPathName
    0 L0 ]' Z/ ?, x' y  p6 p9 c
  20. 9 N7 E* K" j; K/ U" j* E! o1 D
  21.     Path = Left(oldpathname, InStrRev(oldpathname, "")) '路径
    9 R& Y; e; T' ^0 g
  22.     Debug.Print Path
    0 G5 P  v% I, F" G
  23.     ntype = Mid(oldpathname, InStrRev(oldpathname, ".")) '后缀
    ( F0 S( Y# r/ P" f0 J
  24.     Debug.Print ntype
    ) y7 ~: `6 T* |1 t
  25.     oldfi = Mid(oldpathname, InStrRev(oldpathname, "") + 1) '旧文件名  Z9 V3 L2 W/ E& }4 c7 m, L& v
  26.     Debug.Print oldfi" p" `; ^% T9 ~* B2 z
  27.     oldname = Left(oldfi, InStrRev(oldfi, ".") - 1)2 Y8 K# T& t! t6 o; J' X% A
  28.          mipname = InputBox("changename", "name", oldname) '新文件名
    1 n6 R  V+ q6 \1 i
  29. & B% D2 v) w- l! d" r
  30.          mip = Path & mipname & ntype '新文件名带路径' h" }5 N! K; w, n, V7 a$ f
  31.          Debug.Print mip; I+ F  F9 J' y
  32. # P3 G+ X8 r$ w. u7 ^4 ?6 e
  33.     If mip <> "" Then. w, I: I. [! X, d# y' Q" V) \
  34.          Status = swSelModelext.SaveAs3(mip, 0, 512, Nothing, Nothing, Error, Warning) '更改零件文件名(替换装配体中的原文件)8 e9 a0 J9 Y4 i$ S( K
  35.       Debug.Print Status
      a9 E' X& [  v+ v9 t1 [5 v1 ~" d6 V
  36.       '========================* N8 V+ B) u( n1 l/ i- e- K
  37.       '更改工程图文件名
    & `) O2 V$ @! x7 v1 \% m* `9 i
  38.       Debug.Print Path' r: s$ h( c! ^1 T3 _8 S) W
  39.       tmpfi = Dir(Path & "*.SLDDRW") '遍历原文件夹中的工程图文件4 o! y* {  J0 t1 r
  40.       Debug.Print tmpfi
    $ U/ D' z7 ], a2 T% D; w9 C
  41.       Do Until tmpfi = Null; t8 h3 e' E" _! y
  42.         tmpfiname = Mid(tmpfi, InStrRev(tmpfi, "") + 1)  W  s# F( J6 t# b8 k2 d
  43.         Debug.Print tmpfiname
    ! f- ~3 T& I6 \  T
  44.         tmpoldname = Mid(oldfi, 1, InStr(1, oldfi, ".") - 1) & ".SLDDRW"! I/ k# D: ]2 G+ Y
  45.         Debug.Print tmpoldname
    8 @& d9 ]2 B9 T& [% G4 i
  46.         If tmpfiname = tmpoldname Then '查找同名工程图
    9 V8 {  d1 L+ Y" g3 g! G
  47.         newdrwname = Path & mipname & ".SLDDRW"
    - q, t; J0 j7 ?4 G1 i6 N4 w9 ^
  48.         Debug.Print newdrwname
    1 ~3 D: R2 v0 A' C" y5 S
  49.         olddrwname = Path & tmpfi' L8 W& p! V0 f
  50.         FileCopy olddrwname, newdrwname '复制工程图到新文件夹1 R4 B( L6 U. y: q; c  n- C
  51.         vDepend = swApp.GetDocumentDependencies2(Path & tmpfi, False, False, False) '查找工程图依赖4 |% G! c" a5 j4 o
  52. 0 ~' W8 [" d! L" F, ?8 t
  53.         Debug.Print vDepend(1); n% t7 ~! t6 @0 I. y2 J: L4 o
  54.         bl = swApp.ReplaceReferencedDocument(newdrwname, vDepend(1), mip) '替换工程图依赖; Z1 e0 G" `7 q  G( Y0 P: O9 ]- f
  55.   l' t, \/ h+ A! b; w
  56.         Debug.Print bl7 z! L8 Z  |' U6 u! r# v
  57.          Exit Do, e( ^! _# b+ T8 z
  58.        End If
    ' i5 V6 o" n9 g, ?5 t/ [
  59.     tmpfi = Dir
    0 }( |3 w* U4 B8 B8 ?" w
  60.     Debug.Print tmpfi
    + t8 q8 [$ h3 F+ K% V, j
  61.     Loop
    ' @4 O. Z% n% U8 X  W  B) y; c
  62.     End If
    ! e, d6 b$ a0 ]( |" V$ B
  63.     End Sub- C8 W6 z' ]# w# ]
复制代码
6 `* \- \* c* y8 h8 r- S8 t试了下这个宏(本人用的SW2018)报错:: S) P2 x% F5 }
对象不支持这个属性或方法(错误 438)  G# i% o5 M8 ^" t! e; k7 q) l
+ m$ c: l. G) \: q( S有哪位大佬能帮解答一下吗?是不是SaceAs3语句的问题?
1 i, [, {$ o2 E+ o& S$ F0 v! b- u% \! x; S% ^9 V; s/ {
发表于 2024-4-10 09:40:15 | 显示全部楼层
以下方法说明,请自行测试:
8 \+ Z0 B) k6 M7 ]# Z& M) K
3 N# {' e$ M% L$ n'Usage
" z2 Z1 U+ s9 MIModelDocExtension.SaveAs3(Name, Version, Options, ExportData, AdvancedSaveAsOptions, Errors, Warnings); H4 D  `1 S8 z: H
+ {1 Z: P0 X4 n) a9 \/ P4 p' f  Z3 u* y& \" Z3 n6 S) Z- |
'Func Declaration) b1 z% b( k3 Q, J
Function SaveAs3( _  l! Q8 P2 \+ E( V
   ByVal Name As System.String, _
9 S: G6 y5 P, S   ByVal Version As System.Integer, _  e) ]% F% O: s# t( J4 q$ E( q
   ByVal Options As System.Integer, _3 i5 b( J" G+ C' `. Z
   ByVal ExportData As System.Object, _
2 ~( k3 P0 w' C, S   ByVal AdvancedSaveAsOptions As System.Object, _# Q8 n; @# r$ [2 F/ a* X" f9 V
   ByRef Errors As System.Integer, _0 p# {6 Z# ~* J: X9 V: B
   ByRef Warnings As System.Integer _
+ e. C& e' r. ?, d8 V3 b- Q) As System.Boolean4 j2 |+ f- ]: z) }0 D& G
; S, b7 M* J4 z3 ]+ \
Parameters2 |  ^6 M. u$ X! |0 }- d
    Name * Y- e6 h  J7 H) D7 ~) x( n
        Full pathname of the document to save; the file extension indicates any conversion that should be performed (for example, Part1.igs to save in IGES format) (see Remarks)  J2 ~& ~& N( e0 v8 J
    Version + P: l1 e. @$ d2 K$ S7 q
        Format in which to save this document as defined in swSaveAsVersion_e (see Remarks)
1 F! T# Q! {! |$ T3 \: X    Options 5 d" K/ ?- S0 K5 f- r, U( O: d; s
        Option indicating how to save the document as defined in swSaveAsOptions_e (see Remarks)+ q6 L5 @& N# s; \4 d
    ExportData
/ k3 O! L" O; U0 B/ i- Q        IExportPdfData object for exporting drawing sheets to PDF (see Remarks), W3 E" S" C/ A; a- L  U
. v. s  ?" K* B7 g        IAdvancedSaveAsOptions (see Remarks)" I: a* M  _! a
    Errors 5 ~0 A; _0 E4 r0 L* r
        Errors that caused the save to fail as defined in swFileSaveError_e (see Remarks), n: b9 B+ p  `. s( D# @8 v
    Warnings : c/ `% v) y7 [, p7 y9 n
        Warnings or extra information generated during the save operation as defined in swFileSaveWarning_e (see Remarks)
: d. G- L# \; R2 I7 g' |Return Value- c6 z+ D) k' l
    True if the save is successful, false if not' T& ?0 u9 h  U: q" t3 c
, q7 r4 V7 P$ n+ p7 V. H9 P+ O# P7 j, z) C% Q2 F8 X
内容摘自apihelp.chm(通常存于 xxx\SOLIDWORKS Corp\SOLIDWORKS\api\ )
; i! p4 P: J/ _7 b
9 \( ?0 l' j/ N, L% Q- m' k5 Y% N, M1 a/ c
) S3 H4 d. k9 w/ |+ ]& D. [' \' ?+ E: p" E
GMT+8, 2025-2-24 06:24 , Processed in 0.076182 second(s), 15 queries , Gzip On.
