參考
- j* G9 b; s7 `5 z6 G) \. }/ _# v
4 P$ U9 O# |8 e% x7 k6 @" l% b+ e3 S1 @$ J" G7 y
7 m+ n8 X `& A" ]; d
6 z2 m" r- d. Z4 T0 r. H3 o* K" S9 W
2 ?% ]' m- I# G# H. K1 @5 _' B" |$ O4 r6 a; O Z, v
- '~~~~~~~~~~~~~~~~ 2019/07/04 ~~~~~~~~~~~~~~~~
s0 H5 e- c8 r6 g1 B- f1 Q% }8 | - ' 操作:' ]( V9 _- x% |2 V. ^
- ' 1. 開 EXCEL文件.
: h4 x5 H5 h2 v& F2 ^# w4 }& `! ] - ' 2. 開 SW零件./ e, B P4 h; e+ e; F- ~
- ' 3. 執行 ReadSwDimensionInSldPrt().$ n% l: R3 q% d8 u- B: R9 e
- ' 4. 在EXCEL修改尺寸.
8 r8 I5 A0 X8 p' b+ P: D) I) e* @ - '# a+ z# M3 g' x# f& W
- ' 功能:
( C- E( r ^2 x; _+ Q - ' 1. 讀取SW零件的全部尺寸,寫到 Excel.
) _+ `8 e9 Q9 f% N. z' Q0 I9 v - ' 2. 在Excel變動尺寸后,修改SW的零件尺寸.
5 ]( n8 g% g& h; j - '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~# j4 ~- W# O% B
- Function SetSwPart()
8 [ S- {0 Q3 I9 Z3 | - Dim SwApp As Object
6 {1 z' j! ]7 W7 d) M7 D9 ` ~, W - Dim SelMgr As Object, boolStatus As Boolean) \9 F0 V8 z8 t# [/ P/ H* T3 i
- Dim longstatus As Long, longwarnings As Long
# T% D, ^" t1 c6 n' F6 ]$ B - Set SwApp = GetObject(, "sldworks.application")9 i. |' k6 u& ^% {+ ~8 ?0 u! h+ r
- Set SetSwPart = SwApp.ActiveDoc
9 t% W4 G* a# w% J - End Function* O# `- u# ?% w
- '****************************5 Y8 b/ y- o1 [, B9 {
- Private Sub ReadSwDimensionInSldPrt()7 z: n& `( h! H
- '讀取SW的全部尺寸
- {# C- r. F6 M4 z% c$ z' ?$ _ - Dim oDic
; w2 {* o$ [6 Z7 }% D) R3 u) ^ - Set oDic = CreateObject("Scripting.Dictionary")( [- M' t2 c k; B. i. G
- '*** Get active sheet in Excel5 I3 o6 ]6 {/ I. E
- Set xl = GetObject(, "Excel.Application")0 s9 }0 n6 _8 d) d. s# s1 v
- Set xls = xl.ActiveSheet5 ~6 U2 W$ @ P, E3 I$ E; s. a
- With xls
$ j6 G3 S7 t, `4 ~1 O - Dim swFeat As Object, swSubFeat As Object
: o! y( w* g$ o! y3 `8 m - Dim swDispDim As Object, SwDim As Object# I! O' t) O3 ~$ H3 [) r
- Dim swAnn As Object# g7 ^/ o+ o0 O$ }
- Dim bRet As Boolean) o8 `* a2 F; r
- Dim Str- f8 E+ ? `% N( u6 Y
- Set SwApp = CreateObject("SldWorks.Application")# e- e: L/ f5 [& O6 t! n
- Set SwPart = SetSwPart0 c: u7 b" Z# W4 v8 L8 p
- Set swFeat = SwPart.FirstFeature' j/ d9 \' q- u# h# @
- kk = 1
: ^# Y' j; D$ v2 H5 x( n - Do While Not swFeat Is Nothing
% V3 Q2 E4 h: {/ I - Debug.Print " " + swFeat.Name! e: R- q! ]7 S
- Set swSubFeat = swFeat.GetFirstSubFeature, ]: c+ o/ U6 @/ e
- Set swDispDim = swFeat.GetFirstDisplayDimension; f6 \& g# Z1 i; p
- Do While Not swDispDim Is Nothing
$ c `$ A4 J M6 {$ Y - Set swAnn = swDispDim.GetAnnotation
, k) H: R5 S, X( L - Set SwDim = swDispDim.GetDimension% j$ }' G0 A* \+ s) G a
- 'Debug.Print " [" & SwDim.FullName & "] = " & SwDim.GetSystemValue2(""): \5 }- l) `/ Y% Y" u
- Debug.Print SwDim.FullName, SwDim.GetSystemValue2("")
! u2 N) P$ C+ l) ?% }. y - Str = SwDim.FullName: n5 Q; ~, V& d/ A c# @' W
- oArr = Split(Str, "@")
2 J* k3 Y# r3 C. k5 [6 o - Str = oArr(0) & "@" & oArr(1)
% X. w3 T) x7 `) o; e" i2 q - oDic(Str) = SwDim.GetSystemValue2("")
/ w+ I# G" B" ?! l. A! M - Set swDispDim = swFeat.GetNextDisplayDimension(swDispDim)
G# q. }6 O; |! } - kk = kk + 1( l& l* _+ d3 B9 }) B) F5 \
- Loop: z$ b/ G& P8 E6 P S: Q
- Set swFeat = swFeat.GetNextFeature! _# h( W4 Z+ J/ F# S$ z# L
- Loop6 B+ A' u$ W, U) w0 Q; x
- Dim oArr1, oArr24 R2 p$ [0 b6 R2 ?
- oArr1 = oDic.keys: oArr2 = oDic.Items
- L: K: w5 A5 t: b - .cells(1, 1) = "Serial number": .cells(1, 2) = "Array staging": .cells(1, 3) = "Dimension name"
$ a6 r) H/ m# V2 C1 U4 Y - .cells(1, 4) = "Feature name": .cells(1, 5) = "Dimension value":
* N7 i" m' `' y4 G1 D3 H -
2 ^! Y( e0 u" e) ~9 G - For kk = 2 To UBound(oArr1) + 2
* C4 U7 `1 b0 D3 t - .cells(kk, 1) = kk - 27 w% f5 r8 s5 o. @# d( E- t
- .cells(kk, 2) = "=" & """Arr(""" & " & " & .cells(kk, 1) & " & " & """)="""8 r) A6 q% ?* P6 Z: }
- .cells(kk, 3) = "'" & Chr(34) & oArr1(kk - 2) & Chr(34)
) x/ X/ a1 ^; }* ]0 P' ^8 U- T - .cells(kk, 4) = Split(oArr1(kk - 2), "@")(1). G% c# ]8 c8 D
- .cells(kk, 5) = oArr2(kk - 2)5 b% E! I9 U \% C/ b8 j: c9 j
- Next kk$ _- \, s, k1 Q+ W. g9 ~
- nn = .range("C65536").End(3).Row 'End(3)==>End(xlUp)/ H/ m8 [. S7 ?- @
- Stop '暫停修改Excel之尺寸後,再按RUN執行鍵; D1 W0 P( Q# ^
- Set Part = SwApp.ActiveDoc
) E/ Q" x4 H# K1 Y% } - '依據Excel變動值修改到sw零件; g" }: q/ [: K8 Y; m- E
- For mm = 2 To nn! l: [5 g- u% P6 ~0 P7 Q5 p
- Size_name = Mid(.cells(mm, 3), 2, Len(.cells(mm, 3)) - 2) g, o7 b1 S, h
- Part.Parameter(Size_name).SystemValue = .cells(mm, 5)
& C$ J' j- s9 Y2 q+ M - Next mm
' I5 D* g5 ~& U- U$ s. ^ - End With
& R& t+ j6 E" d/ e4 n% T - boolStatus = Part.EditRebuild3()# Y. K. w+ C7 X# F# i
- MsgBox "Part size modification ends" '零件尺寸修改結束
6 {% j) O" m+ n1 U - End Sub
6 N: i7 l7 C/ T# P8 J( D& C
复制代码 " Y( x" f `1 x5 o+ r
- V$ B" A: s4 l0 f+ @% }+ X8 M
# H2 a9 A! L1 W3 J0 G2 x( j( m5 S* t6 i# E# M& G0 V% S+ M9 Q
# R& q: m: y. s4 B7 w. j9 y/ B6 w
- h8 W0 B( j8 A k |
您需要 登录 才可以下载或查看,没有账号?注册会员
