武铠蓝夜枫 发表于 2020-10-13 12:52:46
关于一个水平旋转机构的扭矩计算、电机及减速机选型,求解
各位师傅,您们好!我是新手一枚,我想咨询的情况如下图,基本参数都在图片里面了。
这里有一个比较特殊的问题需要说下,被旋转的物体上有螺栓孔,然后通过螺母被紧固在设备1上面。在旋转之前,先由人工将螺母松开拆除,然后由电机+减速机进行旋转。那么问题来了,“被旋转物体的螺栓孔”跟“设备1的螺栓”只存在一点间隙而已,相当于一个硬限位。我通过草图绘制并测量,得出旋转角度只有1度,也就是说被旋转物体只能旋转1度。速度上因为只有1度,所以大概1-3秒内完成这个动作即可。
我想请问下各位师傅,这个扭矩应该怎么计算?我需要对电机和减速机进行选型。
data:image/jpeg;base64,/9j/4AAQSkZJRgABAQEAYABgAAD/4RDaRXhpZgAATU0AKgAAAAgABAE7AAIAAAAFAAAISodpAAQAAAABAAAIUJydAAEAAAAKAAAQyOocAAcAAAgMAAAAPgAAAAAc6gAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAExIMTEAAAAFkAMAAgAAABQAABCekAQAAgAAABQAABCykpEAAgAAAAM1NgAAkpIAAgAAAAM1NgAA6hwABwAACAwAAAiSAAAAABzqAAAACAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMjAyMDoxMDoxMyAxMjoyMjo1MQAyMDIwOjEwOjEzIDEyOjIyOjUxAAAATABIADEAMQAAAP/hCxdodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdpbj0n77u/JyBpZD0nVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkJz8+DQo8eDp4bXBtZXRhIHhtbG5zOng9ImFkb2JlOm5zOm1ldGEvIj48cmRmOlJERiB4bWxuczpyZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1ucyMiPjxyZGY6RGVzY3JpcHRpb24gcmRmOmFib3V0PSJ1dWlkOmZhZjViZGQ1LWJhM2QtMTFkYS1hZDMxLWQzM2Q3NTE4MmYxYiIgeG1sbnM6ZGM9Imh0dHA6Ly9wdXJsLm9yZy9kYy9lbGVtZW50cy8xLjEvIi8+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczp4bXA9Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC8iPjx4bXA6Q3JlYXRlRGF0ZT4yMDIwLTEwLTEzVDEyOjIyOjUxLjU1NTwveG1wOkNyZWF0ZURhdGU+PC9yZGY6RGVzY3JpcHRpb24+PHJkZjpEZXNjcmlwdGlvbiByZGY6YWJvdXQ9InV1aWQ6ZmFmNWJkZDUtYmEzZC0xMWRhLWFkMzEtZDMzZDc1MTgyZjFiIiB4bWxuczpkYz0iaHR0cDovL3B1cmwub3JnL2RjL2VsZW1lbnRzLzEuMS8iPjxkYzpjcmVhdG9yPjxyZGY6U2VxIHhtbG5zOnJkZj0iaHR0cDovL3d3dy53My5vcmcvMTk5OS8wMi8yMi1yZGYtc3ludGF4LW5zIyI+PHJkZjpsaT5MSDExPC9yZGY6bGk+PC9yZGY6U2VxPg0KCQkJPC9kYzpjcmVhdG9yPjwvcmRmOkRlc2NyaXB0aW9uPjwvcmRmOlJERj48L3g6eG1wbWV0YT4NCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgCiAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAKICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIAogICAgICAgICAgICAgICAgICAgICAgICAgICAgPD94cGFja2V0IGVuZD0ndyc/Pv/bAEMABwUFBgUEBwYFBggHBwgKEQsKCQkKFQ8QDBEYFRoZGBUYFxseJyEbHSUdFxgiLiIlKCkrLCsaIC8zLyoyJyorKv/bAEMBBwgICgkKFAsLFCocGBwqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKioqKv/AABEIAx8EwQMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEUMoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2RlZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUGBwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/AOC+NHinxBpvxi8QWmna7qdpbRzR7IYLyREXMSE4UHA5JP41w3/Cb+K/+hn1n/wYS/8AxVdJ8df+S3eI/wDrtH/6JSvP6ANz/hN/Ff8A0M+s/wDgwl/+Ko/4TfxX/wBDPrP/AIMJf/iqw6KANz/hN/Ff/Qz6z/4MJf8A4qj/AITfxX/0M+s/+DCX/wCKrDooA3P+E38V/wDQz6z/AODCX/4qj/hN/Ff/AEM+s/8Agwl/+KrDooA3P+E38V/9DPrP/gwl/wDiqP8AhN/Ff/Qz6z/4MJf/AIqsOigDc/4TfxX/ANDPrP8A4MJf/iqP+E38V/8AQz6z/wCDCX/4qsOigDc/4TfxX/0M+s/+DCX/AOKo/wCE38V/9DPrP/gwl/8Aiqw6KANz/hN/Ff8A0M+s/wDgwl/+Ko/4TfxX/wBDPrP/AIMJf/iqw6KANz/hN/Ff/Qz6z/4MJf8A4qj/AITfxX/0M+s/+DCX/wCKrDooA3P+E38V/wDQz6z/AODCX/4qj/hN/Ff/AEM+s/8Agwl/+KrDooA3P+E38V/9DPrP/gwl/wDiqP8AhN/Ff/Qz6z/4MJf/AIqsOigDc/4TfxX/ANDPrP8A4MJf/iqP+E38V/8AQz6z/wCDCX/4qsOigDc/4TfxX/0M+s/+DCX/AOKo/wCE38V/9DPrP/gwl/8Aiqw6KANz/hN/Ff8A0M+s/wDgwl/+Ko/4TfxX/wBDPrP/AIMJf/iqw6KAP0a/s+z/AOfSD/v2P8KP7Ps/+fSD/v2P8KsUUAV/7Ps/+fSD/v2P8KP7Ps/+fSD/AL9j/CrFFAFf+z7P/n0g/wC/Y/wo/s+z/wCfSD/v2P8ACrFFAFf+z7P/AJ9IP+/Y/wAKP7Ps/wDn0g/79j/CrFFAFf8As+z/AOfSD/v2P8KP7Ps/+fSD/v2P8KsUUAV/7Ps/+fSD/v2P8KP7Ps/+fSD/AL9j/CrFFAFf+z7P/n0g/wC/Y/wo/s+z/wCfSD/v2P8ACrFFAFf+z7P/AJ9IP+/Y/wAKP7Ps/wDn0g/79j/CrFFAFf8As+z/AOfSD/v2P8KP7Ps/+fSD/v2P8KsUUAV/7Ps/+fSD/v2P8KP7Ps/+fSD/AL9j/CrFFAFf+z7P/n0g/wC/Y/wo/s+z/wCfSD/v2P8ACrFFAFf+z7P/AJ9IP+/Y/wAKP7Ps/wDn0g/79j/CrFFAFf8As+z/AOfSD/v2P8KP7Ps/+fSD/v2P8KsUUAV/7Ps/+fSD/v2P8KP7Ps/+fSD/AL9j/CrFFAFf+z7P/n0g/wC/Y/wo/s+z/wCfSD/v2P8ACrFFAFf+z7P/AJ9IP+/Y/wAKP7Ps/wDn0g/79j/CrFV3voUleMiVmQ4bZC7AHAPUDHQionUhTV5tL1GouWyD+z7P/n0g/wC/Y/wo/s+z/wCfSD/v2P8ACk+3w/3Lj/wGk/8AiaPt8P8AcuP/AAGk/wDiay+s0P5196K9nPsxf7Ps/wDn0g/79j/Cj+z7P/n0g/79j/Ck+3w/3Lj/AMBpP/iaPt8P9y4/8BpP/iaPrND+dfeg9nPsxf7Ps/8An0g/79j/AAo/s+z/AOfSD/v2P8KT7fD/AHLj/wABpP8A4mj7fD/cuP8AwGk/+Jo+s0P5196D2c+zF/s+z/59IP8Av2P8KP7Ps/8An0g/79j/AApPt8P9y4/8BpP/AImj7fD/AHLj/wABpP8A4mj6zQ/nX3oPZz7MX+z7P/n0g/79j/Cj+z7P/n0g/wC/Y/wpPt8P9y4/8BpP/iaPt8P9y4/8BpP/AImj6zQ/nX3oPZz7MX+z7P8A59IP+/Y/wo+wWX/PpB/37H+FJ9vh/uXH/gNJ/wDE0fb4f7lx/wCA0n/xNH1mh/OvvQezn2Yv2Cy/59IP+/Y/wo+wWX/PpB/37H+FN+3w/wBy4/8AAaT/AOJo+3w/3Lj/AMBpP/iaPrND+dfeg9nPsx32Cy/59IP+/Y/wo+wWX/PpB/37H+FN+3w/3Lj/AMBpP/iaPt8P9y4/8BpP/iaPrND+dfeg9nPsxx0+zP8Ay6wf9+x/hSf2fZ/8+kH/AH7H+FJ9vh/uXH/gNJ/8TR9vh/uXH/gNJ/8AE0fWaH86+9B7OfZi/YLP/n0g/wC/Y/wpPsFn/wA+kH/fsf4Un2+H+5cf+A0n/wATR9uh/uXH/gNJ/wDE0fWaH86+9B7OfZi/YLP/AJ9IP+/Y/wAKPsFn/wA+kH/fsf4U37dD/cuP/AaT/wCJpft8P9y4/wDAaT/4mj6zQ/nX3oPZz7MDYWf/AD6wf9+xR9gs/wDn0g/79ik+3w/3Lj/wGk/+Jo+3w/3Lj/wGk/8AiaPrND+dfeg9nPsx32Gz/wCfSD/v2KQ2Nn/z6Qf9+xSfb4f7lx/4DSf/ABNH26H+5cf+A0n/AMTR9Zofzr70Hs59mL9hs/8An1g/79ikNjaf8+sP/fsUn26H+5cf+A8n/wATR9uh/uXH/gPJ/wDE0/rND+dfeg9nPsw+w2n/AD6w/wDfsUfYrT/n1g/79ik+3Rf3Lj/wHk/+JpDfRf3J/wDwHk/+Jo+s0P5196F7OfZjvsVp/wA+sH/fsUhsrT/n1g/79ik+3Rf3J/8AwHk/+JpDfRf3J/8AwHk/+Jo+s0P5196D2c+zHfYrT/n1h/79im/YrT/n1h/79ik+3Rf3J/8AwHk/+JpPtsX9yf8A8B5P8Kf1mh/OvvQezn2Y42Vp/wA+sP8A37FJ9itf+fWH/v2KQ3sX9yf/AMB5P8KT7bF/cn/8B3/wo+s0P5196D2c+zHGztP+faH/AL9ik+x2v/PtD/37FJ9ti/uT/wDgO/8AhSfbYv7s/wD34f8Awo+s0P5196D2c+zFNna/8+0P/fsUn2S1/wCfaH/v2KQ3sX92f/vw/wDhSG8i/uz/APfh/wDCj6zQ/nX3oPZz7Md9ktf+faH/AL9ik+yWv/PvD/3wKb9si/uzf9+H/wAKPtkX92b/AL8P/hT+s0P5196D2c+zHfZLX/n2h/74FIbS2/594v8AvgU37ZH/AHZv+/D/AOFIbyP+7N/34f8Awo+s0P5196D2c+zHfZLb/n3i/wC+BSfZbb/n3i/74FJ9sj/uzf8Afh/8KT7XH/dm/wC/D/4UfWaH86+9B7OfZim1tv8An3i/74FH2W2/594v++BTTdx/3Zv+/D/4Ufa4/wC7N/34f/Cn9Zofzr70Hs59mL9ltv8An3i/74FJ9lt/+eEX/fApPtcf92b/AL8v/hSG7j/uzf8Afl/8KPrOH/nX3oPZz7Md9mt/+eEX/fAoNtb/APPCL/vgU37XH/dm/wC/L/4Uhuo/7s3/AH5f/Cj6zh/5196F7OfZjvs1v/zwi/74FJ9mt8/6iL/vgUn2qP8Auzf9+X/wpPtUf92X/vy/+FH1nD/zr70Hs59mO+zW/wDzwi/74FJ9mg/54R/98Ck+1R/3Zf8Avy/+FN+1R/3Zf+/L/wCFH1nD/wA6+9B7OfZj/s0H/PCP/vgUn2aD/njH/wB8Ck+1R/3Zf+/L/wCFJ9qj/uy/9+X/AMKPrOH/AJ196D2c+zF+zQf88Y/++BR9mg/54x/98Ck+1R/3Zf8Avy/+FIbqP+7L/wB+X/wp/WcP/OvvQezn2Y77PB/zxj/74FJ9ng/54x/98Ck+0x/3Zf8Avy3+FH2mP+7L/wB+W/wo+s4f+dfeg9nPsxfs8H/PGP8A75FH2eD/AJ4x/wDfApv2lP7sv/fpv8KPtKf3Zf8Av03+FH1nD/zr70L2c+zHG2g/54x/98ik+zwf88Y/++RSfaU/uy/9+m/wpDcp/dl/79N/hR9Zw/8AOvvQezn2Y7yIP+eMf/fAo8iD/njH/wB8Cm/aU/uy/wDfpv8ACj7Sn92X/v03+FH1nD/zr70Hs59mO8iD/njH/wB8CjyIP+eMf/fApv2lP7sv/fpv8KPtKf3Zf+/Tf4UfWcP/ADr70Hs59mO8iD/njH/3wKPIg/54x/8AfApv2lP7sv8A36b/AAo+0p/dl/79N/hR9Zw/86+9B7OfZjvIg/54x/8AfAo8iD/njH/3wKb9pT+7L/36b/Cj7Sn92X/v03+FH1nD/wA6+9B7OfZjvs8H/PGP/vkUfZ4P+eMf/fIpv2lP7sv/AH6b/Cl+0x/3Zf8Av03+FH1nD/zr70Hs59mO+zwf88Y/++RR9ng/54x/98Cm/aU/uy/9+m/wo+0x/wB2X/v03+FH1nD/AM6+9B7OfZjvs0H/ADxj/wC+RS/ZoP8AnjH/AN8Cm/aY/wC7L/35b/Cj7Un92X/v0/8AhR9Zw/8AOvvQ/Zz7Md9ng/54x/8AfAo+zQf88Y/++BTftMf92X/vy/8AhS/ao/7sv/fl/wDCj6zh/wCdfeg9nPsx32aD/nhH/wB8Cj7NB/zwj/74FN+1R/3Zf+/L/wCFL9qj/uy/9+X/AMKPrOH/AJ196D2c+zF+zQf88I/++BSi2t/+eEf/AHwKb9pj/uy/9+X/AMKX7VH/AHZf+/L/AOFL6zh/5196D2c+zHfZrf8A54Rf98Cj7Lb/APPCP/vgU37VH/dl/wC/L/4Uv2qP+7N/35f/AAo+s4f+dfeg9nPsx32a3/54Rf8AfAo+y2//ADwi/wC+BTftUf8Adm/78v8A4Uou4/7s3/fl/wDCj6zh/wCdfeg9nPsx32W3/wCeEX/fArC8chbT4eeI7m0UQTw6VdSRSxDayMImIYEcgg8gitv7XH/dm/78v/hWF4+dZPhf4ldDlW0a6IPqPJarhWpVHaEk35MTjKOrR8Z/8Jv4r/6GfWf/AAYS/wDxVFYdFMD0D46/8lu8R/8AXaP/ANEpXn9egfHX/kt3iP8A67R/+iUrz+gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA/SKiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACq1r/AMfN7/13H/otKs1Wtf8Aj5vf+u4/9FpXPV+On6/+2suO0vT9UWaKKK6CAooooAKKKKACiiigAooooAKKKKACkpaQ0AFFFFABRRRQAUhoooAKKKKACkoooAKQ0tIaYhKDRQaAEoNBpKAA0lBpKAA0lBopgFJQaSgBaQ0UhoASkpTSGmAGkopKAEo70GigBDRRSGgBKDRSUxBSUppKYBSd6U0lAAaSg0UAIaKO9FABSUGigApDS0hpgJRRQaBCUUUUAFBoNJQAUUUUAFFFFABRRRQAUUUUAFLSUtABRRRQAtFFFACilpBS0hgKKBQaAFFLSCloAKWkpaAClHSkpR0oAK5fxp/ySTxB/wBgO5/9ENXUVy/jT/kkniD/ALAdz/6IauaX8ePpL84lr4H6r9T4cooorQR6B8df+S3eI/8ArtH/AOiUrz+vQPjr/wAlu8R/9do//RKV5/QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfpFRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVa1/4+b3/ruP/RaVZqta/wDHze/9dx/6LSuer8dP1/8AbWXHaXp+qLNFFFdBAUUUUAFFFFABRRRQAUUUUAFFFJQAUUUUAFFFFABSUUUAFFFJmgAzRRRQAUUUhpiA0lFJQAppDQaSgAoNBppoADRRSGmAGkNLSUAFJQaSgANIaU02mAUGg0hoADSUUlACGig0UAFIaKQ0xAaSig0wA0hoNJQAUGg0lABSGg0UAFIaDRQAUUUh6UAcI3xV09NRurVtI1Z0triSDzoLVpFYoxU9OOoPepv+Fo6SDzpWuf8Agvao/B88d3otxdQZ8m41G9miPqjXEjKfyIraaldgZEfxW8O75UvE1CxeOMSbbq0ZS4JwNoGc88VDH8WtGnmmjt9M1ubySFcpY9CRnu2ehrlvH3hjWtU8SWeoaTaxXEUUcaOGm2EFZt/oeoroPDljewPqF5qMC28t7Kr+QH37AqBPvYGc7c9KXMwLv/C0NPP/ADA9d/8AAIf/ABVL/wALOsf+gFr3/gGv/wAXVpqjIpczAh/4WZZnpoOu/wDgKn/xdV734t6Rptt9pv8ASNat4AwUvJbJjJ6fx1abiua8c6Dc+I/C81hYuiTl1dd/RsHp7UczAuJ8d/CskyRR2mrO7sEUC2X5j2/jrbX4iW7HH9ga2PYwxD/2pXiun/DnxJDq9nNcx2QhhnWR9s5JwD6ba9cPt1o5mBYl+KGnw30NnJo2srcTAtHGYY8sB1/5aU+f4k2ltbyTz6FrSRxqWZjDFwB/20rkfEGn6lJqum6lo8ME0toXDJPIVBVlI6getU75/Fl9YT2kmmacizIULC5bIyPpRzMLXOyl+MXhVJ4reKW5uLmVI2WCGHLEvtwmSQN3zDvjFXf+FgwYz/YGtD28qL/45Xh0HgPxJa61b38cdniCWOVVMx52BQO3+yK7Q3/jAf8AMO0sf9tnNLmY+VHaX3xR0/TLKS8v9F1mG3iGXcwRkAfhJWOfj74UEiJ9k1U7ztH+jrnP/fdclr0HivXdDutNntdNiS4TaWSRiRXHf8K38QLPFJ5tlmOQSAbjzjPFHMwsj1m9+P3h62nEUGn6jMdgZi0YQryR0J9qbYfHa11O5NrY+HL+WcJv2eag+UYBOfxH515ddfD/AMQXV6Ll5bJW2BMAt2JOf1rW8I+DdQ0PWmvr+eBgLdoVjiB7sDnP/AafMwPRrn4wTWcXnXXhS9iiDKpc3KcbmCjt6kVag+MejgKdQ0zUrRS4VpCiMig4GSQ2cfhXJ6/p8mqaLPaW7qkjlGVmGRlXDf0rmrzw7r17ZSW801ggfAJVX45B9fajmYaHrGv/ABV07TdVi07RLb+3LlkZ5BbzqqxAHGCecn2qh/wtjUv+hPn/ABvU/wDia818NeD73Rtcm1C8uoX8xCpjjUjknOetdcelLmYG5/wtjU/+hQl/G+X/AOJo/wCFsan/ANCk4+uoL/8AEVgEU00czA3rf4zEeIrDStT8PS2hvnCJIt0JNp9cbRXoGu6vDoOhXmqXSu8VrEZHVOpx2rwXVdGuLvXdN1S1mhV7Bt6rKrEMfwIroNY8T+Kdb0e50y+fSzb3MZR9sEgJB9PmppiNix+M02pwtNY+Gi0YYpmS+CnI68bDVh/irqe35PDMQb31HI/9F1wWh6T/AGPp32Z5RK7OXZgMDJ9PatA8DilcDoj8VfEXmqV8O2Xl5+YG9OcfXbXaeC/FUnizTLm5nshZS21wYGjEu8cKpznA/vV5Mea7r4QsDpmtKOo1E5/79pTTuwPQ6UdKSirAWuX8af8AJJPEH/YDuf8A0Q1dRXL+NP8AkkniD/sB3P8A6IauaX8ePpL84lr4H6r9T4cooorQR6B8df8AktviP/rtH/6JSvP69A+Ov/JbfEf/AF2j/wDRKV5/QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfpFRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABVa1/4+b3/ruP8A0WlWarWv/Hze/wDXcf8AotK56vx0/X/21lx2l6fqizRRRXQQVL7VdP0zZ/aV/bWnmZ2faJlj3YxnGTzjI/Oqv/CVeHv+g7pn/gZH/jXH/FP/AI/NG/653H84q4SvSoYJVaam2edXxjpVHBI9r/4Srw9/0HdM/wDAyP8Axo/4Srw9/wBB3TP/AAMj/wAa8Uorf+zY/wAxj/aEv5T2v/hKvD3/AEHdM/8AAyP/ABo/4Srw9/0HdM/8DI/8a8Uoo/s2P8wf2hL+U9r/AOEq8Pf9B3TP/AyP/Gj/AISrw9/0HdM/8DI/8a8Uoo/s2P8AMH9oS/lPav8AhKvD/wD0HdM/8DI/8aP+Ep8P/wDQd0z/AMDI/wDGvFaKP7Nj/MH9oS/lPav+Ep8P/wDQd0z/AMDI/wDGj/hKfD//AEHdM/8AAyP/ABrxWij+zY/zB/aEv5T2r/hKfD//AEHdM/8AAyP/ABp0XiTQ55khg1rT5JJGCoiXSEsTwAADya8Tq1pP/If0v/r/ALf/ANGrUyy+MYt8xUcfKUkuU90oopM15B6oZooooAKKKQ0xAaSig0ABpKDSUAKaQ0GkoAKQ0GkNMANFIaKACiikJxQAGkNBNIaYAaQ0GkoAQ0UGkNAAaQ0tJQAUlBpKYBQaDSGmIDSGikoAKDQaSgApDQaKACkNLSUAFFFFABWJ4y1c6D4L1XUo2KzQWzeTgZzKRtQfixUVtGuO8eyG7m0DRI5SrXuorNIu3OYYAZTn/gYjH40MCbQtNXR/D1hpyNuFrAkW71wOv41cNSt/jUbVIETVEalaozSAiaozUjVGaQETVEalaozQBE1MNPamGgBhqJqlao2oGRmmGpDUZoAYajNSGozQAxhxUZqRqjNADGphp5phoAaaYacaaaQDTTDTzTDTAYaaaeaaaAGHrTWpxppoAaa7X4PsDZ66o6jUP/aaVxRrsvg+R5XiAZ6X6/8Aotaa3EelUUUVQCjpXL+NP+SSeIP+wHc/+iGrp65jxp/ySTxB/wBgO5/9ENXPL+PH0l+cS18D9V+p8OUUUVoI9A+Ov/JbfEf/AF2j/wDRKV5/XoHx1/5Lb4j/AOu0f/olK8/oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAP0iooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiimk89aAHUUgzikLbQcnH1oAdRTFcN91gaeOlABRRRQAVWtf+Pm9/wCu4/8ARaVZqta/8fN7/wBdx/6LSuer8dP1/wDbWXHaXp+qLNFFFdBB518U/wDj80b/AK53H84q4Su7+Kf/AB+aN/1zuP5xVwlfRYL+Avn+Z4GM/jv+ugUVZttPvL2OSS0tpZ1iID+WpYrnOOBz2NSf2Nqf/QOu/wDvw3+FdTlFaXOXlk9bFKitCHQNWuJNkem3O7BPzRFRwM9TWfQpJ7MHFrdBRUlvbyXVxHBAA0kjbVBYDJ9MmmyxSQytFMjRyIdrKwwQfQindXsKztcbRRU/2K4/s/7d5R+zeb5XmZGN+AcfkaG0tws2QUUdTgVau9NvbGKKS8tZYFmBMZkXG7HWi6Wg7N6lWrWk/wDIf0v/AK/7f/0atVataV/yH9L/AOv+3/8ARq1FT4H6FU/jXqe50UUma+WPpxaKSigQUlBpKAFNIaDSUAFBoNITQAhoopDTADSGg0UAFFFIaAA0hopDQAGkNBpKYBSGg0hoADRSGigAoopDTADSGg0hpiA0lFBoADSGg0lABSGg0UAFFIaKACiiigApDQaKYCda4mSX+0/itdlXJi0bTkg2EcCWdt7f+ORx/nXbdxjrmuF8EP8Ab7HUtb3lxq2ozXEbEYPkqfLi/wDHI1P41MgOiaomqVqiapAiaozUjVGaAImqM1I1RmgCJqjapDUbUgI2pjdKcfamHnpQAxqjNSNUZ5oGMNRmpGzUZoAYajPWnmmGgBhpjdKcetMNADDTDTzTDQAw0004008dTSAaaYacWUdx+dRmRP7w/OgANNNIZY+8i/mKYZ4f+eqf99CgBTTTTTcQ/wDPVP8AvoUCVHPyOrfRgaAA11nwfkVLvxHbMcS/aY5Qp7oUwD+YNcme/rUug6oPD3jfTtSJ221wfsV16bXPysfowH4ZpoR7sKWkHWlqwCuY8af8kk8Qf9gO5/8ARDV09cx40/5JJ4g/7Adz/wCiGrnl/Hj6S/OJa+B+q/U+HKKKK0EegfHX/ktviP8A67R/+iUrz+vQPjr/AMlt8R/9do//AESlef0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAH6RUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXnnie0j1b4u6Npd+0z2LaZPMYUmeMFw4AJ2kV6HXCat/yW/Q/+wRc/wDoa0nsC3NL/hAfDn/PnP8A+B0//wAXSH4f+G2GGspiD2N7P/8AF10lc3P8QfCdtcSW9x4hsI5omKOjSgFWHY1F2aGJ4StIdH+LGv6Tp5kjsY7C3lWBpWcBiTkjcSa9FHSvL/CesafrXxu1+60m8iu4DpVuvmRNlchjx9a9PHSrRmLRRRTAKrWv/Hze/wDXcf8AotKs1Wtf+Pm9/wCu4/8ARaVz1fjp+v8A7ay47S9P1RZoopM10EHnfxT/AOPzRv8ArncfzirhK7r4p/8AH7o//XO4/nFXC19Fgv4C+f5ngYz+O/66G9owRvC2uCVmRC1tuZV3EDee2RmptBi07Zquy4nkH9nybt9qvA3LyPnOT09PrVfS/wDkUde+tt/6Gav6o+ox2+mfYLtIEbTogym6SMnr2LAnt+VEr80o33f6II25Yu2y/VjfC6aeuqr9kmuZJ/In3iWFUXb5ZxjDE5/x9ucPRre3utZtobx2WBnG/ZGXLDrtAHJJ6fjXXxGQ+KLATMHcaNyQwYE+W2TkcH61wdVTbm5a7pfqTUSgl5N/odBNa3n2uR4PC7qu8lP3NwCBnjo3H4VK9vqmq6p5l54ezLcSAPK8U4Azxk/OAAKbfadBp9xoPkwPHLNHHJO5YkM5IOMHoQCMj3FR6raae/ifUDeakIkN1KWCQszKdx47Dr71Kd9u3n/mU1bf9P8AIp659m/tt4orFtOiiIjaLO5uON2CepGD1/HnNbX2PT4fBFtLcy3klpLeu4McKq+dm3uxAGR1/D3rlkhaW5WGD94zvsTHG4k4HWu0l1tLDw7b/ZES4tLW6NoUPCzp5Q3E9eCxJ/KnVUkoxiKk03KUirqQuLW0sJtOvYLGNrKEO4HlyMxBwSygnkL69jWPq9jexWlre318t0LrcYz5rM2AcZ+bnFbk1t/aWoL4fyqz/wBnwIjEZCzIu78trOM+9YXiK7judV8m3z9ms0W2hyMEqnGT9Tk/jU0m+ZJevy/r8h1UrNv0+f8AX5mVVrSv+Q9pf/X/AG//AKNWqtWtK/5D2l/9f9v/AOjVrpqfA/Q56fxr1Pc6Q0UlfLH0wZooNJQAZoNIaDQAZpDRSGgANFFIaYBSGlzSUAFFFITigANIaCaQ0ABpKKDTAQ0hrD8U+IxoFmghVZbyckRI3QAdWPsOPqSK85uNb1e6lMk2q3m49opmjUfQKQK66OFnVXMtEctbFQpPlerPYTSGvGv7S1L/AKCuo/8AgbL/APFVYgfXbpN9td6vMuduY7mZhnrjg1u8BJbyRgsfF7RZ67RXlSWXiV87rjVYQO897JEPzZgKbfpqlhBFI3iCScycFLfVXkZPrhv5ZqVgne3MivrqtflZ6saTNeOf2jqP/QU1H/wNl/8Aiqmgm1i5jle3v9SkEK75At7ISq+uN2cep7VTwE1vJE/X4vaLPXDSV49/aOo/9BTUP/A2X/4qj+0dR/6Cmof+Bsv/AMVT/s+fdC+vw7M9hNIa8rmTVoNIttRk1e8EVy7LGn26XedvU4z0ptwNYt7G3vG1K/a3uAdki3suAQcFTzwf8ip+pP8AmRX12P8AKz1WkNeQf2hqH/QT1D/wMl/+Ko/tDUP+gnqH/gZL/wDFVX9nz7on6/Dsz1+kNeU2uu6tZSiSHUbiTHVLiQyq3sdxz+RFeh6DrMet6aLhF8uVTsljznYw/oeo+tc9bDTo6vY6KOJhV0W5p0UUVzHSFIaDRTAKQ0GkoEZPiu9k03wbrN9CcSW1hPMh91jZh/Ks/wANWDaX4T0qwfh7aziibjuqgGofieZD8ONUhh+/dCK1GP8AprKkf/s9bP8ACPpUMCNqiapWqJqQyJqjNSNUZoAiaozUjVGaAInIAJJAA7muC1bxndX95JaeGzGkMbbZL6QbgT3CDv8AWtD4iapJZ6HFY27FJdQk8neP4U6sfy/nXHWwWFFjiG1F4CjtUtjSM7xXdavZxWLDXL6WSaUq7bwo6Z4AFYn2rVj/AMxi+/7/AFbfi7549L/6+D/6DWeIvapTGU/P1P8A6C19/wB/jSb9RP8AzFL7/v8Amr3k0vlUxmeFvv8AoJ33/gQ1HlXh/wCYle/+BDVoiL2pfK9qAM3yLo9dQvf/AAIb/Gl+zXB6315/4EN/jWmIqXyvagDM+yzH/l9u/wDwIf8AxpRaS9Dd3f8A4EP/AI1qeV7Uvl+1AGWLST/n5uv+/wC/+NOFm/8Az8XP/f8Af/GtIRe1L5XtQBnCzb/nvcf9/wB/8aX7CSOZpz/22f8AxrSEfPSneX6igDK/s5SOZJj/ANtm/wAaP7KiI5Mh/wC2rf41q+WKd5ftSAyf7IgPZ/8Av43+NA0a2PVG/wC/jf41rhPanbPagDH/ALEtMcxn/vtv8aw/s5ivblYZZYgkpA2SEY4HvXa7K5mSLOoX3H/Lc/yFNCNDRfFd3Y3CW+rS+fatwJj96P6+orqtc2S6DcyD5gsfmKR6jkGvPJo8gqwyO9dZ4Uuje+Gp7Oc72tt0XPdcZH88UwPpywu47/Tba8h+5PCsi/RgCKsiua+Hd6NQ+HWhz4xttEiP1QbD+q10taki1y/jT/kkniD/ALAdz/6Iauorl/Gn/JJPEH/YDuf/AEQ1c0v48fSX5xLXwP1X6nw7RRRWgj0D46/8lt8R/wDXaP8A9EpXn9egfHT/AJLb4j/66xf+iUrz+gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA/SKiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK4fVx/xejQeP+YXdc/8CSu4ri9YUD4v+H2/6h13/NKT2BbnXGvJPCnhvW9Qi1SfTdR062gOq3ICT2JlcYbn5t4/lXrfauS+HihdJ1UAcf2xdj/x+szQ57wZYXWm/GbXIL65guZjpMDGWCDylI3nA27m6fWvU1+6M1wOlrj4760fXRoP/QzXf1aMwoopKoBaq2v/AB83v/XYf+i0qzVa1/4+b3/rsP8A0Wlc9X46fr/7ay47S9P1RZoooroIPOvil/x+aP8A9c7j+cVcLXdfFP8A4/NH/wCudx/OKuFr6LBfwF8/zPAxn8d/10NbTNTt7LRdStp4RM90YtiNnb8pJJJBB9Khk1SObb5unWz7FCLukmO1R0A/edKz6K6ORXb7nPzuyRv6X4hgtr7z7qzQBbd4kaN5GZQVIAG5yMc1kWLWsd0JL5WkiQbvKXjzD2UnsPU+lV6KFTSvbqDm3a/Q14fEdyNRlubyKO7SaQSPC4woI6FSOVIHAPp61anvPDWoXU13eQarBNPI0jrDJG6gk5OMgHvXPUUnSje609BqrLZ6lrUDYG5I0pLlYB0Nyylj+CjA/WtTTtR0yPQYbW/EjvHfG5MaICHXYoAOSOCc/gD0zmsGim4JpJiU2ndGxda/J5k7afvhkuG3TXJb97JznGR9xenyj05JqTUtW07VrATXNnJHq3R5YWCxy/7TDHX6Yz69qw6KXsoqzQ/ayd0wq1pX/Ie0v/r/ALf/ANGrVWrWlf8AIe0z/r/t/wD0atOp8D9BU/jXqe40lFFfLH0wGkozSZoAKKM0lMANGaQ0hoAWkNFJmgBaKSigAJxSHmgmkNMANIaDSUAFIaDSGgDzb4gMT4pjUnhbJCB6ZeTP8hXNV0nj7/kbF/68o/8A0OSubr6LC/wYnz2K/jSCuhsI0m8IiGSGSbzNURFSOQRksYyB8xBHWuerpdPIt9F0iGQgNdaoJwfRFwmT+JP5VdbZEUt2WtPtLW0tNVgmtZIXeHy/Lkv4iWIcZA+Xg9eeaydQsoLTSEk/s2WJp5D5Vw16kn3eo2qo45/P8q0/JeWHxPcQQi4E9wYoNqeZuJkLEr9F5z2yDWVqMsbeGtIhDqZYmn3oD8yZZcZHbpWEL83z8+1+5tO3L8vLv6GXFDJO5SJdzBWcj2UFifyBrejKeHW0PVrQyGWZGkmQkbSA20gfUZ61W0a80+w0/UZLnzHvJoGgt0C/KAwwWz/n9eJtd/5AOgf9ez/+hmtZtykotafnozOCUYuS3/LVGfcK2rapdy2FttV2eYQrjKrnPA74HYe/aq1tbyXd1FbwLuklYIo9zV7SXexA1eLfutLqIYXoQwckf+O4/Gi/1OE63e3ekxeRFPuCBhygbqR6E8/gTV3afKkRZW5mbWv29smqafpsStewizjW2CSCMFjnnODksfp1FZ1lcR6gbbRo7aYRS3AKoZ+Fc4Ut93PSl1+V4LnSJYjtdNPt2U+hAyK0JpbS28aX+p2MkbRW8DXI2nK+YygAZ/33Fc60guun4/0zoes36/gYeteQl+beC1jga3zE5ilLrIRxuyR1rOoPJyaK64qyscknd3Cuu+HpP2rVFzxshOPcmT/AVyNdb8Pf+PzVP+ucH85K5sZ/BZ1YP+MjuKQ0GivCPdCkooNAgNJRR3oA5Tx+ZHsdGtImRftOtWobe4XIjYzEc9T+66Vst1POfcd6x/FzxvrnhKFxktqzyAH/AGbS45/Mitc1D3AjaomqVqiakMiaozUjVGaAImqNuhqRqjboaAOB+JRxcaP/AL83/oIrloSciun+Jf8Ar9G/66Tf+giuXhNQykU/EvzLpY/6ef8A2WmCE+lS6+uf7L/6+h/KrAi9qSApiI+lL5J9KueV7Uvle1MCkIjS+UaueV7Uvle1AFMRUvlVc8r2o8r2oAqeV7Uvle1WxFzS+V7UAVPK9qXyj6Vb8ul8ugZT8s07yzVry6XyxQBV8s0eWateXTvL9qAKojNL5dWvL9qPK9qAK3ln0rmvLzfX3/Xc/wDoIrr/AC/auZEf+m6h7XB/9BFMRXsbZbjWbe3kGVlkCkfWtTwTG8NzrFvMAGimVWHocEGqelHb4p08E9bhf51saDbNaeJvEUUnX7Sp/ME/1oA9n+Edws3w+hgQY+yXM8JH/bVm/kwrt687+DzImjazbK2THqjt9A0aH+ea9ErREhXMeNP+SSeIP+wHc/8Aohq6euY8af8AJJfEH/YDuf8A0Q1c8v48fSX5xLXwP1X6nw7RRRWgj0D46f8AJbfEf/XWL/0Slef16B8dP+S2+I/+usX/AKJSvP6ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD9IqKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigArkNZVR8VPDz4+b7Ddj8Mx119ctrUa/wDCx/DkmPnNtern2xFSewLc6P8AGuV8BKE0/V1HQaxdf+h11Vc14KQR2+tKOg1m6/8AQqg0M7TQB8c9XI6nRof/AEYa7vNcPp64+N2qH10aH/0ZXcVcTNhRRRTAKrWv/Hze/wDXYf8AotKs1Vtf+Pm9/wCuw/8ARaVz1fjp+v8A7ay47S9P1RapM0UV0EHnfxS/4/dH/wCudx/OKuFr0D4l2V5dXOkvZ2dzcqiThzBA0m0kx4ztBxnB/KuJ/srVP+gRqX/gDL/8TXv4OcVQSb7/AJnhYuEnWbSKtFOuYbiyeNb20urYyZ2edbum7HXGQKbXcmnqjjaa0YUUUjMFGWOBTELRVoaXqZGRpOpEHoRZS8/+O0f2Vqn/AECNS/8AAGX/AOJrP2kO6L9nPsyrRVr+ytU/6BGpf+AMv/xNH9lap/0CNS/8AZf/AImj2kO6D2c+zKtFWv7K1T/oEal/4Ay//E0f2Xqn/QI1L/wBl/8AiaPaQ7oPZz7Mq1a0v/kPaZ/1/W//AKNWj+y9U/6BGpf+AMv/AMTVnS9L1Ma5pzNpeoIq3sDMz2cihQJFJJJXAAAqKlSHI9VsXTpz51o9z2bNJRSV8yfRi8Un0opKYBRSGigBc0lJmigBaQ0E4pCaAA0maDSZpgKeaQ0hpDQApNJmikoADRmkNFAHm3j7/kbF/wCvKP8A9Dkrm66Px9/yNa/9eUf/AKHJXOV9Fhf4MT57FfxpBV976C5uFkvIXeOJFjigjfaAo7FsH6njkk9KoUVu0mYJtF281W4u/JUbYIbf/UwwgqsfuO+fckmrV1r8uoaQbTUoUuZ0K+TdtxIgHUE/xD6/rWRRS9nHTTYrnlrruFa9r4jubaxitJbWyvIoc+V9qgDlATkgH0zUOiadFql7JBPI8SrC8m9FDEbVz0JHp61YOlaaNIGo/wBoXXlGcwbfsa7twUNn/WdMGonKDfLIqCmlzREu/E13dadJYx21naW8pBkS2gCbiOmfyrHrpovDenf8JD/ZMt/dPLsLZW2VV/1e8c7z/L/GuZopuG0PX7wqKe8/Q1brWYbk2/madDN5NtHAPOd/4BjI2svX3z0pqaxFHBLCmk2QjlxvG6bnHI58ysyiq9nG1ifaSvcu3mopd2sUCafaWwiJIeFW3HPYksc/jVKiirSSVkS23qwrrPh9/wAfmqf9c4P5yVyddZ8Pv+PzVP8ArnB/OSuXGfwWdOD/AIyO4pKKDXhHugaSiigAo6DNFJz2oEcV4wB/4WF4J+ZgBNd/KMYOLc4P6mukbgkVzni0Y+IPgtsfL514v4mAkf8AoNdG1Q9yiJqiapWqJqQETVGakaozQBE1Rt0qRqjagDz34nNtm0X/AK6y/wDoIrl4OSK6b4pEibQ8DP76T/0EVzNv94VDKQzXF/5Bf/X2P5VfEWO1VNZXP9l5/wCfxf5Vq+XSAreXR5dWvLpfLpgVRHS+XVny6PLoAreXQIxVry6Xy6AKvl0vl1Z8ul8v2oAq+XS+X7VZ2H0pfL9qAK3l+1L5ftVjyz6Uvl0AVvL9qXy6seXS+XQBW8ul8urPl0bKAK/l1y6Rk32p56C5OP8AvkV2Pl1y0CZ1DVh6XP8A7KKYGEZzb+I7JgcbJlP6119l/wAjp4j95Yf/AECuF1A48Qw+zr/Ou6tOPG3iP/rpD/6BQB6F8INyat4lQ/dL28i4PqjD/wBlr1EV5R8LLjZ4y1u1AGHtIH6f3Wcf+zV6vWiJFrmPGn/JJfEH/YDuf/RDV09cx40/5JL4g/7Adz/6IaueX8ePpL84lr4H6r9T4dooorQR6B8dP+S2+I/+usX/AKJSvP69A+On/JbfEf8A11i/9EpXn9ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB+kVFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFGaACjNJmjFABXMaz/yULw3/wBe97/KKunrltdYr8Q/DGB1hvAfyipPYFudJXOeDf8AVa3/ANhm6/8AQq6OuY8FS7zr8eP9XrNzk+uWBqDQrWS4+NOoH10aL/0bXa1xtopHxlvWzwdGjx/39rsc1cTNhmikpaYBVa1/4+b3/rsP/RaVZqta/wDHze/9dh/6LSuer8dP1/8AbWXHaXp+qLNJRmkJABJOAO9dBAtcx4o8Z22hBrW0C3Wokf6rPyxZ7uf6dT7daxfFHj7Jex8OyA9VkvRyB7R+p/2unpnqOD7kkksxLMzHJYnqSe5r08NgnP3qmx52Ixih7tPcmvLu51C9e7v5mnuH4Lt2HoB2HsKhp0cck86QwRvLNIcJHGu5mPsBXcaD8O2fbceIW2jqLOJv/Q2H8h+Z6V6dStToRs/uPNp0qleV195ymkaJqGuzmPTYNyqcPM/Ecf1Pc+wya9J8P+CtP0QrcTf6ZejnzpF4Q/7C9vryfet+CCG1gSC2iSGJBhURQqqPYCpM141fFzq6bI9ejhYUtd2FFJRXGdYUUlGaACjNJmkNAC0ZpKQ0wFpM0UlAC0UlJmgBaKTNGaAA0UhNISaAFNIaTPrQaYBmkoNJQAGjNITSGgBaQ0UZoAKQ0ZopgebePf8Aka1/68o//Q5K5yun+IEDp4ht7gj93NaiNT7ozEj8nFcxX0OFf7mJ8/il++kFFFFdJzBRRRQBpaFemy1AFBL5kw8pGim8sruOOu0/pzXVw6quk3d9De6hN5yRNEqSX7yDfkDjMeBjk55+lcXp3/IUtf8Arsn/AKEK7PWbmVdbu1W+ukAlb5V1tIgOeyFfl+lcVeKc7Nbo7KEmoXvsQLqRtdJl1M3VzdRCT7P5Z1OQ5LKf9gcgc1xZxk44HbNdbrUjSeCsvPLMRqC8y3q3JH7tv4gBj6VyTKVYqwIIOCD2rTDpWbM67d0hKKKK6TnCiiigArrPh9/x+ap/1zg/nJXJ11/w/hcNqVxj925jjB9Su4n/ANDFcmMf7lnXg/4yO0NJRRXhHuBRRQaAA0lFGcUAch4wMaeK/BrMcN/aE4Hpzay/1xW83pXG/FKVrfVPBcynGNdiT/vsFf8A2auyb6YqHuBE1RNUrVE1IZE1RmpGqM0ARNUZqRqjNAHnPxUOJdC97iQf+OiubtfvCul+KmN2hsQTi5fHtla5u0Hz1DKRJq6gnS/+vxK2/L4rJ1RAW0zcD/x+pjmt/wAv1pAVtlKEqxs9qNntTAr7B2pQlWAntRs9qAINgo2VPs9qXy6AK+yl2VP5dHl0AQbKNlWNlGygCDZS7Kn2e1GygCDbS7Kn2e1Gz2oAg20bKn2e1Ls9qAINlcpbp/xM9Z9rn/2UV2YTnpXJWq/8TXW/a4H/AKCKYHE6iQfEK/7Mij9a7+3jKeNfEJP8TQkf98mvO7w7vETEf89h/OvS+vjTWvpD/wCgtQB03wzO34n3q/39KzjP92Vf8a9jrx/4cn/i5L8DnSpe3/TWKvX60RItcz40/wCSS+IP+wHc/wDohq6auY8af8km8Qf9gS5/9ENXPL+PH0l+cS18D9V+p8PUUUVoI9A+On/JbfEf/XWL/wBEpXn9egfHT/ktviP/AK6xf+iUrz+gAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA/SKiiigAooooAKKKKACiiigAooooAKKKKACijNJmgBaKTNFAC5pM0mKWgApMUtFABRSZozQAtcl4hfb8Q/Cvul4P8Ax2OuszXH+Jm2/EXwj7i8H/jkdD2BbnWfWuR8CuGu/EyjOU1qfP4kV11cX4BcHVvFq911qXP5CsjQtQJj4vXB9dGX/wBHV11crGpHxXkYjg6MMf8Af6uprSOxm9wozRRTEGarWv8Ax8Xn/XYf+i0qxWFqniKx8PreS3j7pXmHlQJy8h8tOg7D1J4FY1IuVSml3/8AbWWpKMZN9v1RrXt9badZyXV9MkEEYyzueB/ifavLfE/jG614va2u+207oU6PN/veg/2fz9Bma1rl94gvBPfuAiHMVuh+SL/E+5/QcVBp+nXmrXf2bTbdp5BjdjhUHqzdB/nGa+hoYSNJc9Xf8jxK+KlVfJS2KvCjsAK3tB8Iajru2bH2SyPP2iVeXH+wvf6nA+tdhoHgGz04pc6qVvrochSP3UZ9gep9z+Qrrazr4/7NL7zSjgetT7jM0Xw9p2gwFLCH94wxJO/Mj/U/0GB7VqZpKK8ptyd2emkoqyCikozSGFGaTNIaAFzSGikNMBaQ0UlAC0lFJmgBaTNFB60AFB60maTNAC5pKKSmAppCaDSZoAKQ0ZpCaAA0UhooAXNIaM0maYC0hozSE0CA0ZpCaSmBS1fSbXWrE2t4p253K6nDI3Yg+tcTP4B1ZJSLa5s5o+zSM0Z/EBW/nXoZpK2p16lLSLMKlCnV1kjzn/hBNc/vaf8A9/3/APjdJ/wguuf3tP8A+/7/APxuvRzSZrb67W7mX1Oj2POf+EF1z+9p/wD3/f8A+N0f8ILrn97T/wDv+/8A8br0XNITR9drdw+p0exw1r4a8TWUYS3k0sANuBY7iD9TETU8mi+LJZGklm0l3Y5ZmUEk+58muyzRU/WZt3dvuKWGppWV/vOOXSfFyRhEuNKVA4cKAAAw6H/U9feuY1hr86xcLrBVrxCA7KBhxjgggDPHfFer1yPjvSvMto9VhX57f5Jsd4yeD+BP5E1th8R+8Sklr5GOIwy9m3G+nmcTRRRXsnjiMSEJUZIHA9a27Twjq17Zw3Vu9gYpkDqTO/QjP/POsWu28B6h5ljPpzn5rdt8f+4xz+jZ/MVyYqc6cOaB1YaEKk+WZn23gPUHmAvrq3hi/iMDM7Ee2VAH15rtbKyg06yjtbRNkUYwo/mT6kmp6K8epWnV+Jnr06MKfwoKKKKyNgoNBpKACiiigDyT9oG5ey8O6DeRkh7bVEmBHqqM3/stekg5QH1HrXm37Qieb4R0pDwGvypP1hkrqfAmpDV/AGiXvmea72cYkY95AoD/APjwNQ9x9DcaomqVqiagREajapTUTUhkTVG1SNUbUAcF8UrcvpWnTjAWK9UE/UGuUsuXGa7b4m2zz+C5nj/5d5o5jz2Dc/zrirHqDUMpFvUVJOmfdx9tjz69a6Py+vFYGoLk6Yf+n6LP510+w0gK+yl2e1T7PajZTAg8v2pdlT7KNlAEHl0eXVjZRs9qAK/l0uz2qfZRsoAg2UbKn2UbKAINlLsqfZRtoAg20bKsbKNlAEGyjbU+2jbQBBtrkbVf+Jxrw/6eF/8AQRXa7a421GNc1/8A67r/AOg0wPOZTu10nP8Ay3/9mr01Mt4v11+wkjQfgmf615i//IbP/Xx/7NXpunT/AGm91a5K4El84HuFVV/oaBHU/Ddt3xNmUdE0p/1lj/wr2GvF/hlOD8W9QgwMjSA3uP3oz/SvaK0WwgrmfGn/ACSbxB/2BLn/ANENXTVzPjT/AJJN4g/7Alz/AOiGrnl/Hj6S/OJa+B+q/U+HqKKK0EegfHT/AJLb4i/66xf+iUrz+vQPjp/yW3xF/wBdYv8A0Slef0AFFFFABRRRQAUUUUAdf8M9PtNS8Vvb6hbRXMX2Z22SqGGQV55r1n/hD/Dv/QFsv+/Iry74Tf8AI6N/16v/ADWva69zAwi6N2up4uNnJVbJmL/wh/h3/oC2X/fkUf8ACH+Hf+gLZf8AfkVtUV3ezh2Rxe0n3Zi/8If4d/6Atl/35FH/AAh/h3/oC2X/AH5FbVFHs4dkHtJ92Yv/AAh/h3/oC2X/AH5FH/CH+Hf+gLZf9+RW1RR7OHZB7SfdmL/wh/h3/oC2X/fkUf8ACH+Hf+gLZf8AfkVtUUezh2Qe0n3Zi/8ACH+Hf+gLZf8AfkUf8If4d/6Atl/35FbVFHs4dkHtJ92Yv/CH+Hf+gLZf9+RUdx4R8PJbSuujWQZUJB8kdcVvVFd/8ec3/XNv5UOnC2yGqk77s+YqKKK+VPpgooooAKKKKAP0iooooAKKM0ZoAKKTNGaAFopM0UALmkzSYpaADNFFFACYpaKTNAC0UmaM0ALSZopKAFzRmikoAWkozRmgBa4zxUwX4i+Dge5ux/44ldlmuJ8XNj4jeC895Lr/ANFpSewLc7OuH+HxB13xkM8jWpM/98iu4rhPh4f+Kj8bDuNab/0EVmaGwP8AkqJ/7A3/ALXrpa5ncB8UwCwBOjcA9/31dLWkdjOW4tFIzhFLMQABkk9q888T+Pmm32Xh6Tan3ZL0d/UR/wDxX5etb0qUqsuWKMatWNJXkbXijxrb6Lvs7ALc6hjlf4IfdyO/+z1+lecahcz3s0FzdyNcXUyYL4yzne2AAPyAFWdD8N6jr75so/Lt93z3Uudmc847ufp+JFej+HfDljo7SbVE9zAfKFzIBv2lQxA9Blj07YznFdNaVLCypqOsr/8AtsjkhGrilJy0jb9UcnoPw/ur3bca0WtIDyLdT+9f6n+Efr9K9DsbC1020W2sIEghXoiDH4n1PuasZpM1z1a86rvJnVSowpK0ULRmkpM1ibC0UlGaADNIaM0hpgLSGikoAWkopM0ALSZooPWgAoPWkzSZoAXNJmjNJTAWkopKAFpM0GmmgBc0hopDQAtITRRmgAopM0ZpgBpM0GkNMQUGkoNABQaSkNAC5pKOtJ0oADRRSGgAoNFFABRRSGmAGmSxJPC8Uyh45FKsp6EHgin0lAjyTUdPfStTnsZST5R+Rj/Gh+6fy4PuDVeu58c6X9osE1KFcy2mRJjvEev5Hn6Zrhq9/DVfa00+p4GIpezqW6BV7RNQ/svXba6ZtsZbypv9xuM/gcH8Ko0jKHUqwyCMEVtOKnFxfUxhJwkpLoex0Vj+FdSOpeH4XkbdND+5lJ6ll7/iMH8a2K+blFxbTPo4yUkmgoNBpKRQUUUUAFBoNJ160AeU/H8H/hE9J7n+0x/6JlqD4D6kbz4cfZGxmwu5YR6kNiQH/wAfP5Va+PoJ8HaUcE41Rc4/64zVxP7PV+sGp6vprE5uIUuEB6fI7K3/AKEn5VD3KWx7o1RNUrZ5qJqQiM1E1SmomoAiao2qQ1G1AGL4psl1HwtqVq2cPbt09QMj+VeWaFIJ7GCQcZUZ/lXtDgMCGGQRgg968dsbY2Gqahp7Nk2106jjsTkfzqWNGperkadxx9uiz+ddVt5rmbsfLp//AF/Q/wA66zbUoZDt9qNvtU22jbTAh2+1G32qbbRtoAi2e1G32qbbRtoAh2+1G32qbbRtoAh2+1G32qbbRtoAh2+1G2ptg9aNvvQBFto21Lto20ARbaNtS7aNtAEW2uJgGNe8Qf8AXZf/AECu721wo+XX/EP/AF0T/wBApgeY3Mnl6hLKOqylv1r0/QA50SCSUYefdMcf7bFh/OvLZ42ub0woMtNNsAHck4r15ESysVRRhIYwBk9gKYh/wikaT4zazMG3I1k0QP8AutET+pr32vAvgwNvjWGdo9rXljczHn+9LGR+mK98q4iFrmPGn/JJvEH/AGBLn/0Q1dPXMeNP+STeIP8AsCXP/ohqwl/Hj6S/OJa+B+q/U+H6KKKsR6B8dP8AktviL/rrF/6JSvP69A+On/JbfEX/AF1i/wDRKV5/QAUUUUAFFFFABRRRQB2/wm/5HRv+vV/5rXtdeKfCb/kdG/69X/mte117+A/g/M8PHfxvkFFFFd5whRV610i6vLB7uHyREkgjYyTLHgkZH3iBWt/Yzf8ACHBsWX2j7eR5v2mL7nlj5d+7HXnGfespVIx0uaRpyetjm6Kv3OjXVppqX0xgMLymIeXOjkkDP8JNLo1jc3Wo28kNpNPEk6eYUjLADI6/hVc8bcyZPJK9mjPorrH8OS3XjKSO8s5Lewnupoo2jQRjChiuBj0Awcc89eazbW10y60jU7lbe6R7WJCm64VhlnCj+AetQq0Xt5fiW6Ulv5/gYtFFFbGQVFd/8ec3/XNv5VLUV3/x5zf9c2/lSewLc+YqKKK+SPqgooooAKKKKAP0hzRRRQAmKMUtJmgBaKTNGaAFopM0ZoAWkzRmkoAXNGaSloAM0lGaM0AFLSZozQAUZopM0CFzRSZpaYwpKKSgQua4fxiR/wALF8EZ/wCe11j/AL9rXb1w3jP/AJKJ4GP/AE8XX/osVL2GtzuBXBfDv/kZ/HH/AGGT/wCgCu9FcF8PP+Rr8dD/AKjH/sgrPoadS9cED4x2nT/kDP1/66109/qNrpdk93fzrDCg5Zv5Adz7CuA8V6xDoPxVsdRuI3kSPSJFCr/Exk4Ge3Q8+1EOga740vVv9ekaxsxzFFjDBf8AYU9P95uT6Yrro0rrmm7L+tjlq1LPlgrv+tyhrniXUvFt4NP0yCYWzfdtY/vyj+9IegHtnHqT23dB+HkMO2419luJByLVD+7X/eP8X06fWur0vR7DRbXyNOt1iU8s3VnPqxPJNXK2nibR5KSsvxMoYe8ueo7v8ARVjRUjUKqjCqowAPSoLb/j4vP+uw/9FpU9V7b/AI+Lz/rsP/RaV5lX46fr/wC2yO2O0vT9UWM0ZpKM10kC5pM0lFAC0hozSUALSUUmaAFpM0ZpM0ALmkzRmkoAXNJmjNJTAXNJRmkoAXNJQaTNACmkzSZpKAFzSGijNABRmkzSZpgLmkzRmkoELmjNIaSmApNJmg0n1oAM0ZpD7UdaADNGaTpRQAZpCaKDQAZooooASjNBpKYC5opKDQIKDSUUAI6LIjJIoZWGCpHBFeUappzaRq09i2diHdCT/FGfu/lyPqK9YrmfG2lfa9LF/CuZrPLNgctGfvD8OD+B9a68LV9nUs9mcmKpe0p3W6ODoo6jIor3TwzofBWofZNbe0dsR3ifL7SLyPzGfyFegV4+skkMiTQHEsTiRD/tA5Fes2N3Hf2EF3D9yZA4HpkdK8bHU+WfOup7GCqc0OV9CeiiiuA7woNBpKACiiimB5b8fs/8IVpYHfVkz/34mryP4Sai2n+PdHkMuyO5ee1k9wwLAf8AfSLXrnx+48FaX/2Fk/8ARE1fP2k3jab9kv0Xc1ndi4A/3Jcn9AazluUtj6+YY4HYYqJqeriSJXBBDDIIpjUhEZqJqlNRNQBEajapDUbUARNxXm/iq0+w+OUnXPl6hBzxxvT+uK9IPWuT+IFi0/h9b6FczafKJ1/3ejD8qTAw7sYXTv8Ar/h/nXX7a4y5lSW10yZGyj3sDA+ozXb4qCiPbRtqXFGKYEW2jbUuKMUARbaNtS4oxQBFto21LtpdooAi20bal2ijbQBFto21LtFG0UARbaNtS7RRigCLbRtqXFJigCLbXBSDGv8AiL/eT/0A16FivP7kbfEPiLPrGf8Axw0wOC8LWf27xZESMpb7pm56EcD9a7jxLMY9EmjjH7y4IhTnHLHH9ayfANgYtOn1CRfnunwhP9xf8TmrOsSi68Q29sMFLNPOfv8AMeFH8zQ9g6nUfDIJD8SLKGMfIunTIuD6GP8Awr3KvDvhnNGPiFbRkfvGtZSMegxn+le41cdiWLXM+NP+STeIP+wJc/8Aohq6WuZ8af8AJJ/EH/YEuf8A0Q1Yy/jx9JfnEtfA/VfqfEFFFFWI9A+On/JbfEX/AF1i/wDRKV5/XoHx0/5Lb4i/66xf+iUrz+gAooooAKKKKACiiigDt/hN/wAjo3/Xq/8ANa9rrxT4Tf8AI6N/16v/ADWva69/AfwfmeHjv43yCiiiu84TotPaBfA16bqOSRPtsfyxyBDnae5U/wAqlMmnf8IMD9luvK/tEjb9pXdu8sc58vpjtj8ax7bWbyy02SytJTCkkokZ4yVfIGMZB6Vv2Mmsap4PZbC5uZ7tL/LbZzvCeXx3zjNcc4uLu9r9zrhJSVl27FPUGgbwNZG1jkjT7bJ8skgc52juFH8qreFLZJ/EVvJNxDbHz5Dn+70/Nio/GtSHRvEV7GYNYWT7LDHLIrXMgwrlCAdxOeuPasXR7tkuLa0RQolu42lbP3wGG1foDk+/HpTTvCUYv+mJq04ykv6R1FnFp7eOjc28rx3aahPHNbvyGG2Q71PpxyOetc7pX/Iua7/1yh/9GrV+7b+ydZ1rUpflmknnhtFPBJZiGkHsBnnuT7GqWhoLjStXtFliSaeKPy1lkVA22QEjLEDoKiKtHm6e7+DKk7yt1978jEorQ1qzjsb5IoZYJB5EZbyHDhX2AMCRxncCfxrPrsi1JXRySTi7MKiu/wDjzm/65t/KpaZKnmwvHnG5SufTNNiR8wUV0fi3wdeeGLwkgy2bn93MB+h965yvlJwlCXLJan1EJxmuaOwUUUVJQUUUUAfpBmjNJS0AGaSjNGaACijNGaAFpM0ZooAM0ZopM0ALmjNJmjNAC0UmaM0xBmjNJmjNAC5pKKM0AFGaSigBc0ZpM0maAFrhvGv/ACUPwL/19XH/AKLFdxXC+N/+R/8AAv8A1+z/APoqlLYa3O7FeXeGLrVIPFnjS20Wy865uNVys8xxDCoQAsx6nnOAOeD6V6eyCRGRs4YYOCQfzHSuD+HkUcHivxvFCgjjTVEVVUYAHljpURaWrRUk3ojOttHk034x6VDqF6+ozz6fNdTSzKMGQMANo/hAHT616bXB6t/yXfQffSLj/wBCFd3WvM5asjlUdELSUZpKAFqtbH/SLv8A67D/ANFpViq1v/x8Xf8A12H/AKAlc9X46fr/AO2yLjtL0/VFnNJk0Uma6CBaKTNGaADNFJmjNAC5pM0maKYC5pKM0hPNAC0lGaQmgBc0maTNIaAFzRmkpKAFzSUUmaAFpM0ZpM0wFoNJmjPrQIM0lBpKYC0lBpKAFNJRSZoADRRmkzQAtJmikoACaM0UUAFJS0hpgFBoooEFJQaSgBc0lFFABRRRQAUEAghgCD1BoNJQB5XrOmHR9YmswD5X+sgJ7oeg/A5H4D1qlXf+MtKN9pH2qFc3FnmQY6sn8S/kM/UCuABBAIOQa97C1faU9d0eDiaXs6mmzCuz8B6hutrjTXbmFvNiH+wx5H4Nn/voVxlXNI1D+ytZtrwnEatsl/3G4P5cH8KeJp+0ptdRYap7Oomeq0GkorwD3wooopgFBoNJQB5f8fP+RI03/sKp/wCiZq+erOMSac0Z6MZFz/wI19FfHWCSXwJaOi7lh1GN3Ofur5ci5/NhXzxZcWxxz878f8CNZS3KR9NfD3Uhq3w80a53Fn+zLHIT13p8rfqDXQNXzl4K+JGt+FbKXS7OzTU4GnkeGI7t0XzHdjaOmTn6mugPxz1hoDMuhWZUDOfPbt17UriaPaDUTVX0nUV1fRbPUEQxrdQrKEPJGRmrDUwIjUbVI1MNAETVBPEk8LxSAFHBVge4NTtUTUmB5S8badINGlJ32Wpw+XkfeiLZU/0/CvScVyXj3SV+36VrEbbGjuo4pgP+Wilvlz9DXXgdqljQ3FGKfikxQMbijFOxRQAm2jbTuaOaAG7aMU7mjmgBuKMU7FGKAG4oxTsUYoAbijFOxRigBmKMU/FGKAGYrzDxDcPH4g1u2gOLi7lhhjHuVOT+Aya9SxXnFxZRzfETU7ts5gSNFHbJB5/pTAtRRwaVpiouEhto/wAgB/WuXsGeaGW9lBEl2/mYIwQvRR+Q/Wr/AIluLu7W40/TrOW4jtYBd37rx5cAPOfr0qAuCAVGAeg9B6UmCOw+GSx/8JvbSFRv8uRQ3oNpP9K9vzXiHwyZf+ExtQc5w4H/AHwa9urSOwpC1zPjT/kk/iD/ALAlz/6IaulrmfGn/JKPEH/YEuf/AEQ1Yy/jx9JfnEpfA/VfqfENFFFWI9A+On/JbfEX/XWL/wBEpXn9egfHT/ktviL/AK6xf+iUrz+gAooooAKKKKACiiigDt/hN/yOjf8AXq/81r2uvFPhN/yOjf8AXq/81r2uvfwH8H5nh47+N8gooorvOEKKKKAClVmRgyEqwOQQcEGkooAVmZ2LOxYnqSc0lFFABRRRQAUUUyV/KheTGdilseuKAIr6xttRs5LW8iWWGQYZWFeKeNPAtx4cma6tA02nseG6mL2Pt7/5Ps2l6tZazZLdadOs0beh5HsR2qzPBFcwPDOiyRuMMrDIIrlrUIYiPn0Z00a86Ev0PmGiu98cfD2XSGfUNHRpLI8vGOTF7/T/AD9OCr5+pSlSlyyPdp1I1I80QooorM0P0fzRmkzRmgBaKKKYBSZozSUCFzS03NLmgAzSUZozQAZozSUUALmjNJmkzQAtFJmigB2abmjNJmgBaKM0maADNGaTNGaYC1wnjhsfEDwIvrfT/wDoqu6zXB+Of+R+8Cf9hCb/ANFUpbDW539cL4D/AORz8c4/6Caf+ixXdVxHgfA8Z+N8f9BGM/8AkIVj0NCtrJx8efD2P+gTc/8AoQrvM1wWtH/i/Phz30q5/mK7vNaw2IluLRSZozVEi5qvbH/SLv8A67D/ANAWps1Xt/8AX3f/AF1H/oC1hV+On6/+2yLjtL0/VFnNJmjNJW5AtGaTNJmmAuaKSjNABmkzQetJQAuaTNIaKAFzSUlFABmikooAWkzRSZpgLmkzRmkoELmkopKYC0lFJQAppKKTNAC0maQ0UABoopKAFpKM0UAGaKSigAozQaSmAuaKSjNAgozSUUAFFFFABRQaSgBTSUUUAFFFFABXl2vaX/Y+tS2yLiCT97BxwFJ5X8Dx9MV6iawfF2lHUtHMsKFrm1JljA6sP4l/EfqBXThqvs6muzOXE0vaU9N0eeUhAZSDyDwaFYMoZTkEZBpa988I9F8J6idQ0CISNumt/wBxIT1JXofxXBrbrz3wbf8A2PXjbucR3i7fo65K/mNw/KvQjXz+Ip+zqNHv4ep7SmmJRmiisDoCiiigDzP47DPgayPpqSf+ipa+ebHiA/8AXRx/48a+iPjoAfAlp7ajH/6Lkr54s+IG/wCur/8AoRrKW5SPS/gZCkXxJ0d0GDNZXhf3PnY/kBXCiHdp1w3c+Z/Wuq+GWv2nhvxr4dv9RZ0tfIuopZFUkRBrhwGb/ZztBPbNbeo+CPCDTXaaT8R9MitZGcxRTgMyBsnBYHnr1xUjPQfBP/IiaL/15Rf+g1sNXmHhzxZpdpYWOkL8QtOi8iMRBm01tg2j++zDjjrXSDW9KI/efFPQwfa0X/4ummKx0xqNq58axoePn+KmjZ9rRP8A4ut/SfDVzr9kLzR/G9re2zHAlh09WH6SU7hYY1RN3rUb4da02P8AirFGPTTF/wDi6Y3w11phj/hL8fTTV/8Ai6VxWOE8f/8AIBt/+v6D/wBDroB7Vc1P4O6jq1ssF54vkKLIsg26eo+ZTkfxVY/4VXq+MHxnN+Fgn/xVJjRl4NHNaX/Cp9W/6HW4/wDAFP8A4qmv8KtbijZ7XxlJJKB8iz2S7Ce2cNnFAzPFLVKC4urbVrnRdZjWLUrVQ7bM7JkPSRM9icj2Iq7SAKKXFFACUUtFABSUtGKAEopcUYoASilxRigBKMUpqjfz3ZntdO0qES6hfuY7cODsXAyWYjoAOaALhFcDeSJbeLddmmIWNFiZj/wE10N6PCun6j/ZeueIPEOo6pGxWY6bGVhDgZKqAp6fWua1a08Gm7mVPD3jfUEmA8yUSqgfHYhgDQBZ8IXD6h4E+I19PGqmTTlEXHIj2vjP5ZrlYj/o8f8AuCusj8WaNpPgTxBougeC9YheaDN7JqU6qfLIIyXGcYAOBiuQtjutISe6A/pSY0dp8NSB42svcyY/79vXudeE/Df/AJHjTwfWT/0W9e61rDYmQtcz40/5JR4g/wCwJc/+iGrpq5nxp/ySjxB/2BLn/wBENWMv48fSX5xGvgfqv1PiGiiirA9A+On/ACWzxF/11i/9EpXn9egfHT/ktniL/rrF/wCiUrz+gAooooAKKKKACiiigDt/hN/yOjf9er/zWva6+Yra7ubOQyWlxLA5G0tE5UkemR9Ktf27q/8A0FL3/wACH/xr0cPjFRhytXPPxGEdafMnY+k6K+bP7d1f/oKXv/gQ/wDjR/bur/8AQUvf/Ah/8a6P7Sj/ACmH9ny/mPpOivmz+3dX/wCgpe/+BD/40f27q/8A0FL3/wACH/xo/tKP8of2fL+Y+k6K+bP7d1f/AKCl7/4EP/jR/bur/wDQUvf/AAIf/Gj+0o/yh/Z8v5j6Tor5s/t3V/8AoKXv/gQ/+NH9u6v/ANBS9/8AAh/8aP7Sj/KH9ny/mPpOivmz+3dX/wCgpe/+BD/40f27q/8A0FL3/wACH/xo/tKP8of2fL+Y+k6iu/8Ajzm/65t/KvnH+3dX/wCgpe/+BD/40f27q/8A0FL3/wACH/xo/tGP8of2fL+Yfomv6h4fvRcadMUOfmQ8q/1Fez+FPHWn+JIhExFtegfNCx6+4PevBqdFLJDKskLtG6HKspwQfrXBQxM6L01XY7q+GhWXZn0+yq6lXAKngg968q8c/DkxGTU9AiJT70tso6e6/wCH+TJ4Q+J+PLsfETf7KXX/AMV/jXp8csdxCskTLJG4yCDkEV7H7rFw/q6PJ/e4Wf8AVmfMBGDg0V6546+Ha33manoaBLj70sA4EnuPQ15LJG8UjRyqyOpwysMEH0NeJWoSoytI9mjWjVjeJ+jdGaM0lYmo7NGabRmgAzUH262Bw1xDn/roKLwkWU5UkMI2wR9K8+8E/Dnwpq3gbSdQ1LSRcXdzbLJNK08mXY9Tw1AHoP260/5+of8Av4KQ39oOt1B/38Fc9/wqjwR30CFv96WQ/wA2pR8KfBA/5l62P1Zz/WkM3/7Qs/8An7g/7+Ck/tKz/wCfy3/7+CsIfCvwQOnhy0/Hcf604fC7wSpyPDdl+KE/1oA2/wC0rLH/AB+W/wD39X/Gj+0rL/n8t/8Av6v+NYw+GPgpTkeG7D8Y81j+M/h74StfBOrz23h+wimjtJGR1hAKnHWgDuQVYAqcg8gjvRWT4W/5E7Ru3+gQf+i1rVqhDs0mabmigBaKSjNAC5pKSigBaM0lJmgBa4bxwP8AiufAp9NRl/8ARRruK43xoAfFvgs9xqjY/wC/TUnsNbncVxfgwAeNPGmB/wAv8X/ooV2lcb4QUL408Z473sJ/8hCsjQoa5x8d/DZ/6hd1/MV3VcNrwx8cfDLd/wCzbofyruM1pDYze4tFJmjNWIKr2/8Ar7r/AK6j/wBAWp81Xt/9fdf9dR/6Atc9X46fr/7bIuO0vT9UWKM0maSuggdmkzTc0UALmjNNzRQAtGaSkzQAtFJmjNMAzRmkzRmgQZpc02jNACk0lGaTNMBaSkzRQAtJQaTNAC5pM0hooADRRSUAcZd+PZoL65t00pHWCZ4gxuipbaxXONhx09ai/wCFhXH/AEB4v/Aw/wDxuuZ1D/kMah/1+z/+jWqCvbhhKLim0eJPF1lJpM63/hYVx/0B4v8AwMP/AMbo/wCFhXH/AEB4v/Aw/wDxuuasrC51CZorKEyuiGRgCOFHU80thp9xqVyYLRQ8m0vtLBcgDJ5PHSm8Lh1uvxEsVXez/A6T/hYVx/0B4v8AwMP/AMbo/wCFhXH/AEB4v/Aw/wDxuuSoqvqdHsT9crdzrf8AhYNx/wBAeL/wMP8A8bpP+Fg3H/QIi/8AAw//ABuuYtbaa8uo7a2TfLKwVFyBkn602aGS3neGZdkkbFWU9iOopfVKF7W/Ef1uva9/wOp/4WDcf9AiL/wMP/xuj/hYNx/0CIv/AAMP/wAbrk6eIZSMiN/++TT+qUe34h9brdzqf+Fg3H/QIi/8DD/8bo/4WBcf9AiL/wADD/8AG65byJf+eT/98mpLiyubWOGS5gkiSZd0ZdSNw9R/n0pfVKHb8Q+tV+/4HS/8LAuP+gRF/wCBh/8AjdH/AAsC4/6BEX/gYf8A43XN2ljcXzyJax72jjaV+QMKOp5qvR9UobW/EPrdfe/4HWf8LAuP+gRF/wCBh/8AjdJ/wsC4/wCgRF/4GH/43XNXNnPZmIXCbPNjWVOQcq3Q8VDQsJQeqX4g8XXW7/A6v/hYFx/0CIv/AAMP/wAbo/4WBcf9AiL/AMDD/wDG65u8srnT7gwXsLQygA7WHY9DUt3pN9ZZ+0W7BQiyFl+ZQrfdJI4Gfel9Vw/b8R/Wa/f8Df8A+FgXH/QIi/8AAw//ABuj/hYFx/0CIv8AwMP/AMbrlKKr6nR7E/W63c73QfFcmtao1nJYLb4haUOs+/OGUYxtH979K6OvPvBP/I0N/wBecn/ocdeg15eJpxp1OWOx6uGnKpT5pbhRRRXOdB5l4i0v+ydbkjjXbbz5lh9Bz8y/gT+RFZlejeKdKOq6M3krm5tz5sOOpI6r+IyPrivOFYOgZTkEZFe5hKvtIWe6PDxVL2dS62Yu6SNlkhbbLGwdG9GByP1FerafepqOmwXkXCzIGx6HuPwPFeU12HgS/wDkudNkP3D50Q/2SfmH4Nz/AMCrLG07xU10NcDUtNwfU6+iikzXkHrhRRRQB5v8ch/xQdufTUIz/wCOPXzvaf6hv+usn/oZr6J+OC58Axe19Gf/AB16+d7Uf6Ox/wCmsn/oZrKW5SOt8G2sl1qlnsXcsWmXUjg+n2sj+ZFbXg/TYLjwzbyTQxyOS4LMoJPzHvVb4cKG1IA9Dotz/wCnBa6TwHa7/CNucf8ALSUf+RGqBjRoNh/z424/7ZL/AIU7+wrDP/Hlb/8Afpf8K6QWXtSiyHpQByGqaLZR6NeulpApW3cgiIZBCmt/4KMbLxmbW3/dw3elpNKi8BnBwGx0zjvT9bswPD+oHHS1kP8A46ab8KG8nx9p5fA8zR8AnjJBzj8qYHvWBSYFIrE0uaAFxRSZozQAtIRkUZoJoA8q+JQEXxG8NsgCtLaXUbkDlgNhAP4iq4rd+I3h3UdQ1PR9a0m1kv5tPMsT2kTKrFJB94FiBwVHHufSudFj4qxn/hEL7/wJt/8A45QBLRSLpnixhn/hEroexvLYf+1Kd/ZXiz/oU7r/AMDLb/45SASimnS/GGePCVxj/r+tv/jlNbS/Gf8AD4Rlx739v/8AF0ASUVA2meNhjHhF/wAdQtx/7PTTpvjjjHhIfjqMH/xVAFmiqp07xzj/AJFOMe51KD/4qmnT/HX/AEKsA9zqcP8AjQBcoqn/AGf47/6Fe1H11SL/ABo/s7x1/wBC3ZD3OqR0AXaoaeSPifYYJG3TLorjsdvWnf2b46/6F/Tv/Bon+FaPhnwprsniGTXdfis7JLSylgjht7jzjIXHJJAAGKAOA0mNHPhpiP3jG5JOPvH5sk+9dgIF9K5Tw/Er3HhkDJIN0Pb+Ku/Ft7UhnnfiMlI/FUQXAOloc+v364+zy9lb+pjXGPpXfatbK/iXX4ZIDPE+mRhowcbuX4ycVwemf8e1rn/nkv8AKgDrfh0f+K+0vn+KX/0U9e814H8O/wDkoOkj/bl/9EvXvea1jsTIWua8af8AJKPEH/YEuf8A0Q1dLXM+NP8AklHiD/sCXP8A6IasZfx4+kvziNfA/VfqfEVFFFWB6B8dP+S2eIv+usX/AKJSvP69A+On/JbPEX/XWL/0Slef0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV0/hXxzqHhqVYiTcWRPzQsfu+6/4VzFFXCcoPmi9SJwjNcskfR+h+INP8QWS3GnzB+PmQ/eQ+hFc1438Aw65G19pirFfqOQBgSj0PvXkOl6te6NerdadO0Mq9cdGHoR3r2Pwj8Q7LXlS1vytrfY6E/LJ9D/AEr16eIp4mPs6u55VTD1MPL2lPY+prS8t7+0jurOZZoZRlHU8Gpq8b8P+Irvw7dl4My2shzNbE8N/tL6N/Pv2I9Y0zVLTV7FLuwlEkTcHsVPcEdiPSvPxGHlRfkd1DERrLzLlNyKXNcD4X8Mab4i/tq81VtRlmXWLyMFNUuYlCrMwUBUkCgAcdK5jpO5nZRC/I+6ePwrE+HDZ+G+hD/pzSmN8M/DDnLwai2eudXuz/7VrpbSytrG0itbKFIIIlCRxxjCqB0AFIZPRRRQAUUUUAFYHjcb/AutL62cn/oJrfqK4tobq3kguEEkUqlXQjhgeooA5/wrcxf8Ido2ZYx/oEH8Y/55rWsLiJiAssZJ6YYVzg+EfgQY/wCKctuOxZ//AIquT+JfgPwz4a8CXmraDpMVhqFtJE8NzAzK8bbxyDnrTuB6l9aKSjNMQtJmjNJmgBc0ZpM0ZoAXNJmkozQAua5DxkoPibwe3caqR/5CeuuzXK+LkDa74Tc9V1cAfjFJ/hSew+p2Vcj4VQL418X473UB/wDIQrrq5Xw0m3xr4twck3Fuf/IIrI0MvXxj42eGWP8A0D7ofyrtM1xviAEfGbwy3b7DdD9BXY5rWOxm9x2aTNJmkqhC1Bbn9/df9dR/6AtTVXt/9fdf9dR/6AtYVfjp+v8A7bIuO0vT9UWKTNFJW5AtFJmjNMAozSZozQAuaTNJmigQuaM0lJTAXNFJmkzQAtFJQaADNIaM0hoAWikozQAuaTNIaKAFpKM0UAGaKSimB5FqH/IY1D/r9n/9GtUFT6h/yGNQ/wCv2f8A9GtUFfSU/gXofNVPjfqdNpOnFtEEdre2sdzqRKOWkO6OFTkjAGRkgkk8YUetLp1/plr4stxpOntJb+b5YkdnaRlI2sQoPoScEE1S0+90q10KeOVLs3s7bH8llXMfBxuIO0Hvwc49KtWCefBdQrc3mnC3tnnkiSMLuQYwCwILE5HUVzST97m2OiLXu8u5burRtC8+yeSGO+uj5VvBBbq4KFsbnZ8nDY6A5rm47AveTW7XEELREgtK+1Tg44OK6aLUzoFtawLcXN6J7dbi1hlhRljYk7euT1HRSOtcrNJLqOoPIIwZrmUnZGOCzHoB9TV0ebW/3k1eXS33G5o2iyQXmmakLq3khOoxQgIWyx3AnGQKW/0eG38RXdxq0hj0/wA5pFI+/OD8wVB3PIBPQetTtMkHiLQdGgcMmn3MYlZTkNMzgv8AgDx+BpLm2/t9L22h51HT55WiTvNCXJKj1Kkkj2NZ80ubmb0f5X0NOWPLypar87anM3Bha5kNsjJCWOxXbJA7ZNbdiz32gXTLqE1vdWCB1BnbbLH0xjPBBwBjjkDHesNHe3nDBV3oejoGGfcEYP41a/tW4/552n/gHD/8TXTOLaSRzQkk7s39Qa6urnRIvts0ER02OSeXzCAq7m3Mff8AmcCsXWr5dQvpJrVJo7PdiJJJGfHvz0J64rU8QajPFFpOxLf59OjY7raNv4m6ZXgcdBxWPNrN9PYGyeSMWxbd5SQogz68AYNZUouylb+rmtWS1jc3/DMUUmnOv2W3jlvX+xJKxkO8Y3vuAcccKPlx1rOWG11WwuruVIbGPT1jT/Q4SxlDMQCQzjn36+tafhaPWTeaaJ4NunxOTE88SLw3J2Mwyc+1NivDN4c1ZbyeK9jhSBVFugiVRvPAO0d/bH51k21N2fbr52NEk4K67/lcW70yw1PVNPtjeXKM2nRlf9HXBCxFgSd/B46YP171k+HdM+23cl1KivbWQEsqlgu/+6vPYkcnoBmt+CS2PiPTVW3cSHSwVYy5Cj7O3GMc8Vzvh6PTG1BpNZuPKgiTeEKFhKQeFOOff8D0qouXI15L9ewpKPOn5v8ATuX9WtYGtRcatcomr3khuCQ5ZEiPAHyhgc9RyOO/rfv9Rt9N12xvDdXChrCEMkcAYSRlOQcsP5daw7vVEeWeaDN3NLJ5j3Fzbp8o6bQp3ADp37YxXRs6zWGma3eXhtrGO1EciW+I5JZVYjYuMYBwPYAdqmScUubzX/AWg4tNvl8v+H3ONv4Y7e/mihSeONW+VbhdsgHow9ar1Zv5Lma4E128zmRdyNPIXYp2571WrtjsrnHLfQ3/AAT/AMjQ3/XnJ/6HHXoNee+Cf+Rob/rzk/8AQ469B614uM/jM9rB/wAFBmjrRRXIdgV5t4n0v+y9bcxri3usyx+gbPzL+Zz+PtXpNZPiXSv7W0aSKMA3ER82A/7Q7fiMj8a6MPV9lUT6HPiKXtINdTzarOmX50vVra9zhI3xL7oeG/Lr+FVVYMoYZ57HtSkAgg8g17soqcWn1PCjJwkmuh67nIyDkUVh+ENQN7oEccjZltT5D56kD7p/75I/HNbtfOSi4ycWfRxkpxUl1EpaSjNSUed/G/8A5J+hJ6Xsf/oLV8/QQEaVHKBw0sv6O1fQHxwGfh1nst7CT+ZH9a8ctLDzvh9BcqOY7mZW/wC/hNZS3KRr/DV1bVQqkEro84I9D/aKH+Rrvvh1bbvBsPHAnnA/7+tXnPwqH/FSXgx002b/ANLYq9a+GUGfBUXoLq4H/kZ6gZq/ZPal+y+1bH2b2FAtuelAHMa9bY8OakQP+XSX/wBANeWyRzSCzmheSFrTTlmiljkKtG+CMrj/AOt+Ne0+IbbHhjVDj/lzm/8AQDXmWnR+Z4fvie+lW4/9DpgU9Fn8Q6lodrdz+KdaDyxhm2XIA/DirptdaI58Va9/4Gf/AFqteD7Mv4Q05gOsIra+wn0pAc19h1gjnxRr3/gcf8KP7N1Q9fE2vH/uIPXTCxPpThZH0oA5f+y9S7+Jdf8A/BjJR/ZN+eT4i14/9xKT/Gup+wn0pfsJ9KAOXGkXv/Qwa7/4M5f8acNIu/8AoO65/wCDSb/4qun+xe1L9iPpQM5n+ybrvretn/uKz/8AxVPGlXGP+QxrR+uq3H/xddH9i9qX7GfSgDnl0ycDnVNYP11W4/8Ai6cNMm/6Cer/APg1uf8A4uuhFmcdKUWdAHONpLycSahqrfXVLj/4ukOgow+e71JvrqVx/wDF10v2OlFn7UAcufDkDDDT6gR76jP/APF0h8LWbD5nvT7G/n/+LrqvsdL9j9qAOT/4RHTiORdEehvJv/iqT/hDdLI5inP1u5f/AIquuFpQLSgDkf8AhCtH728uP+vmX/4quU8N+J9T8A+N9bl0oST6Zby/6VpzsWEsfAJGejAc5r1v7JXlVhCv/CyPEUZAwXIIPOeRQI7E2mnWlxpvjXw3cvd+FGeR5okXc+nu4w2R12ZPPUj6V38KRXEKTQOskcg3I6nIYdQRXjuiXl98O/ETXekbH029bbcWErjypc/w5P3Tz8rdM8Hiu9sry28P2o17w+0tz4Pnci6tNp83Rpc/NleojB6qfu9RxQBl6wuzxtrI8z/mGxnZ6ctXmmk829t7xKf0r03XXjm8carLbyLJDLo8To6HIYEtgg9wa8y0bm2tv+uK/wAqQzp/h+cfEfSB/wBNJv8A0TJXvleBeAuPiVpA/wCmk3/omSvfK1jsTIWua8af8kp8Qf8AYFuf/RDV0tcz40/5JT4g/wCwLc/+iGrGX8ePpL84jXwP1X6nxHRRRVgegfHT/ktniL/rrF/6JSvP69A+On/JbPEX/XWL/wBEpXn9ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABQrFWDKSCDkEdqKKAPtvxH4B27rvw8oHd7MnA/4Ae3+6ePTHSuU0jWL3QdRM9nlXB2z20oKh8fwsOxHY9R9OK9n/GsHxD4UsteXzT/o96owlwg5Psw/iH6+hFejRxWns6uqOCrhdeeloy9ouuWeu2IuLN+RxJE33o29CP69DWV8OnzZ66v93Xb4f+R2rgpI9X8I6yjkfZ7kfdcfNFOvce49uCOvHWux+Ft4s9lrCTFI7qXU57toQ2SFlcsD7jnGfasa+H5Fzw1izSjX5/cnpI72iiiuQ6wooooAKKKKACiiigArhfjHj/hVuqn/AK5n/wAfFd1XEfF8D/hVur5/ur/6EKAOpzRmm9qKsQtJmjNGaAFzSUmaM0ALmjNNooAXNc34qQNqnhh8/d1hB/5Ckroq5/xP/wAf3hz/ALDEf/oqWpew+p1lczoCbPG3irByTLbH/wAgiumrm9D/AOR28Uf79r/6JFZGhleIVx8X/DLdvsd0P0FdbmuU8Qgj4seGW/h+y3Q/8dFdTWsdjN7i0UUmasQVDb/665/66j/0BalqCA/vrn/rqP8A0Ba56vx0/X/22Rcdpen6osUmaM0V0GYZozSZpKYC5opKM0AGaM0lIaAFzRSUUABopDRQAtFJSUALmikozQAUZopKAFopKM0wCiiigANFFJQI8jv/APkL6h/1+z/+jWqCp7//AJC+of8AX7P/AOjWqCvpKfwL0Pm6nxv1NG31q8gs47O1kjtEBO6aJNsjZP8AE4+Yge3anzalDBp01np4lY3JBuLmbhpADkKACdozz1JP6Vl0Uezje4c8rHRw6vpEkml3F9HeiewjSPZFsKPsYkcnnnPNZMWoCzu559Pi8lmJELM25oVOeh9ccZ+vfkUqKSpxQ3UkzX8PXWlWepQ3GqJdboH81HhcYLLyAVIz1HXNUjqE6as2oWzGCYymVSp+6Sc1Vq7pWmnVbs2sUqxzshaIOOHI5K57cA/lTcYxbkwUpNKKF1bVrjWbw3N2kKyHr5UQXPHUnqencmqNX9J0ttT1BLd5Ps8ZjaV5mXIRFBJb6ZGKqpbyTSulsjTbAWJRSflHVvYU4uMfdXQlqUvefUu6vqMN/Fp6wo6ta2iwOWxyQSePbms2nxRPNMkUY3O7BVHqT0q5qumf2fqF1BBI1zDbSeW84jwob0PXHII/ChcsfdG+aXvEuh6ilnrlnc30kjQ2+ccltowcAD6mk07VIrHS9QtpIBM115e0N90bWJOeQajXTVPh59TefaRcCBItud525Jz2wKoujRuVdSrA4IIwRU8sZN/1tqPmlFL+t9DctPEhjv4ri5s4W8qBoUMYIYDyyqjk47/lWfp+pnTkmCWlpO0oAD3EIkMeM8rnjNUqKfs49he0l3NYa28q7r9ZLxgcrDJJtgX/ALZrjP4EfjViHxM9x5ltrcIu7GTAESAJ5GOAY8cLgdu/esGik6UH0Gqs11NTxBdWN3qKPpZk+zrBHGokXDLtXGD69OtZdFFXGPKkkRKXM7m94J/5Ghv+vOT/ANDjr0GvPvBP/I0N/wBecn/ocdeg14uM/jM9rB/wUFFJmg81yHYGaKSloGedeK9L/s3WjLGuLe8zIuBwr/xD8ev4n0rGr0vxBpQ1fR5bdcCZf3kLHs46fnyD7E15mpJHKlT0KkYIPcGvawlXnhyvdHh4ylyT5lszc8I3/wBi18QucRXi+Wf98ZKn/wBCH4ivQq8hJdcNE22RCGRv7rA5B/MV6npl8mp6Xb3kYwJUDEf3T3H4HI/CuXHU7SU11OvA1LxcH0LdFFFeeegeefG4Z+HD+15B/wChV574MtBffDW5ixk/aJyP++jXofxsz/wraYjtdwH/AMfFcV8LwD4QkUjI+1yg/nWUtykc58Ncw+JdWA4Memz/APpZFXtnwshz4Gj46Xl0P/I714t4Wnj074h61auv+vguYE+dFwftCP8AxEE8KeFBPtgEj3n4Uwn/AIQVQw5F9dg4/wCvh6gZ0X2f2o+z+1aXk+1Hle1AHOeIrf8A4pbVeP8Alzm/9ANeQ6H+98PXTDp9ggT/ANDr3DxHDnwtquOv2Kb/ANANeJeGV3eGrhs8G1hX9XpgdB4Gtt3gjSzj/lgP5mugFp7VW+H9vnwDpJx/yw/qa6P7N7UgMb7J7Uv2T2rY+ze1L9m9qAMYWntS/ZPatj7N7Uv2b2oAx/sntR9k9q2Ps3tS/ZvagDH+ye1H2T2rY+ze1L9m9qAMj7L7UfZfbNa/2b2pRb8jigDH+y4GSB+FKLXnGKzPHtxqen6dpa6LfGwnub5YWm8lZSE8qRyMMMdUFYfhLUvEH/Cwf7G1jW/7St2083IBtY4cNv2/wjJoA7H7L7UfZR6Vr/Z/agW3PSgDIFp7Uv2T2rX+z+1L9n9qAMj7L7V4oVMHxR1/jH7xv5ivoL7P7V4JexBfinr45z5j/wDoS0wNZliu7d4pVDo4wynoRVPR9b1HwLrAntz9otpgInjlJ8u7ToIpTztcDhJTwfutxzUwyh4qWRIb63eC4iSVJBtZHGQ1AFm/0zT9Ls7zxd4PSa68P3cDQXlngmXSXByR5Z5CAk5UfdzkZFcFoXzWduR08lf5VvWOu6v8OtXF/aZvLJwI5VkbiePp5cue46JJzjo2RV/W/D1gumt4w8EI8uhzH/T9OwfN0yTqx29dueq9uo4pNAV/Ax/4udo//XSb/wBESV75XgXgN45fiVo0kbhlLylSpyGHkPzmvfa0hsSwrmvGn/JKfEH/AGBbn/0Q1dLXNeND/wAWq8Qf9gW5/wDRDVlP+PH0l+cSl8D9V+p8R0UUVQHoHx0/5LZ4i/66xf8AolK8/r0D46f8ls8Rf9dYv/RKV5/QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAfovSZpM0ZqhFe/sLTU7N7W/gWaF+qt2PqD1B9xXkFjbarbS6lqml+YItK1K4tBNGdzxrG5ALjupGM9uuR3r2auT+GOCPFI/wCphu//AEOtqdaVLbbsY1KMam+/c1vCfjG38RQCCfbBqCLl4gflkH95PUe3UfqelriPEfgETT/2l4acWd8jeZ5SnarN6qf4G/Q9+pNWvC3jFr+4Oka9GbTV4vlKuu0TfQdm9uh6jjoThGS56e3bt/wBQnKL5Km/fudbRRRXOdAUUUUAFFFFABXF/FpQ3wv1nPaIH8mFdpXH/FVQ3ww1vPa3J/I0Ab9Gab+NJmrEO/GjNJmk/GgBfxopKM0ALmk/GkozQAua57xS4W98OE9P7Yj/APRUtdBmua8YMFn8OM3T+2Yv/QJKT2Gtzsx0rmtDdf8AhO/FEZPzbrU49vJFdLXJaG6/8LM8UIT82y1P/kOsTQg8RAj4n+GW7eRdD/x0V0tc74j/AOSjeGfTyrrn/gAroM1rHYzluOzRSZpKskXNQQH99c/9dR/6AtS1DB/rrn/roP8A0Bawq/HT9f8A22Rcdpen6onozSZpM10EC5opM0ZoAX8aSk/GigBaQ/WikoAWikozQAUUUUAGaKSlpgFJRmigBaQ0UlAgooozQAUZpKKAClpKKAPJL/8A5C+of9fk/wD6NaoKnv8A/kL6h/1+T/8Ao1qgr6Sn8C9D5up8b9QooorQgKKKKACui8NXM0kGowvciKOGxdo2cHEZ3p83AJ7n8652tzSYpU8O6rNFE7yXGy2j2KWJ+bc/TtgD8xWNZJx+41pNqRpu97ZwSJLqF7OzW0cv2y0iMnkxN823kqVBIyT6AdOaG/0V/wDS/E+qqhtFuRhSMhwNqj94cnJHGOx5HWrl/ZyLpt5ZiQLcTQWlpDG3Bdo4w7L9eR+JArL1u9Wwms4ZdNtZpDpsCM1wrll+QZGNwAI9cZFckPe0X6eR1S93V/r5kHg83A1ppYppFhgjaeaNJCplCj5VwD83zEce9aGqW2rhbeaO/ukja3juLg3NySiyE5ICegI6YOM9hXO6dZWl0JnvtRSySMAjMZdnz2UD/GtbxLJZRLpqxwyTv/Z8QSSVto284JQd/wDgWPatZxvV0/Iyg7UtfzLeqXF3BpemW/8AasUUxja4kbcw372+XGF/ugfnXP6vua8Ej6iuoO6AvKN2QcdDuAPHr6VvfarqS8bVtesrVrSNFKlIkZZmAwqK3Ppz6AGuXuZhcXUkywxwB2LeXECFX2Ge1VRVn/w3UVZ3RFRRRXUcwUUUUAFFFFAG94K/5Gc/9ecn/ocdegV5/wCCv+RnP/XnJ/6HHXoFeHjP4zPcwf8ABQlLRRXIdYUUlFABXn3i7TPsGsfaolxBeEscfwyDqPxHP516BVDW9MXV9JmtSQshG6Jz/C45B/z2JrehV9nNSMK9L2tNrqeZV1nga/w1zprnp+/i+h4Yfng/8CNckN3IdSjqSrKeqsDgj86sWF8dM1O3vRnEL5cDuh4b9Dn6gV7GIh7Sm0jxsPP2dRNnq1FICGUMpBBGQR3pa8A+gPP/AI1/8kzuD6XUH/owVxPwtx/wic3teSf0ruPjSrt8MLzYpbbcW5OBnA81a4b4WY/4Ri574vX/APZayluUjjE4+L5Xv9ruB+e419MfCiMDwQRjkahej/yYkr5oQY+Mm09TeT/+gtX018LFK+DZAev9pXuf/AmSpGdltFG0elLRQBmeI0z4X1UAcmzmx/3wa8G8Nru8ITFSAGhgAP8AwJq9818E+G9SA6/ZZcf98GvmvSZp0TRYIpXWGeF98YYgPtwRn1xk0AexfDu3/wCLe6RyG/cdR/vGumFt7VlfDWHPw30bI/5YHv8A7RrqfIHpSAzPs3tR9m9q0/JHpS+QPSgDL+z+1L9m9q0/JHpR5I9KAMz7P7UC39q0/JHpR5I9KAM37P7UfZ/atPyqPJHpQBm/Z/agQc9K0vJHpR5I9KAPOPiagisdBbgf8TZRk/8AXCeuZ8KLv+M8Q/6gz/8Ao0V1nxgQR6NoLemsx9f+uM1ct4HAk+NUQ/6g0n/o1aAPWRB7Uvke1aHkj0pfK9qAM7yB6Uv2celaHle1Hle1AGf5HtXz1qkez4r6915kk/8AQlr6V8qvmbxmzw/EbXTAzIzzMjOOCoMiAkfnTAusvtTMFDkfh71v638LdAsPGfh3TraKa3iv1lD3cE7rKzBcjLZ5PfnNVPEvg3XfBm+aYtrGjg83kUYE0A/6aIPvD/aH4igCiGSeIxygMGGCG6GsfTv7Z8Aa62q+Fz59lJxd6bIflkXPIA+mcdx2yOKvxSxzRJNbyLJG43K6HII9c1M0qtbSI4/hP8qANa10DR9MvdL+JPheG5k8OTB5p7OEfNYuwZGcKRkxglsqOmMjI4r0zT9W0/VofO0u+t72L+/byrIPxwSBWV8EVVvgvoYZQQUmBGOD++eq8Vrb6X8W72w0y3itLRtGgkMMMYRSwlkAOB7H9auL6CZ1Vc140/5JV4g/7Atz/wCiGro65vxof+LVeIP+wLc/+iGrKf8AHj6S/OJS+B+q/U+JKKKKoR6B8dP+S2eIv+usX/olK8/r0D46f8ls8Rf9dYv/AESlef0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAH6J0ZpM0lWIXNcl8MP9Z4s/7GG6/wDQhXWZrkvhd/r/ABdz08Q3X8xSYHf1jeIfC9h4it1F0rRXMfMN1FxJGeowe4z2/kea2aKSk4u6BpSVmctpWsajo91HpHiwgs52WmpKMR3Porf3X9j1/n1NRXVrBe2r213Ck0Mgw8brkEfSodPs3sITB9oeeFT+6EvLov8AdLfxexPPqTVSalr1JimtC3RRRUFhRRRQAVyfxPQP8MtdBPS1Y11lcv8AEld/w018ellIfyFAGpmkozSVoIWjNJmjNAhc0lJRmgBc0ZpM0lAC1y/jZgr+Hien9tQ/+gPXT1ynjtgF8Pk9P7bg/wDQXpP4Rrc7yuM0M4+LXinn/l3tOP8AgFdn3ryjxd4Rubjx/f6rceFDr9rdQQrE0V55DRFRgg8c1zrU1Z1PiPJ8eeGiRxtuv/RYrczXl2iaOumfEDRJF8JSaDvS5HmPfef5vyD5cdvWvUMnvW8NjKW4tFJSfjViFzUMB/fXP/XQf+gLUuahgP764/66D/0Ba56vx0/X/wBtkXHaXp+qJqM0maK6CBc0UmaM0AH40UUlAC5opKWmAUlGaKAFpM0UUCCikozQAUUlFAC5pKKKAFpKKKACijNJQAppKKKAPJb/AP5C+of9fk//AKNaoK7C68CTT31zOmqxos0zyhTakldzFsZ3jPX0qL/hALj/AKC8X/gGf/jle3DF0VFJs8SeFrOTaRylFdX/AMIBcf8AQXi/8Az/APHK53VLA6Zqr2a3iXXlqPMZYSm1jzt+8c8c/iK1hiKdR8sWZTw9SmuaSK1FFFdBgFWhqNwn2XyW8n7LzF5fGGJyW+p4/ICqtFJpPcabWxc1HVLnU5kkuHJEYwgyTj1Oe5J5J/8ArVoJ4svzbeTew2mobV2o95AJHT6E9fxzUGjeHL3W0M0bra2w+7NJGW8w/wCyuRke+fz7av8AwgNx/wBBeL/wDP8A8crknVw692XQ6oUsQ/ej1OWdi7s7YBY5O0AD8hwKtahqMmom2MiKn2e3S3Xb3Cjqfet//hAbj/oLxf8AgGf/AI5R/wAIDcf9BeL/AMAz/wDHKPrVC97h9Vr2tYx9K1y60lZootstvOhWWCUZRsjGcetZtdV/wgNx/wBBeL/wDP8A8co/4QG4/wCgvF/4Bn/45QsVQTbT38hvC12kmvxOVorqf+ECuP8AoLRf+Ah/+OUf8IDcf9BaL/wEP/xyn9bo9yfqdbsctRXU/wDCBXH/AEFov/AQ/wDxyj/hAbj/AKC0X/gIf/jlH1uj3D6pW7HLUV1P/CBXH/QWi/8AAQ//AByj/hArj/oLRf8AgIf/AI5R9bo9w+qVuxU8Ff8AIzn/AK85P/Q467+uc0HwtJo2pteS3y3GYWiCLBsxllOc7j/d/Wujry8TONSo5R2PUw0JU6fLLcM0UlLXOdIlLSUtACUUtFAHBeMdM+x6ot9EuIbvh8dFkA/qB+YPrXPkZGDXqGr6cmraVNZyHaXXKN/dYcqfwNeXlXRmjmXZLGxR1/usDgivZwdXnhyvdHjYylyT5lszvvB1/wDa9CWCRsy2h8k57qPun8sD6g1vV534Vv8A7D4gjRjiK7Hkt/vdUP55H/Aq9DrzsTT9nUaPQw1T2lNM4T4zk/8ACsL3H/Pe3/8ARy1wvws58MXPP/L42P8Avla7r4z8fC3UD6TW3/o9K4b4XADw9eDt9sP/AKAlcUtzrRy8Np5vxUurouFMOosm0990ch/9lr6U+Go2+F7hfTVL7/0pkr5vhkK/FO5t8cy6lvB9hFKP619I/Dg58N3R/wCorf8A/pVJUjOtooooAo65/wAi/qGP+fWT/wBBNfNWkKTJ4d4P+qk/pX0trHOh32P+feT/ANBNfP1rEEk8H7FADWpJx6kLQB7H8M+Phxo4/wCmJ/8AQjXV1y3w2/5J5pPGP3Tf+hGupoAKKKKACiiigAooooAKKKKADFIRxS0h4FAHm/xrJHh3Q/8AsNRf+ipa5b4fsD8aoP8AsDSj/wAirXZfFzQtR8ReGtPtdJt5ppodRSd/I270RY5MkbzjOSB+Ncp8NvCfiDTfiZHqep2Wpparp0sJmvlhXDl0IAEZPYGgD2uiiigAxRiiigAPSvm/xbZLe/EPXIJek4mXnt864r6QPSvnPWrhJPi9rkCx7Wh3lnz97LD+VAHW2Wp3PiT4fWGoW6b9d8LXCtLAM/vAgwR1/iSvT9N1C01rSLe+s3Ettcxh1OM5B7EevavCrbUtQ8Nasus6OC3y7Lu2A4nj+nTcOxrpfC3i208O3ouIZxL4Y1aXzBJjBsJmODkdlJ6+hoA5rx/oZ8OePLo+HbLOntafbry0RvuncFZ419eQSB1+tZImiu7Dz7aRZI5EJVl6EYr0bxeRJ4+vmRtyt4eYqVPX94vSvENAlbRbW2ic/wCg3sS4J/5Yylf5N/OgD334FsT8HNHzzgzcf9tXpLvj433I9dCj/wDRzUfAon/hUem57STf+jWpL1gPjlMvc6Ch/Kc/4047iZ0tc340/wCSVeIP+wLc/wDohq6TNc140P8AxavxB/2Bbn/0Q1RL+PH0l+cSl8D9V+p8S0UUVQj0D46f8ls8Rf8AXWL/ANEpXn9egfHT/ktniL/rrF/6JSvP6ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD9EKM0maSrEOzXJfC/wD4+/GP/YwXH8lrq65P4X5+3eM8f9DBN/6ClJgeg0UUVIwooooAKKKKACiiigArmfiN/wAk18Qf9eEv/oNdNXMfEc4+GniAnoLCX/0E0AaFGaZHIJIldejAEfjS5rQkdmjNNzRmmAuaSk/GjNAC5opM0ZoAPxrkviAQINAz/wBBu3/k9dZ+Nch8RP8Aj00Dn/mN23/s1J/CNbnoeaTjNL3rxP4mfEzxZoPjybRvDYtI4ILeORmli3sxYZrmNWeg+JCf+Ez8ND3uv/RQrXzXiHg7xt4o8UfEjRofE0lu0MSTtEIYdnzFADn8K9ureGxk9xaT8aM0VYhaghP764/66D/0BamqGH/XXH/XQf8AoC1hV+On6/8Atsi47S9P1RNRRSZroICikooELmikooAKWkozQAUUlFAC5ozSUUAFFFFABRRmkoAWikooAKKKKACiijNABQaSimAZoNFFAGbr2rLo2kyXHDTN8kKH+Jz0/AdT7A15jliWaRi7uSzuerMeST+NaniPV/7Z1dnibNrb5jgx0b+8/wCJHHsB61l17WEo+zhzPdniYut7SdlsgoopCcY6kk4AAySewA7muw4wJCqSxAA6k10nh7wo9+UvNVRktescB4aX3b0X27/Tre8O+EvLZL7WEBkHzRWx5Ce7ere3QfXp11eXiMXf3af3nqYfCW96p9wiqqIFRQqqMAAYAFLRSZrzT0xaTNFFABRRRQAUUUlAC0lFFABRRRQAUUUUAJRS0UAJS0UlAC0UlFABXDeM9N+zahHqMS4iufklx2kA4P4gY/AetdxVXU7CPU9Nns5uFlXAYdVPUEfQ4Na0ajpzUjGtT9pBxPLW3YyjFXByrD+EjkH869Q0m/XU9Jt7xQAZE+ZR/Cw4YfgQRXmLRyQyvDcLsmiYo6+hH9K6jwPf7JrnTnPDfv4v0DD/ANBP4mvSxkFOmproebg5uFRwfUg+Mv8AySvUuP8Alrbf+lEdcJ8L/wDkX73HT7Yf/RaV3nxkH/FqdV9pLb/0pjrhfhf/AMgK+9rsf+iYjXhy3PaRyRcj43rxjbfNx/2yavpf4asH8MXTA9dVvv8A0pkr5okGPjef+vxv/RBr6N+E7b/CNyx6nVL3P/gQ9SM7iiiigCpqv/IHvP8Arg//AKCa+ebUn+3fBgycfYckflX0TqAB025BOAYmz+Rr56tQo1zwac5UWTYOOvSgD2b4c/8AJPtK/wCubf8AobV09cv8Nzn4e6T/ANc2/wDQ2rqKACiiigAooooAKKKKACiiigAoIyMUUUAIVz3pNoznvTqKACiiigAooooAD0r5u1ZNvxv8RkOp3ICQO3I619InpXzdqxH/AAvbxIPWJf5igDSIrHubK409prjSYo5Y5xi6spPuTD1Ho3vW2RSbaAOcsPEosJ53ja5uohYtZCwlIE9qC244z99QRjg9K5xfs174VNuZ4z5duEc5wUZR1IPIwRXb6ho9jqS4vbdJCPutjDL9D2rFfwRpCyNO6zyELjbJMxBHXBHegD1v4ENn4T2IxgLNMBn/AK6NTdR4+Pg9/Dxz+FwP8aX4DNu+FkAwPlupxx/vmjU1A+PMZ7nw8/8A6UJVR3EdPXN+NP8AklfiD/sC3P8A6Iaukrm/Gn/JK/EH/YFuf/RDVnL+PH0l+cRr4H6r9T4loooqgPQPjp/yWzxF/wBdYv8A0Slef16B8dP+S2eIv+usX/olK8/oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAP0OzSUlGa0JFzXK/DH/kI+M/bX5f8A0WldTmuU+F7f8TPxr/2H5f8A0WlTIaPQqKZv9ulPqRhRRRQAUUUmaAFopM0ZNAC1y/xJIHwx8RE9P7Pm/wDQTXTFiO1cv8SWB+GHiP0Onzf+gmgCzYMH062YHgxKR+QqfNVdMYHSLMr0MCY/75FWc1oSLmk/GjNJ+NMBfxozSfjRmgBc0maM0UAFcd8Rzix0L/sN2v8ANq7CuN+JX/IN0T/sN2v8zSlsxrc9IArxPxXpcOo/F/WDcSxRBLO3AMjhc8e9e2V5hd6Z4f1T4v67F4litJUSyt2jW5cLg4xxyK5UanO6ZpNvp3xC8PvBcRSFmmB8tw2Bs74r1uuH1bw54f0Txf4UuvD1jbW/nzThpbc5Dr5frnmu3rpp7GUhaWm0uaskM1DD/rrj/roP/QVqWoof9bcf9dB/6Ctc9b46fr/7bIuO0vT9UTZpKM0ZroICikpc0AGaSiigAooooAKKM0ZoAKM0lFAC5pKKKACiiigAoozSUALSZoopgFFFFABRSZooAU1zXjLWDZ6eLC3fFxdggkHlI/4j9T0H4+lb11dRWVpLc3L7IolLMfYV5be3supX817ccPKeFz9xR91fwH65rrwtH2k7vZHJiq3s4WW7K4AAAAwB0paKltbW4v7tbWyiMszc46BR/eY9hXtNqKuzxEnJ2RGiSSzJDBG0ssh2pGgyWNd54e8Lx6Ztu77bNekcY5WH2X39TVrQvD9vosRYETXTjEk5H6Adh/k1r14+IxTqe7HY9jD4VU/eluGaKSlriO4SloooAKSjNFABRmiigAooooAKKKKACiikoAWikooAKKKKACikooAWkoooAKKKKAOK8a6Z5F3HqcS/JNiKfHZv4W/EcfgK5+zvG07ULe9XJ8h9zAd16MPyJr02/sotR0+a0nH7uZSpPcehHuDz+FeXSwy208ttcjE0LFH9yO/0I5/GvWwk1UpunL+keTi4OnUVSP8ATOg+MLq/wl1R0YMrPakEdCPtEVcR8MuNFv8AH/P0p/8AIERrd8UXP9o/BTVrKSVEks2gXMjYyizRsg+pA2j1IrE+Gi7dIvh/09If/JeGvHqxcJuL6Hq05KcVJdTkZ1x8cuehu/8A23NfRPwpha38O6jA/wB6LV71T/3+avnm7yfjqO/+kj/0mr6N+HBH2XXducf25edf+urVkaHZUUUUAQ3nNlP/ANc2/lXzfZTb7vwu5/gt5QPoMV9JTjNvIPVT/KvmvTYy994aRRyyTqB+VAHtXwubd8ONKOMfu2/9CNddXG/CkMvw401X6qHX/wAfNdlQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAAelfN2s4/4X34gHrAv86+kT0r5x14g/tAa4oVVxbJ0HWgDVIpCKk20hFAERFRyj9230NTkUyQfI30oA674EMD8NFAH3b2cf8Aj9TapgfG6HuzaC/5CdP8a86+GfiLxTYeF5rbRf7OFqt7NgXCMXJ3e1dBoGpazqfxfE2vNaGUaJIsf2VSBjzo+ufrTW4j0iub8af8kr8Qf9gW5/8ARDV0ma5vxp/ySvxB/wBgW5/9ENUT/jx9JfnEa+B+q/U+JaKKKoDv/jn/AMls8Rf9dYv/AESlcBXf/HP/AJLZ4i/66xf+iUrgKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD9C80lJ+NGa1JFzXm2ifDzSvE/ijxZdXl5qls8eq7AtleNCpzDGxJA6nJPNekZrE8BjGueMB/1FlP528VTIaPJPBnxd8SaZo8ektDp16bR2hW5vbtlkZQxwD9B3rvLH4jeJ72MOLfw6gzjJvHIz+Vd6fCfh4ytIdD04u5yzG1Qkn8q+f/ABvoGlSfGfVbQ2MKWyxW5WGMbFU+WMnC4HNQM9Zi8W+ISF+0XfhWAuMqHvJPmHr0qG8+Il5o0lrLqk+hXltPcJAU065dpQXOAQG4IrjPB3hTQrf4pWFvHpVqYW0qRjHIm9c7/Rsiun+LPh/SLHwlZz2Ol2VtKuq2hDw26o3+sHcCgD1CvPfFHj+60/xmvhzTH0+0kS38+e71KQrGAfuqoHJJr0KvMbTTbLUv2gPEUeoWkF2qaRbMizxBwp3HoD0oAjn8c6zEB/xU3hAM33R5kmT+lUJfiPrakqniTwoT6q0hq78T/DWiCTw5Guk2UaS6okcgjt1XcpByDgdKoeKfBXhqy+G99dWmiWcdwjjZIsY3D5hQAxviDr01hNJ/wlfhWJlDAL+83dOoqtZeHLK6/Z9n1zU45bjV30+4nkupJpMs+5yGwTjpjt0r1seGdDx/yBtP/wDAVP8ACsn4iRJF8LvECRqqIunSgKowAAh4xQBJpeP7Is9vC+QmPptFWs1S0jH9iWP/AF7x/wDoIq5WpIuaKSloAKSjNJQAtBYKCT096SmuCyMAcZBFAHON8RvCKsQdetMg4PJ/wrk/iD438PahpWlrp2pxXLx6vayMsYOQobk9PevNPh7pXhfxHLDpWt69rFpqt1dyRQw26nytoJx83QcA10vi34f+MPDGiala2djHqeh27+ct492PP8reGwUPUjpUN6D6n0ZG6yRq6HKsMg1kar4S0HXLoXOr6VbXcyrtEkifNj0zXF2nx18ERWMCSXd2HWNQR9lc4IFSN8evA6qSbu8wOv8Aob1z2NTJS3isPEOjWtogjgg8QX0UUYJKogjHyj0FekV5Ppmu2niHVdF1TTHZ7S58RXkkTOhUlTGOx6dK9X710U9jOW4tGaSs/XtXj0DQL3VZ4nljs4mlZEIywA6DPerINCoof9bcf9dB/wCgrXnk3xdaCwa8l8L36wqnmFvOi+7+ddNBq+uyIJrfwvcSibDsPtcQ8s4GAST/AHdrf8Cx1Fc9aSU6fr/7bI0gtJen6o6Kiszw/rK69okWoLbvbF3kjaGQglGR2QgkcdVNaYrpMwoozRmgAozSUUALmkoooAKKKKACiijNABRmkopgGaKKKACiiigAopM0UAGaDRRQAUUVm67qy6PpUlxw0p+SFD/E56fh3PsDTScnZCk1FXZzPjXVvtFyulwN+7hIecj+Juqr+HU/h6VzFGWZmeRi7uSzuerMeST+NaWi6Fc65NlCYbRTiSfHX/ZX1Pv0H6V7sFDD09TwZueIqaEGmaZdaxd/Z7JQAv8ArZmHyxD39T6D+XWvRNJ0e10e08m0U5bmSVuWkPqT/ToKnsbG3060S2s4hHEnQDufUnuferFeVXxEqr8j1qGHjSXmFFFFcx0hSUZooAKKSloASlpKWgAooooAKKKKACkoNFAAaSlpKACiiigAooooAKKKKACiiigAooooAK43xtpnlyxapEvDYinx/wCOt/T8RXZVBeWsV9Zy2twu6KVCjD2NaUqjpzUkZVaaqQcWeJ+LHmXwlqUMILLcJGsgB7JKjg/htI/4FU/w4AGk3wH/AD3i/wDSaGtC/sHje5068ALxkxvx970b8Rg1W8CwfZoNVgGcR3aJz7W0I/pXRj4K6qx2ZzYGbs6b3Rx16APjyvHW4X/0lr6B+F1yLjTtcnAISTWrtkB64Mhr5/vv+S8r/wBfCf8ApLXt3wicrousjJwNYuMf99V5h6J6XvFLuFU/N96XzaALRKkEGvnLRF/4nvhX/em/9CFfQfm/WvnrTma31HwzLt5VZ3Ge/INAHsPwtJPgO2yekso/8iGuwrh/hJOZfh7au/Uyy/8AoZrtt4oAdRTd49aXePWgBaKTcPWjcKAFopNwo3CgBaKMj1oyPWgAooyKM0AFFFFABRRRQAUUUUAB6V84eIQP+GhtZHT/AERDX0fXzn4nUD9onVMd7KM/pQBs0hFPxSYoAj202Rco30qbFMZcqaAGfCOwE/hK6bH3dSuB/wCPVt2lp9l+L8PH3tFl/wDR0VP+B1sJfBV+QM7dXuR+orV1K38j4u2RHRtFnx+E0VNbiN+ub8aH/i1fiD/sC3P/AKIaukrm/Gn/ACSzxB/2Bbn/ANENUT/jx9JfnEa+B+q/U+JqKKKoDv8A45/8ls8Rf9dYv/RKVwFd/wDHP/ktniL/AK6xf+iUrgKACiiigAooooAKKKKACiuh8FeHrbxNrzWF3LLEggaQNFjOQR6g+td//wAKe0j/AKCN7/45/hXTSwtSrHmitDnqYmnTlyyPH6K9g/4U9pH/AEEb3/xz/Cj/AIU9pH/QRvf/ABz/AArX6jX7GX12j3PH6K9g/wCFPaR/0Eb3/wAc/wAKP+FPaR/0Eb3/AMc/wo+o1+wfXaPc8for2D/hT2kf9BG9/wDHP8KP+FPaR/0Eb3/xz/Cj6jX7B9do9zx+ivYP+FPaR/0Eb3/xz/Cj/hT2kf8AQRvf/HP8KPqNfsH12j3PH6K9g/4U9pH/AEEb3/xz/Cj/AIU9pH/QRvf/ABz/AAo+o1+wfXaPc8for2D/AIU9pH/QRvf/ABz/AApkvwh0iKF5P7QvTsUtjKc4/wCA0vqNbsP67R7nkVFFFcR2BRRRQAUUUUAfoR+NGaT8aWtSQzWP4JGzXfF20ddTjP520Na+a4Txbp+reHpLzxHoevT2aS3VtJPYrEjJMxeOIkk8/d44xUtaAj1euK8TfCnw94p146xeyX9teMio72lx5e8LwCRg9BxXZxsWiVj1IBp1QUcj4Z+G2i+FtWbUrOe/uroxeSr3lx5nlrnJC8DGaofGFC/gq3x/Dqdof/Iorva4b4tJv8Epg/d1C1Y/9/RQB3Nec6P/AMnD+I/+wNa/+hGvRq860kf8ZEeIv+wLbf8AoZoA6rxN4T03xZp8dnqwm2RyCWN4JDG6MO4Irn4vhB4bjdPNn1W4iVw5gnv5GjbBzgrnkV3dFABXL/Eds/DTxFwf+QfN/wCgmuoryW80iXxj448U6fqur6nHYWjQQpa28ypGUdCWBG05zRuB12h/8i/p3/XrF/6AKvUyCFLa3jghXbHEoRBycADAp9akBS5pM0maAHUlGaTNAC0ho7Uf5xTYz5/8Ca1q/hHSx/ZXg7TtUMk7zx311OkcqhicAcEjg+veqPi+PWNd0nVdd8SXd9BcTS7v7PivC1vHHvGE2jggD8a3/DhB8OWOOf3Q/nWkVDKQwBB4II7VPKK51th4n+FCafbq974aDiJQwKRZzgZzxVkeKvhR0F94ax7Rxf4VwI0ywHSxth/2yX/ClFhZg5FpAPpGKj2ZXMQw+JvDkPia0NlfWUVlB4guJl8pgqLE0YAYAcBc16P/AMLC8I/9DFp//f4V5+9jaSIEktYXUHIDRggGk/s2x/58rb/v0v8AhVxViWz0D/hYnhD/AKGPT/8Av+KoeLtb0zXfhj4gn0a+gvIktJEZoX3AHHTiuO/s6y/584P+/Qo0xUj+Gnj2ONVRA8nyqMAfu1pgjK1g58BTn1sgev8As173oP8AyChj+7Hj/vyleBazz8PbjP8Az4f+y1734XP/ABJIf+uUP/omOuLE/wASn6/+2s2pbS/rqjzXw/pWuaHpEniPQDNqNtNe3jahpTNliBcyjfDno2B93vXeaTq9lrmmQ3+mTrPBKMggYIx1BHYg8EHpS+Ah/wAUqf8Ar/vv/SuWszxD4SvrHU5PEHgoIl653XmnO22G+9T6JJx97v3rojPuTKJv/WisvQPEFn4isPtNpvjkRzFcW0y7ZbeUfeR1PII/Xr0rUrVO5mFFFFMAoozSUALmkoopgFFFFABRRRQAUUlFABmiiigAooqOe4htYjLczRwxjq8jBQPxNAElFZv/AAkWi/8AQYsP/ApP8aP+Ei0X/oMWH/gSn+NVyy7E8y7mjXmviPV/7X1ZnjbNrb5SHnhv7z/jjj2HvW94o8UWg0s22mXsM0lxlXeGUN5adzkdCc4H1z2qr4d8JGcJd6vEUiGDHasMZ9C4/wDZfz9K7KCjSXtZ/I48Q5VX7KHzKfh/wzJrG25vA0Vj1A6NP9PRffv29a7+GGO3hSGBFjjQbVRRgAegFOAAGBwKWuerWlVldnTSoxpRshKWiisTUSiiigBKKWigBKKKWgBKWiigAooo74pAFJmjPFJTAWko5/GigAooooAKKKKACiiigAooooAKKKKACiiigApKWigDj/G+nBVi1WMAbcQz/Qn5T+BOP+Be1c5pLLDezRYAEw8wf7wAB/TH6103xQdo/hvqjxnDIImB9xKhrg9MvmnsLa7I/fRqkjKDk8qGx+Kt+td1J+2oyovdao4Ky9jVVVbPc5S+5+PSj/p4T/0lr3T4OgNpOuggEDWLj+YP9a8NljN18e0EPzbpVcEegs92fyFe5fB3jTfEA9NYm/kteUekeieWn90UbF/uinUUANKL6CvngNvvPC3GMW0ygflX0SeBXzvaAvqHhcMMYjmGD35FAHo3wiWQ/D22AGQJpR/4+a7fZL/drkfhEc+AY1ChQtzMvH++a7nFAFQRy/3aXZJ6VaxRQBV8uT0o2SelWsUYoArbJfSjbL6VZooAr7ZfSjbL6VYxRigCvtl9KXEnpU+KKAINslLiT0qaigCL95SZkqaigCLL+lGX9KlpM0AMy/pXzz4rXb+0Vf8AvYRk/ka+iM187ePZFsvj5qF3IR5aaYjtnj+EmgC/qGq2umlEuGZpZDiOGJC7ufZRzWZZ+JrjUNUlsLTw9q0s0PMipblmQepUc11ljpEnh7wRZXAeOfxH4klSKO4lOfIWTnCegVee3Nem6Lo1poWmRWdmpARRukY5aRu7MTySfegDxaz1izvJ3gRmiuEJDQTKY5Fx6qeaukZBre+Iei2WteNLK3vIN7DSbmSORGKvG6uhVlI6EV5p4O8VS6hBBaauSLmVS0EpAAlUdv8AeH4ZFAHp/wABuPBeqgdtauh+q1qa6pHxY01j0OjXIH/f6Csv4D/8idq+Dn/ieXX81rY18H/haGlEjj+yLrn/ALbW9NbgaVc340/5JZ4g/wCwLc/+iGrpK5vxoP8Ai1fiD/sC3P8A6Iaon/Hj6S/OIL4H6r9T4moooqgO/wDjn/yWzxF/11i/9EpXAV3/AMc/+S2eIv8ArrF/6JSuAoAKKKKACiiigAooooA7f4Tf8jo3/Xq/81r2uvFPhN/yOjf9er/zWva69/AfwfmeHjv43yCiiiu84QooooAKKKKACiiigAooooAKiu/+POb/AK5t/Kpaiu/+POb/AK5t/Kk9gW58xUUUV8kfVBRRRQAUUUUAfoPRRSZrUkK5b4kHHgO9wefNtyP/AAIjrqK5X4lf8k+1Ajrvgx/3/Sh7AeiQf8e0f+4P5VJUdt/x6xf7g/lUlZFBXEfFnePh/cTJGZPs9xBKUUjLBZF4Ge9dvWV4j0GHxJ4futKuZpIUuFA82PG5CCCCM+4oAxrfxlrFyiPF4I1gq4yCZ7Uf+1a5zwpeXV/8c9fu7vTZtPY6RAnkzyRs3D9fkZhj8a2ofA3iKBFjj+IOrCNRgL9ktv8A4irnhvwOdC1+71m71u91W8uoVhZrlI1CqDngIooA6uiiigArz/VPBviS38Vahq/hTVdPhXU/LNzFqFu0mxk4BQqw4IJ4PcV6BSbRnNC0A4QeH/H5Hza/ogPtp8h/9qU4eHvHR+/4h0Yf7umyH/2rXdYox707sVjiE8OeND/rPEmkj6aU5/8Aa1SJ4c8XFsP4m00D20hj/wC1q7LFLii7CxyH/CNeK/8AoaNP/wDBM3/x+oJfDfi8zqF8U6eIwDuI0htwPGMDzuep/Su2pCue9F2FjhNQ8DeJtUsHs7rxjFHFKV3tbaYYpMAgkBxNkZxV9Phz4fiUBhqUhA76rc9fX/WV1o6Uw9SaLjPmywg1Hwz4gk8IaxaxrLaw+ZBPFNvWaPPB5GR+PNbdZfxf8QWfhz4zJdXkcsiSaYiDyRuOdx68+1c7H8VtBaZVljvIoyfmkeLhfqAc/pVp6ENHb0VlW2v297ax3FnZ6ncQyDKSRadOysD3B2Vbtr+O5mmhMVxbzQEb4rmB4XGRkHDAHBHemLUtUlV7y/t7C2ae4chAQPlUsSScAADkmql/rR0uB57/AEnWLeGP70sumzIo/FlFO4rGpVbS13/D/wAfqOpd/wD0UK5K5+JumSBI9Ggmvrh24QxugAHUk7SfyBrb8Iar/afw08eXYRQzAvtUnHMeO4B7dxU3KSsV9Y5+HE5/6h4/9AFe9+Ef+Rctf+uEH/oiOvAtWP8AxbSYj/oHD/0AV7z4NY/8ItZE8/6NbnP/AG7x1yYn46fr/wC2s2pbS/rqiLwH/wAir/3EL/8A9K5q6PGRXnOjeI9T8KW1xpd54R126ZL66lWe1ijeN1kmeRSp38/K4+nNaA+It0fu+CfEZH/XGIf+1Kqw7ljxV4Nlvr9dd8M3Cadr8a4MjA+VdoP+WcwHUdgeornl+Keh2R+x+JDLo+rw/JcWEsbM0bD+IMoIZDwQw4IIrZ/4WBeMc/8ACEeIsehSAf8AtWuf8T6hc+ITDfWHhLxFpuuWYxaalEtvuXPVGHm/OhPVTxzkc1cZNEOKLjfFfweCf+Joxx6W8n/xNVrj4zeB7UgT6s6kjOPs0hP5ba1tH8d+Im0qAa34H1Rb8Lic20tuYiw7qWlB5647dOeteb/Ezw/4p8c+NrHWNM8MXlvDbWQt2W5uLdWLB2bIxIRjDeuavnfYOU64fGzwKwJGqynnGPscv/xNJ/wuzwP/ANBKf/wCm/8Aia8ovPDXiPwmZNR1nQp4re9mjhiZZ4X+fZ04c4+61Rfbrr/oEXI/7aRf/F0c77Bynrn/AAuzwQemoXP/AIAzf/E07/hdHgn/AKCFz/4ATf8AxNeQnULvH/IIuc+8kX/xdRm/1HHGjTf9/o//AIqj2j7Bynsf/C5/Bfa+u/8AwAm/+JrX8O/EDw94qvZLTR7uR50TeUlgeIkeo3AZ/CvA/wC0dV/6Asn/AIER/wCNaHhXxDqWg+LV1i50OWRFt2hMcdxHk5PXk01PuJxPpGkzXln/AAuW56Dwpc/+BcX+NN/4XLek8eE5/wAbyP8Axq+ZCsz1WivKD8ZNRzx4Sk/G9jpp+MmqdvCTfjfJ/hRzIOU9ZoryU/GPV/4fCQx736//ABNIfjHrPbwlH+OoD/4mjnQWZ6jqWoQaVp017dHEcS5OOpPYD3J4rxvWdZu9cvmubxzj/lnED8sY9B/j3qbVfG2oeK7OOK805dOjikLeWs/m+YccEnAxjn86ya9TC00o873Z5WKqty5Fsh0cjROHjO1v5/WtmKYSwCTBHGSMc1gTTGCPesPnkH/Vb9m/23YOPrg1qDxPPrmrBrnR4dMHlCMCG580Pt6fwrjA479vSuhV4wqKm+pzexcqbqLoTQwOZTPOxDkhlCnGzHTkdxXofhTX31KJrK9bddwruD/89U6Z+o6H6g964WnwXs+m3Md9aKGmgO5VJwHGOVP1HFXiKKqQ8ycPWdOfketUV5V/wtrW/wDoXrD/AMGL/wDxmkPxa1v/AKF6w/8ABi//AMZr5/nifQWPV/wNJmvJv+FseIM/8gHTcf8AX8//AMaph+K3iTJxo2mAHt9sk/8AjdHOg5TqdX+I9vpms3OnW+jajqDWxCyS2oTaCRnHzMDVQfFEkZHhXWfyhH/s9eZ3GueI5dav9RhttNR76QSOjSuwBAxgfKKade8Vk8RaSB6Zk/wqHN30KUT1AfE9j/zKusfi0A/9qVWn+MFpb3C28nh/VROylzHmHIXOM/fxXm513xb2GkAemJKy7seJLzUhfSSaYsoi8rAD7cZz09an2jDlPWh8YbY/8y5qn/fcH/xyl/4XBbf9C5qn/fyD/wCOV5Hs8S/89tN/75egR+Jf+e+m/wDfuQ/1p87FynrbfGCHHyeG9SJ95IB/7UqNvjAMfL4avyfeaH/4uvKRH4k73GnD6RSf40eV4i6G407/AL8v/jT52HKepH4xSY+XwxeE+huIf/iqwvF3xF1TxH4ffT7DStQ0yR5EZpoLuNWKg5Khg2RmuLEPiDobqw/78v8A41Hdy6xZWxnub2wWNSASLdyeTgfxepFLnY+UckmrgfPceJie+NbHNRynWjnyZ/Ea/XW6qR65dzH93f28nuthKf61N/aeof8AP0n4adN/jSuwsiBdQ8UaNf22pPfasYLaeOSSObVDIHUOMgjPfp+Net6H8Z5tT8UWGj3egm2F5IYxKLgNt4JzjHtXlF617f2b289w4jfBJXS5R0IPXPqBTLe5k0zVrTWBesslrJvjL6XLt3dOfmqlJiaR9X5oz+deBj42a7gEXun9e2kT4/8ARldd8Ovij/bsGonxTfWFoYJgtu5zAJEx/ddj3960UrkWPTqKwz428Lg4PiLTP/AtP8aQ+N/CwXcfEWl7c4z9rTH86oDdorA/4TvwmOviXSR/2+J/jSt468KIMt4k0odubyP/ABouBvUVzsnxB8IRRNIfEulkKMkLdIx/IGsmf4s+HvL3aZFqOqHOMWtm5H/fTAL+tFwO4orzaf4ma1NJjTvDIiTH3728VT/3ygasq48T+Nb5Tv1Ww04dltLQuQP95z1/ClcD14nAycY+tUb3W9M0xN+o6hbWy4zmWUKP1rx+e2v72UPqWvatd8YK/aTEp/CMLUEHh7SYHLrp8DuTkvKnmMT7s2TSuB6NcfFLwpDL5UGoNfSf3bKF5v8A0EGsqf4pzSn/AIlfhm/kUHG+6dIAfQgE7sfhXPqAgAXAA4AAxRj06YxjA4ouBB4x8ea3q3hK+sb7QILSCVU3zJeCQph1I+XbzyAPxqh4YjxY3VyoP7trZZP902kGD+B/maPFeT4ZvPopx/wNa0PAapJaajFIAQfswYHoQbSGnCo6c1JdCZ01Ug4sw9KsJLX43adM5JS4SYofQLaSLj8ABXs3wf4svES+msSc/VEP9a8+tLaCLxZYzTvmTTpZIyw6kSQsq5/7+LXoXwhG2DxIPTV3/wDRaVeJgo1Lx2eqIw0nKFpbrQ9FooormOgDXzxpe+bUPDh5JRZ8/QEV9DmvAvC53XOmMOqW10P/AB5aAPQ/hCf+KFwOgvJx/wCPmu6rg/g//wAiOw9L64H/AI/XeUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAhtIacRSEUANr5r+K0Rm+M2qoOc6ShPXkBST+lfShFfPvjiNZP2hZ43GVfTkVh6goaBndaveWsr+ALiFkeEXKLhWzt3RYX9a9CzzkGvn+ykn/ALBufCj/ALq805xPYSDgMobchBHXB4Ir2Xwh4lt/FPhyG/h+SVf3dxEesUo+8p/H9MUAYuvKr/FLR43UMsml3SkH03JXg93YrHp8iWCeU9lcyta4P3CkjbefwxXvetI5+K2hsFJUadchjjpkrXh13MkFrfyynCpPcZ/7+NSYHqf7Ot19u+H2oXeNouNYuJduc7dwQ4rpvEP/ACUnR/8AsFXn/o22rkv2aI2i+GV1HIhjdNVmDK3UEKgINdb4g/5KTo3/AGCrz/0bbVS3EX8VzfjT/klfiD/sC3P/AKIaukrm/Gn/ACSvxB/2Bbn/ANENUT/jx9JfnEa+B+q/U+JaKKKoDv8A45/8ls8Rf9dYv/RKVwFd/wDHP/ktniL/AK6xf+iUrgKACiiigAooooAKKKKAO3+E3/I6N/16v/Na9rrxT4Tf8jo3/Xq/81r2uvfwH8H5nh47+N8i5p2mTao0sdoVaeNC6xE4MgHXb7jrio0sLySJZI7Sd42+6yxkg/Q1LpEM1xq1vFbyvCzNgyI2Ci4+Y59lzXS3ZOpaFp0q2tzMv+kyiO3nEZRPNVR1U5AyBxW86jhK3f8A4P8AkYQpqUb9v+B/mZtj4ejm0qO4vY7yGR7vyCVjyEQpkOVIyQD156Vlahp8umajJaXQZSjcNtxuXswB7EV015Y3B8NwWsFrPaSz6hFsjln8wkPEQDkAYBxnGOOawNUtbO316e1ivJXt4nKec6ZOR14zzzxmppTcpO7KqQUYqyHXegXltciJPLmR4hPHKrgK8Z6Nzip4fD7PodzdSHFxHKiRqsybSDnOTn29atWml276joDS3Ml7DeMVMcqYCorlcDk8deKvrZNH4XvsWGnrG12gQG7+RsBurebwRkcZHXpUyrNWV/6vbuVGknd2/q3ocrdafPaQxyTGLEhIASVXIx6gE4qzpFhb3tpqT3BcPbWpmjCMBkggc8cjmpvEsMMF9arBDDDmzhZ1gOVLFck5yc/XPPvW14Y3y+HNWuZvskSpCIY5Gtk46Ft2Fyw+7nOaudR+yUvT8yIU17Rx/rY5y10lrnSpL9rqGCKKURN5gbqRkY2g0l/pf2Gzs7kXUNwl2rFfLDDG1tp+8B3roNVivovDGoDVDG1wbyFt8QUK6lDhhtAByKydV/5FzQv+uU3/AKNaiFSUmnfr+lwlBRTVun62Maorv/jzm/65t/Kpaiu/+POb/rm38q6Hsc63PmKiiivkj6oKKKKACiiigD9Bs0lFFbEhXK/Ezj4d6kR2MOPwmSuqrm/iFZNf/D3WYYgS62xlUDqTGRIP/QaQHe2vNnD/ANc1/lUtUNHvob/RbK6tnEkM0COjjowIFX6yKCiiigAooooAKKKKACiiigAooooAKKKKACiiigAprLnIJp1NLEE8dKAPhO+knvPEt1Nqt3PdFIt++eVpCB1wCxJxz0q/qPg7W3FjaHQryzm1OQR2jXcflLIcZ4Y8dPX1qz4i8I+I9J8YwaZf6aun3GqRGOI3MqurADlh5ZbH3a9O1zXvG2vaXZ2V3Z6BGtjNFPbPHPNuDx/d3ZT5lxnIGCfUVSEze8E/CJ9I8J6fDeatq2k6qjNJN/Zl+RGzHoCjbozj6c+9eFeI313WvFWoT65d3b3UUpg8yVPJZgnAyFAGQO4Fey/8Jv8AEkoQ48LENwR9nuMH8N9c7b+EdPuHuLvXdN02W8uZmlkFtblI1yc7VU54FW7PYlM8mm0u4VV8m8kEpdQhaYgBiRg5+te+6T4B8Fz6RDJ401+HWdaMO2Se61czLC2MfIMrwPcdaxrfwroNvIHg0mzRx0PlLn9ad/wjOg/9ATTf/ARP8KFpuDOJ1bwDc+G/E1nD4S1mLW0WJpZJbfy4Ci5C7N2XUnnuPwrb8L22u6NoWt6JNo8Yt9ZIRrhr1Wa3XBBbAUb+uf4a6ez06x05GXT7O3tQ5ywgiVAfrgDNWPp0pWQXMHxHbi1+H9/bhtwhsTHux1wuM/pXuXgoZ8JWGf8An1t//SeOvAvH+uWWm+F7u1nlBubqIxxQqcsd3G7Gc4q/afEvxvpnhvRotMGlBZbFGcvauxyrNGuMSD+CNPxye+ByYle/T9f/AG1m1L4Zf11R0fx5eWXXfDFmZ7hLaUXDSRxzuisQFwTtI5GT+deanRrR+Wa6Y+95L/8AFU/XfFniPxT4p0c+JjaH7PHP5X2aEx9QM5yxz0FXa0AzToNgTys5/wC3qX/4qmt4d018b4pWx0zcSHH/AI9WpRQFjJPhnST1tmP1nk/+KpD4Z0jvaEj3lf8AxrXpO9ICWAG3+FslqGk8i28VRrDGzkiNTakkLnoMsSfqaiHTj9K524v9VjvJNONyo0ptWjneDy15l8jAbd1+7xjpXR0AhKMUUtACfjRS0UAJRS0UAJiloooAT8KMUtCjLAetVGPNJR7kyajFssxLtjHvzT6KK+mSSVkfOttu7K87ZfHpTEYxyK68FTkUMdzE+ppK8CtUbrOS6P8AI92jTSoqL6/qdTG4kjV16MARTqp6VJ5lgo7oSv8An86uV9NCXNFSXU+bnHlk4voc1eReReSIOgOR9DUNaWtR4mjk/vDH5f8A66za+axcOStJH0WFnz0YsKSlorlOkTFFLRQMSilopgJRS0UCExRilooABxWbrpH9mDPT7RDn/v6taVZniD/kEk/9Nof/AEYtC3B7HS/8I/oxYn+ybDr/AM+yc/pR/wAI9o3/AECLH/wGT/CtADFLW5iUP7B0jtpdl/4Dp/hSf2DpHGNKshj/AKdk/wAK0KKLAUP7C0jOf7Lss/8AXsn+FL/YmlZ/5Bln/wCA6f4VeooAp/2Ppv8A0D7X/vyv+FKNK08DAsbYDrgQr/hVuigCqNMsR0srf/v0v+FO+wWh62sJ/wC2Y/wqxRTAiS1t42BjgjQjuqAVLRRQAUUUUAIaBS0d6ACiiigDF8XZHhO/I6hAf/HhWj8Pz8uoj/ZtD/5KRVQ8WjPhPUP+uX9RV74ffe1Ed/Ls/wD0ljqGUjGvL+eH4r6nZkO0F2qDj+ErAGLfgBn8K9j+DbO9hr7yjDtqeT7nyY8/rXlESq/x1hRgGDPNkH3sDXpvws1SK117VdDLjJbcmT/EoHH1KFT/AMBNbJ89Lle8fy6mDXJV5ls/zPU6KKK5zoA14D4V+aSzI/gguwf++lr3414F4TUnyCOQsd4D/wB9rQB6D8HxjwVL7X9wP/H67yuE+EPHgycemoXH/odd3QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACEV8/eNRj9olz62Kf8AoBr6CPSvAPGw/wCMhmP/AE5IP/IZoAm1bRotTjRw5t7uE5gukHzxH+o9R0NYya34o8K6kl/a2jfaPuzSWkPm296o/wCeqJ86N6EBsc11lGPoaAMq1+LGn674y0zV7rSNVtJLG0nhmtltXlZnfBGwqOnGMsF6/jXN6d4Yu9V1BrnWYTb6eJ3nis3ILylnLAyBSQAM/dz1HNdzg+ppPrQBo/AhtvhXXMf9B664/wC+a2PEr7vij4dHrp17/wChwGsT4Eqx8La6T1/t66H/AKBWx4iT/i6Ph3OcjTr0j/vqCmtxG5XN+NP+SV+IP+wLc/8Aohq6XFc340/5JV4g/wCwLc/+iGqJ/wAePpL84jXwP1X6nxJRRRVAd/8AHP8A5LX4i/66xf8AolK4Cu/+Of8AyWvxF/11i/8ARKVwFABRRRQAUUUUAFFFFAHb/Cb/AJHRv+vV/wCa17XXinwm/wCR0b/r1f8Amte117+A/g/M8PHfxvkb/hu5dLPWIDchEksZNsTNje5wBgdzjIq9Lc2ltDLpc84iS10zyXKgMTM0qO4AyM46dexrlreeS1nWaEgSJypIzg+o9x2pIpWimEq7SwOfnUMPxB4Nbyo3k2YRq2ikeg2EwS2dbSdPtN1ZQjT45l2uzxxFS+DwM5IGTgkcZHNcVLo94lza2qwyNdXKbxDt+ZfmYYI+i5/GqslzPLcm4kmdpiQ3mFjuyOhzVi61e/vbuK6ubp2uIkCJKDtYAZxyO/J560oUpQd09xzqxmrNbG3d6cj6bYQTThhpkcgvBbfvHjJcsFGOO+N33QQeegMiaw7+FLqSKCBLeG6iSC1kUOgXDEgg9Sc5J6/Tty9vcTWk6zWszwyr0eNipH4itgeMteA/4/VPu0EZP5lamVKW2/X8b+Y41Y77f1YqarJpk6282mQvbu6nz4CSyow6bSecH9K2dOuY5tK1O2tyTBaacyqTxvdnUu/4kAD2ArH1HxDquqwrDfXjSRL0RVVFP1CgZ6d6gstSuNPS4S32YuE8uTeobK5B7/SrdOTgk9153JVSKm2tvQ0LyRrXwpa2kzEzXU32kgnlY1XYg/Hkj2xVk2Dalpnh61TdueC4I2jJJDucfpXP3FxLdTvNcOXkc5LGrNvrWp2lsLe1v7mGEZwiSkAZ64punKy5d73/ADEqkbu+235FIgg4IwRUc6GS3kRerIQPyqSitjE8ak+EetL/AKu5tn+pIqBvhP4iXo1mfpKf8K9sorh+oUfM7fr1Y8Lk+GPiWPpbxP8A7slVn+HvidemmO30df6mvfaKl5fS7spY+r2R8+P4G8Sx/e0mb8Cp/rVWTwvrkX39LuR/2zJr6NoqXl0OkmUswn1SPUl8Q6K/C6vYk+n2lM/zqdNU0+X/AFd9bP8A7syn+teTEA9RmmmOM9UU/hQ8Av5h/X3/ACnsSTRSf6uRG/3WBpzKrqVdQysMEHoRXjJt4W+9DGfqopVhjT7ihf8Ad4qf7Pf8xX9oL+U9C8Fai3hvUm8Gau3loGd9FmZiRPBnPlbj/Gg429cYIzXfiTIGBXz9NELgIJ2eQRuHTdIx2sOjDng+9XRq+pxjjV9QUen2yTH/AKFWTy6fSRoswh/Ke70V4YnijWIvu67djH96fd/OrEXjXXzxBrczn2jjf+amoeX1F1Rax1N9Ge10V5FD4q8Zv/qpbyf6acG/9BStCDxJ47b7umzP/wBdNOZf54rJ4Sa6r7zRYqD6P7j02iuCi1v4hP8Ad0K1cf7UYQ/rMKuwan48YjztB09f9652/wAmasXRa6r70aqsn0f3M7CisO3uvFDY+0aXpa+v+nuD/wCijWxA0zQg3McccndY3LgfiQP5Vm42NU7klFFFSMKKq6pY/wBp6XPZfaZ7Xzl2+dbvskT3U9jXJf8ACtf+pu8S/wDgf/8AWrOUpp+6rnZQpYecW6tTlfo3+R29FcR/wrX/AKm7xL/4H/8A1qP+Fa/9Td4l/wDA/wD+tUc9T+T8To+rYL/n/wD+Ss7emlM1xX/Ctf8AqbvEv/gf/wDWpP8AhW//AFNviX/wP/8ArUc9T+T8Q+rYL/n/AP8AkrNLxX8PfDHjb7P/AMJNpaXjW2RE4keNlB6jchBx7Zrnv+FBfDbv4cz9b24/+OUup+EdK0VI31j4gazYJISEa71ZYgxHYbgM1nfYvCH/AEVi6/8AB/D/AI0+er/J+Ivq2C/6CP8AyVmkPgH8NR/zLa/+Bk//AMXQPgR8NkJx4aQ/9vU5/wDZ6zfsXg8f81Yuv/Cgh/xpPsXg8/8ANWbn/wAH8P8AjS56v8n4h9WwX/QR/wCSs808f+Gfh++t2GmeCdNClJZEu7mNpmiZlH+rDMSrEdflOKxf+FeWGP8Aj3H5muj8XaT4U8PappbeH/GFte211JJ9oCXkTvEwXIfchwM9OR+NVPtuhf8AQ1N/4HJVqdX+T8RPDYL/AKCP/JWY/wDwrzT/APn2Wnf8K80/jFqv5VrfbtD/AOhqb/wOSj7dof8A0NT/AIXy0c9T+T8RfVsF/wBBH/krPPtR8PQ2nh97mOJVbdIMgejsP6V7zo3guW+8OaU3lk7LOMH8Rv8A/Zq8ev7y0bw5LNb3SXDo0mYTIHXG84JA9Rz+Ne56FoNne+HNNlk8Ta3a/wCiRELb3e0HKBueOxYqPZVHauSvOpzw93r3/us1hh8Gk7V//JWefePfDj6D4k0FnTb5onH5KKzgMDFb3xL0y207VtDit9Y1HUjOZstfT+Y0WFz8pxxnvXM/ZP8ApvL/AN9Vrz1P5fxD6tg/+f8A/wCSss0VW+x/9N5v++qPsf8A03m/76o56n8v4h9Wwf8Az/8A/JWWaSq/2P8A6bzf99UfY/8ApvN/31Rz1P5fxD6tg/8An/8A+Ssr3unH+wLjUyPlTX4Ic+5twa0PrVW5SJPClw5upjIuuQw/Zy2YyGgB80r/AHweAfSnfZPWeX/vqnz1P5fxBYbB/wDP/wD8lZYparfZP+m83/fVH2P/AKbzf99Uuep/L+I/q2D/AOf/AP5KyzRVb7H/ANN5v++qPsf/AE3m/wC+qOep/L+Ivq2D/wCf/wD5KyzRVb7H/wBN5v8Avqj7H/03m/76o56n8v4h9Wwf/P8A/wDJWWaKrfY/+m83/fVH2P8A6bzf99Uc9T+X8Q+rYP8A5/8A/krLNPhGZB7VT+x/9N5v++qkhsdxP+kTjHo9dOGlVdVWhf5mGJw+CVJ3xFv+3WaNNc4Qn2qr/Z//AE9XH/fdMlsdqZ+0zn6vXsSr14pv2f4o8iODwDaX1n/ySQ+iq32P/pvN/wB9UfY/+m83/fVfP89T+X8T3vq2D/5//wDkrN/RH4lQn0IrVrltOsPNutn2u5jyp5STBrV/sT/qI33/AH+/+tX0GEr13RVqd/mjwcVgsAqzvibf9uSJdYTdZBv7rA1h1o3Wi4tJG+33j7Vzhpcg4rF+x/8ATeb/AL6rgzCVZzUpU7fNHdgMPgVBxjiL/wDbjLNFVvsf/Teb/vqj7H/03m/76rzeep/L+J6H1bB/8/8A/wAlZZoqt9j/AOm83/fVH2P/AKbzf99Uc9T+X8Q+rYP/AJ//APkrLNFVvsf/AE3m/wC+qPsf/Teb/vqjnqfy/iH1bB/8/wD/AMlZZoqt9j/6bzf99UfY/wDpvN/31Rz1P5fxD6tg/wDn/wD+Sss0VW+x/wDTeb/vqj7H/wBN5v8Avqjnqfy/iH1bB/8AP/8A8lZZrL8Q/wDIHb/rrF/6MWr8UHlEnzHfP945rP8AEf8AyBJP+ukX/oxa1g291Y4a8KcJNU5cy72sduKWkAwP0pa6jkCiiigAooooAKTrSmkFAC0UUUAFFFFABRRRQAUd6KKACigHNFAGP4s/5FPUf+uJq58Pf9fqWP8AnjZH/wAlkqp4q/5FPUv+uDVa+Hpxd6l/172X/pMlQykVbfJ+PcOP+mp/8kSP6V2+jafPbprWv2S5u9I1dbgqrAmSE28XmLx/s8/TPrXk/jDj4tW+eM31t/6Cgr6D+GaA3HiZZBndqCZB5yDbQ+tEJcruKceZWO6t547q1iuIHDxSoHRh3UjINSVg+Gh/Z73uhHJTT3BgYnOYXyyD/gPK/wDARW9RJWdgi7q4HpXhfhS3KWVvKP41vf0kAr3M9K8S8L/8gq2/7fgT6fvhUlHafCUEeE7oHj/iZXH/AKFXdVwnwrlSPw1erI4UjU7nhjj+Ku3+0Q/89U/76FAElFRm5hA/1qf99U03cA/5ap+dAE1FQfbLf/nsn50fbbb/AJ7J+dAE9FQfbrb/AJ7J+dJ9vtR/y3T86ALFFVv7RtP+e6fnR/aNp/z3WgCzRVX+07T/AJ7LSf2paf8APYUAW6Kp/wBq2Y/5aik/tez/AOen6UAXaKpf2vZ/89P0pp1m0H8dAF+is/8Atq1/vGkOt2vqaANGvB/G8Y/4Xt5nf7Og/wDIRr2Y63a46mvF/F1yl18aFljPBiUY/wC2RoA1KKWigAxSc06koA0PgRIqeFteDHpr91/7JWr4mdW+KXhrac/6Be5/OGuL+EjONG10KSB/blz0P+7W3dFv+Fp+HcsTmyvBz/2zpx3Edtiua8aD/i1XiD/sC3P/AKIaumxXNeNB/wAWq8Qf9gW5/wDRDVEv48fSX5xGvgfqv1PiOiiiqA7/AOOf/Ja/EX/XWL/0SlcBXf8Axz/5LX4i/wCusX/olK4CgAooooAKKKKACiiigDt/hN/yOjf9er/zWva68U+E3/I6N/16v/Na9rr38B/B+Z4eO/jfIKKKK7zhCiiigAooooAKKKKACiiigApHYIjOxwqjJPtS1Fd/8ec3/XNv5UmCMiTxn4djHOsWh9hIDVOX4i+GYjg6gG/3EJrwWivEeY1OiR7Ky+n1bPcZPil4aQfJcTP7CFh/MVSk+LuiofktbqQewA/ma8boqHj6z7FrA0V3PW5fjFYAfudNuT/vlR/WqUnxkkH+q0hT/vTY/pXmNFQ8bXfUtYOiuh9pp8Pef3uqsf8AcgC/zJqwvw/sf+WmoXp/3TGP/ZTXWYoxTeJrP7Q1hqK+ycyngPSV+/Jdyf702P5AVOvgnQh961kc/wC1cyfy3YrfxRipdao/tMtUaa+yjGTwnocfTTYT/v5b+ZpmoeD9D1DTpbQ6fBb+YMCa3jEciHsQwGc1uYoxWbnJ7spQitkc74W1b+zdSTw34mgt47/B+xX0cSol+g/QSAdV79RXebx0Arlda0Sz17Tns79CVJDJIhw8Tjo6nswNUvDfiW9sNWTw54tYG8IxZagBtS+Udj2Eg7jv1FZNGisdzRTQ/sadUjCiiigAooooAKKKKACiiigAooooAKaR15p1NJxnNAHyH408Y6x428X2tzqumWN1BpImb7NECgeMDncWLZIyPyrb1fw5eaDpVtqOo+AdNjgupooIttxGxZ5PujGz+ZrlNI8m48aahbM5AkjuYWKnoCQK6nxNrviq80awOo6zDex6XcRzRWwtgiyspUJu28nHNUiSwfCXiFMn/hV0CgdSbq3GP0qvYvoDGeHVtM03Sr62laKa2leIlCPfgH8K6m++Kmk654WsrPxLoEl1qkriR9PgjaQZUkBgg+Yjvg/TNeW21xGnjPWLjxPZJayXJWWOK9iWNgp+78h6cdq0lHl3IjJS2O4ik8LJIPJk0rf/ALDx5/Q1N9t8Pg5+16aD6+an+NcZreoeH/7HuFtEsWm2jYqBWJ5HbvTdM8N+H9V1JJYtctNGvZEZ5LDU9JVliwM9DhSCOhx9aSXYp6bne2s2l3jlbKS0nZeSInViPyNWhFFgfu19htFeXXniC5sf7KvdG0bT7WZFe1nmghVFu2LZEnloBtwB713HhyDxL4gttVuodU0oppqrIAkDss4IY4ySCp+UjoaXULFPx1oVlf8Ahq7uHjCXNvEXSWPhuB93PcH0rsdE8PeML/wxpMul2mnmIWUefPv2UjI3L0iOfkZD25JHbJ5vW7j7d4Fu7kJ5YnsTJtz93cucZr2vwF/yJWmf9edt/wCk8VcmJ+On6/8AtrNqW0v66o8N8d6L4i0vXtBbxBDZosjTLF9muWlydnfKLiqHc49a9G+OdrcyXHhy7htp54IJ5hK0MLSbN0ZAyFB715sGmP8Ay4aj/wCAE3/xFaAPoo8u7/6Beqf+C6f/AOIo8u7PTS9U/wDBdP8A/EUAFFMIvMkDSNWODjI06b/4mmlr0H/kCayff+zpsf8AoNAGVqFnqTWF1ex/Z/7OTWraN8uRL5hhBHGMbce9bNLd213H8N7+4urG7tEl8R2mwXMDRswEODhWAyM96Oc0AJS0maXtmgAopKKAFopM0UgFopO1GaAFqe3Hyk1X+lWYP9X+Nd+BX71vyOLGv938ySorg/KB71LUNx/DXp4h2pS9DzaCvVj6kNFJmlAywHHPqa+fSbdke82krstaaduoRH3I/SuhrEttOuo7mKQoNoYEncOlbdfQ4GE4UuWatqeBjZxnU5ou+gyZd0Ei+qkfpXL11dc+2mXSgkooUdywrLMKU6ijyK5pgasablzOxUoppdR1YfnTfOjH/LRf++q8Jpp2Z7ad1ckoqL7RBjPnJj/eFJ9qt+88X/fYoGTUVB9stv8An4i/77FH221HW5hH1kFAE9FVv7Qs/wDn7g/7+r/jQdRsh1vIP+/q/wCNAFmiqv8AaVj/AM/tv/39X/Gj+07Dve23/f1f8aALVZXiQ40Kb/fj/wDQ1q1/amn/APP9bf8Af5f8ao6zcWl/pM1vBf2gkbBXdMoHBB/pQB3g6UVybeM5ONsOnD66iP8A4mmnxpPjiLTPx1Af/E1tzIyszrqM1x//AAmVzjHl6WD/ANf4/wAKafGV5jhNJ/8AA4f4UcyCx2R4pM1x/wDwmN5j7mk/+B3/ANatbwrceJPGU95Fo1ppbfY9vmM94cHcMjGAT+OMU7isbdFWf+EL8eZ/49tG/wDAqT/4ml/4Qnx4f+WGi/8AgRJ/8TTCxVzRVr/hCPHnURaJ/wB/5P8ACl/4Qbx0RkjRAfTzJKAKlGat/wDCD+OlGduiv/siSQZ/Hmqk2keLbOUrd+GJZVHWS0uUkH5HaaACis+TWFtg/wDaNhqNjs6/aLNwB+IBH60631rTLogQahbOT0USjP5daAL1BooPFAABiij9PrRQBk+Kf+RU1L/r2f8AlVj4enN9qX/XtYn/AMl1/wAKg8Uf8inqn/XrJ/6Cad8N33Xmp+1vZj8osf0qHuUjmvGRKfFu26H/AEu16j/dr2fwldTw6r4iWN2QG8i4B/6doa8Y8agH4tWoJ2/6Vac491r2fwyM6z4hP/T1Cf8AyVhqRm5BeXH9o3cm9t5Kjd3xtq19vuj/AMtX/Oqduub27/3lH/joqztq57/d+RENvv8AzHfbbk/8tWH415HpV1cR6dpYjumhDarNGyhypdSzErx1BIr1ojivILLjTtK/7Dkv/oTVBZ3Hggv/AGdqPJH/ABMp8/8AfVdJlv7xrA8GDNnqXb/iZT/zFdHtoAi+b1NHzepqXaKNooAi+b1o59al2ijaKAIufWjn1qXaKNooAi59TRz61LtFG0UARYNHNS7aNtAEWD60u01JtoxQBHtPrSYNS7aNtAEWKOal20baAIq8y1pSPi6jH/nmB/5CNepbfSvNddjP/C0437YA/wDIJoA3KKMUYoAKMUYpaAM34Tvt0nXecf8AE7uT/wCg1tXj7vip4bx/z6Xg/SOuZ+Gc5W015DwBrM5/Ra2zIX+Kvhv/AK9rsf8Ajqf4U1uB6Liua8aD/i1PiD/sC3P/AKIaunxXM+NB/wAWo8Qf9gS5/wDRDVnL+PH0l+cRr4H6r9T4hoooqxHf/HP/AJLX4i/66xf+iUrgK7/45/8AJa/EX/XWL/0SlcBQAUUUUAFFFFABRRRQBp6Br934c1Fr3T1iMpjMf71SQASD2I9K6T/hbPiL+5Zf9+T/APFVxFFawrVIK0XYylRpzd5K52//AAtnxF/csv8Avyf/AIqj/hbPiL+5Zf8Afk//ABVcRRV/Wa38zJ+r0f5Udv8A8LZ8Rf3LL/vyf/iqP+Fs+Iv7ll/35P8A8VXEUUfWa38zD6vR/lR2/wDwtnxF/csv+/J/+Ko/4Wz4i/uWX/fk/wDxVcRRR9ZrfzMPq9H+VHb/APC2fEX9yy/78n/4qj/hbPiL+5Zf9+T/APFVxFFH1mt/Mw+r0f5Udv8A8LZ8Rf3LL/vyf/iqP+Fs+Iv7ll/35P8A8VXEUUfWa38zD6vR/lR2/wDwtnxF/csv+/J/+KpH+K/iF0ZGSyKsMEeUen/fVcTRR9ZrfzMPq9L+VBRRRXObhRRRQAUUUUAfoRRS/hR+FakiUUv4UfhQAlFL+FH4UAJWfrWi2evaa9lfxko2GV1OGjYdGU9iK0fwo/CgDnvDfiO+0fUY/Dni6UNO3FhqLcLdqP4W9JB6d67ndXMazotlr2mvZahFujbBVlOGRh0YHsR61i2uu+IPB6m31+1n1rTE/wBVqFqu6dB2Ekf8X+8PyqGh3PQ80VyMfxR8HNgS61HbvjJSeN4yvscin/8ACz/Bf/QxWf5n/CpGdXRXJf8AC0fBX/Qw2v8A49/hUFx8V/C0aM9pc3OoKo+Y2dpJJg+nTrQB2lFcQ3xX0AHH2fVj9NOk/wAKafizoIPFnrDfTTpP8KAudzRXCn4taH20/Wz9NOej/hbOjH7ul663005v8aNQO6orhf8AhbGkHpo+vH6aef8AGh/ixpaQvK+i68sacMzWO0D829jTsxXO6qKaSOGJ5Z5FijQEs7tgAepJ6VwVz8Vree0zo+m3Jlbo14AiD3wCSfpx9a4vUdavdf1FItU1KJnY5VLiZYYYvfBOB+rH3rrp4SclzT91eZy1MVCL5Yasy/idYW+u/EG21Tw7dw21nBZGGeaOIfvJDIScZHPGOeazzodzLaCOG5aFjwZpVDSH3A6A/nVXQrjUNb1k6mzxJpkPmQxRq24ysGxv9gMH1611VNzhBWpL59RKE5a1X8jnrDw3qOlpt0/xTq1uM7v3bIDn64q3Y6F5GoXOoajf3Oq3twqo894QzbV6AcVrUVgdBRvtIs9QsJbSWJVSVcZjUKR7g+tY114RvL5I0vfFGr3CxEFBJIrAY6dRXT0UAef6j4EWS8jhtL57XbL5qKxJiPqAAQVP0Nd78KbCWx03xbZXJjIiijRRHuwFKSHqST1JPWo7q3W4i28bhypPrWh4HlhsX8QR3M2Jb+AGMN3ZEcMufXBB9+a0cFOPPHdb/wCZmp8kuWXXb/I5Scb/AIb46Z01f/RYr3DwFn/hD7FTxshiQfRYUA/QCvEmUt8O1A76co/8hivcPA//ACKlr/uR/wDopK4MR9h/3v8A22R003q15fqjktA0bU/GNxrd9e+KdZtGg1We0SC0n2RoiY24GPQ1tD4dy5yPF/iL8L00nwzH+h+Ih3/t+6/9lrts47UyzjD4AkHXxd4j4/6iD1z3i2yh8NpBZQeJvEN5rN4CLSz/ALVdc/7bnPyoO59sDmuo8UeMm027TRfD9uupa/OMx2+fkgU/8tJSOi+3U9qyrP4daRKrXnia3i1zWLgl7m+uUyWJ/hUdFQYAVRwKcU2S3YpaN4RaHTIxrnxF1Sa+b5pfJ1Uoin0UZzgdOfSvPfitqeo+FNd0mz8P+NdXlhuYXadjqRfkEAc544r1r/hXvhP/AKF+x/79CmSfDfwdLjzfDWnOR0JhBq+Rk8x88Prl7r081hr/AIhvr21jEU0az3zFfM+b5uvUVIYNO76rN/4HH/GvoD/hWPgr/oWNN/78CgfDPwWB/wAizpv/AH4FPkDmPn0waaTzqsv/AIHH/Gmm20o/e1ST/wADj/8AFV9EL8OfB6DC+G9OA/64CnL8PvCS/d8O6cP+2Apcgcx85m00c9dTc/8Ab8f/AIqtfwX4c0XX/HNppk1zNc2ssEryJHeMTlQMcg17wvgPwqv3fD+nj/tgKt6f4Y0XSbn7Rpul2trNgr5kUQVsHqM01EOY5U/Bjwcf+Xa8P1vpf/iqP+FL+Df+fS7/APA2T/Gu+xS4q7Im5wP/AApjwb/z5XP/AIGSf40f8KZ8Gd9PnP1u5P8AGu+xRiiwXOD/AOFNeC++mSH63D/415/qen22lavd2FhH5dtbTNHGmc4AOOte+YrwjxA6/wDCT6plhn7ZKOT/ALZruwa95nFjPhRQrovB/hfSfFF7cw63aC5ihjDopJADE4zx7Vzm9f7w/Ou9+FmGvtRYEHEaDj6muvEfwmceH/io1h8J/BYGP7DhP1JNPX4V+C1HGg2x+oJrsMUYrxrHs3PPfEXhAaVEbvSEdrNR+8gyWMX+0O5X1Hb6dObBBGQcg17NiuE8UeFDbF9Q0mImHlprdR9z1ZR6eo/KvVwuL+xP7zy8Vhftw+45QkAZJwBXTeHPCKanF9s1mHdaOP3Vu+R5g/vN7eg79aXwr4XOoFNQ1OP/AEQfNDCw/wBd/tEf3fQd/p17/HtRi8V/y7h8wwuF+3P5HL/8K38Gf9Czpv8A4Dij/hW/gznPhnTcf9e611GKMc15Vkepc8B8VaP4U0bx/qVpd6VbQW/lQtBGtqzLynOMA96oeV4H/wCgdB/4Ayf/ABNfRL28UjbpIkZvUqKT7NB2gjH0QVDj5lKR89C08FnppUXP/UPk/wDiaxNX0jR21qCSw0ZxaCBhJtsJQu/cMcbeeK+ofIi/55J/3yKUxIeqL+VHIHMfLo0HTTyNBnOe/wDZsv8A8RR/YOn/APQAuP8AwWy//EV9SAcen0oxT5A5j5aOiaep/wCRfuf/AAWy/wDxNJ/ZFiOnh26P002X/wCJr6mxS4o5A5j5YOl2S/8AMuXn4abJ/wDE0Lp9oD8vhy+5/wCoZJx/47X1Nilx/OjkDmPkm41Pw/YXD293ZNbTJjfHLbFGXvyDz0OaaPEHh1AGEAAPQ+SOcV9Fa98MvDXiTWpNU1WzZ7mSNUYxuUyQCNxx1OMD2wKzZfgl4KmRVexuCEUqv+lP0Jz6+5pcgcx4PJe2etaZew6Jpl1dzCIqfs9oX2EjjOOlXtF0XU7/AMbaKIdAv1VbyJpGltGRAoYEkkjHQGvonwr4H0PwXFcx+H7VoBcsGlLOWJIGB17V0OOelNQFcqf2dZZJ+xwc/wDTJf8ACpIraCAkwQxxZ67FAzU2KXFWK43FJtp+KMUANxRj6U7FGKAGkZ60m304p+KMUARvEki7XVWX0IBrJv8AwloGqAjUdHsrjP8AfhBraxRigDh7j4S+F3ZnsobnT5D/ABWly8ePwBxWVcfCa7iQjSvFF2mSSFu4UlA9s4B/WvTcUYoA8hufAfjK1K/Z5NK1Bf4vvwN/7NWZc2XiTT/NbUPDF55cY/1lo6zg/QZB/SvcMUbef5ZoEfOWt3d3e+HNShGi6pADZzMZJ7YoihYyxyc8cCp/he2681Pn/lha/orf4V7J8QFH/CtvEm7n/iV3H6RtXjHwqbN1qnvBbn/0YP6VEikYfjjj4s2h/wCniz/9DWvbfDuP7b18f9PFv/6SQ14p47I/4WtYgLg+dac/9tBXtHh1v+J3r/8A18W//pJDUjNm2/4/Lz/rov8A6AtWaqWzf6Vef9dR/wCgLVneKue/3fkRDb7/AMxxrxyBiLXSF7Nr0/8A6E1ewbxXkEYHkaT7a/OP/HmqCz0LwkR5Gq44/wCJnPx+IroM1zvhhgBqwHT+0p/5itzfQBLmjdUW/wB6N49aAJd1G6ot9G+gCXNGai30b6AJc0bqi30b6AJd1Gai30b6AJd1G6ot9G+gCbNGag30b6AJuPWjj1qHfSeZQBPketeba9PF/wALRhtwwEuN+zvjyiM16HvryvXWz8c7XHGbMn/x2gDraKMVDdXltY27T3c6QxL1eRsAfnQBNijFc3N470lLpLeCK8upJBlBDbn5/wDdzgn8Ku6V4o0vWJzb205S5XOYJlKOMHB4PXn0oAzvh84DeIFHGNWlP5gVrmVh8XPCQB4dLxW9/wB1n+YrF8BkC68RKO2qOT+IFa4Gfi34Qb/r8H/kE00B6zXM+NP+ST+IP+wJc/8Aohq6jFcx40H/ABabxB/2BLn/ANENWcv48fSX5xGvgfqv1Ph+iiirEd/8c/8AktfiL/rrF/6JSuArv/jn/wAlr8Rf9dYv/RKVwFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB+heKMVT1u4ls/D+o3Nu+yaG1lkjbAOGCEg4PuK83/4SrxB/0F5f+/EP/wARXbRw86ybj0OWtiIUWlLqeqYoxXlf/CVeIP8AoLy/9+If/iKP+Eq8Qf8AQXl/78Q//EVt9Qq90YfXqXZnqmKMV5X/AMJV4g/6C8v/AH4h/wDiKP8AhKvEH/QXl/78Q/8AxFH1Cr3QfXqXZnqmKMV5X/wlXiD/AKC8v/fiH/4ij/hKvEH/AEF5f+/EP/xFH1Cr3QfXqXZnqlFeV/8ACVeIP+gvL/34h/8AiKP+Eq8Qf9BeX/vxD/8AEUfUKvdB9epdmemS2FnOxaa1gkJ7vGDTP7K0/wD58LX/AL8r/hXm3/CVeIP+gvL/AN+If/iKP+Eq8Qf9BeX/AL8Q/wDxFH1Cr5B9epdmelf2XYf8+Nt/35X/AAqeK2hgUrBEkQPUIoH8q8u/4SrxB/0F5f8AvxD/APEUf8JV4g/6C8v/AH4h/wDiKPqFXyH9epdmeq4pMVk+E7251LwzbXV9L507NKGcqFztkZRwAB0ArVnnhtYGmuZUhiQZZ5GCgfUmuKUXGTidsZKUVIXFMmmhtoGluJUhiQZZ3YKB9Sa5LVfH8KbotFg+0N08+YFYx9B1b9B71x1/f3mqTiXUbl7hgcqrcKn0UcD69a66WDqT1eiOSrjKcNFqzsdW8ewRbotFi+0v08+UFYx9B1b9B71x2oajd6nJ5upXLTbTkK3CJ9FHA+vX3qKCGa6uUt7SF553+7GgyT7+w9zxXeaB4Ihs2S61jZc3I5WIcxxH/wBmPuePQd67WqGFXdnGnXxT7I53QfCd5rO2e4LWlkeQ5H7yUf7IPQe5/AHrXd23h3SLWBIodOttqjGWiDMfck8k+5rUxSd+K8ytXnVfvHpUqEKS0PBPDsaw2d1HGoCrfXAUAYA/eNWtn/Jrn/Dlh4w1q91yHwtpun3NtY6nNE8lzcmNtxbcePTkVW1vxG2hpqmjeKPKsNYgiI8uFiyksmVKn8awua2Z1VJmt7Sfgj4M1DRrO88zUpfPhSQuuoPgkgE4q2PgP4MB+7qf/ge9T7RFchy9JmoX8GeHdI1fUYrGD7bAup2Vqn2idpgqSKS4Bz1yK9E/4Vv4RP8AzA7f82/xpqVxOJwOQOpA+tUtN0qe/l8QXUTF1smhdo1P8DK2WHuNoP5969LPw18IHroVt+bf41Zi8NaP4d0bUhounxWYnhYy+WD8+FOM5+prWnUcJKSM501OPKzyC6CxeHp7JMAJbFYSDwyhePxAr23wYMeGbfHH7uP/ANFJXhmkKJ/Dtil1l457dDubqG28ivY/A2sW8unR6dKyx3SoHROzoo2Aj1Pyc/Wpx1ONqdSns5fd7siMLUkpSp1N0vv1RD8NeIPEuRz/AG9ck/8AfKU/xJ4tuZNSbw34QVLjWXH764YZh09e7ue7eidz14rkPD2paxe6j4l8O+HUe1kfWp5LvU3X5beNlQAJ/ekODj06mu/0Hw9Y+HNO+x6dGRubfLK5y8z93Y9ya54xvudbfYr+HvDNn4dtnWAvPdTnfdXc53S3DnqzH+nQdq2cU7FGK2SsZjcUYp2KMUxDaKdijFAxuKMU7FGKQDcUYp2KMUANxRinYoxTAbijFOxRigBuKTFPxRigBmKMU/FGKAGYoxT8UYoAZijFPxRigBmKMU/FGKAGYoxT8UYoAZijFPxRigBmKMU/FGKAGYoxT8UYpAMxRinYoxQA3FGKdijFADaKdijFMBuKMU7FGKAG4oxTsUYpANxRinYoxTAbijFOxRigBuKMU7FGKAG4oxTsUYoAbijFOxRigBuKMU7FGKAOc8fqD8NvEvtpN0f/ACE1eJ/Cj/j51P8A64QH/wAelr2/x+P+LbeJf+wTdf8Aolq8Q+FH/HzqJ9be3P8A4/MP6VEhox/Hg/4utY/79mf/ACLXr3h5/wDiofEHPHn25/8AJWKvI/Hw/wCLqad9bP8A9HV6j4ekI8UeIh2823/9J46kZ0tsw+0Xn/XYf+i0qxuFZ9u/765PrL/7ItT76ue/3fkRDb7/AMyzvryvZtt9NBABHiCbp/vPXpe+vNVUfZLL/Z8RS4/76eoLOy8NP/yFv+wlP/MVt+Z71zPhmQ7tXGf+YlNx+Irc30AWvM96PM96q7zR5hoAteZ70m/3qt5ho8w0AWd/vRvqt5lHmUAWd9HmVW30bqALPmUeZVbdRuoAs+ZR5lVt1G6gCz5lHmVW3UbqALPmUb6rb6TfQBa3+9eYa0wPxysuf+XJv/Qa9F3+9eaa0f8Ai9+nnPWzb+VAHW316bZUit4/PvJzst7cHBlfsKiudBGn6gllelNV8TzR+Yzuu610tD0IU8Fuw7mrvhiW2s7HWPHeohZVs0eDT4ieQF4ZgD3ZuPwqfw/aTW9k13qDF9Qvm8+5djn5jyFHso4/CgCnoXhyy0b4i+G9ga4uZXuGmuJuXciFsfT2A6V5/f2iXRviPkmS9ujHKvDI3nPgg16tbkN8RvDLHrvuP/RD15ZeTpaxalPKdqpeXRJ/7bPSAt/DKeWaDWHumDTtdAykdN2wZ/WuogQP8VvCjH+H7Vx/2xNcZ8LEkt7bV0nBEpuQ7qexZQT+prsrJs/FPwucf8/Q/wDIJqkB63iuX8aD/i0viD/sCXP/AKIauqxXL+NP+SSeIP8AsB3P/ohqzl/Hj6S/OI18D9V+p8OUUUVYjv8A45/8lr8Rf9dYv/RKVwFd/wDHP/ktfiL/AK6xf+iUrgKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigD788Sj/AIpTVv8Arym/9ANeS1654mH/ABSer/8AXjN/6Aa8jr28v+GR4+YfFEKKKK9M80KKKKACiiigAooooAKKKKACiiigDodK8YyaT4ah0+ytN1yjylpZvuLmRmGAOW4I9Kxb6+vNTnE2o3Mlw4OVDH5U/wB1RwKgoAZnVEVndzhUQZZj6ADrWEaNODcram0q1SaUb6BWrofhy+15w1uPJtAcNcuOPoo/iP6e/aug0DwGX23XiADHVbNTkf8AAyOv+6OPXPSu5REjRUjUKijCqowAPSuKvjUvdp/edtDBN+9U+4ztH0Ox0S28qyi+Zv8AWSvy8h9z/TpWjinYoxXlOTbuz1UklZDcUmPbvT8UmKQzxH4dfEDw54L1vxja+Ib0Ws02sySIqoTlcAZ4+lHir4oza3Lq0nhjwzpGqadHDtN9ejEjfu8ngjnGfWuyvfg74avb66une+jkupWmkEcygbmOTj5a5nx98MtJ8PfDzV77TL3U0mih+VWuQUOWCnICjsaiwXH+HfgdaXnh2wup/EWpwvNAsjRWszLGmRnCjPArUHwG04HnxJrhH/X03+Nei+HrVbLw1p1shysdtGo/75FW7m8trNVa7uIoA3AMjhc/nWVzSx4lb+FYvBS3mkQXk15HFrmnOsk/3vmVjj6V7PivMfFNzBca1qU1tNHPH/bGmfNG4YZ2HuK9PxWsCGJioriAXFtLCSVEiMmR2yMVPijFWI8wt/hBPa2MVnH4ouDDEgRQ1onQe+aybpbixkssSmG5SBZo5IjyoYsykH1wRmvZDgAk9q5Cfw8uueFYlj2reW8cbQOfXyUyp9j/AIHtV06qpzhzbc3/ALbI561Jzi+Xe36or/Dqe2Frf27Tu2oXFy13cLJj5yyqpZcdvlHHYnHpntcV4rFLPaXazQs9tdW7nB6NGw4II/MEV6j4Z8Rw69aEOFivYgPOiB/8eX1U/p0rqxOG9n78PhMsNifae7Lc2cUYp+KMVxHaMxRin4oxQAzFGKfijFADMUYp+KTFADcUYp2KMUCG4oxTsUYoAbijFOxRigBuKMU7FGKAG4oxTsUYoAbijFOxRigBuKMU7FGKAG4oxTsUYoAbijFOxRigBuKMU7FGKAG4oxTsUYoAbijFOxRigBuKMU7FGKAG4oxTsUYoAbijFOxRigBuKMU7FLigYzFGKfijFADMUYp+KMUAMxRin4oxQAzFGKfijFADMUYp2KMUANxRinYoxQIbijFOxRigDnvHi7vhx4kHrpN1/wCiWrw34Urtmvsd7WA/+RJx/SvdfHK7vh54jA76VdD/AMhNXhnwsGJrs+tpCf8AyLcVDGjI+ISgfFLSyOp+yH/yOa9I0KQ/8Jf4jHbzLc/+QErzr4igD4oaOR3W0P8A5MNXfaGx/wCE08Rj/atz/wCQEpDOkgf95OfWT/2UVNvqnA3zTf8AXT+gqXdVz3IhsT768/4+z2uP+hik/m9dyWrhmXbFAPTxFJ/Nqgs3PDDnz9ZHpqUv9K3t1c14Yb/S9bHpqMn9K6DPvQBLuo3VFn3oz70AS7qN1RZ96M+9AEu+jfUWfejNAEm+l31FmjNAEu6jdUWfejPvQBLuo3VFn3ozQBLuo3VFn3ozQBLupNxqPNGaAJN+a8w8VsV+LFrIjbWGnSkfgpr0rNec+IYg/wAY9JWQErJaOp9+2KANLVbyO1+FOjW8CGdDPbblP8eXyc/ia74Px/SvMNRVtK0htC1NnhhR99jerGSikNuAbHQitjS/iRpV5ahHW4e8Q7GihhZvMb1X1BoA7KzI/wCE/wDDjscYluMn0/cPXmWnaVN4g1+8WZCul22o3EjN2nbzmZVHqvOSa3pE1bxLcRyXUTaRZRbtiKf9IcMNpBI+4CpI9ea3Le3htLaO3toxFDGoVUXgAUAcd4VZY/EHiRQet8OP+A10OmNu+KXhf0DXI/8AIDVyWiRay3ijxL/ZOi3mpD7WpdrdRhDt6HNdHoEWtR/FDwydX0O802IyXIR7gABj5D8CmhHtuK5fxoP+LR+IP+wHc/8Aohq6rFct40H/ABaLxB/2Arn/ANENWUv48fSX5xLXwP1X6nwzRRRWhJ3/AMc/+S1+Iv8ArrF/6JSuArv/AI5/8lr8Rf8AXWL/ANEpXAUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAH6AeJh/xSWr/wDXjN/6LNeQ17B4nH/FI6v/ANeM3/os14/XtZd8Mjx8w+KIUUUV6h5pqaDpLapqluhMRh81RKHmVW2jlsKTk8Z6UajpgjM91byWqw+cwjt47pJJAnUHAJyMe+afok1rb21+8t0kF1JD5MHmIxXDcOcqCQduR+NdMtvbjx/5yXkf2nnFukTDjyDzuxjOf/19q5J1JRm30S/L+tzqhTjKC73/AK/4Y5N7aAeGYboR/v3vJIy+4/dCIQMdOrGs9lZGKupVgcEEYINddG+vf2FZlpr7zftz7yZWzs2x4zz0zn9ayvEVw0XjG/lZUmKzsNso3KR0wRV06jba9epFSmkk/QpQPpggUXMN20v8RjmVV/AFTWxJpei6apOsx30EjLmO3WZHdgejcKAB9TzjpT3jhfw5ZCeztDcXLvOTvjt2WMfKvJxkE5NbOpWdrdeIbiGa2gLTRqnmLdqZj+5BAEeeOVAzjvnpWM6mvXr17GsKen3dO558cZ46dqKv6nqjah5MawRW9vbqUhijX7o926sfUnvmqFdiba1OR2T0CiiiqEXtJ0a+1y5MOnxZVTiSZ+Ej+p7n2HP0616VoPhax0FN8YM92ww9zIPmPsB/CPYfjmoPAQH/AAhdp/10n/8ARz10eK8DFYic5OHRHu4bDwhFS6sbijFOxRiuM7BuKMU7FGKAG4oxTttG2gBuK5X4m2M1/wDDTW7e2jaWU2+4KoyThgx/QGutxSbT+tLcDkNO+JnhSLTLWOTVVV0hQMPLbghR7VyPiHxZ4S134iaTPqEq3ulQWcyyCWFmRZCRg4x1xXruDRj9ajlK5jybXda8KX1lp2k+DrdRO+q28rQ21qUDBTyTx2FergcU7FLirSsTe4zFGKfikxTAjkwI2z6Gs3w+MaXGD1CRf+ikrTnX/R5P9w/yrP0If8S5f92P/wBFJWVX7H+L/wBtkOO79P1Ry3jzw7gNrVknKj/S0A6gdJPw6H257VxlrdT2N3Fd2UvlTxHKOOfqD6g9xXtzIGUqwBBGCCOteT+KvD50DU/3Kn7DcEmA/wBw9TGfp1Ht9DXtYOupL2U/keTjKLi/awO/8OeIbfxBYmRAIrmLAngzkofUeoPY/wBa2MV4pZXtzpl9He2Mnlzx9M/dYd1Ydwf/AK/WvWdA1221/TxcW/ySp8s0LH5o2/qPQ965sVhnSd1sdOGxKqqz3NLFGKdijFcZ2DcUYp2KMUANxRinYoxQA3FGKdijFADcUYp2KMUANxRinYoxQA3FGKdijFADcUYp2KMUANxRinYoxQA3FGKdijFADcUYp2KMUANxRinYoxQA3FGKdijFADcUYp2KMUANxRinYoxQA3FGKdijFADcUYp2KMUANxRinYoxQA3FGKdijFADcUYp2KMUANxRinYoxQA3FGKdijFADcUYp2KMUANxRinYoxQA3FGKdijFADcUYp2KMUAYPjZd3gDxAB30y5H/AJCavCfheu2W597GE/8Aka4r33xbby3PgvW4LdDJLLp86IijliY2AFeC/DNSrzE97CEj/v8A3I/pUsZj/Eb/AJKdo3+5af8ApS1dxop/4rfxEP8Ar2P/AJBWuL8fxNP8VdCiTlpBaKPqblq7LR/l8eeI0PUC2/8ARQpAdDCcGX/fP9Kl3VDCf9Z/vmpM1c/iIh8I7dXFOcpD/wBjFJ/Nq7PNcUeVjHp4hf8Am1QWafhdv9P10emov/SuizXNeFz/AMTPXx6ag/8AIV0eaAHZozTc0ZoAdmjJpuaM0AOzRmm5oyKAHZozTcijNADs0ZpuaM0AOzRmm5ozQA7NGabmjNADs0lJmjNAC5rz3xCcfGDQ+TzA1egV594kJHxc0A5GDC3GPegDu2AYEEAg9Qe9MjgihB8mNI89dqgZp9GaADHH0pDwKM0maALfwXGzX/GYPX7bD/6LrpPF/PjzwZ/193P/AKSyVw/wzstZuPFPi/8AsPV4LErdQees9p5wb938uDvXHfP4V0+q2WuW3jjwk2tatbXyG8nEawWfk7T9ll5J3tmmhHb4rlfGg/4tD4g/7AVz/wCiGrrMVyvjT/kj/iD/ALAVz/6TtWMv48fSX5xLXwP1X6nwtRRRWpJ3/wAc/wDktfiL/rrF/wCiUrgK7/45/wDJa/EX/XWL/wBEpXAUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFbH/CI+Iv7K/tP+w9Q+xY3faPsz7MeucdPegD7s8T/wDIo6x/14z/APotq8dr2PxR/wAihrH/AF4z/wDotq8cr2su+GR4+YfFEKKKK9Q80v2c2mQWrNd2k11c7vlUy7ItuOpwNxOfQiuqNxI/xIFvtjRFQ8KgBP7g9W6n8Sa4ap5b25mu2upJ3M7/AHpAcE8Y7e3FYTpczb8n+JtCrypeq/A2Yrdf7Gs7UXVqZkvmlKidfulUA7+qmma3bC68Z6gjyCKITu0shHCKDyf8B3OB3rDBKkEEgjkEUO7SOXdizMclickmmqbTvfv+InUTVrGzLePq9+/2TSBdpGoSGPEjNFEowo+Rh9SfUmtLxJqn9neKrkx6famdVhImkDl0YIhBHzYBBA7due9ctDNJbzpNA5jkjYMrKeQRS3FxNdXDz3MjSyucs7nJJpeyXMu1v8h+1fK+9zX8Qw6fM0eqabcxbbz55LTPzwv/ABcemc//AKqxKKK0hHlVrmcpczvYKKKKsk9T8Aj/AIoqz/66T/8Ao566PFc94A/5Emz/AOuk/wD6Oeujr5et/El6s+kpfw4+iG4oxTqKzNRuKXFLRQAmKMUtFACYoxS0UAJj2ox7UtFIBMUYpaKAExRilopgQXf/AB5zf9c2/lVPRB/oX4R/+ikq5fHGn3BHURN/I1W0fAtXwP7n/opKxq/8u/8AF/7bIcd5en6ovYqnq2lW+saZLZXa/JIOGHVG7MPcGr1FbJtO6JaTVmeH39hcaXqE1jeriaE9QOHHZh7H/EdqdpmpXWj6gl7YtiReGU/dkXup9v5V6V4y8N/25pwntEH2+2BMXbzF7ofr29D9TXlQORyCD0IIwQfQ19Bh6scRTtLfqeFXpSw9S8duh7Noms2uu6ct3aHH8MkZ+9G3dT/nmtHFeLaRq93oeoreWRyfuyxMfllX0Pv6Ht+Yr13SNWtNa05LyxfcjcMrcMjd1YdiK8rE4d0ZXWx6mHxCrLXcuYoxTsUYrkOobijFOxRigBuKMU7FGKAG4oxTsUYoAbijFOxRigBuKMU7FGKAG4oxTsUYoAbijFOxRigBuKMU7FGKAG4oxTsUYoAbijFOxRigBuKMU7FGKAG4oxTsUYoAbijFOxRQA3FGKdRQA3FGKdRQA3FGKdRQA3FGKdRQA3FGKdRQA3FGKdRQA3FGKdRQA3FGKdRQA3FGKdRQA3FGKdRQA3FGKdRQBieMFLeB9dAxzp1x2/6ZtXg/w1YM0gB6afD/AOlF1XvviznwXreBz/Z8/wD6Lavnn4WSbru/XPK2kAx/21n/AMakZF4w5+M/hkf9NbH/ANKjXVaXx8QfEY/2bf8A9F1yvi8H/hc/hk/9NbL/ANKjXUaacfETxEPWO3P/AI4aAOgh6P8A75qSooTw/wDvn+dSZq5/EyIfChc1xlujTy+XGpLDxC/H/fRrsq5XQedZx6eIJP8A0B6gsm8Ln/ibeIR6ag38hXSZrmfDB/4nPiH/AK/z/IV0lADs0ZpuaM0AOzRmm5ozQA6k/KkzRmgBaKTNGaAFozSZpM0AOzRmm5ozQA7NGabmjNAD80ZpmaM0AOzXAeKBt+K3h1/WJv513ua4HxUf+Lo+HD/0zb/0KgDuz0ppozTSaAFJpCaaT/nFMeRE++yr9TQBneAtfGi+MfGIaRY/MuLc/MQOkfv9RXVy+IU1rxz4WjS4STy7ydsKQf8Al1lHasX4V6DpGs+MPGb6vpdhflJrXyzc26SlAYzwMg46V2eseHNF0jxV4Un0rSLCxlbUJUZ7a1SJiPsk5wSoBxkUCOtxXK+NB/xZ7xB/2Abn/wBJ2rrMVynjQf8AFnfEH/YBuf8A0nasZfx4+kvziWvgfqv1PhOiiitiTv8A45/8lr8Q/wDXWL/0SlcBXf8Axz/5LX4h/wCusX/olK4CgAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigDt/g7pWn6z8WdEs9WVZLdpi/lP0kZVLKp/ECuytfin4yf4vvaarry6TardtAbK6TFqqBsCNlA4BH8X9K8ctLu4sL2G7s5WhuIHEkciHBVgcgivTtZ+L+r6v4IX+1dJ0a7u755rOa8ezHmsiJEc5B+8d559hQB9SarKzeDtbiQK9vHZXHlyrJuGNjYX3wOOvavKa9l8TqqeDtYVFCgWE+ABj/lm1eNV7WXfDI8jMPiiFFFFeoeYFFFFABRRRQAUUUUAFFFFABRRRQB6t8Px/xRNn/wBdJ/8A0c9dJiuc+H//ACJFn/10n/8ARz10lfL1v4kvVn0lL+HH0QmKMUtFZGomKMUtFAxMUYpaKAExRilooATFGKWigBMUYpaKAExRilooEVdRO3TLo+kLn/x01DpQAhlA7Mn/AKKSptUIXSLwntA5/wDHTTNMG1Jh6Og/8hJWVX/l3/i/9tY4by9P1RcxRilorUQmK858feG/ssza1Yp+5kP+loP4WPST6HoffB9a9HpssUc8LxTIrxyKVdGGQwPBBrajVlSmpIyq0lVhys8GrR0LXLrw/qP2q1y8b4E8GcCVf6MOx/pU3iXQJPDurGAZa0ly1tIecr3U+4/UYPrWRX0K5K9PumeA+ejPs0e4abqNrq1hHeWMokhkHB7g9wR2I9KtYrxrw94hufDuoedEDLayEfaLfP3h/eX0Yfr0PYj1+xvrbUrKK7spVlglXKsP5ex9q8HEYeVGXke3QrqtHzJsUYpaK5jpExRilooATFGKWigBMUYpaKYCYoxS0UAJijFLRQAmKMUtFACYoxS0UAJijFLRQAmKMUtFIBMUYpaKAExRilooATFGKWigBMUYpaKAExRilooATFGKWigBMUYpaKAExRilooATFGKWigBMUYpaKAExRilooATFGKWigBMUYpaKAExRilooAyfFC58I6wB3sZ//AEW1fNvwmYtrGqg8YtoB/wCPy/419LeJP+RV1b/rym/9ANfMXwiYtrWpFjybWHP/AH09IZoeLLeR/i54cuFUmOO4sFc9gWumIH/jprotP/5KL4g/6423/oLVjeKJnX4kaJAGxHJeaYzL6lbiTB/U1tWJH/CxNdPO7yLfPp0agDeh+63++386fUUJ+Rv99v5mpM1c/iZEPhQtcv4dOdcf216T/wBAeunzXLeG+fEE+P8AoOuf/IbVBZJ4Z41vxEO/27P/AI6K6TNcz4bONf8AEX/X4P8A0EV0e6gB+aTNNLD0pM0APzRmmZpc0AOzRmm5ozQA7NGabmjNAD80mabmjNADs0ZpuaM0AOzRmm5ozQA7NGabmjNADs1wPir/AJKb4dP+wR/49XeZrg/FX/JSPDx9v/ZqAO5zTSfekNULW1bxTJdMbv7B4b0/J1LUlfaXwOYYz/6E3bOOTQAxLi81prldEaCG0tNxvdWuzi2tsDkZ/ib2H4kVxOs29lqcrGGS4nt7c5kv9SGZJDgE+XARsjUjBG4E8j612q6i2veKfCtrDYR6f4WW7WGy0phxIFBYSuvA5IGFOfU8mn2/hdvF/wAUtfjugo0GzvvOv5zLtWT5FxEMcnO07ueB7kUAO/ZtS4S88WfallDPNbOolXDeWyuU47Dbtx2x04r1HxT/AMjH4S/7Ccv/AKR3Fcx8Nr631D4keO5bJVS1SWzSELGEG0RMO36Z7Yro/FzgeIfCHOP+Js//AKSzigR0eK5PxoP+LOeIP+wDc/8ApO1ddiuT8af8kb8Qf9gC5/8ASdqxl/Hj6S/OJa+B+q/U+EKKKK2JPavjv8Oddi8ZXXiXyhKmqzKIrSAGSUbY1B4A5+6TXkKaPqckAnj067aIo0gkWBipVThmzjoCRk9q+sPFesXWrarc2N+0U8djO0aN5QGcAdR+NYH2S3/54Rf98CvRpYCVSCk3a559XHRhNxSvY+bv7H1P/oHXf+p+0f6hv9V/f6fd9+lH9j6n/wBA67/1P2j/AFDf6r+/0+779K+kfslv/wA8Iv8AvgUfZLf/AJ4Rf98Ctf7Nf834f8Ez/tFfy/ifN39j6n/0Drv/AFP2j/UN/qv7/T7vv0o/sfU/+gdd/wCp+0f6hv8AVf3+n3ffpX0j9kt/+eEX/fAo+yW//PCL/vgUf2a/5vw/4If2iv5fxPm7+x9T/wCgdd/6n7R/qG/1X9/p9336Uf2Pqf8A0Drv/U/aP9Q3+q/v9Pu+/SvpH7Jb/wDPCL/vgUfZLf8A54Rf98Cj+zX/ADfh/wAEP7RX8v4nzd/Y+p/9A67/ANT9o/1Df6r+/wBPu+/Sj+x9T/6B13/qftH+ob/Vf3+n3ffpX0j9kt/+eEX/AHwKPslv/wA8Iv8AvgUf2a/5vw/4If2iv5fxPm7+x9T/AOgdd/6n7R/qG/1X9/p9336Uf2Pqf/QOu/8AU/aP9Q3+q/v9Pu+/SvpH7Jb/APPCL/vgUfZLf/nhF/3wKP7Nf834f8EP7RX8v4nzd/Y+p/8AQOu/9T9o/wBQ3+q/v9Pu+/Sj+x9T/wCgdd/6n7R/qG/1X9/p9336V9I/ZLf/AJ4Rf98Cj7Jb/wDPCL/vgUf2a/5vw/4If2iv5fxPm7+x9T/6B13/AKn7R/qG/wBV/f6fd9+lH9j6n/0Drv8A1P2j/UN/qv7/AE+779K+kfslv/zwi/74FH2S3/54Rf8AfAo/s1/zfh/wQ/tFfy/ifN39j6n/ANA67/1P2j/UN/qv7/T7vv0o/sfU/wDoHXf+p+0f6hv9V/f6fd9+lfSP2S3/AOeEX/fAo+yW/wDzwi/74FH9mv8Am/D/AIIf2iv5fxPm7+x9T/6B13/qftH+ob/Vf3+n3ffpR/Y+p/8AQOu/9T9o/wBQ3+q/v9Pu+/SvpH7Jb/8APCL/AL4FH2S3/wCeEX/fAo/s1/zfh/wQ/tFfy/ifN39j6n/0Drv/AFP2j/UN/qv7/T7vv0o/sfU/+gdd/wCp+0f6hv8AVf3+n3ffpX0j9kt/+eEX/fAo+yW//PCL/vgUf2a/5vw/4If2iv5fxPm7+x9T/wCgdd/6n7R/qG/1X9/p9336Uf2Pqf8A0Drv/U/aP9Q3+q/v9Pu+/SvpH7Jb/wDPCL/vgUfZLf8A54Rf98Cj+zX/ADfh/wAEP7RX8v4nzd/Y+p/9A67/ANT9o/1Df6r+/wBPu+/Sj+x9T/6B13/qftH+ob/Vf3+n3ffpX0j9kt/+eEX/AHwKPslv/wA8Iv8AvgUf2a/5vw/4If2iv5fxPm7+x9T/AOgdd/6n7R/qG/1X9/p9336V6tL8C/EL/DG21UXdoIYVmvyMnJV0jAX6jyz+dd39kt/+eEX/AHwK3v8AhKdR/sL+yMxfZPL8vbsGdv1rOeXzVuV3Lhj4O/MrHqt1caXe2c1rc3Vu8M+62kXzgNxYYKZBznB6dawP+EQ8Gf3U/wBZ5X/IRl+//d+/19q8r+yW/wDzwi/74FH2S3/54Rf98Ct44Gcfhnb+vUxljYS+KF/69D1T/hEPBn91P9Z5X/IRl+//AHfv9faj/hEPBn91P9Z5X/IRl+//AHfv9favK/slv/zwi/74FH2S3/54Rf8AfAqvqdX/AJ+P8f8AMn63S/59r+vkeqf8Ih4M/up/rPK/5CMv3/7v3+vtR/wiHgz+6n+s8r/kIy/f/u/f6+1eV/ZLf/nhF/3wKPslv/zwi/74FH1Or/z8f4/5h9bpf8+1/XyPVP8AhEPBn91P9Z5X/IRl+/8A3fv9faj/AIRDwZ/dT/WeV/yEZfv/AN37/X2ryv7Jb/8APCL/AL4FH2S3/wCeEX/fAo+p1f8An4/x/wAw+t0v+fa/r5Hqn/CIeDP7qf6zyv8AkIy/f/u/f6+1H/CIeDP7qf6zyv8AkIy/f/u/f6+1eV/ZLf8A54Rf98Cj7Jb/APPCL/vgUfU6v/Px/j/mH1ul/wA+1/XyPVP+EQ8Gf3U/1nlf8hGX7/8Ad+/19qP+EQ8Gf3U/1nlf8hGX7/8Ad+/19q8r+yW//PCL/vgUfZLf/nhF/wB8Cj6nV/5+P8f8w+t0v+fa/r5Hqn/CIeDP7qf6zyv+QjL9/wDu/f6+1H/CIeDP7qf6zyv+QjL9/wDu/f6+1eV/ZLf/AJ4Rf98Cj7Jb/wDPCL/vgUfU6v8Az8f4/wCYfW6X/Ptf18j27Tv7G0mwjstPuLeK3jkaNUNxuw5JYrkkktknjrVr+0rH/n9t/wDWeV/rV+//AHevX2rwf7Jb/wDPCL/vgUfZLf8A54Rf98Cs3lzbu5/h/wAE0WYJaKP4/wDAPeP7Ssf+f23/ANZ5X+tX7/8Ad69faj+0rH/n9t/9Z5X+tX7/APd69favB/slv/zwi/74FH2S3/54Rf8AfAo/s1/zfh/wQ/tBfy/ie8f2lY/8/tv/AKzyv9av3/7vXr7Uf2lY/wDP7b/6zyv9av3/AO716+1eD/ZLf/nhF/3wKPslv/zwi/74FH9mv+b8P+CP+0V/L+J7x/aVj/z+2/8ArPK/1q/f/u9evtR/aVj/AM/tv/rPK/1q/f8A7vXr7V4P9kt/+eEX/fAo+yW//PCL/vgUf2a/5vw/4If2iv5fxPeP7Ssf+f23/wBZ5X+tX7/93r19qP7Ssf8An9t/9Z5X+tX7/wDd69favB/slv8A88Iv++BR9kt/+eEX/fAo/s1/zfh/wQ/tFfy/ie8f2lY/8/tv/rPK/wBav3/7vXr7Uf2lY/8AP7b/AOs8r/Wr9/8Au9evtXg/2S3/AOeEX/fAo+yW/wDzwi/74FH9mv8Am/D/AIIf2iv5fxPcRqjXF1NDp1ut2ICFkdZlADHt9RVqzuVvLOO4VCm8fdPUHoRXl/gXUbu11aLSbFlghu3YuyxBtpVGOf0x+NeoWVqtnZx26sX2D7x6k9Sa86tSdGfKzvo1VVhzImopaKxNSnq+Bol8T/z7yf8AoJpNPG03IPaRR/5DSjWv+QBqH/XrJ/6CafZDEt2COfNX/wBFpWVb/l3/AIn/AOksIby9P1LNFLRWoCUUtFAGbr2i2+vaTJZXHyk/NFJjJjcdGH+eQSK8ZurWewvZrO8Ty7iBtrr29iPYjkexr3iuS8deGTq1kNQsI831svKqOZo+pX6jqPxHeu/B4j2UuWWzOHF4f2keaO6PL62vDHiSfw5fE4aWxmbM8I7H++vv7dx+FYisGUMpyD0NLXt1IRqR5ZbHjQnKnLmie72t1Be2sdzaSrLDKoZHU8EVLXkXhTxTJ4duvKuN0mnStmRByYj/AH1H8x369evrcM0VxAk1vIskUihkdDkMD0INfO16EqMrPY9+hWjWjdbjqKXFGK5zoEopcUYoASilxRigBKKXFGKAEopcUYoASilxRigBKKXFGKAEopcUUAJRS0UAJRS0UAJRS0UAJRS0UAJRS0UAJRS0UAJRS0YoASilxRigBKKXFGKAEopcUYoASilxRigBKKXFGKAEopcUYoASilxRigBKKXFGKAM/Xh/xTepf9ekv/oBr5a+EGf7e1DP/AD5xZ/76avqjWwP7A1DI4+yy/wDoBr5V+EWR4hvR2NnHn/vo0AbXio/8XU8OjIz9psP/AEpet2zwPiJrgwc/Z7c9f9+uQ8Q6lC/xa0uWaVI4ba8sg8jnCqonJJJ7AetdbZsG+IWsMpBBtLc5Bz3egDehPyH/AHm/makzUMX3D/vN/M0/NXP42RD4UPzXL+Fz/wAVHdj/AKjT/wDotq6Umuc8JEf8JLf8/wDMXfH/AH7aoLE8On/ioPEX/X2v/oNdFmub0A48Q+IMjH+lL/6BXQbqAJM0ZqPdRuoAkzRmo91G6gB+aXNR7jRuoAkzRmo91G6gCTPvRmo91G6gCTJ9aTNM3UbqAH596M+9R5o3UASZoz71HmjdQBJmuG8VZPxE8Pn0A/8AQ67XdXD+K2VfHeiOxwFAJPtvoA6DVJZtS1GDQNOm8qW4G+4mU828PRj/ALx6CrVzcR661toGmkL4b0RwhiCgrczLzjjqF6nPU9jXPW+otaeFNS17zB9t1FysTAk7FztQc9hya3vDGi3OsaZDaadJLp2gWyf6VrDDaZvUQbs7ixz8/Qds0ASNYXHijxPaWWkX7WDaU7XN5qIhWRLP5SFByQC57DnHUirHiPxLpXh/w8bDT3Nvo9sSzPI2ZLqQ8l3J5ZiefxpNZ1nTtD0EaZpEf2PSbds4/wCWly5/iY/xMT2qojReD7W38ReKLQXPiG6UjRtFY/8AHupH+sk569z6dBzQBX8L+NNK8D6DqesrqenX2u+IJY2jsLa5EwtVRSA0xQkjAOT37DJr1jR/BsENxDqmv3M2sawreabid2EUTkYzFBnZHgcAhd3JySSa+b9ba5uWur7Vrg3F7cgtNJjhfRFGeFGeBX1wg+UZ9KEITFcp40/5I34g/wCwBc/+k7V1uK5Lxp/yRrxB/wBgC5/9J2rCX8ePpL84lr4H6r9T4Pooorck+r9cO7xVrB3bv9MYZxjsOPw6VSq7rh3eKtYO7d/pjDOMdhx+HSqVfT4f+DH0R83X/iy9WFFFFbmIUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAbvgn/kddO+/96T7vT/VP19v64r2HFePeCf+R1077/3pPu9P9U/X2/rivYc14GP/AI3yPcwP8H5hijFGaM1wHcUNe/5FvUv+vSX/ANANTWo/0m9/67D/ANFpUOunHh7UMf8APtJ/6CamtT/pN7/12H/otKyrf8u/8T/9JY4by9F+ZZxRijNGa1EGKMUZozQAYoxRmvOY/itPJErroUeGAIzfHv8A9s61p0Z1b8ivYyqVYU7c7sVfHvhr+zL06rZpizuX/fKBxFIe/wBGP6/WuRrtbr4kte2kttdeH4ZIZVKOhvjgg/8AbOuITdg7htGTtG7cQO2TgZP4V7uF9qoctRbHiYn2TlzU3uOrpPCHix/D84tbxi2mSNk9zbserD/Z9R+I755uit6tKNWPLIxp1JU5c0T3yN1ljWSJldHAZWU5BB6EGnYryLw740vvD1q1oLdb62zmNJJjGYj3AO1uPbtWz/wtO4/6AUX/AIHH/wCN14csFWUrJXPajjKLV27HomKMV53/AMLTuP8AoBRf+Bx/+N0f8LTuP+gFF/4HH/43U/U6/wDL+RX1uh/N+Z6JijFed/8AC07j/oBRf+Bx/wDjdH/C07j/AKAUX/gcf/jdH1Ov/L+QfW6H835nomKMV53/AMLTuP8AoBRf+Bx/+N0f8LTuP+gFF/4HH/43R9Tr/wAv5B9bofzfmeiYoxWJ4V8Rt4l02e6e0Fq0M5hKCXzAcKrZztH9707Vt5rmlFxbi9zojJSXMtgxRijNGakoMUYozRmgAxRijNGaADFGKM0ZoAMUYozRmgAxRijNGaADFGKM0ZoAMUYozRmgAxRijNGaADFGKM0tACYoxS0UAJijFLRQAmKMUtFACYoxS0UAJijFLRQAmKMUtFACYoxS0UAJijFLRQBS1cZ0W9B6fZ5P/QTXyV8LrgWusahMT9zTg347q+uNTGdJux6wOP8Ax018T+HL42Ul9tOPMsUX/wAeoAj1vUZm1y5vYJXimR43jkRsMpDMQQexBr17TnLeONSZiSTYWxyfrJXhl8xeSc56qP5mvcdPP/FZXv8A2D7b/wBCkoA6CI/J+J/nT91QRn5PxP8AOn5q5/GyIfCh5biub8LNKviHVPs6LJJ/apwrPsB/dnPOD2z2roc8Vx9heTWN/rM1pKsU39rxojsoON2FPB9iagsv6Lx4g10hNo+0JyAcH5K3N1YOnAReKNfjDZ2XCLk/7ta+6gCfdRuqDfRvoAn30bqg8z1o3igCfdRuqDfR5lAE+6jdUG+jf70AT7qN3vUG+jzKAJ93vRu96g8yjzKAJ91G6oN/vRv96AJ91JuqHf70m+gCfdXI67ayX3xC0GCFN7SMqAHocvXT7vesGW7jtPih4cubhtsUUqMxxnHz0Ael6b8J/C+hW/27WzLexx5f7NczvJbxk8/LGTg/iD7Vh+L/ABik0BJItNNtwBFCo69hwOpPYUeM/Gf20SXFxIYLGD7kfXP4DqTXGJcG2nh1TVYkmvJXxpemDB2Mf439D79u3NAG3pAi0y7stU12zNxr15Js0PRnYBYmPAlkJ/i5/DoOa5+/gvx4p1mXXLlb3U0uPKlnAwANittUdlBYj8K0rXTpIfGfhu+1GU3GpXOrQ+dKTnaM8Ivoo/Xqaj8Sf8jx4k/6/wA9f+ucdJgcnrv/AB7Semxq+uV+6PoK+RdcP+iyf9c2r66UfKP89qEAtcl40/5Iz4g/7AFz/wCk7V11cl40/wCSM+IP+wBc/wDpO1Yy/jx9JfnEtfA/VfqfBtFFFbkH1frh3eKtYO7d/pjDOMdhx+HSqVXNcO7xVrB3bv8ATGGcY7Dj8OlU6+nw/wDBj6I+br/xZerCiiitzEKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKAN7wR/yO2nff8AvSfd6f6p+vt/XFexYrx3wR/yO2nff+9J93p/qn6+39cV7FXgY/8AjfI9zA/wfmGKMUUVwHcZ+u4GgXvGcwsP0qa1H+k3v/XYf+i0qLXMf2Fdg9DGR+dTWv8Ax83v/Xcf+i0rKt/y7/xP/wBJY4by9F+ZZxRiiitRBijFFFABivnq0/484f8Armv8q+ha+erT/jzh/wCua/yr1st3l8v1PLzHaPzJaKKK9g8kKKKKACiiigAooooAKKKKACiiigD0r4Xf8gC//wCv9v8A0VFXbYrivhd/yAL/AP6/2/8ARUVdrXzOJ/jS9T6PD/wY+gYoxRRXObhijFFFABijFFFABijFFFABijFFFABijFFFABijFFFABijFFFABijFFFABikxS0UAJijFLRQAmKMUtFACYoxS0UAJijFLRQAmKMUtFACYoxS0UAJijFLRQAmKMUtFAFe+GdPuAe8Tfyr4OtpSlwB/etVB/OvvO7GbOYeqH+VfA8f/H5EPW2H86AG3h2mX/rl/U17pZN/wAVfc+v9nW//oUleF3hwzn/AKYk/rXv18iw/ETUljUKos4QAPaSWgDQQ/IKXdUCthaduq5/GyIfCiXdXFSP5UPiGSNsumowuMgcMGU12BfiuPSBrseJYImCvJexBGboGJUA/nUFl7Tpi/iTW5HPzNLGSfqla3mj1rqbb4E2uTPc+JNUFxMA0xhKIpbHbA6VZHwN0/PPiTWyP+u4/wAKAON80etJ5o9a7QfA3TAf+Rh1s/8Abx/9anf8KP0rPOva0f8At6NAHE+aPXNL5oNdx/wpHR/+g1rX/gY1PHwT0MY/4mms/wDga1AHCeaPWk83jjmu11P4UeFdH0u41HUtW1aG0tYzLNI19JhVAyTwa81/4Sj4SjpL4tbnGRM/P/j9AGr5w9aPO96zh4r+EeP9X4sJ9fPk/wDjlH/CWfCP/nl4s/8AAiT/AOOUAaPne9HnD1FZv/CUfCIn/UeLM/8AXxJ/8cpD4k+EBPNt4rP1nf8A+OUAafnCjzx2rIfxF8Ic/LY+KWHvcuP/AGpUT+IvhJgbdL8TN7G6cf8AtSgDc84UecK59vEfwmC/LoniNvY3b/8AxdRt4l+FIHHh3xAx9Det/wDFUAdJ5wo84etcwfE3wrxx4X10n0N83/xVIfFHwuAyPCOssfQ3zf40AdP5w9a5TxNdx2/iLT7iUtsj2E7V3H7/AKCnHxX8McceC9V/G+P+NanhXxl8NLfxbp0o8JXVlIJQqXVxcGVIieAxXnOO1AGxPp9joOht4i8fWK3txcRt/Zvh913hV/56Sj17k9FHvVTQdEttP82+MECXl588nkRhI0HZEXsB+tdT46mVrzxy4IONGtzGSOmc9PSsS0kLWUBPXy16/SgBsx/4qrwuOw1eD+dZfiQ/8Vx4k/7CB/8ARcdaErD/AISXw2xYDbq0B5/3qy/EbZ8b+IyP+ggf/RaUmM5fXP8Aj2l/65mvrxfuj/PavkLWjm2mHpGa+vVPyL9KEAuK5Pxp/wAkY8Qf9gC5/wDSdq62uS8af8kY8Qf9i/c/+k7VhL+PH0l+cSl8D9V+p8GUUUV0EH1drh3eKtYO7d/pjDOMdhx+HSqdXNcO7xVrB3bv9MYZxjsOPw6VTr6fD/wY+iPm6/8AFl6sKKKK3MQooooAKtjT5Do7ajvQRLMINpJ3FiM8cYxiqldrplt9t8IDyNPslaa9byYZmk2ykRHODu+91xkgceuKxq1ORJmtKHO2jnrbw7ql0rMlsyopUFnOACxwP1qpPp9zbWUF1OgSO4z5YLDcQO+OuPeun1G4UaZBbC4tdOv5GjuLvduB3BflyFU89WI7Eil1eKfULK6uNBEd7FOwN6UBeVWHQAMMhO4wM9QelZRrSur7f1/SNXSjZ23/AK/pnM6Zp0uq6lFZW7IskudpckDgE84+lFtpl1dxTy2yK8cBUO+8KBuzjqR1wa3PAsUE/iO3xDKZold2k80BQNpH3due4HWplSG00LVYW0qS3aI2yyRSzFjL8zYbIA/Tg8U51WpuK8vxZMKScFJ+f4IwE0e7d1X9yuTjLXCAD9aq3EDW1w8MhUshwSjBgfoR1roWsoI9K0+7t9G+0TXJmDxbpGChMAEAHPQk/hXOKQsgZl3KDkrnqPStYTcr/wBfqZzio2/r9AjQySKg4LEAZqxqenyaVqU1lO6PJCcMYySOme9bd5bWVt4wOm2unJtFysaEyOTyR7+9N165tpfFl2k2nKSbgqWd3UsM4zjPcc1CqtyVlpa5bpJRd3rexzlXYNKuZ7O5uSFijt41lPmZXerHA28c81Nr1rFD4mvLSxg2IsxjjjUk+3GfU10k1/ZPpmp2zRzXNvp9tb252zhVk2yLkj5TjLZ55yB2onVdouK3t+gQpq7Unt/wTlItNml0mfUQ0awwSLGdzYLsey+uOpqnXYI2nx6Nd20loklrYIZW3yNk3Mhwq5UjcFHBP+ycYFOv7HTrOw1WOPToFntrO38xsuSsrsM7dzHGMipVfWzXX/L/ADKdDS6f9a/5HJ2ltJe3sNrCAZJnCLnpknFOuLKS21GSydkaSOQxlkbKk5x1re8G2QN3JevL5LqkkdqxXdmXyyScd9qgn6kVD4etLDUr9Fnt5kSCMzXE4nz07gbe5wMZ71UqtpPsiY0rpd2ZOpWEul6jNZXDI0kJ2sUOR0qmGBkKdwAfzz/hXY+KhY2XiJ7uWwN0JZG3BpyF3qcFSAM9Cp696xPDUFveeMY4poFaCRW/dOcjG1yBn+tR7d8kZW9fub/Qv2K55Rv/AFdf5la802axtbSaZ4yLuMyIitllXOASO2e1KdLuF0VdUOwW7TGEAthiQM5A7j/CtrSZk1pr5JdOtWljsNsJy/y4KIvViBgHr+vWoNW1CGFLXTksYp7a0jxFLL5i+aW5ZxhhwT09hVqpK/LbXqQ6cbc19DAqzDpt9cRq9vZXEqOMqyRMwPOOMD1rR8VW1taawkVnbpAgt4iVQnBJUHPJ96ui2S90LQrb7LNcyvHcFEinWLo5J5ZTnge1N1fdjJdf8riVP3nF9P8AOxkpoOosMywC2XOCbmRYcf8AfZFQ6jp506ZYzdWtzuXdvtpRIo9j710Qgsx4Xa2+zPuN4H8r+0It+NhG7dtxjoMY/GsfWbWGyjtoV097WVk83zGulm8xG6HAAA/z9amFRylZ/wBfiOdNRjdf1+BTsLGbUr1bW22+Yysw3tgfKpY8/QVP/Y03/P1Y/wDgZH/jWh4ZijtdVhvEvIZHSKQmFEmLrlGXnahxgkZINafm3/8Az+t/38vv/iaU6slKy2KhSi43e5zd7pE9hZQXUstu8c7MqeVKH5XGenHcVRVSzBRjJOOTgfnXWasn2+ysY9SvktooJJAbh0uZC27acDfH1G3pnv2rmYobc3LpNdBY1ztlSMsHx0wDg8+9aU5uUby3M6kFGWmxJHpty2rRadKhgnklWLEgxtLEAE+3NRXlq9lezWsrIzwuUYocgkccV1WiXEOqa7pEctyZTYKdrG32kquWG5tx6Y4rAuhYXN3NO17KDK7Of9H9Tn+9UxqNys+w5U0o3XczqK2NW0q00jVLSGSeaaGSKOWbagVlDckLk9cetbOkQeGvEF+2mW+lT2cjoTFc/aGc5AzyvQfrTlWSjzWbQRpNy5bpM46it/w9pNlPHf6hq5ZrLT1BZIzjzWJwAD+H6irf2HRtd0K+udKsX067sF81ozOZFkTvye+AaJVop2t8/UFRbV7/ACOVorZ8P6XBdNPfankadZLvmwcGQ/woD6k/55rQ1vTbTS/HNnb2EXkw74W27i3JYZ5JJputFT5OolSk48/Q5aium8Q6Xear431GHT4DM6sGbkAKNo5JPArJ07QdS1Z5F061afyzhmDKFB/3icfrTjVi4qTdv+CKVOSlypXM+itTU/DeraPbLcalaeTEz7A3mI2TgnHBPoay6uMoyV4u5Eoyi7SVgoooqhBRRRQAUUUUAFFFFAG94I/5HbTvv/ek+70/1T9fb+uK9irx3wR/yO2nff8AvSfd6f6p+vt/XFexV4GP/jfI9zA/wfmFFFFcB3FDXBnRbkZxlQP1FTWv/Hze/wDXcf8AotKh1sZ0eYDvt/8AQhU1r/x83v8A13H/AKLSsq3/AC7/AMT/APSWOG8vRfmWaKKK1EFFFFABXz1af8ecP/XNf5V9C189Wn/HnD/1zX+Vetlu8vl+p5eY7R+ZLRRRXsHkk9pY3d85SytpZ2GMiNC2M+uOlauteG7mxvLw2VrctZWuAZpVxn1I4GRnPI7VF4aWFdXFzPLCn2VGmRJXCCRx91QTx97B/CtmTSVk1jRp2ayQlLd5kMylrhi+GIAJDfXv71y1KjjO19P6/r5nRCmpQ21Odt7OKXRL28dnEkEkSIBjB37s5/75qjXWTXVxFp2tLFbW6rFeRJGos48bcydtvPQcn+tZ/ifZHrcBMMYUW0BaNECA/ICemKqFRuTT/rRCnTSimv61ZnW0NjJEWu7uWF84CpBvGPXO4VqWug6fIonutRntbUAEyzWuwOOuF+Yljj0BqS0srG90G5uhpsgkadYYBbs8jjjcxwTg8Y/Otu60mK6OkRXNpqDxpZxIGKYji3OykuPXkZx0wOtZVK1na7X3GkKV1eyf3nCzpHHcSJDJ5sasQsm0ruHY4PSo609Tns4rddOs7QAwOfMupRiWRuhGM4VfQc9PrWZXXF3VzmkrOwUUUVRJ6X8Lv+QBf/8AX+3/AKKirta4r4Xf8gC//wCv9v8A0VFXa18zif40vU+jw/8ABj6BRRRXObhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAMmG6Bx6qa+BIv8Aj8g/69h/MV9+sMoQO4r4CiH+lW//AF7D+lADb37zenkNXulxeLd+Ob25VdolsoXAJz1klNeO29tHcw6sZF3NFpjPH7N50S5/JjXq+n6N4q1O9XVtL8N3U9lcWcSxSSOse8AsQQD2w1AGx5gHejzPesy7h8WxXBW18G6hdxEApNC67WBpn2fxvjjwDqp/4Gn+NXP42RD4Ua3me9ctGQt9qoVvvarbZwf9pOK1Ps/jgdfAGq/9/I/8ateDvhz4p13XZptb0t9E09r2O4l+0ODK+wAhVA4wSOtQWfRKkGnZpqgj6U7NABmijNJuGaAFoJwM0ZpjSxgHLqMepoA5X4pDf8KvEgA6adM3Pspr44HQe4r6V+N/xA0yy8G3egadew3GoakvkskTBvLjP3y2OnGRivmoUAFFLRQAmKPwpaKAEo5paKAE5o5paKAEpaKTFABU9mSNStCP+fiP/wBDFV8UpDYyjbWBBVvQjpQB778Sb0W+ueLkbA8/R7cD3PNZ1lKfsMHPPlr/ACqOK90H4oaRbt/bVto3iP7MttfRXzERzRqOo5H1znNS3nha5sLaKJvH3hq3DkJG2C/4feoAqahOsWqaJMzY8vU4Gzj/AGhWfrMwm8W69IpBDXxPH/XNKtaN4Wl8XanHa6R8QdC1O5tmFytvFbOpbaeOvbPpWGwvI9X1aPU7f7NdpeFZYt2QGCKOD6HGR7EUmMztZOba4/65Gvr225tYSe6D+VfH2qnda3fPSM/yr69sDnTbYnr5S5+u2hAWa5Lxp/yRjxB/2L9z/wCk7V1tcl40/wCSMeIP+xfuf/Sdqwl/Hj6S/OJS+B+q/U+DKKKK6CD6u1w7vFWsHdu/0xhnGOw4/DpVOrmuHd4q1g7t3+mMM4x2HH4dKp19Ph/4MfRHzdf+LL1YUUUVuYhRRRQAqjcwAxknHJxXXXOprD4Rj+wBGjsr1YoHZereWxMmPUsSRn29K5CtKDUoE0P+z57d5M3Xnkq+3gIVx0Pc5/CsasOa3ka058tzWvrvztP06db2NB9nEcry25kLShmLZbaecEd6i8TXE0Nvptp5pDraZlCLsDB2LDjA4xjj2qguqWq2Rs/scptzKJTGbjgsARn7uehp9zrFrdG7km07zJ7nnzXmJMZ7beBx049BislTaknbb0NHNNNX39TW8EXMVnqVvFGVe5vWZXx/yziVScfVmA49FHrVawurq/8ADOpLNON0ItYYnYhdih3IGfbPWsvQ9RXSdZgvpIzIsW47FOCcqR/WkstVNnYXVobWGeO5KF/MLD7pJH3SPWnKk+ZtLt+D/wAgjUXKk33/AC/zNyaWW40bSrVdZhimiebz3N10DFduSOTwDXLzIYp3QushViN6HIb3Bq2mowRyK66VZkqQRuMpH4gvg1DPcrc37XEkMcau+5o4hhR64GeK0pxcTOclI6XXbyHSPFGo3kLiXUGkKwgD5bfIwXPq2Og6DqeeKo6fqttc6W1jqymSWEq1lNjLodwyhP8Ad5zz7+1ZusX41TWbm9WMxrM+4KTkgU7SdQt7C7SS7sIryMNuKuSGH0IP8wazVK1NXWun4Fupeo7PTUn8Snb4s1AglcXLHI6jmtazn0210PWRpEbyFIot092qsHzIo4TGAB15ya5zULx9R1K4vJFCtPIXKjoMnpUlpqAtdNv7Uxljdoihs427XDZ9+mKp024RXa36CVRKcn3v+psWksN26eczHSrB/tFzKw5uZT7e+NoHYZPrQt5LfeH/ABFf3HDXU0AHPfeWwPoAKx31OU+UkaRxwQnKQbAyZ6EsDncT6n8McVa1PXVvdNisbSxhsYFfzZFiJPmSYxu56Drgdql03daf8DW/4lKorPX+rW/Am8MTyza/axyOSkUE6ovQKPKcmpYFMNglhYy25LzK15K1xGpZgcqigsCVHqMgnp0rL0fUF0vUPtTReaRG6Ku7HLKVz+tVIn8uZHxnawOPXFXKm3Jv0/UhTSil6/od1qFtbXGsazaate2tvbTzh4mMymSKTGA23PTsc4PT61znhRFi8dwpHKkyqpxIgO1vkfpkA/mKpavqH9q6vcX3l+V577tm7OPxqPR9QbSddS+WLzPLThScAkhh1/GuaVGShFdX0/7daOiNWLk3/XxI2dHv5rq01hJEt1A09zmK2jjP307qoP4VmS6kJtAt9PkhBkgmZ0mz91GHKfnk1JBrt1FBdRMsTi5gMJ/dqu0Eg54A9KZpWowWM3+mafBfQZyY5Bhs9sMOfTg5HXiuhQau7GDmnZXLvjJifFFwpP3I4lHt+7X+tathJHaatoNnI6p9mspZZWc42tIjvg+nBX865q+1JtR1mTULuNX8yQO0YOBgfw5+gxThfwy3Ul5fQtd3MjFtrNtjB9wOSPYEYxUum3TUX0X42sUqiU3JdX+tzQNrMngaLFsXae7aYOse4rGqhSScfKC354qv4gmimfTvJkSTZp8KNtYHawHIPvVSfVr2e/W8Nw0cyALGYvkEajoqgdB7VY1XWjq9vAbm1iW7jJ8y5jAUzDjG4AdRjrVRhJSTfmS5RcWl5EvhmRIr+5eV0RDaTJl920kqQAdvPX05rasPK/sLVsfYsbYs7ftWPv8AfPP/AHz+PFc3Z30FpCVUXqO3+sMF2I1bnjjYf5mr8PiKOGzubcR37C4Cgu19lk2nPynZx71FWnKTul2/Bl05xirN9ybUyH8JxpCqMI7xnkMCTbFBRQMmTvkVzdbMWsWiyA3Fte3cfeGe+yjfUBBVC2uLa3uHma187BzFFI2UH+9/exxxxn9K0ppxTVjOo1Jp3Na1xofh6e6lOL3UozFbp3SEn5nP1xgfnUD3tlqOiyJeQ7dViK+TNEuPPBOCHA4JAyc9Tj88y6u5766e4u5Wllc5Zm/zwPatLSNYsrBle90mG7kiAMLhihDA8bscEfhmk4NLmtd+X5eg1NN8uy/r8Sfxgjy+MLi3iUuy+XEiKMkkIowAPerZKeDbGSIOsmuXUe19pyLRD2z3Y/598I6teHWW1RZdt2ZDIHABAJ9Ac8Vp/wDCdeI/+gj/AOQI/wD4modOpyxgrNJa6/8AAZSqQ5pSd7vb+rotaDG974H12zt1Lzq0coQDkqDk4/75NHhdGtvDviC8mUpA1oYVdhgM7AjA/Ej86wrfV7+01N9Qtrlo7qRmZ3UD5iTk5HTGe2Kl1PxDqusRrHqN48qKchAoUZ9SFAzTlSm21pZtP8v8gjVgkn1Sa/r7zembQLrQLHT49eFnHEokmQWUjmSUjlieOnQVc8XQWq+MbCZLzdcmWFWt/KI2rnht3Q/SuDq7d6tfX2opfXU++5TbtfYoxt6cAYpewakmpd+3X5D9unFprt36fM7rxIrXtnq1vonyXUU2+/jA+edNowQfQen1/HJ0yG1k+HzRanetp8Et8Sk0cbSbyFHDKO3B/IVzya7qUertqkd0y3j/AHpAo54xyMY/Suq0PUz/AMIwItK1ey03UXuGluTdYRWz025BA4x0HbtWMqc6VNLzX9bP5aeRtGpGpNvyf9bmJ4n1SzvUsLTT5JLiOxh8v7RIu0yE47HnAx3qC40FYPC8GsJfRSmWTy2gUcoeeM568dMVreLdQt7jSLO3uLy11DVEctLc2qjaEwfl3Dg84/KuamvpZrKG0AWOCHLBEGNzHqzep6D8OMVvSUnCPLpr/X3mFVxU3za6Faiiiuo5gooooAKKKKACiiigDe8Ef8jtp33/AL0n3en+qfr7f1xXsVeO+CP+R2077/3pPu9P9U/X2/rivYq8DH/xvke5gf4PzCiiiuA7jP1vJ0iQDrvj/wDQ1qe1/wCPm9/67j/0WlQ62SNLbH/PWL/0YtTWv/Hze/8AXcf+i0rKt/y7/wAT/wDSWOG8vRfmWaKKK1EFFFFABXz1af8AHnD/ANc1/lX0LXz1af8AHnD/ANc1/lXrZbvL5fqeXmO0fmS0UUV7B5JcsItPcSvqVzNEExsjhiDNJ68kgLjjrXSXE8C674cjgtQoaK2KySMWcLv4HZfxxmuPq5Lql1Lc2s5cLJaIiQlV+6E6fXmsJ03J3ubQqKKtY6O5XVPsetKGuQ7XkZhG85KgyZxz05H6VneKIppvEEMIVnme3gXb3LFFGPzrDkkeWVpJGLO5LMT3J61LNe3M8/nSzOZAgQNnBCgbccdscUo0nGV/66f5DlVUo2/rr/maeoXdkiQadtkuILNCA8MwQPI3LtkqcjOAPZfer+s3OnwHSHms7iX/AIlqGPbdBNvzPg5CckHnPH0rm7e5ntJ1mtZXhlXo6NgirGqatd6zeC5v5A8gUIMKAAB2/U0Ol7y7eoKro+/oamvWSX9mniGxMYiuDi5i3AGKb+LjuD1/GueoorWEXFWuZTkpO9goooqyT0v4Xf8AIAv/APr/AG/9FRV2tcV8Lv8AkAX/AP1/t/6Kirta+ZxP8aXqfR4f+DH0Ciiiuc3CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK+AY/+Pm2/69v8K+/q+AUBFzbg9rfH8qAL8FxHBDqySsFM+mPGme7ebE2PyBr174/eIdUsdZ0LRdPvJbOzXTluNlu2wlyzLyR1ACjA+teJXy7pAo6tE4Gfwrt/iv440nxx4j02/wBGaQxW+mpbSeamz94HcnGeo+YUAdV4A0pfEeueIV1O8v3W3nVYlS6dQoI9Aa7k+A9JHWfUD9b2T/GuT+ETZ8S+LADwLof1r1Fq0mveZnD4Ucv/AMINpQP+tv8A8byT/Gm/8ITpA73h+t3J/jXTGomqbFHOHwZpIPS6P1upP8aT/hEdJU8JcH63Mn+NdAaiakBhnwtpQOfKl/8AAiT/AOKrwa61C+XULtEv7wKk8iqPtL8AOQB1r6QkZURmYgKBkk9q+ZbiRZdQvJIzuRrmQhh0ILmkNEv9o3//AEELz/wJf/Gmm+vD1vbr3/fvz+tQ0UDGhQCT3Y5Y9c++adRRQAZozRRQAZozRRQAZpaSjNAC0UmaM0ALSGjNGaACiiigBpUMRuUH6ip9KhiPiLTFaNCrXKhgVHNQ1NYTR22u6dPO+yOO4Uk4oA77SdK/sX4reHp7OMR293qcPMYxsO7DL9CO1XvHlyYviZ4kXGf9LU5/7ZR1buWuIZbO/sIo5rixuY7mJJGIVyjZwSPWuUvtauPE2s6hrd7bpbT3k+6SCNiRGVVUxz/u/rSYyMuixyPNEZlwS0Y/iHpX1xpLbtGsz1zAn8hXyhYf8fUZ/wBoV9W6Mc6FYc7v9Hj5Pf5RQgL1cl40/wCSMeIP+xfuf/Sdq62uS8af8kY8Qf8AYv3P/pO1YS/jx9JfnEpfA/VfqfBlFFFdBB9Xa4d3irWDu3f6YwzjHYcfh0qnV/XI5P8AhItSnZX8qa5Zo3ZCoZcDpn8qoV9Ph2nRjbsfN4hNVZX7k8VlcTWstzDEXihI8xl52Z6Ejrjjr0p8GnT3EQkja3CnPD3MaHj2LAir+iWl+6XDWF1axCa1lWUSSjPlgZbI6jp1q9ZWcdrZaPf2sLi5lDl5VuRHgiRlHB68cUSq8t0Ead7My/8AhH73+zpr5jbiCHqwuUO4+gwTk98VQt4JLm4jghAMkjBVBYDJPQZPFdtf2Nvf+KL5Lyz3QwJMUC3QCjapIwg5HPP1rjLa0kumYRNCpUZPmzJH+W4jNKlVck2/6v8AMdSmotJDJ4Jbad4biNo5EOGRhgg1PYadLqAujE6J9mgad95PKggEDA681tXVtc3PiCW11aG2udTmVGR/PKqx2DCfLxkgDrjn6inaHLCh1mNtPSF49PlDqXfPDLlTk8UOq+W630BUlzWe2pzFFWrqeO8kiW2so7chQm2Esd59Tknmrt54W1qwsTeXdg8cCgFm3KSo9wDkVrzxVuZ2uZcjd+XWxkUVp6b4d1XWIml06zeWNTguWCjPoCxGarahpl5pVz5GoW7wSYyA3Qj1BHB/ChTi5cqeoOEkuZrQq0V2WtwLdfE25gOn/wBolwoFv53lbiIVOd3bGM1zNhpl5q92YNNtmlfBbaCMKPcngfjUQqqUeZ6aJ/eXOk4y5Vrq19xTorsY9IvtI8D67DqVs0Ds0DLkggjeOhHFcxeabd6esDXcXlrcRiWI7gwZT0OQaIVYzbt3+/S4TpSglf8ArUq0Vcv9JvtMvEtb23Mc8ihlTIYkE4HQn0qRtD1JdWOmfZWa8GMxIwbGRnkg4HBHer542vcjkltYz6K1tQ8MazpVt9ovrF44gcFwyuB9dpOPxqOw8ParqcCTWNo00buUDBlHIGTnJ4+p4pe0hbmurD9nO/LZ3M2iuns7Oew8LeJ7W7j8uaI2odcg4PmHuKxJtJvrext7yeApDcnEJLDc/wBFznHvjHI9aUaik2v6eiY5U2kn/W9inVrTtPuNU1CKztF3SSHGT0UdyfYVduvCut2dgby5sHSBRuZtykqPcA5H5VLoiveZsLIfZkkUtfXjHkRDlhn+FfbucZ44ClUTi3FjjTfMlJFRdDvXWV4hDJFFKYTKJ0CFgM8EkZ45ofQr+OymumSIwwY8xknRsZOBwCa3JrjSJNCnjsEt0gOoFooryV87RGBuG0hvzz1qGNrceFtXhhFmsj+SQls8hZgrEk4cnoOePfNZe1n26rp/wTT2UO/R9f8AgHMVYsLKXUb+K0ttvmyttXccDNTaIpfX7BVUsTcx8AZ/iFdDpum3kfxCWY2M0cC3j4ZYCqBcnHQYxWtSpyXXlczp0+a3rY5KSNopXjfG5GKnBBGR7jrTa6jw/pt9F4tWWaxnWLM2WkhO3lG65GK5cnJzVRmpOy8iZQcVcKKKK0ICrlnps17aXdzG0aRWiB5DI2M5OAB7mqddXZwaY+kW8Rvma2gAu79VhPzN0CEkgf7IAzySfplUnyrQ0pw5nqYFhpz6gl2YpEQ2sDTsHz8ygjIGB15qssUjxvIiMyJjewGQueBk9q6nQr2W51iSVNOgtdLlDxTMsKhI0YHrIw7cHGecdKnu7G6iSHR45L2WW6YGS7jLJb7MZKoo4cYJ546Vk6zjKz/ruaqinG6/rscZVvTNOm1bUY7K2ZFlkDFTIcDhS39Kbaw2sqyG6uzblR8oERfd+XSup8O6TBYavot6t00pu/OIiaLYQiowz1NaVaihF9/+BczpU3OS7f8ABOOIwSMg49KSt77JYaFeyy34W+I5trYNkOp+67kdBg5A6n2HXCYhnJChQTkKOg9quMubbYiUeXcuHRtRU4azmB9CtK2i6kjYeymU9cFMVYxp914aeSRkg1G1kVFVRjz0b1HqOefTGe1bGsC2j8Vrd35Bt7a2hkMeRmVtg2oB7nr7ZrF1JJ29f0/zNlTi1f0/X/I5vUNNudMmSO7VQzoHG1wwwe2R3FFtp093Z3FxbhXFsA0qA/MF/vY7gd/TNOv47mY/2jLaC3hunYxlE2x8dQtbektLP4cvJbWG0S4WSODc2yMMhByCWIByQOKqU3GCZMYKUmjEsNMn1FbloWjVbaEzO0jbRgEDGfU54qnXWTXE9uJ7GW5062vZJglyHttyOF4RQFRlxzkng5wO1Nure8tNP1SGbU9MRYsRTQw2gUyPnhc+WOeCQRnGO3WpVV31/X/Ip0lbT9P8zntPsZdS1GCzt8CSZwqlug9zUM0fkzyRb1fYxXchyrY7j2roPC809na39+sUZjtYW8tzArN5r4VQGxnuTjNT6rb6na38lpHFBdWVrIdjS2kUUe4qM9Mc8jvzjpTdVqo4/wBf1sJU04KX9f1uYM+myW+l2t88key6LhEBO75Tgk8dKp12OsG+tryxtrWCyDWkEYO8RYWQ/MxAboMn9KxILO7/AOEmFpELaSeWXblI0liwerAYK4A59vaiFW8bv1CdO0rIqX2nS6elq0zoftMKzqFJJCnpn34ptnYSXy3JiZFFvC077zjKggYHvzXU6zf3DxR3mjhWWfzofLS0jcCCPA67c7cYOOlItnpul6jrdnFBdMIrElmNwvzAlDgDZx1689KhVpcuq1/4JTox5tNv+AcdRWrqtnZw6Zpl1ZRyxm6SRnWSQP8AdcqOQo9P898qumMuZXOeUeV2N7wR/wAjtp33/vSfd6f6p+vt/XFexV454NPkeK7G6lEggjZ97qpKrmNgN2Pc/nivYIZo7iFJYHDxuMqw6EV4OPadbTse5gU1R1H0UUVwnaUNaONOH/XxAP8AyKlTWv8Ax83v/Xcf+i0qHWcfYI88g3VuP/IyVNa/8fN7/wBdx/6LSsq3/Lv/ABP/ANJY4by9F+ZZooorUQUUUUAFfPVp/wAecP8A1zX+VfQtfPVp/wAecP8A1zX+Vetlu8vl+p5eY7R+ZLRRRXsHkhRRRQAUUUUAFFFFABRRRQAUUUUAel/C7/kAX/8A1/t/6Kirta4r4Xf8gC//AOv9v/RUVdrXzOJ/jS9T6PD/AMGPoFFFFc5uRzzxWtvJPcyLFFGpZ3c4Cgdya4e++KEEc7LpmmPdRg4EssvkhvcDaTj64o+KF7LHaafp6MRHcu8kgH8QTbgH2y4P4CvO69XCYSFSHPM8zFYqdOfJA7v/AIWncf8AQCi/8Dj/APG6P+Fp3H/QCi/8Dj/8brhKK7fqVDt+LOP65X7/AJHd/wDC07j/AKAUX/gcf/jdH/C07j/oBRf+Bx/+N1wlFH1Kh2/Fh9cr9/yO7/4Wncf9AKL/AMDj/wDG6P8Ahadx/wBAKL/wOP8A8brhKKPqVDt+LD65X7/kd3/wtO4/6AUX/gcf/jdH/C07j/oBRf8Agcf/AI3XCUUfUqHb8WH1yv3/ACO7/wCFp3H/AEAov/A4/wDxuj/hadx/0Aov/A4//G64Sij6lQ7fiw+uV+/5Hd/8LTuP+gFF/wCBx/8AjdH/AAtO4/6AUX/gcf8A43XCUUfUqHb8WH1yv3/I7v8A4Wncf9AKL/wOP/xuj/hadx/0Aov/AAOP/wAbrhKKPqVDt+LD65X7/kd3/wALTuP+gFF/4HH/AON06L4pv5g+0aJtTuYrvc35FAP1rgqKX1Gh2/Fh9drdz3HR9asddsRdadLvTOHVhho29GHY1fryLwDey2njG3gjYiO9V4pF7HajOp+o2n8zXrteNiaPsanKevh6vtocwUUUVznQFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFfApUi+hyMYgP8xX3ywyK+DryeS41rz58GWVXd8KFBJIJ4HFAHU/DrwrZ+K/HEVvqaNJaWtu88kY6SHcoVSfQ8n8K9yPgDwqo2jQrMAcfcrg/gPYt/xPNROCjPFbIfTYpY/+jBXrznAJ9KZLMfRNMsrCxSWztYoXuUWSZkXBdiM5Jq81MsBjTLUekKf+gintVz+JkQ+FEZqJqkamGpLIjUTe1StUR60Act451CSDRUsLQkXOoN5Kleqr1ZvwFeBRRrEZIk+6kjKv0BNe1Xkn9reJNRvSMwaen2WDI/i6uR+grxcf6+4A4/fv/wChGpKHUUUlAC0cUlFAC8UcUlFAC8UcUmaKAFooooAMmjNFFABRRRQAUUUUAFVrwBxEp6GQCrFV7rrF/wBdFoA9N8G6q2o6Gsc7ZntT5T+47H8v5Vn6vZ/2f4hJQYhvhuGO0i9fzH8qwvCmoHTvEcSs2IrweU4/2v4T+fFdr4ms2u9GkeFcz25E0WOu5eSPxHFAGVZjFzH9a+qdAYt4c00nqbSL/wBAFfK9g6y+TOn3ZAHHtkV9S+GmL+FdKb/pyiJ/74FJAalcl40/5Ix4g/7F+5/9J2rrM1yXjQ/8WY8Qf9gC5/8ASdqwl/Hj6S/OJa+B+q/U+DaKKK6CD7L8aeI49Zuvsi27wyWUjRybmBG72rlqua2d3inWDu3f6YwzjHYcfh0qnX0uFgoUY266nzuJm5VXfobnheCWafUPKid/9AnX5VJ5KEAfUnpVmS4ih0Xw+slnDOxWTDSFwV/fN02sP1rHk1W6k0yCwDKkEDmRQi7SzHuxHUjsauJ4h8xQNT02zvm7yuhSRvqykZ+pyaJQk5c39dV+oRnFLl/rodGoMvinWZorCHyo0uQ90jOSDsPX5sDP0rhACxAUEk8ACuih8RaTAGMfhyFSy7WxdPhh6Edx7Vl2mrzWV3NdQRQCaRCisIwPKz/EgHQ470qUZxvp2/rdjqyhK2vf+tkX/FZltvFssq7o3UROjYxghF5/MfpVzS4b+e21vV73a6XFhIDMHUguWU4IB4PtWNZ61cWsXlSxQXkOSRFdR7wpPUg9R+Bq3Dr1ikTxtoVvtfG5UuJVVsdMjcc4pShNRUUtuv8AVgU4uTk3v/XmZmnyTxalbS2kRmnjlV44wpbcQcgYHXpXU3UNt4htNV1PT3vLC8ij8y8t5GJjkHcA9e3Q/lXP3OsRm/hubKyWySHBVbU/OD/ey33j7EgHpkdasX3jLUtTtDbXxumhbh1Rox8vY8Abm9VOBx97kYitKXMmk7/N/kmmdGHo88H7yt5tL82maXiUTDwroH2Xd9i+z/Ps+75nGc475z+tHiAyjwPog1Hd9s3yFfM+/wCXn+X3f0rK03xZf6TAYbEXUMRPzJvSQKP7yhh971Xgcfe54q3+svql0bnUYbqWUjazGVTtXsVGAN3+zwOvzc8ZRk00mnZNvZ3/ACNpYdtNqUbtJfFG35/1c7T/AJrR/n/n3rJ0PzP+EC1s2OftPmR+Z5f3vL4/T7361kf8JLc/21/azRTi+6NKGjOF27dwGAC2OCpAHH3ueItN16bSLgzafFc27sNr7JEYbexwRhm/2TgccNzwrtRSs9FHo+nyK9hLmb5o6uX2o9fmb9h9s/4Vnq/2nzfs/mReRvzj7652+3T2q5o1p/wkWh6KW5fTbwxyk/8APLG/8uAK5288W3+oQzw3v2p47gKsqb0ICqcqV4HzZ6rwDj73IxBp/iGfS4p47KK4gS5XZMFdG+XnDDI+/wAnjgf7XIwnKTi9Gne+z7W7eoLDtSXvRatb4o979/Q7aER+KLnS9YYjZZ3cyzkjGEUmSPPsBgfjWbol5calD4pvbTf9tmRWi2/fCEtkDHPAwOPaubtPEM9jY3FnbRXEVvcgrOiujfKRjIJGd2Oq8Dj73IxFY6w2m3S3NlBdW8o4LRyqcL6gH7zeqnC8fe5GC1k1Z+Wj737B7GTafNHz96Pa3c6DwaZxbawbnf8A2d9jk83d93f2/HGaZ9pmt/hiiwSMgmvzHJt/iXZnH5gVnaj4u1DVrcQaj9qeLPzIjxgY7NwBub/ZOBxw3IxTOsM2mLp7204tVl83yw6HacY3g4BLY6qcLx154rmu+aUXuns+nyJ+ryS5Yyjs/tR6/M6HwlPaxaHrUuqRme2V7QyrnqPMP549O+MVF4lXUoPFVveBvtiSMktgyLlHQEFVUD044HrnvWHDq5gsri0jtp0gutonQOjZVTlWBIzuz1Xgcfe54mj8R3EdlBaLHcrDBKJYwHRjER0ZSRnd6rkL1554fNao5pPXyfZeXkL6vJwUHKOn96Pd+fn/AFqdDdJb+IoNV1Gya906/hhL3cDsTHIoHK569uh/Kqfh2+zY6nZwRLFENNmeQ9WlcADJPoMnA7Z7nmqd74z1PUrQ216bpoW4dUaMfL65AG5vVTgcfe54qaZqaWBvW+zti5tHt1QvkruxyTj2p005RcWn5b/m0iK0PZSU+Zedmn+CbNKwMk+myvZ6pqIW0QM8MbbSqd2A3cgH+laMOpxR+FY7ie+1N0N+yMySbZGHlg7c5Py965GC4ltnYxOwDrsdQxAdT1U47GtC/wBXt7nR7ewsrFbREkM0uJGYNIQFyM5IGB0z/wDX3nSba7XOWFVJfIXw9a2974mtrd95gd2x821gACQcjoeBUvhZt/jKxcbvmnz8zZPfqe5rO0zUJdK1GK9gRHkiJIWQEjkEdj71ctde+xXUdza6bYxzRnKMFkOD/wB91dSMnzJdVb8yISirN9H/AJDNO3HxTbosjx+ZdiMtGxVtrNg4I6cE1Uv4Y7bUrmCHd5cUrIu45OAcc1ft9djgv4ro6VZlo5RJ8vmAkg54O44/I1nXc/2q9nuNuzzZGfbnOMnOM1Uebmu10Jly8tk+pr+JLoXEdgBof9lbIjzs2+d056DOMe/WsKtDVNbv9ZEA1CYSfZ12phQOvU8d+B+VZ9OnFxgkxVJKUm0FdBbXK3Hh+KztNBe5dHLzTZkKFugYhSOg9Tgc8c1z9XH1K4u47e3v7maS1gUKkatwAOgA6Z7Z5/HGKJx5rBCXLc1VitrvSb68v45nksvLRQLoMjMzYwvBwAAeATVyfUp9Aup9L0QXIby0kRzcFtuUDthMbe57VgXmpm4tI7K2hW2tI23iMHcWbGNzN3P5AdhWmvia0+2rfS6Okl4IhGXM7bGwmzO3Hp2zWEqcuquu33W/U3U49HZ9/vv+hk2FlLqmopAhClzueQ8LGvVmPsBk10ml6hHqHj6z+ygi0t4ngtwf7ixsAfx5P41y63cscEsMWI0lPz7Ryw7Lnrj2/POBWloetWukM80mnJLdIjCCcSMCGII+YZwRgnoP8aurByT06WXzIpSUWtet38i1a2w8S6KkEB/4mtgmEQn/AI+Ic5wPdc/lWEklzY3JMby286EqSpKMvYj1FNt7ia0uEntpGiljOVdTgg1Je311qN01xfTvPK3VnPT2HoPYVcYuLa6ESkmk+pL/AGzqf/QRu/8Av+3+NbXizU7+DWwkF7cRr9niO1JWAyUGehrmKv6zqn9r3wufJEOIkj2ht2doxnNJ01zp201/QaqPkavrp+pBPqF5dRiO5u55kBztkkLDPrgmtiyUx+GbaH7sl7qS7Rj7yoMZ/wC+n/SufrXtvENzaX0EtoTDDCgjSLhsLzk8jBbJJzjqfTiipFtWighJJ3kzotZS4NhdFORLrMkrKh58tTsDEem79cVk+JbnT11nVYWspnuGnbbMbnhGzyQu3ofQk/Ws+4169l1Zb+GQwSRjbGF52rzwc9c5JOepJq1eeILLUIpJb3Q7Z75/+XhJXRSfUoDyfxrCFKUGm1f0+RtKpGadnb1INMsrprCW6j1SGwt9+1t87KXI54Vck4z6d61/Ed3HF4tkXNzess8bfZWO2PjacDkls/QcnvXJVe1rUV1bWbm+SMxLM2QhOcDAH9K1dNupd7a/oZKolCy8v1NnzrO5uNQ1PXdMKgOwEZldXeVui8njA5PHHHHOKxdMt7u4vz/ZbmGWNWcOZhGUUdTuJHY/zq2NfebRJNO1KEXe0f6NM5+eA5HAPUjA6Vj04Qkk0/8ANBOSbT/4DOt1O5mtPDun+brM8su+cbrWRmWTleC5I6euD1q5f3Kr4g19DbQsUsMliDluI+Dz0rlLq/SfR7CyWMq1qZSzHo28g/0q1feJb26v57iHZAswClAitxgDBJGT0rH2Mvz/ADNfbR/L8iTW5BLoOhuI0jBim+VM4H71vWsOr1/qsuoWtnDKiD7KjKGUAbssW6DgdcVRrppxcY2fn+Zz1GpSuvL8js/AWu/YZm0yK0e4nu5NyEMFA2qSck+wr0LS7eS10yGGcASKCWAOQCSTj9a8o8Ef8jtp33/vSfd6f6p+vt/XFexV4ONgo1nbrqe3g5uVJX6BRRRXGdhQ1kA2MQP/AD92/wD6OQ1Na/8AHze/9dx/6LSodYGbWEf9PUB/8irU1r/x83v/AF3H/otKyrb0/wDE/wD0ljhvL0X5lmiiitRBRRRQAV5xH8KZ44lRddjwoAGbE9v+2lej0VrTrTpX5Ha5lUpQqW51c86/4VZcf9B2L/wBP/xyj/hVlx/0HYv/AABP/wAcr0Witvrlf+b8jL6pQ/l/M86/4VZcf9B2L/wBP/xyj/hVlx/0HYv/AABP/wAcr0Wij65X/m/IPqlD+X8zzr/hVlx/0HYv/AE//HKP+FWXH/Qdi/8AAE//AByvRaKPrlf+b8g+qUP5fzPOv+FWXH/Qdi/8AT/8co/4VZcf9B2L/wAAT/8AHK9Foo+uV/5vyD6pQ/l/M86/4VZcf9B2L/wBP/xyj/hVlx/0HYv/AABP/wAcr0Wij65X/m/IPqlD+X8zzr/hVlx/0HYv/AE//HKP+FWXH/Qdi/8AAE//AByvRaKPrlf+b8g+qUP5fzMPwp4dbw1ps9q92LtprgzFxF5YGVVcY3H+76963KKK5pScm5Pc6IxUVyrYKKKKko86+Kf/AB+aN/1zuP5xVwld38U/+PzRv+udx/OKuEr6LBfwF8/zPAxn8d/10Ciiiuw5AoroNO0TTo9CGr69cXEcEshjgitgC8hHU5PGOD+VM1vRLS10y11XSLiWaxuWKYmADxuOxxx2P5d6x9tHm5fl8zX2UuXmMKip7L7J9sj/ALR877Nk+Z5GN/Ttnjrium0nSvC2tailnZ/20JGBJZzEFUAZySAf8mnOooatChTc9EzkqK6TR9E0q+n1mW4mums7AF42hK73QE4PIxnAHpWfqf8AYH2Zf7G/tLz9/wA32vy9u3B6bec5x+tCqpy5UmDptR5mzLorpodJ0G28NWGpau+omS7Mg22pjwNrEfxD0x3rFvksZL5U0Rbt4mACrcBTIWPYBfwojUUm0kEqbik2U6tXenXVjDby3UYRLmPzIjuB3L64B4/Gtq1tLh/Dl3Y6jpd4Z4mD2TC2fcrE/MucdO+Pr3rRu9ImM+kXF7ZXDwWenR+ZCsRLSOGbEeMfTPoPqKzlXSdv6+RoqLaucZJG8UhSVGR14KsMEfhTa2dbh1m9L6xqtu6K77PmG3YOw29QPesatoS5lcxlHldgoooqyTb8Gf8AI86T/wBdJf8A0TJXsteNeDP+R50n/rpL/wCiZK9lrwcw/jL0PbwH8J+oUUUV553hRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAAa+DbkEasg6EI4/HK195GvgzVHMWoSP0KRyn8crQB9CfBmxW1+G9vcBSr3s8s7Z75chT/AN8ha7mT7jfSqHhrTTo/hTS9NON1raxxEjuVUAn9KvTf6p/oaaJZVsv+Qdbf9cl/kKc1NtP+PC3/AOuS/wAhTmq5/EyY/CiJqYae1MNQURNWdrF8mmaPd3shwIImb15xwPzxWi3euS8dyeZY2GmBnBv7xEO0fwL8zZ/KgChptm1n4SiEoHnSqZpSO7vyf5/pXiI/19x/13f/ANCNfQOoj/iXuB2GK+fgf9Iuf+u7/wDoVIofSH6UtFACc+lHPpS0UAJz6UfhS0lABj2oxRkUZFABS0maWgAooooAKKSigBaKSjB9aACoLkf6r/rotT8+tQ3PIj/66L/OgCSTcF3IcOhDKfcdK9a029TU9Jt7pcYniDED17/rXk9dx4AuzJo89oXZmtpjgY6K3Ix+OaAG6XH9luLqy4H2SdggH9xvmX+ZH4V9T+GXMnhLSXP8VlCf/HBXzDqjCx8SCTPy3dqwxj+JOR+jN+VfTXhE7vBeit62EH/oC0AbFcl40/5Iz4g/7AFz/wCk7V1tcl40/wCSM+IP+wBc/wDpO1YS/jx9JfnEtfA/VfqfBtFFFbkH1drZ3eKdYO7d/pjDOMdhx+HSqdXNbO7xTrB3bv8ATGGcY7Dj8OlU6+nw/wDBj6I+br/xZerCiiitzEKKKKACrem6dNql59mgaNDsZ2eRsKoUEkk9ulVK6Ezx6b4Z0+WK0geS8E8UzvuBZQ6nGVYf54rOpJpWW7LhFN3eyMS0tZL2+htYMGSaQRrnpknHPtReWsllezWsxQyQuUYo24ZHoa66TyNKe01a2sYlkTT0aGKIN80jLlnbnO1QeT7jn0zNK+x31hq8kum26vDaF0ZWkJDbgM8sayVZv3rafqaukl7t9TEs7Z72+gtYioknkWNS3QFjgZ/OrFvpFzdXl1awmIyWqs7lpAq4UgEhjx374rS8L6YZbqDUpSVjhvbeOP8A25DIuR+C5P4itZL3TYX1JraSG2LW7xyCaBmAlaTBG4KSVwucc9fY4U6zUmo6hCknFORgw+F9SmuIoR9lVpkMkebuI7lAJyAGJI4PI9KxyMHFd1b6nZG7gkt7uyla201ohGlu4d5drcLlBwS3TP4Vy9lBN4g1+GEooadwH8lAgVR95sDgYAJp06k3dz0SCdOKsobsgv8ATpNPW2Mskb/aYFnUJnKq3TOR1p0Glzz2l7PlIxZBTKshKtycYAx1z2rp5oNOvH0aC7VkuFs7eQS7vlMQyZAw7YVSQfeo3vbTVbDxFePc3RExhLboFzGvmfKB8/Pp2qfbStt/VyvYxvv/AFY4+rf9mz/2P/aRKCDzvJALYYtjOQO4ovv7O2QjTjclguJTOqgFvUYJwPb9a3be4sb20uLP7JHcW+l2TyQyOzqXk3rubAYcEk8dcAVrObSTSMoQTbTZz0VldXERkgtppUB2lkQkA+mRT/7MvxFJKbK4EcQ3OxiICj1Nb7N9s8JyyStb6Xvv0YAI6oR5RxgKGPPX0rMuNNaPRX1BNUiuEEwh2RiTkkE/xKOwpKo3vpqN00jNgglup1hgXfI/CqDyT6D39u9W9M0e41S/eziKRSojO3nZUDb1B44qG0SA7nmunt3QgpsjLE++cjGK6rT72K+vNX1iS5w62Bjd1t9oDEBAfvHJOKKs5RTt/TCnCMmr/wBI4w8GitG2sbG5u4oEvpd0rqg/0fuTj+9U0ltpem+Jbm2vTcXNnbyMn7sBWdhxg+2cjIq/aK9upHI9zIorrYrPQ9d0PUptP06TTbmxj84Hz2lVxg8HP0qvYafpen+GE1nV7WS+a5lMUFuspjUYzkkjnsaj267O97W/rQv2L7q29zmqAMnArotd0zTm0Kz1rR4nt4Z5DDJbu5fY4z0J57H9KpQW3iC0Qpaw6lApOSsaSKP0qlUUo3X4kum4uz/AZa+HdXvSPs+nXBBGd7psX/vpsCotU0ufSLoW9y0TOVDZikDge3Het69s9UufBlos1veTXAvJGYOjM+No5PfFY0fh7VJLeeb7FLGkC7m8xdhI9gevrxUQqXd5NWLnTtpFO5m1c03Tn1KeWOOWOLyoXmZpM4CqMnoCelSaVdXIuYbOG4eGKeZQ2zGRkgZrbTVYNIvr+2uNSv53CSW2RbqArZxuH7znpVVJyWi3/ryJhCL1e39eZyyI8kipGpd2OFVRkk+gFNrpHuJYtCbU7PWL5nW5EChoxHyVJPIY9q52WR5pWllYu7kszHqSe9VCTlcmUVEettO1s1wsEhgRtrShDtU+hPTNTJpV9LEskdrKyOMqwXgitvXf+JV4V0vSB8sswN5cDGDluFB/Dj8BWfpA0+5s7211JkgdYmmt7joQ4H3D6g+ntx1qFUbjzLv+BbppS5WVzoupBVY2UwVuhK8GkutJvLKziubmMIkrFQNwLAj1HUf/AFq1bqBLjw74djllWGMi4LyN0VRJkn3PoO54qlqznU5JL6w077PYW4WEMidAOFLkfxH/AApRnJvXz/O34hKEUvu/K5lVcttLuLyxuLq22yC2G6WMH5lX+9juPpTYruCOFUfTraVh1kdpct9cOB+QrfsYt/hmS+07SA9zJcm2dYDOQYtmSCA/qRVVJuK2/r7xQgpM5ait4R3umRjUJPDkEUcbhd88cpAJ6ZVn/XHWspYnv7mRolt4c5fYZVjUc9BuP6ZqlNPXoS4NadQgsZptTisWXyZpJVixKCNrE457jrUh0m7OqzafbJ9pnhLBhDkg7euPyrprWK51jUdBEcMMl3Ysv2mVLmJi6K42nhiThR+tMv47jSbjUhaSW6Xt9K++RrqNDDEWJAGWBy3BJ7DHfph7Z3tpf/gm/sVa/Q5AgqxVgQQcEHtSVa1Cx+wTrGLq3uQyht9vJvA9vrVWupNNXRzNNOzCiiimIKKKKACiiigAooooA3vBH/I7ad9/70n3en+qfr7f1xXsVeO+CP8AkdtO+/8Aek+70/1T9fb+uK9irwMf/G+R7mB/g/MKKKK4DuKGrgmC2x/z9w/+hiprX/j5vf8AruP/AEWlQ6tny7QDvdxf+hVNa/8AHze/9dx/6LSsq29L1f8A6Sxw3n6L8yzRRRWogooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA86+Kf/AB+aN/1zuP5xVwld38U/+PzRv+udx/OKuEr6LBfwF8/zPAxn8d/10Ciiiuw5Dp9bUv4E8Pyxf6pDMj4/vFv/AKzU6b918LrcSLzLflo8+gUgn9CKzdL8S3ml2UlmIra7tZG3GC6j3qD6gZFQ6vrl5rUkRuvLSOFdsUMKbUjHsPwrkVOd1F7J3udTqQs5dWrGdXVWA/sDwVc6g3y3eqH7Pb+qxj7zevPP/jtYus6zca5dx3F2kSPHEIgIlIGASe5PPNGq6zcav9mWdIoo7WIRRRRAhVH4k89PyrSUZTSTXqZxlGDbT9CTRden0QXIht7e4W5QI6XCFlIHtketbN39i1zwZdamNNgsLqylRN1quxJAxAIx+P8AKsbStfuNJglgS3tbqCYhmiuot65HftT9V8SXuq2qWjpBbWqHIt7aPYmfXFRKnJzulbXe5caiULN302sWLHxXJaaZbafNplheQW5Yr9oiLt8zEnBzgdfSpPF9haW0theWMH2Vb63EzW//ADzPt7c/pUdt4uuoLaCGXT9NujboEiluLfc6gdOcis6+1a51TUvtupEXD8DYeFwOi8dB9KI05KpzJW367hKcXDlbvt02Lmi2kNqg1nVF/wBFgb9zEetzIOij2B6n8K3NZvE1WawttXlEX26wjlSb+GKbc+CfRTnB/D0rkby9nvphJcPnaNqKowqKOiqBwBVzW9Qhvxpwt93+jWMcDlhj5hknHtzRKm5TUnv+QRqKMXFf8OVdQ0270q7a2voWikHr0YeoPcVVrSn1/UbnSI9Mnn8y2jPyhlBbHGBk84Hb6/Ss2t4c1ve3MJct/dCiiirJNvwZ/wAjzpP/AF0l/wDRMley1414M/5HnSf+ukv/AKJkr2WvBzD+MvQ9vAfwn6hRRRXnneFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAB6V8PwWa6j8QdLsJIjIlzfCORR/d81C3/joNfb5r5L+HOm/b/jNbzcf6AlzcFT36Rj9Xz+FAH0JjCgegxUFxxBJ/un+VWDVa6OLaU+iH+VUtyHsQW3FlB/1zX+VONJbjFpCP8AYX+VKact2KOyImqI1K1RGpKI271xOuSC6+IFnCshxZWjSFP9pzgfpXbN0NefwzJd+PNamC4MTRwA/wC6vP6mkxrc19S/48W+lfPo/wCPm5/6+JP/AEI19A6if9Bb6V8/D/j4uf8Ar4k/9CpIY/NFJzRz60wFpaSjNAC0lGaM0AGPaj8KM0ZoAKM0ZozQAZoozRmgAxRijNGaADFFGaD0oAKguPux/wDXRf51NUNwflj/AOui/wA6AJ66HwJOYvEFxCWws8GQPVlP+BNc9XR+F0jhWK8KZdb+OHd6B45B/PFAG144MkOkwXcXHkTjccfwsChH/j1fTPg058C6EemdOt//AEWtfOXi62N14UvkXqqbwPdef6V9H+EontvBeiQTIyPHp8CMrgggiNRgg8g+1AGxXJeNP+SM+IP+wBc/+k7V1ua5Lxp/yRnxB/2ALn/0nasJfx4+kvziWvgfqv1Pg6iiityD6u1s7vFOsHdu/wBMYZxjsOPw6VTq5rZ3eKdYO7d/pjDOMdhx+HSqdfT4f+DH0R83X/iy9WFFFFbmIUUUUAFdDc3ktp4S0bylhbc9xnzYEk/iXpuBx+Fc9WmdbmXSrSyhREFuXJdlV924g9COMYrKpFya06/ozSElG+vT9Uaeq6i9lrei34A3R2Vu7KgCgjHIwOACMimaZOj6X4luYoxBG8S7UHOwNJwv9KytR1WXUbi3mlSNWghSIYUYbb3I6fhjFW59fSTQ3sLfT4LaSdlNzNHx5gU5Ubei/h+lZezfKlbXT87mvtFzN37/AJWK+gE/8JHpi5OPtkRx/wADFatrcS2tj4llt5nhkEkYV0YqR+97Ee1YWnXQsdUtbtlLiCZJSoOM7SDj9KtJqNnDcyXa2fn3DuXXz2zGhJz90fex6k49qqpBuW3b87kwkkt+/wCVjqILqew8T6NBNe3SA26vd+dcsU3lCSDk4GOPzrhvMfzC+9t7Zy2eTnrWjaa9dQ38k93i9jnbdcQTcrL+HY+hHT9Ko3TQPeTNaRtHAXJjRjkqueAT9KKVNwevYKk1Jadza124e3bSynIfS4VdTnDLkkg45wcdqm028gbw5rTDTbVQqw5QNLh/3nfL549iKz7rWY7iS0Y2UUgt7RLbbMSQxX+LgjHWli14w201vHptksU4USLtk+bByP4/Wp5JciVv6uVzrmbv/Vine3q3jRFLO2tfLQLi3Vhux3OScn361v6NqVz/AGNqE+o6ldRJK0dtFLvLbGJ3EgZ7BecdjWLd6oLqyS2FjZwLGxZXhQhueuSSc/jUd5e/aIobeFPKtoAdiZyST1Zj3JwPyA7Vcoc8VG1iIz5W5XOkvlmt/Ddxb+IpLm6kh1BUDLPk48okYZgflwc496x7nUbA+Hf7PsorhHN0JyZWVhgIV6gD19KSHW1GkNY3lot5unE3mSytxhNoHBB4Hv8AhUQ1KzEcirpFsC6FdxeQlc9xlutRGDW66/L8y5TT2fT5mcAScDk10V5I3h7RItOifbqE8i3F0V6xAcpGff8AiI7VlWN+unjzoIQ14D8kr8iL3Vf73uenpnmqju0kjPIxd2JLMxySfU1rKLm9dl+JlGSitN2dRpr6bq2q6PJbwC21EXa/aI4lxHIq/NvA6A8dB71kXFrcax4muYbGMyyz3MhUD0LE5Pt71c07xHb6dC80elW41IArFdISAgIwTs6Z+mOv55em6peaRdG506byZSpQttDcH2IPpWcYzTbS9L/1saSlBpJ/O39bm3qt1baFpUmhaZKJp5WBvrpejEf8s19h/j6modN14W+hDT9V0oahY+YWhy7RlW7gMB7/AKmkfxx4hdGRtQyrDBHkR/8AxNVNN8S6vpFsbfT7wxRFt20orDP4g4qVSlyWklffd/5aFOpHmvFu3ov89ToPE0sUXgrT7YWC6a01yZktQSWCBSMsTzk7h1ri6sXt/dajdNcX07zytxuc9vQeg9qr1rSp+zjZmVWfPK6N64/5EKy/6/pP/QRWDWhLqYk8Pwab5RBinabzN3XIAxj8Kz6qmmk792Ko02rdkT2M622oW88gJWKVXYL1IBBrpLhtPure21CfS4BPqd++0GSX/VZGScP97cT7cdK561eyiG+6hluHzxGG2L+J5J+gx9akudWuLu/hupQg8jaIokXaiKpyFA9KicHKV0VCSjGzNDWbuJDdaFZWKQpFqDFGR2JbblADuJ598j6VV0PSm1HxHb2Eq8eb++Hoq8tyPYEVZk1rSpdXbUX0ibzWm84r9s+UtnPTZnGfep9O1u0tjrWpYEF9coUtoU3HbvPzNk8ccH86j34waS1/Uv3JTu3p+hR8Rao2o+JLm8hchVk2wsp6KvCkenTP41W/tnVP+gld/wDf9v8AGqVFbqEUkrbGLnJtu+502p6nfp4X0ORL65V5BPvYSsC2JOMnPNYkmq6hLG0ct/cujDDK0zEEe4zT7vUvtWk2Fj5W37H5nz7s797bunbFUainTSWq6v8AMqpNt6PovyFRGkdUjUszHCqoySfStnXnS1tbLR42DGzVmnKnIMznLD324A/OqVnqH2CMtaxbbs5AuGOTGP8AYHY+/J9MUywu47a4zc20d1C5HmRyDkj2YcqfcH86ck2722FFpK3c1L3bb+BtMiAObq5lnP8AwHCVhxxvLIscSM7uQFVRkk+gFaOt6uuqSQJb2wtLS2j8uGAMW2jOSST1Jqnb3k1oH+zv5bONpcD5gO4B6jPtRTUlHzdwm4uXkdNpU0eh31lplswfULq6iW8lU5ES7x+6B7n+8fw5ptzbx+IdQvNP8xYtSt7iUWzOcCdN5Plk9iCSR+Vc7pt0tjqtpdupZYJkkKjqQrA4/Sm3d0bnUZ7tQYzLK0oAPK5OetZ+yfNdb9/M09quWz27eQXlldafcGC9gkgkH8Lrj8R6j3q5/Y3+jki7iNysAuTb4OQm3d97GM7TnHp37VVvdQu9RlEl9cyTuowDI2cCpP7Xvfsn2bzV2eX5W7y137M5278bse2cVq1Oy7macLvsUqKKK0MwooooAKKKKACiiigDe8Ef8jtp33/vSfd6f6p+vt/XFexV474I/wCR2077/wB6T7vT/VP19v64r2KvAx/8b5HuYH+D8wooorgO4oaqcCz97uP+tTWv/Hze/wDXcf8AotKh1QgNYg97pP5GnJPFbPfzXEixRrOuWc4A/doB+tZVt6Xq/wAmOH2/T9UXaKKK1EFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHnXxTH+l6Oe2y4H6xVwlexeLvDv8AwkOjiKFlS7gbzIGboTjBU+xH9D2ryC9gm0ycwalC9pKpwVmGPyPQj3Fe7gasXS5L6o8TG05Kpz20Yyiovtdv/wA94v8AvsUq3ELttSVGPoGBr0Lo4LMkooopgFFFBOBk0AFFRfarcHBni/77FH2u3/57xf8AfYpXQWZLRUX2u3/57xf99ij7Xb/894v++xRdBZktFRfa7f8A57xf99ij7Xb/APPeL/vsUXQWZLRUX2u3/wCe8X/fYo+12/8Az3i/77FF0FmS0VF9rt/+e8X/AH2KdHNHM4SFxK54Cx/MT+Aouh2ZveC/+R50n/fl/wDRMley1wvgPwncWE51bVYjDMU2W8DfeQHqzehPTHYZz147qvnsbUjUq3j0PewdOUKVpBRRRXGdYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAGvm34NWqT+N/FF8UIa3CQIcdmkkJ/8AQVr6SPtXhXwdtIorfxPcqvzya3Mm71VVXA/NjQgPRWqrdnFpMf8AYb+VTzyxwRmSZ1RB1ZjgCoL3/jyn/wCubfyrSK1RnLZkcIxbRD/YH8qDSxf8e8f+6P5UhqZbjWxE1RmpGqNqQyJq830G5F5qmrXKjiS/kx+GB/SvSGryvwZ/qblieWu5T/4+aT2GtzqNRP8AoL/SvAB/x9XX/Xw/869/1H/jxf6V4AP+Pu7/AOvh/wCdJDHUUUUwCijNGaACijNGaACijNGaACiiigAooooAKKOaOaACijmjmgAqC64RP+ui/wA6nOcVXu/9Wv8Avr/OgCxXY+HI1i8C393KuRHqVmVP/A8H+dcd2ru7dRH8C72VeGOpR5P0dKANrW1LaDfAdTA38q+hvC1w134Q0e5c5aayhdj6koD+PWvn7UV3aXcL1zEw/SvefBGf+Ff+H93B/s23z/36WmBu1yfjQ/8AFmvEH/YAuf8A0nausrkvGn/JGvEH/YAuf/Sdq55fx4+kvziWvgfqv1Pg+iiityD6u1s7vFOsHdu/0xhnGOw4/DpVOrmtnd4p1g7t3+mMM4x2HH4dKp19Ph/4MfRHzdf+LL1YUUUVuYhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBveCP+R2077/3pPu9P9U/X2/rivYq8d8Ef8jtp33/AL0n3en+qfr7f1xXsVeBj/43yPcwP8H5hRRRXAdxla9d29jDaXN7KsUEVwGd26DCMa8x8Ua/NrV7HNAXitC4nigk6FlO0M2O+EHHbJr07XbODUEsrW8jWWCW42ujdCPLevMfFGgTaLexwwB5bQOIIp5OgZjuCtjvhxz3wa6aPs/a0ube7/8ASZHHiPack+Xb/go0f+Fl65/z7af/AN8P/wDFUf8ACy9c/wCfbT/++H/+Ko/4Vprn/Pzp/wD32/8A8TR/wrTXP+fnT/8Avt//AImvR/2Ly/E4/wDbP6sH/Cy9c/59tP8A++H/APiqP+Fl65/z7af/AN8P/wDFUf8ACtNc/wCfnT/++3/+Jo/4Vprn/Pzp/wD32/8A8TR/sXl+If7Z/Vg/4WXrn/Ptp/8A3w//AMVR/wALL1z/AJ9tP/74f/4qj/hWmuf8/On/APfb/wDxNH/CtNc/5+dP/wC+3/8AiaP9i8vxD/bP6sH/AAsvXP8An20//vh//iqP+Fl65/z7af8A98P/APFUf8K01z/n50//AL7f/wCJo/4Vprn/AD86f/32/wD8TR/sXl+If7Z/Vg/4WXrn/Ptp/wD3w/8A8VR/wsvXP+fbT/8Avh//AIqj/hWmuf8APzp//fb/APxNH/CtNc/5+dP/AO+3/wDiaP8AYvL8Q/2z+rB/wsvXP+fbT/8Avh//AIqj/hZeuf8APtp//fD/APxVH/CtNc/5+dP/AO+3/wDiaP8AhWmuf8/On/8Afb//ABNH+xeX4h/tn9WD/hZeuf8APtp//fD/APxVH/Cy9c/59tP/AO+H/wDiqP8AhWmuf8/On/8Afb//ABNH/CtNc/5+dP8A++3/APiaP9i8vxD/AGz+rB/wsvXP+fbT/wDvh/8A4qj/AIWXrn/Ptp//AHw//wAVR/wrTXP+fnT/APvt/wD4mj/hWmuf8/On/wDfb/8AxNH+xeX4h/tn9WD/AIWXrn/Ptp//AHw//wAVR/wsvXP+fbT/APvh/wD4qj/hWmuf8/On/wDfb/8AxNH/AArTXP8An50//vt//iaP9i8vxD/bP6sH/Cy9c/59tP8A++H/APiqP+Fl65/z7af/AN8P/wDFUf8ACtNc/wCfnT/++3/+Jo/4Vprn/Pzp/wD32/8A8TR/sXl+If7Z/Vg/4WXrn/Ptp/8A3w//AMVR/wALL1z/AJ9tP/74f/4qj/hWmuf8/On/APfb/wDxNH/CtNc/5+dP/wC+3/8AiaP9i8vxD/bP6sH/AAsvXP8An20//vh//iqP+Fl65/z7af8A98P/APFUf8K01z/n50//AL7f/wCJo/4Vprn/AD86f/32/wD8TR/sXl+If7Z/Vg/4WXrn/Ptp/wD3w/8A8VUF34/1O/tzBe6bpVxE3VJYXYfkWqf/AIVprn/Pzp//AH2//wATR/wrTXP+fnT/APvt/wD4mj/Yv6uH+2f1Y4+5Z5ZzJbRQ2yn/AJZIXZPw3EkfnUfnsn+ujZfdRuH6c/pXaf8ACtNc/wCfnT/++3/+Jo/4Vprn/Pzp/wD32/8A8TXQsTQSspGDw1Zu7icWXmkH7qMIP70n+FXtMvf7Ok8yTT7K+lByGu1dwv0UMF/TNdN/wrTXP+fnT/8Avt//AImj/hWmuf8APzp//fb/APxNKWIw8lZy/MI4evF3URB8StbVQFtdOAHAAjfj/wAepf8AhZeuf8+2n/8AfD//ABVH/CtNc/5+dP8A++3/APiaP+Faa5/z86f/AN9v/wDE1h/sXl+Jv/tn9WD/AIWXrn/Ptp//AHw//wAVR/wsvXP+fbT/APvh/wD4qj/hWmuf8/On/wDfb/8AxNH/AArTXP8An50//vt//iaP9i8vxD/bP6sH/Cy9c/59tP8A++H/APiqP+Fl65/z7af/AN8P/wDFUf8ACtNc/wCfnT/++3/+Jo/4Vprn/Pzp/wD32/8A8TR/sXl+If7Z/Vg/4WXrn/Ptp/8A3w//AMVR/wALL1z/AJ9tP/74f/4qj/hWmuf8/On/APfb/wDxNH/CtNc/5+dP/wC+3/8AiaP9i8vxD/bP6sH/AAsvXP8An20//vh//iqP+Fl65/z7af8A98P/APFUf8K01z/n50//AL7f/wCJo/4Vprn/AD86f/32/wD8TR/sXl+If7Z/Vg/4WXrn/Ptp/wD3w/8A8VR/wsvXP+fbT/8Avh//AIqj/hWmuf8APzp//fb/APxNH/CtNc/5+dP/AO+3/wDiaP8AYvL8Q/2z+rB/wsvXP+fbT/8Avh//AIqj/hZeuf8APtp//fD/APxVH/CtNc/5+dP/AO+3/wDiaP8AhWmuf8/On/8Afb//ABNH+xeX4h/tn9WD/hZeuf8APtp//fD/APxVH/Cy9c/59tP/AO+H/wDiqP8AhWmuf8/On/8Afb//ABNH/CtNc/5+dP8A++3/APiaP9i8vxD/AGz+rB/wsvXP+fbT/wDvh/8A4qj/AIWXrn/Ptp//AHw//wAVR/wrTXP+fnT/APvt/wD4mj/hWmuf8/On/wDfb/8AxNH+xeX4h/tn9WD/AIWXrn/Ptp//AHw//wAVR/wsvXP+fbT/APvh/wD4qj/hWmuf8/On/wDfb/8AxNH/AArTXP8An50//vt//iaP9i8vxD/bP6sH/Cy9c/59tP8A++H/APiqP+Fl65/z7af/AN8P/wDFUf8ACtNc/wCfnT/++3/+Jo/4Vprn/Pzp/wD32/8A8TR/sXl+If7Z/Vg/4WXrn/Ptp/8A3w//AMVR/wALL1z/AJ9tP/74f/4qj/hWmuf8/On/APfb/wDxNH/CtNc/5+dP/wC+3/8AiaP9i8vxD/bP6sH/AAsvXP8An20//vh//iqP+Fl65/z7af8A98P/APFUf8K01z/n50//AL7f/wCJo/4Vprn/AD86f/32/wD8TR/sXl+If7Z/VhP+Fl65/wA+un/98P8A/FVy/h2+u/Ddnc29mtvItzdSXTmRWzuc5I4I4HArqP8AhWmuf8/On/8Afb//ABNc9oui3+uaYL62a2jjMssW2R2zmORkJ4HqpNH+xeX4h/tn9WJr/wARajqNjLaTx2qxyjaxVGzj8WqTTdda2sZbG+YtCY2WGU8lDjhT7eh7dKjv/Duo6dYy3c8lq0cQ3MFds4/Fak07QmudPmv71SsKxM0MR4LnHDH29B361Uvq3s/d7/iSvrPP73b8Drk/1Sf7oprVIBhFA9KjavFe5662IjUbVIajakMjNeUeCuLe4/6+pf8A0M16u1eS+Cm/c3I/6e5f/QzSew1udXqJ/wBAf6V4E3F5dj/p4f8AnXvepHFg/wBK8Fn51C7/AOu7UkMM0U3FLimAtFFFABRQelJzQAtFJzRzQAtHNJzS5oAOaKTNFAC5pM0UUAFLzSUUAFQ3Z/dD/fX+dS1Bef6kf76/zoAs84rvIf8Akgt8P+oiv/oUdcFmu9h4+A19/wBhBf8A0KOgDb1himiXjA4xCx4/3a9/8GL5fgXQkPGNOtx/5DWvn3Xv+Rdvsf8APu/8q+i/D8P2fw1psXTy7SJcemFApiNGuT8af8ka8Qf9gC5/9J2rrK5Lxp/yRvxB/wBgC5/9J2rnl/Hj6S/OJa+B+q/U+EKKKK3JPq7Wzu8U6ud27/TGGcY7Dj8OlU6ua2d3inVzu3f6YwzjHYcfh0qnX0+H/gx9EfN1/wCLL1YUUUVuYhRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBveCP+R2077/3pPu9P9U/X2/rivYq8d8Ef8jtp33/vSfd6f6p+vt/XFexV4GP/AI3yPcwP8H5hRRRXAdxQ1EZvNLH/AE9k/wDkGSnJBFcvfw3EayxtOuVcZB/doR+tWniSRo2dQTG25CexwRn8ifzqG1/4+b3/AK7j/wBFpWNZ+9T9f0kVBaS/rsWaKKK2JCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKM0AFeV/D0EeD1DDBF7eAj3+0y16mTxXm3hBUi0u/gjOfJ1jUUx6Yu5cfpTQma88Mc8TRzIHRuqsMg1V1I40y7PpC//oJq61QyIsiMjqGVhgg9CKqLs0yGrpojIwAPQVG1StUTVJREaYaeaYaAImryHwY3F2PS7l/9DNevNXjPg6TE18npdy/+hGk9hrc7HVHxp7/7teESkfb7vHTz2r2/WJMaZIc/w14e5/026/67NSQxc0UlGaYC0UmaM0ALmikzRmgBaKTNGaAFopM0ZoAWikzRQAtFJmjNAC5ozSZozQAuarXh/cD/AHl/nViq15/qB/vL/OgC125r0/Ukii/Z+gKKqtK6s2O587/ACvL816J40B074S+HtPkfE0hEu0d1OW/9mFAGhr77PD93n+KPZ+fH9a+m4wBEiqAFAwMdq+ZtZt3u7OC2hXc891BGFzjO6RR/WvppeQM+nrTELXJ+NP8AkjfiD/sAXP8A6TtXWVyXjT/kjfiD/sAXP/pO1c8v48fSX5xLXwP1X6nwjRRRW5J9Xa2d3inVzu3f6YwzjHYcfh0qnVn4y+LfD/hezgl0OO1ub1pNs0KylXHHVgQT0ryNvjM/zbdDUZxtzdZx65+Tn9K9qhjaUaajLRo8etg6kqjlHqep0V5Y3xmf5tuhqM425us49c/Jz+lDfGZ/m26Gozjbm6zj1z8nP6Vt9eodzH6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pQ3xmf5tuhqM425us49c/Jz+lH16h3D6lW7HqdFeWN8Zn+bboajONubrOPXPyc/pXuJ8ReCv+FX/AG8Xem/2p9h87Z54378ZxmonmFNW5dS44Co/i0MGiu+b4Wv823WlGcbc2mceufn5/Shvha/zbdaUZxtzaZx65+fn9Kv69Q7kfUq3Y4Giu+b4Wv8ANt1pRnG3NpnHrn5+f0ob4Wv823WlGcbc2mceufn5/Sj69Q7h9SrdjgaK7K6+Geqxk/Y7u0nXP/LQtGcfQBufxrIuPBviK2yX0t5FH8UMiPn8M5/StI4ulLZkSwtWO6MSipbm0urIZvbO5thnrNCyD8yKgV0f7jBvoc1upp7foYuDW46iiind9ibLuFFFFF32Cy7hRRRRd9gsu4UUUUXfYLLuFFFNffj93tzno3p6UXfYLLuOoq9p1tpl1hdQ1aSwkLcl7IumPTcr5/EgCuptPh1BfwCax8RQXERb78VuGGPTIk6/5xXPPFU4aSuvkdEMNOfw2fzOIorvv+FWv/0Gl+9n/j0/h9Pv9ff9KP8AhVr/APQaX72f+PT+H0+/19/0rP69Q7l/Uq3Y4Giu+/4Va/8A0Gl+9n/j0/h9Pv8AX3/Sj/hVr/8AQaX72f8Aj0/h9Pv9ff8ASj69Q7h9SrdjgaK77/hVr/8AQaX72f8Aj0/h9Pv9ff8ASj/hVr/9BpfvZ/49P4fT7/X3/Sj69Q7h9Srdjn/BH/I7ad9/70n3en+qfr7f1xXsVcTo3h3TNAurmDV3W4kBVoZzCyfKQcgYJ/nXUaLv/sa38zfnbxvznGTjr7YryMVVVWpzR2PVw1J0qfKy9RRRXMdIVWtf+Pm9/wCu4/8ARaVZqta/8fN7/wBdx/6LSuer8dP1/wDbWXHaXp+qLNFGaM10EBRRmjNABRRmjNABRRmjNABRRmjNABRRmjNABRRmjNABRRmjNABRRmigAooooAKKKKACiiigAooooAKKKKACiiigAoozRmgAoozRmgAoozRmgAoozRmgAoozRmgAoozRmgAoozRmgAoozRmgAopCaM0ALRmkooAXNGaSigBc0hNFFABRRRQAh6V5l4XhktdW8V20owE12eRR7SKkv/s9emmvOLZpofif4ttZBiKX7JeR++6ERk/nDTQM2WqM1I1RmgkiaomqVqiagCJqYae1MNAETV4h4Wl8u/vl/wCnuX/0I17e1eFIp0fxDqFu5GYbtw2O4JyD+tJjR1Gu3IGmuM9RXjrHN1ckf89TXoPiDUlWwPzcEcV5zC2XlPrITSQybNGabmjNMB2aM03NGaAHUmaTNGaAFzS03NGaAHUU3NGaAHZpM0maM0AOopuaM0AOopuaM0ALmoLw/uP+BD+dTVBe/wDHuf8AeH86ALVW9V1m91aC2jvJmkS1j8uIE9B/kVSB9adDA93dwW0X35pFQfieaAPZLcPJ4p8NwIP9ZqsGforbv/Za+jD1/GvA/CirN8TvDlu6btsk0/02wuM/mRXvlMQVyfjT/kjfiD/sAXP/AKTtXWVyfjT/AJI54g/7ANz/AOk7VhL+PH0l+cS18D9V+p8I0UUVsSd/8cv+S1eIf+ukX/olK4Cu/wDjl/yWrxD/ANdIv/RKVwFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB+kVFGaM0AFFGaM0AFFGaM0AFUbvRNKvjuvdNtJ2/vSQqx/Mir2aM002thNJ7nM3Hw+8Oz5KWb27HvDO4x+GcfpWVc/C61I/wBC1W5iP/TeNZB+m2u7zRmto4irHaTMpUKUt4o8vufhnrEZP2W7s7hf9vdGT+GGH61k3Hg7xFagl9KkkUfxQyI+fwBz+lezZozXRHH1lvqc8sDRe2h4Hc21zZDN7aXNqPWeFkH6ioVdX+4wb6HNfQWaz7vQ9JvmLXmmWk7f3pIVJ/PGa3jmT+1Ewll6+zI8Por1i4+H3h6fJjtZbdj3hncY/Akj9Kyrn4X25H+harcRn/pvGsn8ttdEcwpPe6MJYGqtrM88orrrj4a6zET9murO4Uf3i0ZP4YI/Wsq48IeIbUEyaTK6j+KF0kz+AOf0rojiaMtpGEsNVjvExqdDJJbTia1lkgmHSSFyjfmKdc29xZf8ftrcWv8A13haP+YFRK6v91g30NbXjJdzK0ovsdPp3xA1yxwtw8V/GO0y7Xx7Mv8AUGur074k6RdYS/SawkPd13pn/eX+oFeXUVyVMFRn0t6HTTxlWHW571a3ltfQCayuIriI9HicMD+IqbNeAwSy2s/nWk0lvL/z0hco35iuk074ga5Y4W5aLUIx2mXY+PZl/qDXBUy+pH4Hc7qePg/iVj1rNGa5DTviPo93hb9ZtPkP/PRdyZ/3l/qBXUWt3bXsAms7iK4iPR4nDKfxFcM6c4O0lY7oVIT1i7k2aM0UVmWGaM0UZoAM1Wtf+Pm9/wCuw/8ARaVZzVW1/wCPm9/67D/0Wlc9X46fr/7ay47S9P1RaoozRmuggKKM0ZoAK4fx34ruNPmXStKkMU7JvnnHWNT0Vfc889h9eO4zXjfjQk+ONVz2eID/AL8x12YKnGpVtLocmMqSp0rxMKWNJ3L3A85z1eX5yfxNM+yW/wDzwi/74FS0V9DZHg3ZF9kt/wDnhF/3wKPslv8A88Iv++BUtFFkK7Ivslv/AM8Iv++BR9kt/wDnhF/3wKloosguyL7Jb/8APCL/AL4FH2S3/wCeEX/fAqWiiyC7Ivslv/zwi/74FH2S3/54Rf8AfAqWiiyC7Ivslv8A88Iv++BR9kt/+eEX/fAqWiiyC7Ivslv/AM8Iv++BV7TNSvdGuFm0u4a3YHJQHKP7MvQ/zqtRSlCMlZopSlF3TPbPD+tR69osN9Guxmyssec7HHBH+HsRWnmuK+F5/wCKfvx6X7Y/79R12ua+YrQUKjiuh9HSk501J9QzRmjNGayNQzRmjNGaADNGaM0ZoAM0UZozQAUUZozQAUUZozQAUUZozQAUUZozQAUUZozQAUUZozQAUUmaM0ALRSE0ZoAWikzRmgBaKTNGaAFopM0ZoAWim5pc0ALRmkooADXn2tia2+MMRHEF9omPq0M5/pOK9ANcH8Qg1j4k8J6sz7YEuZtPmx3EyBl/8ehUfjQBfaozUrdeaiamSRNUZqRqjNAETVGakaozQBE1edfELwtPJOdd0uIyOqbbqBRy6jow9x6V6Kajb2oA+ZtSkEqbo3LKO3p7YrFgPzSj/bP9K+i9a8A+HtbmMt1ZmKUnLSQNsLfXFYJ+DvhwOSsl6ATnHnUrDueL7qM+9e0/8Ki8ODnfe/8Af8/4UH4S+Gv+n3P/AF8H/CmB4vmkzXs5+FHhsdr3/wACD/hTD8KfDf8A0+f+BB/woA8bzRn3r2E/Cnw36Xn/AIEGmH4V+HM9Lv8A8CDQB5Dn3ozXrh+Fvhwfw3f/AIEGm/8ACrvDo/huv+/5pAeTZpM16yfhh4dH/LO5/wC/5pv/AArPw708q4/7/GgDyjPvRmvV/wDhWvh0f8sZz9ZjR/wrjw6P+XeX/v6aAPKM+9Ga9W/4V14eBz9mk/7+mj/hX3h7P/Ho3/fw0AeU5o3D1r1U+APDwP8Ax5n/AL7NL/wgnh4f8uI/76NAHlOaguz/AKN+I/nXrv8AwhHh8f8ALgn/AH0aD4L8P4502Ij3J/xoA8pDZYKgLueiqMk13vhDws9nImp6gP3xT93CVwY88ZPv/jXS2WiabpxJsrKGFj3C8/nVw4A78UAbfw1WO4+KZDJlrTS5HB9C0iD+QNe2Zryv4N6W0r6v4ilUYuJBZ23GP3cedx9wWJ/75r1OmgDNcp40/wCSOeIP+wDc/wDpO1dXXKeNP+SOeIP+wDc/+k7VhL+PH0l+cS18D9V+p8I0UUVsSd/8cv8AktXiH/rpF/6JSuArvvjj/wAlq8Q/9dIv/RKVwNABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB+kNFFFABRRRQAUUUUAFFFFABRRRQAUUZozQAUUZozQAUUmRRkUALSZFLmkz7UAGRWfd6DpF82680y0mb+88KlvzxmtDPtRTTa2E0nucxcfD3w9MD5VtLbMe8M7j9CSP0rKufhfAf+PLVriP/rvEsn8ttd5RW0cRWjtJmMsPSlvFHl1x8N9aiJNtcWdwo9WaNj+GCP1rKuPCXiG1BMukzOo7wssmfwBz+lezUldEcfWW+phLA0ntoeC3ME9n/wAftvPa/wDXeJo//QgKbbTvbzefY3DwS/8APSCQo35ivfOKz7rw/o96S13pdnKx/jaBd354zW6zG6tOJi8BbWMjznTviDrljhboxahGO0o2P/30ox+YNdVp3xG0e7wl6JrCQ8fvV3Jn/eXP64qW4+Hvh6YHyrea2J7wzt/Ikj9Kyrn4Xwn/AI8tXmT/AK7wrJ/6DtrKUsJU6OJpGOKp9VI7e2ure9gE1nPHPE3R4nDKfxFTV5efh74g0+cz6XfW4f8AvwzPC5/IEH8TWhb6t470gY1DSf7SiXuNm8/QoT+q5rCVCP2Jp/gbxrS+3Fr8T0Cq1r/x83v/AF2H/otK5dfG8t7NbWNtp9zp1/NIVZdQtW2KoRmJGCueQB1HXOK1tEu7uTUr+2vnhkdVin3wxmMfNuXGCzdPKznPevMrSiq8KTfvLW3lZo7IO8HJbf8ADG3RSZozXSQLRSZozQAteN+Mv+R41b/rpH/6Jjr2OvHPGX/I8at/10j/APRMdehl/wDGfocGP/hL1MWiilBwQSAfY96948Q0vsEH/CK/2id/n/bDAPm+XbsDdMdfxq1pWiKNYsY9RVJoLu2e4VUkIJARyM45Byv6VoW9zYnwgrvZQx2/9osCkjSOB+668HJPp0FXbV7ZNZ0RIYnlc6W+yWQ4wu2X+AZ5+pIweneuGVWVmvX8jsjTjdP0/M4co/liTYQhJAbHGfTP4irWnWsd7cGBvOaVh+7SFVJYjkjkj8Mda07u8nuvBEJmkyP7QcBVAVQBGuAFGAOp/M1mWsKL5dwupW9vKrblVlk3KQeDwhH610qTcX3OdxSki7Y6XYX32zbPdRm0t2nYNEvIUgEfe680+107T20u51CSO9lt4yIg42Jtc9DjJzj09617eeHVNS12+F1aIZ9OcMkYkwvKAscoPTtzz0rJc2d0LSzn1WCDT7f+CKOVmJP3m5QAkn8h9OcFOT0d+hu4xXYxI43lkWONSzuQqqBkknoK2NY0qOGaVNMhklSwjRLyYNuXzD1I9BkEfhTdGnjsNdP2a3/tJzmO2Kkodx4DAeuPy/DNaN3MY7aTT9Oa1tra2O68kZGkjklPHG4MSF6D3ya0nOXOrf1/XQzhCPI7kU+m6Uq6OlzvtBeWoZ7hGyFcsQGYHtxzjFYV5ayWN7LbTKyvGxU7lK59Dg+o5rqtQmnfTdEa31SVWljeIfY1YeYwc9B8vqBzisDXsDUijTX0ssahJftwG8MOuME8dx9e/Wpoybdn5/mVVikrry/IzaKKK6jmPSfhf/yAL/8A6/z/AOioq7WuK+GH/IAv/wDr/P8A6KirtM18zif40vU+jw/8GPoLRSZozXObi0UmaM0ALRSZozQAtFJmjNAC0UmaM0ALRSZozQAtFJmjNAC0UmaM0ALRSZozQAtFJmjNAC0maDRQAZozRRQAZozRRQAZFGRRn2oz7UAGRQTRn2oz7UAGaM0UUAGaM0UUAFcx8RtPm1H4f6qtpxdW8Qu7cgZPmQsJVA+pTH4109IwBUhgCDwQe9AjitOvYtS0y2vrdt0VzEsqN6hgCP51K1c/4KBstMvNDcuW0W9msQXGMxq26I/Ty2SugamIiao2qQ1G1AETVG1SNUbUARGmGnmmGgCJqYae1MNADGqM1I1RmgZG1MNSNUZoAYajPWpD1qNqAGGmGnmmGgBjVGakamGkAw0004000ANNMNPNMNMBppppxppoAYaaacaaaQDTVHV52ttIupk4ZImI/KrxrM8QceH77/ri38qAPfvCul2+i+FNM0+zH7mC2QA4xuJGSfqSSfxrYPSqeksG0WyI6eQn/oIq3mqATNcr40P/ABZ3xB/2Abn/ANJ2rq81ynjT/kjviD/sA3P/AKTtXPL+PH0l+cS18D9V+p8JUUUVsSd98cf+S1eIf+ukX/olK4Gu++OP/JavEP8A10i/9EpXA0AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAH6Q5ozSUUALmjNJRQAuaKSjNAC5ozSUmaAHZozTc0tABRRSZoAWikzRmgBeaOaTNGaACjNFFABmjNFFABmlpKKACiiimAUUUUgCiiigAo5opKAK1/p9vqUKR3aswR96FJGjZWwRkMpBHBI696qaTpdpY3d68COZN6x+ZLK8jbQinbuYk4yxOPetTNVrX/j4vP+uw/wDRaVz1VapBrv8Aoy4/DL+uqLVFJmjNdJmLRSZozQAteOeMv+R41b/rpH/6Jjr2LNeO+Mv+R31b/rpH/wCiY69DL/4r9Dgx/wDCXqYtKq7nClguTjJ6Ckor3TxTpbptM03QBpNzdfbpxdG4YWbYQfKFxvI/HgH04q6v2yK60XU7DTLi8hj08x4gRmAYmRcZAPTcK42poru5gUrBcSxqeSEcgfpXO6Om/wDTN1W12/pHSfYtY1DRbiC/037JDZQtOkjW/kB33LknoCdoI/nXK1NLeXU6bJrmaRf7ruSKhq6cXG9yJyUrWNzw0Mx61j/oGS/+hJWHT45pYQ4ikdBIux9rEbl9D6jgcUyqUbSb7kuV4pdjW8OPdQ6k01jf2tjLHE37y6bCkHjHQ5PI4qe6hk1WRsalc6nMgyWEZWGPPq7kbR/wECsKl3Hbtyduc4zxmpdO8uZblKfu8r2O40mWKHSv7L068trnWoN72sm35E3Y3IjHgtgZzjHNcxrOnzaebQXiSLdTwmabzCd2S7AZz3woP41mgkHIOCKs3eoXd+I/ttxJOYl2oZG3ED0z1qI0nCV099y5VVKNmtitRRRXQYHpHww/5AN//wBf5/8ARUVdrXFfDD/kA3//AF/n/wBFRV2tfM4n+NL1Po8P/Bj6BRRRXObhRRRQAUUUUAFFFFABk0ZNFFABk0ZNFFABk0ZNFFABk0ZNJRQAuTRk0lGaYC5NGTSZozQAuTRSZozQIWikzRmgYtFJmjNAC0UmaM0CFopM0ZoAWikzRmgBaKTNGaAFpCMijNBP40AedX0J0r4sXigP5OtWEdyCT8vmwny3A99rRVqtVb4kwfZ/7B11Y2dtP1BYpSGxiKceW2fbeYz+FWCcjNAiM1G1Mvr21060kur+4jt4I/vyysFVecck1inxv4XPTX9PP0uF/wAaANhqY3SsZvG3hn/oO2H/AH/Wo28a+Gf+g7Y/9/1oA12phrGPjbwxnH9vWGfTz1pp8ZeG/wDoN2X/AH+FAGs1MNZJ8YeHc/8AIZs/+/oqW28RaPf3C29nqVtNM/3USQEmgZeNMbpTyaYTQBE1MNY1z418O21zJbzatbLLGSrrv6EdR+FasM0d1bxz27iSKRA6OvRgehoAU1G1SGmN0oAjNMPSkuZ4rW1luLhgkUSF3Y9FAGSawrPxnoeoXcNva3m6Sc7U+QgMcZxnHtQBtmmGnk5zVe7uYrO0luZ22xQoXc+gAyaQDiaaawx4y0hxlDdMMZ4tZOfQ9KU+LNNPSO9/8A5P8KANk0w1jDxbpzYKx3pB9LOT/ChvFFjjPkX+P+vKX/CmBrmmmsf/AISixIyIL7H/AF5y/wCFWrXUzf7vsWmapPt+95dhK2P/AB2gC2aaaztV16DQ/KOr2eo2PnZMZuLGRN+OuMijTdesNXcrZyNu2hwskZQsvqMjkUAXzWZ4g/5F6+/64N/KtM1meIf+Rdv/APrg38qQH0PohB8P2BHQ20f/AKCKvVneHyD4a0wj/n0i/wDQBWjVAFcp40/5I74g/wCwDc/+k7V1dcp40/5I74g/7ANz/wCk7Vzy/jx9JfnEtfA/VfqfCVFFFbEnffHH/ktXiH/rpF/6JSuBrvvjj/yWrxD/ANdIv/RKVwNABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB+j+aM0UUALRSUUCFopKKAFpKOKMCmAUUUUAGaKKKACiiigYUUUmaAFopM0ZoELSUZo4oAKKpatez6dpNzd2tnJfSwpuS3i+9IfQcGuK/4WJ4i/6J9q3/fTf/EVlOrCDtL8md+GwGIxUXKklZd5RX5tHoWaM157/wALE8Rf9E+1b/vpv/iKP+FieIv+ifat/wB9N/8AEVH1ml3f3P8AyOn+xcb2j/4HD/5I9CzRmvPf+FieIv8Aon2rf99N/wDEUf8ACxPEX/RPtW/76b/4il9Zpd39z/yH/YuN7R/8Dh/8kehZozXnv/CxPEX/AET7Vv8Avpv/AIij/hYniL/on2rf99N/8RR9Zpd39z/yF/YuN/lj/wCBw/8Akj0LNFee/wDCxPEX/RPtW/76b/4ij/hYniL/AKJ9q3/fTf8AxFH1ml3f3P8AyD+xcb2j/wCBw/8Akj0Gq9r/AMfF5/12H/otK4b/AIWJ4i/6J9q3/fTf/EVWbxz4j86SSPwPrcXmMGZVIIzgDvEewFYVsRC8JRTdn28mutu5cMlxmqaj/wCBw7/4j0qivNf+E78T/wDQma7/AOO//GaP+E78T/8AQma7/wCO/wDxmj69H+SX3L/MP7Dxn93/AMDj/melUV5r/wAJ34n/AOhM13/x3/4zR/wnfif/AKEzXf8Ax3/4zR9ej/JL7l/mH9h4z+7/AOBx/wAz0qvJvHllLaeL7ieRT5d4qSRtjg7VVGH1G0H8RV//AITvxP8A9CZrv/jv/wAZqnqfiTWdZthBqXgTXJ41bcuWClT6giIEV0YfNI0anN7OX3L/ADMMRw7jKsOW8f8AwOP+ZzVFLMniBpSYPBl8idle3lYj8Qw/lTBH4lzz4Pu8f9esv/xdet/btD+SX3L/ADPKfCuYr+T/AMDj/mOoqc/a7eAS6joM9gpON1xDKq59NxOKPtEf/PpD+b//ABVejDFyqR5oU216x/8AkjwauGdGbhUkk16/5EFFTpKJpRDb6eJ5iMiKFZHc/QA5qKaLxCJCIPB97tHdraU5/wDHhWNfMY4dXqU5L/wF/lI6sHlVfGy5aDT9XZfe0kNopvleJv8AoT7v/wABJf8A4ujyvE3/AEJ93/4CS/8Axdcn9u0P5Jfcv8z1f9Vcx/uf+Bx/zHUU3yvE3/Qn3f8A4CS//F0eV4m/6E+7/wDASX/4uj+3aH8kvuX+Yf6q5j/c/wDA4/5jqKb5Xib/AKE+7/8AASX/AOLo8rxN/wBCfd/+Akv/AMXR/btD+SX3L/MP9Vcx/uf+Bx/zHUU3yvE3/Qn3f/gJL/8AF1bsxqiHOo+BNUuMEFRCrxj8QwbI9qTz6hbSnL7l/mC4UzG+vJ/4HH/M9I+HNnLa+F2mmUqLu4adAf7u1VB/Hbn6GurzXmi+OfEyqFXwXroAGABt4/8AINL/AMJ34n/6EzXf/Hf/AIzXi1MxU5uThLXyX+Z7MMgxcIqK5dP78f8AM9KzRmvNf+E78T/9CZrv/jv/AMZo/wCE78T/APQma7/47/8AGaj69H+SX3L/ADL/ALDxn93/AMDj/melZozXmv8Awnfif/oTNd/8d/8AjNH/AAnfif8A6EzXf/Hf/jNH16P8kvuX+Yf2HjP7v/gcf8z0rNGa81/4TvxP/wBCZrv/AI7/APGaP+E78T/9CZrv/jv/AMZo+vR/kl9y/wAw/sPGf3f/AAOP+Z6VmjNea/8ACd+J/wDoTNd/8d/+M0f8J34n/wChM13/AMd/+M0fXo/yS+5f5h/YeM/u/wDgcf8AM9KzRmvNf+E78T/9CZrv/jv/AMZo/wCE78T/APQma7/47/8AGaPr0f5Jfcv8w/sPGf3f/A4/5npWaM15r/wnfif/AKEzXf8Ax3/4zR/wnfif/oTNd/8AHf8A4zR9ej/JL7l/mH9h4z+7/wCBx/zPSs0ZrzX/AITvxP8A9CZrv/jv/wAZo/4TvxP/ANCZrv8A47/8Zo+vR/kl9y/zD+w8Z/d/8Dj/AJnpJo5rzb/hO/E//Qma7/47/wDGaP8AhO/E/wD0Jmu/+O//ABmj69H+SX3L/MP7Dxn93/wOP+Z6TRXm3/Cd+J/+hM13/wAd/wDjNH/Cd+J/+hM13/x3/wCM0fXo/wAkvuX+Yf2HjP7v/gcf8z0miuS8L67rGvXM8epaTqmjrEgZXuAhEhJ6DMYrpfss3/P9cf8AfMf/AMTW0MRKauqb/D/M86vhpYeo6dRq67O/4q6LFFV/ss3/AD/XH/fMf/xNH2Wb/n+uP++Y/wD4mq9rP/n2/wDyX/5I5+VfzL8f8ixRVf7LN/z/AFx/3zH/APE0fZZv+f64/wC+Y/8A4mj2s/8An2//ACX/AOSHyr+Zfj/kWKKr/ZZv+f64/wC+Y/8A4mj7LN/z/XH/AHzH/wDE0e1n/wA+3/5L/wDJByr+Zfj/AJFiiq/2Wb/n+uP++Y//AImj7LN/z/XH/fMf/wATR7Wf/Pt/+S//ACQuVfzL8f8AIsUVX+zS/wDP9cf98x//ABNJ9ml/5/rj/vmP/wCJo9rP/n2//Jf/AJIOVfzL8f8AIs0VW+zS/wDP9cf98x//ABNH2aX/AJ/rj/vmP/4mj2s/+fb/APJf/kg5V/Mvx/yLNFVjbS/8/wBcf98x/wDxNJ9ml/5/rj/vmP8A+Jo9rP8A59v/AMl/+SDlX8y/H/ItUZqr9mm/5/rj/vmP/wCJpfssv/P9cf8AfMf/AMTR7Wf/AD7f/kv/AMkHKv5l+P8Akcr8WXCfDPUXLbdstsd3pi5j5qoNX07y1JvrcDA6yj0rq9S0WHVtNmsNTke7tZ12yQyxxsrD6bfx/DisK1+F/hG14i0SxwOf3lnA/wD6Eho9rP8A59v/AMl/+SDkX8y/H/I83+IlzL4kbSvD/h+A6vLPOZ5orZgxVEGBuOcBSW6njiq3hjw7q3g/xFPN4j8HXE8V1aII0sLX7WIyHbO4qCobGOhPGK9m0zwxpujM7aRBDYGQAObW1hiLY6Z2oM4zWj9ml/5/rj/vmP8A+Jo9rP8A59v/AMl/+SHyr+Zfj/kedJrWmAg/8IRrKH1/sJ//AIirCa1pWAT4T1hD/wBgCbj8o6737NL/AM/1x/3zH/8AE0fZpf8An+uP++Y//iaXtZ/8+3/5L/8AJByr+Zfj/kfOF9o/iCKfVUTwtrM0jzyvDKli+FU/dIYj+XSvTNO8TaZa6RZxXuk6sJ0gRZC2jXBO4KM87Oea9DNtL/z/AFx/3zH/APE0fZpcY+3T/lH/APE0e1n/AM+3/wCS/wDyQcq/mX4/5HAt480CP71rqa4PfSJx/wCyVzvjfxjpus+HvK0r7Wby2njuUWexlQMEYEgFlHOO3evX/ssuP+P6f/vmP/4mj7NL/wA/lx+Uf/xNP2s/+fb/APJf/khcq/mX4/5Hi/8AwmOlkAhNQPuLCbn/AMdpP+Et09gStvqRHcjTpv8A4mvafs0uf+P2f/vlP/iKBbSj/l9uPyj/APiaPaz/AOfb/wDJf/kg5V/Mvx/yPm/wl8Ptc8S6pqlxLZT6fpcwvT9qnjKlhNE6LtQ4Lfez2xWxoOrLb+HdOtn07VjJBbRRuF02dsMEAPIX2r3c2sp/5frgD2Cf/E0v2aX/AJ/Z/T7seP8A0Gj2s/8An2//ACX/AOSDlX8y/H/I8YGqmTOzStZb6aVcf/E0ovppDhNF1xj6DSbj/wCIr2b7NKB/x+z8+ix//E0n2aXP/H7Pn6R//E0e1n/z7f8A5L/8kHKv5l+P+R4ZrseoX/h7UbO20DXGmuLWWOMHSrgZZkIHJXA5NZF/4M8U+H4dKsG8O3dxbWuoGaO4sF89fLw/VV+dT8+OR2619F/Zpf8An9n/AO+Y/wD4mj7NL/z/AE//AHzH/wDE0e1n/wA+3/5L/wDJByr+Zfj/AJHiTTX/AFHh3Xz7f2VP/wDE1k+IYNY1LQLqztfDWveZOoQZ0yYcZGe3pmvoL7PL/wA/0/8A3zH/APE0fZ5f+f6f/vmP/wCJo9pP/n2//Jf/AJIOVfzL8f8AI8S0nwlq3i7WI45dO1DRbe3syhur21KASeZG64UlSw/dnODx+VbeoeE/HMFjNB9m0vVlm3Rh7eYwOqkYyUcY7/3q9R+zy/8AP7P/AN8x/wDxNL9ml/5/Z/8AvmP/AOJo9pP/AJ9v/wAl/wDkg5V/Mvx/yPFtH8M+MtM0K0s/+EVnlkhjCMxvLcKcemZM0+88O+PLyyntl8KpH50bJuk1GLjIx2Jr2b7NL/z+z/8AfMf/AMTR9ml/5/Z/++Y//iaPaT/59v8A8l/+SHyr+Zfj/keJ2/gjx5b28cCaJZssaBQz36gnA9ADXVfDnwbr+i+JtQ1bX4bS2FxbrCkUE/mHIOSSdoFehfZpf+f2f/vmP/4mk+zS/wDP7P8A98p/8TT9rP8A59v/AMl/+SFyr+Zfj/kch8S/hxB8QNLhRbs2d/akmCbbuU5GCrD09xzXn8PwU8TJptlaG50mN7L/AFV3HPJ5g/4D5eCD6bsV7f8AZpf+f2f/AL5T/wCJpDbS4/4/Z/8AvlP/AImj2s/+fb/8l/8Akg5V/Mvx/wAj55a7vLSeSz1TS7+O9gYxypDaSSLkdwyggg9RVTVZbi+0q5tbbS9VeaaMoi/2fMMk9P4a+kfs0o/5fZ/++U/+Jpfs8ve9n/75j/8AiaXtJ/8APt/+S/8AyQcq/mX4/wCRW0CJ4fDmnRyoySJaxKyMMFSEGQa0ar/Z5c5+2z/kn/xNH2aX/n9n/wC+U/8AiaftZ/8APt/+S/8AyQcq/mX4/wCRYrlPGn/JHfEH/YBuf/Sdq6P7NL/z+z/98p/8TWD4+iWD4UeJokJKpol0oJ64EDClHnnVUnFpJPe3W3ZvsN2UbXufBtFFFbkHffHH/ktXiH/rpF/6JSuBr6j8dfs9XHjPxvqPiBfEcVmL11YQG0L7NqKv3t4z93PTvXP/APDKdz/0NsX/AIAH/wCOUAfPlFfQf/DKdz/0NsX/AIAH/wCOUf8ADKdz/wBDbF/4AH/45QB8+UV9B/8ADKdz/wBDbF/4AH/45R/wync/9DbF/wCAB/8AjlAHz5RX0H/wync/9DbF/wCAB/8AjlH/AAync/8AQ2xf+AB/+OUAfPlFfQf/AAync/8AQ2xf+AB/+OUf8Mp3P/Q2xf8AgAf/AI5QB8+UV9B/8Mp3P/Q2xf8AgAf/AI5R/wAMp3P/AENsX/gAf/jlAHz5RX0H/wAMp3P/AENsX/gAf/jlH/DKdz/0NsX/AIAH/wCOUAfPlFfQf/DKdz/0NsX/AIAH/wCOUf8ADKdz/wBDbF/4AH/45QB8+UV9B/8ADKdz/wBDbF/4AH/45R/wync/9DbF/wCAB/8AjlAHz5RX0H/wync/9DbF/wCAB/8AjlH/AAync/8AQ2xf+AB/+OUAfPlFfQf/AAync/8AQ2xf+AB/+OUf8Mp3P/Q2xf8AgAf/AI5QB8+UV9B/8Mp3P/Q2xf8AgAf/AI5R/wAMp3P/AENsX/gAf/jlAHz5RX0H/wAMp3P/AENsX/gAf/jlH/DKdz/0NsX/AIAH/wCOUAfPlFfQf/DKdz/0NsX/AIAH/wCOUf8ADKdz/wBDbF/4AH/45QB9OUVS+03X/PCL/v8AH/4mj7Tdf88Iv+/x/wDiaALtFUvtN1/zwi/7/H/4mj7Tdf8APCL/AL/H/wCJoEXaKpfabr/nhF/3+P8A8TR9puv+eEX/AH+P/wATQBdoql9puv8AnhF/3+P/AMTR9puv+eEX/f4//E0wLtFUvtN1/wA8Iv8Av8f/AImj7Tdf88Iv+/x/+JoAu0VS+03X/PCL/v8AH/4ml+1XP/PvF/3+P/xNAFvNGap/abn/AJ94v+/x/wDiaPtNz/z7xf8Af4//ABNAy5mkqp9puf8An3i/7/H/AOJo+03P/PvF/wB/j/8AE0AW6Kqfabn/AJ94v+/x/wDiaPtNz/z7xf8Af4//ABNAi3RVT7Tc/wDPvF/3+P8A8TR9ouf+eEX/AH+P/wATQMt5ozVT7Rc/88Iv+/x/+Jo+0XP/ADwi/wC/x/8AiaBFvNJVX7Rc/wDPCL/v8f8A4mj7Rc/88Iv+/wAf/iaALVFVftFz/wA8Iv8Av8f/AImj7Rc/88Iv+/x/+JoGWqKq/aLn/nhF/wB/j/8AE0faLn/nhF/3+P8A8TQItUVV+0XP/PCL/v8AH/4mj7Rc/wDPCL/v8f8A4mgC1RVX7Rc/88Iv+/x/+Jo+0XP/ADwi/wC/x/8AiaALVFVftFz/AM8Iv+/x/wDiaPtFz/zwi/7/AB/+JoAtUVV+0XP/ADwi/wC/x/8AiaPtFz/zwi/7/H/4mgC1RVX7Rc/88Iv+/wAf/iaPtFz/AM8Iv+/x/wDiaALVFVftFz/zwi/7/H/4mj7Rc/8APCL/AL/H/wCJoAsuiyIySKGVhgqwyCK5a++Hmi3d2s0HnWa5y8VuwCN9AQdv4YroPtFz/wA8Iv8Av8f/AImj7Rc/88Iv+/x/+Jq4VJQd4uxEoRmrSVxmm6RYaPB5Om2scCn7xUZZvdmPJ/GrtVftFz/zwi/7/H/4mj7Rc/8APCL/AL/H/wCJqW7u7KStoi1RVX7Rc/8APCL/AL/H/wCJo+0XP/PCL/v8f/iaQy1RVX7Rc/8APCL/AL/H/wCJo+0XP/PCL/v8f/iaALVFVftFz/zwi/7/AB/+Jo+0XP8Azwi/7/H/AOJoAtUVV+0XP/PCL/v8f/iaPtFz/wA8Iv8Av8f/AImgC1RVX7Rc/wDPCL/v8f8A4mj7Rc/88Iv+/wAf/iaALVFVftFz/wA8Iv8Av8f/AImj7Rc/88Iv+/x/+JoAtUVV+0XP/PCL/v8AH/4mj7Rc/wDPCL/v8f8A4mgC1RVX7Rc/88Iv+/x/+Jo+0XP/ADwi/wC/x/8AiaALVFVftFz/AM8Iv+/x/wDiaPtFz/zwi/7/AB/+JoAtUVV+0XP/ADwi/wC/x/8AiaPtFz/zwi/7/H/4mgC1RVX7Rc/88Iv+/wAf/iaPtFz/AM8Iv+/x/wDiaALVFVftFz/zwi/7/H/4mj7Rc/8APCL/AL/H/wCJoGWqKq/aLn/nhF/3+P8A8TR9ouf+eEX/AH+P/wATQBaoqr9ouf8AnhF/3+P/AMTR9ouf+eEX/f4//E0AWqKq/aLn/nhF/wB/j/8AE0faLn/nhF/3+P8A8TQItUVV+0XP/PCL/v8AH/4mj7Rc/wDPCL/v8f8A4mgC1RVX7Rc/88Iv+/x/+Jo+0XP/ADwi/wC/x/8AiaALVFVftFz/AM8Iv+/x/wDiaPtFz/zwi/7/AB/+JoAtUVV+0XP/ADwi/wC/x/8AiaPtFz/zwi/7/H/4mgC1RVX7Rc/88Iv+/wAf/iaPtFz/AM8Iv+/x/wDiaALVFVftFz/zwi/7/H/4mj7Rc/8APCL/AL/H/wCJoAtUVV+0XP8Azwi/7/H/AOJo+0XP/PCL/v8AH/4mgC1RVX7Rc/8APCL/AL/H/wCJo+0XP/PCL/v8f/iaALXNJg1W+0XP/PCL/v8AH/4mj7Rc/wDPCL/v8f8A4mgCzzRVX7Rc/wDPCL/v8f8A4mjz7n/nhF/3+P8A8TQBaoqr59z/AM8Iv+/x/wDiaPPuf+eEX/f4/wDxNAFqiqvn3P8Azwi/7/H/AOJo8+5/54Rf9/j/APE0AWqKq+fc/wDPCL/v8f8A4mjz7n/nhF/3+P8A8TQBaoqr59z/AM8Iv+/x/wDiaPPuf+eEX/f4/wDxNAFo0lVvPuf+eEX/AH+P/wATSefc/wDPCL/v8f8A4mgC1RVXz7n/AJ4Rf9/j/wDE0efc/wDPCL/v8f8A4mgC1RVXz7n/AJ4Rf9/j/wDE0efc/wDPCL/v8f8A4mi4FnFGKrefc/8APCL/AL/H/wCJo8+5/wCeEX/f4/8AxNFwLNFVvOuv+eEX/f4//E0eddf88Iv+/wAf/iadwLNFVvOuf+eEX/f0/wDxNHnXP/PCL/v6f/iaLgWaKredc/8APCL/AL+n/wCJo865/wCeEX/f0/8AxNFwLNJVfzrn/nhF/wB/T/8AE0edc/8APCL/AL+n/wCJouBYoqv51z/zwi/7+n/4mjzrn/nhF/39P/xNFwLFFV/Ouf8AnhF/39P/AMTR51z/AM8Iv+/p/wDiaLgWK5z4if8AJL/FP/YGu/8A0S9bfnXP/PCL/v6f/iazfEWn3Ov+F9V0f91b/wBoWc1r528t5fmIV3YwM4znGRRcD4Bor6D/AOGU7n/obYv/AAAP/wAcoqRn/9k=
sankyowuhan 发表于 2020-10-13 21:17:31
这个还得考虑弯曲扭矩吧
武铠蓝夜枫 发表于 2020-10-13 13:04:17
请求各位师傅看下并指导下,万分感谢!
落春城 发表于 2020-10-13 14:18:10
你这个需求是旋转位置要准确,要匹配下惯量以防过冲,此外假设旋转之后还需要用自动销来定位,看你直径这么大,如果用的是步进电机可能有必要查一下细分度。
抛砖引玉啦,各位兄弟觉得有问题一定要告诉我,其实我很少用到伺服和惯量匹配,不太懂
武铠蓝夜枫 发表于 2020-10-13 14:57:11
|落春城发表于 10-13 14:18你这个需求是旋转位置要准确,要匹配下惯量以防过冲,此外假设旋转之后还需要用自动销来定位,看你直径这么大,如果用的是步进电机可能有必要查一下细分度。<br>
<br>
抛砖引玉啦,各位兄弟觉得有问题一定要告诉我,其实我很少用到伺服和惯量匹配,不太懂你好!这里的话用的是伺服电机
远祥 发表于 2020-10-14 13:15:08
楼主可以参考比计算选型公式,如图http://appi.cmiw.cn/upload/2020-10-14/20201014131506_456206562.jpg
LHCA2020 发表于 2020-10-14 14:08:11
加我q,我给你发个计算的资料3261132838
LHCA2020 发表于 2020-10-14 14:16:05
你在论坛里搜“松下伺服电机选型经典计算实例讲解”,可以下载,里面讲的很全
武铠蓝夜枫 发表于 2020-10-14 14:27:34
|LHCA2020发表于 10-14 14:16你在论坛里搜“<strong><font color="purple">松下<font color="#ff0000">伺服电机</font>选型经典计算实例讲解</font></strong>”,可以下载,里面讲的很全<br>
威望不够,能麻烦您发一份给我么?879155466@qq.com,谢谢了!
OK
查看完整版本: 关于一个水平旋转机构的扭矩计算、电机及减速机选型,求解
