Universal Material Testing
3 g7 H* h7 \+ x5 ^7 d* aStatic Universal Testing Machines 0 i' d: D: j1 ?1 C1 k) g) \
Series LFM-L 0.5 - 20 kN
3 H# k6 I) H4 t% H/ g' i% lSeries LFM 20 - 125 kN
8 h% A- t% J2 h+ `, K- B# ^Series LFM-H 150 - 600 kN
" S% x; I) y# c$ e7 V& Z& LSeries LFMZ 20 - 500 kN
# i4 ]! ^" G! z( z4 NSeries LFM - T 20 - 200 Nm
. l$ [, B4 Z; B3 o7 `# BSeries LFM-C 0.5 - 40 kN
6 @: O6 q4 n: r* A6 jSeries TTM 100 - 3000 kN
& c9 J/ _& Q4 Z9 n: aSeries LF(SV) 50 - 1000 kN
! J1 Y1 v% o' H- r* E& }Dynamic Testing Systems $ M! S4 R3 i! J, P2 c, F
Digital Controllers
( X% L2 i3 Y8 o& m2 E/ h9 ?Material Testing Software DION 9 B9 E [, B& T" J7 O; K
Accessories ! y0 l# H' y' B1 E/ @/ t" |1 G2 b, e
Customized Test Systems
9 A7 r0 P9 Q' {- Y) iPendulum Impact Testers * _ ^6 Y! q) N7 d
Pipe & Pressure Testing Systems * S+ ?# b& p v9 I& ^
Shear Testing Device EN 15340
0 h- [6 a0 H- l, Q/ Q$ JTorsion Testing Machines
' ]) c$ W6 b& c5 S- N$ u& ~; YTest Bar Dividing Machines - ]8 @' Q( s; t( j$ b1 F, w+ q
: c% m9 V0 V0 E3 u5 X
Civil, Structural and Architectural Testing
B5 P* n$ Q' \/ g7 _Products
5 {" C- J6 z/ L5 E' w9 h6 d& ^Servo - Actuators * D1 S' L# N9 K
Portal Load Frames ' V" G' f& d# ~9 F2 L% m1 H# c/ _1 V2 ~
Joints
1 K! F3 o& T( CHydraulic Power Packs
, ]( s% {: {. `3 JAccessories ; G8 ~2 i% @+ H% J% X" e5 @
5 m7 S- a% c; Q- \Building Material Testing
2 {" q- V9 g8 |6 \; iCement * I* X7 |! g) n+ G6 Y' C8 T
Concrete b F' {, ]$ G @/ ~! g, [: M* `
Concrete Pipe and Masonry
& ]* O" @4 d* H: F! \Bituminous
/ _$ R# V3 l& O- ]3 ?Rock Mechanics
9 r7 c9 v: C) q7 ], e4 lAggregats, Sands, Soils & P5 e6 |" R5 P& h9 _! |
Laboratory Equipment V0 R6 |! {6 K# a8 C2 r$ |) n9 O0 H
Wood and Timber
& m8 P, e) C$ o. L. j9 l( u
6 j5 }) [6 s7 b7 n, }Modernisations 1 h' S( z* P5 R5 {( k
Hydraulic Testing Machines
4 ?% F/ M0 g9 IElectromechanical
& _" i9 n) \1 rTesting Machines 7 o h# \% r* L' c% F7 M
4 t8 O. a& J! l- h: o2 V6 a) JSecond Hand Machines 8 ]; L9 H. n1 \& f Z$ o$ d/ d5 L
Universal Material Testing ) u4 ^% }7 b; H5 B! j9 ^: E
; P% B8 x: ]9 l$ k8 B* y5 ~' ~$ O3 i : T* L9 P0 q6 X" M; s) o
( T1 ~' [5 D/ e6 _+ } 0 F% M3 e* h3 l4 v+ c
, A! Y \8 j" y# W3 s
2 H1 y3 }, K% y4 b7 E1 X 4 G; ~& K' I* r- d% r
- V. R& A5 _7 f
Static Universal Testing Machines " @) B) @5 s2 ~" }, s
Series TTM® 100 - 3000 kN# t+ F# G C. e3 j% ?
9 [) B+ Y; E4 p, _( J, I8 e1 e2 H. T
TTM® Tensile Testing Machine is a registered trademark of walter+bai ag Testing Machines.+ F+ N; O# j. V) f; }
The Series TTM testing machines are “state-of-the-art”, rugged and durable designed especially suitable for high capacity testing of round, flat and profile specimens meeting the needs of the metal, aerospace, automotive and fastern industries.The economic solution mainly in the field of higher and highest capacity testing.
$ ~. s7 v5 s3 E- G* w" d( V
% t" {7 v1 R! VServohydraulic Universal Testing Machines y+ l+ G/ E! _6 ?% u
The Series TTM testing machines with its single test space designed for tension, compression, bend and folding, shear and static cyclic testing is specifically suitable for testing of metals-(wire, rod, tube, strip, plate, strip), fasteners (tensile, proof, single and double shear), construction materials (reinforcement bar, wire, mesh, folding, compression of concrete) and components. All models of the Series TTM feature a rigid load frame either in two- or four-column construction for minimum maintenance and low reaction at specimens failure. The servo-actuator, which is integrated in the upper crosshead with a long piston stroke makes testing space accessible for easy and efficient testing of different samples lengths. The high precision load cell is located between base platen and lower grip, providing high accuracy test after test. The servoactuator, which is integrated in the upper crosshead, has a long piston stroke which makes testing space accessible for easy and efficient testing of different samples lengths. The long piston stroke meets the extreme requirements of international standards without changing the crosshead adjustment. On piston rod end a anti-rotation system prevents the natural tendency of the actuator to rotate. Ergonomically design with unchanged height of lower grip and accessible test space for easy and efficient testing. With chrome plated columns for easy cleaning and longest life.4 _7 r# ~) C- E7 B' |
% X# X# F. J% B
Examples:+ S- V, W% M# O4 o
Type TTM 300 kN
' Q. E+ s+ D8 ~" G- e- i: I# i0 a4 Y
Type TTM 600 kN5 \4 j$ {5 L. P4 I- M, S
Type TTM 1000 kN
3 O, H) f( d7 Z/ P4 X
& P' r+ ^/ s: ?$ K( FType TTM 1200 kN1 k3 c8 Z- B, F& J# g
Type TTM 1500 kN " A7 t# k) {2 X. y4 i. t
% n% ]) E* H: f+ Q- l
Type TTM 2000 kN
1 [# S. }. k9 E1 o2 D [Type TTM 3000 kN |
