张海青 发表于 2009-3-4 00:01:20
英文文献,帮忙翻译一下~感激不尽,在线等~~
完整文献在附件里,诚盼各位好心人士的回复~~~~The economic assessment of process control quality using a
                                                Taguchi-based method                                                 R. Di Mascioa,*, G.W. Bartonb aSchool of Quantitative Business Methods and Operations, University of Western Sydney, PO Box 10, Kingswood NSW 2747, AustraliabDepartment of Chemical Engineering, University of Sydney, Sydney NSW 2006, Australia
Received 17 August 1999; received in revised form 5 November 1999; accepted 22 November 1999
Abstract
   This paper derives a measure of dynamic control quality within the Taguchi framework (G. Taguchi, E.A. Elsayed, T. Hsiang, Quality Engineering in Production Systems, McGraw-Hill, New York, 1989) which estimates product quality (in economic terms) by the losses incurred when specified product characteristics depart from their nominal values. In this sense, a control system may beviewedasa‘‘product’’withstabilityandperformancepropertiesasitsrequiredcharacteristics.Thedegreetowhichsystem inputs and outputs depart from their nominal values is used to give an estimate of stability and performance quality, respectively. Displaying control quality graphically with stability and performance qualities as the two axes can be used to highlight the trade-o betweenthesetwo characteristics.Thistechniquewasusedtoevaluatethequalityoeredbyfourmodel-basedcontrollersona distillation column model responding to a typical disturbance, and how the presence of measurement and valve dynamics aected control quality. It is anticipated that the measures derived in this paper (being both time-based and economic) may prove useful in conveying control quality in a common language understood by engineers, operators and management.   2000 Elsevier Science
Ltd. All rights reserved.
Keywords: Taguchi; Process economics; Control quality; Stability; Performance
1.Introduction        Thechiefrequirementsofapracticalcontrolsystem
        are that it should have good stability and performance
   A product is normally considered to be of acceptable                      properties.   Hence,    these   willbe   treated    here   asthe
quality if its characteristics lie within specification limits               ‘‘characteristics’’ofaprocesscontrolsystem.Awide
set by the customer. Techniques such as statistical pro-                     variety    ofmeasures   have    already    been   developed   to
cesscontrolarecommonlyusedinmanufacturing                  quantify these characteristics. These include time-based
industriestoensurethatkeyprocessvariables—and                measures      (such   asrise-time,    overshoot   and   integral-
henceproductcharacteristics—remainwithinrange.                  square error), frequency-domain measures (such as sin-
However, analternativeapproachtoqualitycontrolis                  gular value analysis and operator-based methods) [4–
based on the work of Taguchi et al. . This approach is                     6]. All these methods — explicitly or implicitly — assign
built around the simple premise that a product has the                        anidealvalueforthecharacteristictheyaretryingto
‘‘best’’ quality when all its characteristics are exactly at               measure, and the closerthe actual value is to the ideal
theirspecified   values,   and   quality    lossesoccur    when         value, the better that system characteristic. In this sense,
these characteristics move away from these values even                     they conform to Taguchi’s quality approach.
iftheyremainwithinspecification.Thispaperapplies                   One    of   themajor   attractions    ofa   Taguchi-based
the Taguchi approach to gauge the ‘‘quality’’ of a pro-                      measure is that it can quantify control quality in economic
cesscontrolsystembytheextenttowhichits‘‘char-            terms. The general framework was originally appliedto
acteristics’’ deviate from desired values.                                    assess the design quality of manufactured products, but
        hassincebeenusedtomeasurethequalityofmanu-
*Corresponding author. Tel.: +61-2-9632-2381; fax: +61-2-9632-         facturing processes and computer software . It has
2381.        been applied to the problem of controller tuning but
梦回书香 发表于 2009-3-10 08:45:08
下面的是我用然间翻译的,仅供参考!
krin 发表于 2009-3-10 11:33:50
让别人全文翻译的行为不太赞同哦,如果中间有些句子拿捏不准可以提出来大家讨论,这样对自己对大家才有提高嘛:)
梦回书香 发表于 2009-3-10 21:56:00
回复 3# krin 的帖子
呵呵,是啊是啊,我是用工具翻译的,没怎么动脑袋。
一定积极参加对这篇文章的讨论:handshake
张海青 发表于 2009-3-17 19:14:27
谢谢各位好心人士的提醒了,其实我有翻译的,可是翻得太烂了,不好意思拿出来~~~~
张海青 发表于 2009-3-17 19:18:21
我先自己看下,到时再请教各位大侠~~
wz10340119 发表于 2009-5-5 14:02:11
ddddddddddd
leoliu26 发表于 2009-5-6 12:51:00
2# 梦回书香
是啊,这样长篇大论不太好啊!
机械翻译99 发表于 2009-5-21 10:14:40
可以帮你翻译,发到我油箱
stonesxiaolei 发表于 2009-12-5 18:40:09
连文本都没怎么整理,就让别人翻译,没诚意,鄙视
查看完整版本: 英文文献,帮忙翻译一下~感激不尽,在线等~~
