查看: 6231|回复: 12
英文文献,帮忙翻译一下~感激不尽,在线等~~
发表于 2009-3-4 00:01:20 | 显示全部楼层 |阅读模式
完整文献在附件里,诚盼各位好心人士的回复~~~~
The economic assessment of process control quality using a 0 A# m( F2 Q# f2 ]& ?+ u* `$ E
                                                  Taguchi-based method
                                                R. Di Mascioa,*, G.W. Bartonb aSchool of Quantitative Business Methods and Operations, University of Western Sydney, PO Box 10, Kingswood NSW 2747, Australia  bDepartment of Chemical Engineering, University of Sydney, Sydney NSW 2006, Australia
% b# X2 F9 J) G7 U% m
Received 17 August 1999; received in revised form 5 November 1999; accepted 22 November 1999
; [8 m! S$ f: E1 O  O5 B. ]1 `; M9 V, v$ Y) c) M
Abstract
/ Y" H, D: e* [$ @& k   This paper derives a measure of dynamic control quality within the Taguchi framework (G. Taguchi, E.A. Elsayed, T. Hsiang, Quality Engineering in Production Systems, McGraw-Hill, New York, 1989) which estimates product quality (in economic terms) by the losses incurred when specified product characteristics depart from their nominal values. In this sense, a control system may be  viewed  as  a  ‘‘product’’  with  stability  and  performance  properties  as  its  required  characteristics.  The  degree  to  which  system inputs and outputs depart from their nominal values is used to give an estimate of stability and performance quality, respectively. Displaying control quality graphically with stability and performance qualities as the two axes can be used to highlight the trade-o between  these  two characteristics.  This  technique  was  used  to  evaluate  the  quality  oered  by  four  model-based  controllers  on  a distillation column model responding to a typical disturbance, and how the presence of measurement and valve dynamics aected control quality. It is anticipated that the measures derived in this paper (being both time-based and economic) may prove useful in conveying control quality in a common language understood by engineers, operators and management.   2000 Elsevier Science
- e7 I- p& s: X4 n, ?Ltd. All rights reserved.
6 h. y$ A+ g; W+ b
, I5 V- T# E# Y+ Q# i3 m) U: E. |Keywords: Taguchi; Process economics; Control quality; Stability; Performance
* |% q6 W" p, }! ?4 m, M7 l) Z# b' e! m& |4 h
1.  Introduction        The  chief  requirements  of  a  practical  control  system
/ D$ L- v4 l: g* ?( z+ \        are that it should have good stability and performance & R- H4 \; p" _! ~2 b7 X1 I
   A product is normally considered to be of acceptable                      properties.     Hence,    these   will  be   treated    here   as  the
! d& J" m( c! p# O- Xquality if its characteristics lie within specification limits                 ‘‘characteristics’’  of  a  process  control  system.  A  wide : v8 I  ?8 t5 t+ W% k& _# Y
set by the customer. Techniques such as statistical pro-                     variety    of  measures     have    already    been   developed     to & a$ d* L  k" M9 n% _
cess  control  [1]  are  commonly  used  in  manufacturing                    quantify these characteristics. These include time-based
0 ]: S' i8 s: s. p0 Findustries  to  ensure  that  key  process  variables  —  and                measures      (such   as  rise-time,    overshoot     and   integral-
, I, ^# C, r' F2 f) |; u( p( T  ^2 Khence  product  characteristics  —  remain  within  range.                    square error), frequency-domain measures (such as sin- + u5 M. o5 j7 G4 M
However, an  alternative  approach  to  quality  control  is                  gular value analysis [3] and operator-based methods) [4– : @4 i3 A! f- q9 I
based on the work of Taguchi et al. [2]. This approach is                     6]. All these methods — explicitly or implicitly — assign ; u2 j8 x' f1 M" S9 z$ W
built around the simple premise that a product has the                        an  ideal  value  for  the  characteristic  they  are  trying  to 7 K; z# j" `  d1 k4 E* M( |
‘‘best’’ quality when all its characteristics are exactly at                 measure, and the closer  the actual value is to the ideal 6 G% c! b5 ~* f
their  specified     values,   and   quality    losses  occur    when         value, the better that system characteristic. In this sense,
" C4 m* A7 b7 G4 }1 M0 u5 uthese characteristics move away from these values even                       they conform to Taguchi’s quality approach.
4 j$ I; H) I4 |# Z& wif  they  remain  within  specification.  This  paper  applies                   One    of   the  major     attractions    of  a   Taguchi-based * R# x% W+ C  E6 r2 F, ~
the Taguchi approach to gauge the ‘‘quality’’ of a pro-                      measure is that it can quantify control quality in economic
" h; A8 Y" A3 p# m6 ]# rcess  control  system  by  the  extent  to  which  its  ‘‘char-              terms. The general framework was originally applied  to
4 Y& z! I4 B7 d( ^$ vacteristics’’ deviate from desired values.                                    assess the design quality of manufactured products, but
/ g/ M+ }' _1 J/ C8 C        has  since  been  used  to  measure  the  quality  of  manu-
0 ^9 G# x" @2 @1 r" r4 ?  *  Corresponding author. Tel.: +61-2-9632-2381; fax: +61-2-9632-           facturing processes [7] and computer software [8]. It has # b- U$ n  \( a8 t7 h9 N
2381.        been applied to the problem of controller tuning [9] but
您需要 登录 才可以下载或查看,没有账号?注册会员
发表于 2009-3-10 08:45:08 | 显示全部楼层
下面的是我用然间翻译的,仅供参考!
发表于 2009-3-10 11:33:50 | 显示全部楼层
让别人全文翻译的行为不太赞同哦,如果中间有些句子拿捏不准可以提出来大家讨论,这样对自己对大家才有提高嘛
发表于 2009-3-10 21:56:00 | 显示全部楼层
回复 3# krin 的帖子
呵呵,是啊是啊,我是用工具翻译的,没怎么动脑袋。
7 K$ ?% W* N* @  K+ H5 ^' t5 G一定积极参加对这篇文章的讨论
 楼主| 发表于 2009-3-17 19:14:27 | 显示全部楼层
谢谢各位好心人士的提醒了,其实我有翻译的,可是翻得太烂了,不好意思拿出来~~~~
 楼主| 发表于 2009-3-17 19:18:21 | 显示全部楼层
我先自己看下,到时再请教各位大侠~~
发表于 2009-5-5 14:02:11 | 显示全部楼层
ddddddddddd
发表于 2009-5-6 12:51:00 | 显示全部楼层
2# 梦回书香 5 N& [. K0 t/ v) A$ e& Z( s/ q
是啊,这样长篇大论不太好啊!
发表于 2009-5-21 10:14:40 | 显示全部楼层
可以帮你翻译,发到我油箱
发表于 2009-12-5 18:40:09 | 显示全部楼层
连文本都没怎么整理,就让别人翻译,没诚意,鄙视
GMT+8, 2025-10-17 11:52 , Processed in 0.094680 second(s), 17 queries , Gzip On.
