amsler 发表于 2009-2-23 13:46:34
Series TTM® 100 - 3000 kN
TTM® Tensile Testing Machine is a registered trademark of walter+bai ag Testing Machines.The Series TTM testing machines are “state-of-the-art”, rugged and durable designed especially suitable for high capacity testing of round, flat and profile specimens meeting the needs of the metal, aerospace, automotive and fastern industries.The economic solution mainly in the field of higher and highest capacity testing.
Servohydraulic Universal Testing MachinesThe Series TTM testing machines with its single test space designed for tension, compression, bend and folding, shear and static cyclic testing is specifically suitable for testing of metals-(wire, rod, tube, strip, plate, strip), fasteners (tensile, proof, single and double shear), construction materials (reinforcement bar, wire, mesh, folding, compression of concrete) and components. All models of the Series TTM feature a rigid load frame either in two- or four-column construction for minimum maintenance and low reaction at specimens failure. The servo-actuator, which is integrated in the upper crosshead with a long piston stroke makes testing space accessible for easy and efficient testing of different samples lengths. The high precision load cell is located between base platen and lower grip, providing high accuracy test after test. The servoactuator, which is integrated in the upper crosshead, has a long piston stroke which makes testing space accessible for easy and efficient testing of different samples lengths. The long piston stroke meets the extreme requirements of international standards without changing the crosshead adjustment. On piston rod end a anti-rotation system prevents the natural tendency of the actuator to rotate. Ergonomically design with unchanged height of lower grip and accessible test space for easy and efficient testing. With chrome plated columns for easy cleaning and longest life.
Examples:[*]Type TTM   300 kN
[*]Type TTM   600 kN[*]Type TTM 1000 kN
[*]Type TTM 1200 kN[*]Type TTM 1500 kN[*]Type TTM 2000 kN[*]Type TTM 3000 kN
http://www.walterbai.com/images/stories/universal/PM/Img/ttm.jpg
[ Back ]
amsler 发表于 2009-2-23 13:50:15
Universal Material Testing
Static Universal Testing Machines
Series LFM-L 0.5 - 20 kN
Series LFM 20 - 125 kN
Series LFM-H 150 - 600 kN
Series LFMZ 20 - 500 kN
Series LFM - T 20 - 200 Nm
Series LFM-C 0.5 - 40 kN
Series TTM 100 - 3000 kN
Series LF(SV) 50 - 1000 kN
Dynamic Testing Systems
Digital Controllers
Material Testing Software DION
Accessories
Customized Test Systems
Pendulum Impact Testers
Pipe & Pressure Testing Systems
Shear Testing Device EN 15340
Torsion Testing Machines
Test Bar Dividing Machines
Civil, Structural and Architectural Testing
Products
Servo - Actuators
Portal Load Frames
Joints
Hydraulic Power Packs
Accessories
Building Material Testing
Cement
Concrete
Concrete Pipe and Masonry
Bituminous
Rock Mechanics
Aggregats, Sands, Soils
Laboratory Equipment
Wood and Timber
Modernisations
Hydraulic Testing Machines
Electromechanical
Testing Machines
Second Hand Machines
Examples:
Type TTM   300 kN
Type TTM   600 kN
Type TTM 1000 kN
Type TTM 1200 kN
Type TTM 1500 kN
Type TTM 2000 kN
Type TTM 3000 kN
查看完整版本: Series TTM® 100 - 3000 kN
